查看: 6683|回复: 6
[Win CE] 新手求助,ok6410A 256M 1G NAND Flash 上电白屏,重装Win CE报警
RK3399通行证
发表于 2015-1-2 09:24:05 | 显示全部楼层 |阅读模式
ok6410刚刚拿到手,按照说明书上开始上电,正常进入Win CE系统后,大概一分钟左右,LCD开始闪烁,然后白屏,搜索论坛,试着重装Win CE,结果出现报警,DNW输出如下:
Welcome! This tool just for TE/OK6410
+OALArgsInit()
SocID:0x36410101
Arguments area is initialized
-OALArgsInit()
INFO: (unsigned)C_IsrHandler : 0x8008095C
INFO: (unsigned)ASM_IsrHandler : 0x80084018
INFO: (unsigned)pISR : 0xEA020FFE
HSMMC init
[HSMMC1] Setting registers for the EPLL (for SDCLK) : SYSCon.
[HSMMC0] Setting registers for the GPIO.
[HSMMC1] Setting registers for the EPLL : HSMMCCon.
#### this SD card is made on SPEC 2.0
This SD card is made on SPEC 2.0
This SD card is High Capacity
CardSize: 15523840 sector
[HSMMCLIB:INF] ClockConfig() Card Working Frequency = 24MHz
BP_Init
[FMD] ++FMD_Init() ****
[FMD:INF] FMD_Init() : Read ID = 0x00002c38
[FMD] FMD_Init() : NUM_OF_BLOCKS = 1024
[FMD] FMD_Init() : SECTORS_PER_PAGE = 8
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 1024(0x400), SECTORSPERBLOCK = 128(0x80), BYTESPERSECTOR = 4096(0x1000)
wNUM_BLOCKS : 1024(0x400)
TOC_Read ERROR: INVALID_TOC Signature: 0xFFFFFFFF
TOC_Init: dwEntry:1, dwImageType: 0x2, dwImageStart: 0x0, dwImageLength: 0x0, dwLaunchAddr: 0x0
+BootConfigInit
-BootConfigInit
TOC {
dwSignature: 0x434F544E
BootCfg {
  ConfigFlags: 0x10020
  BootDelay: 0x2
  ImageIndex: 1
  IP: 0.0.0.0
  MAC Address: 00:00:00:00:00:00
  Port: 0.0.0.0
  SubnetMask: 255.255.255.0
ID[0] {
  dwVersion: 0x20004
  dwSignature: 0x45424F54
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x80
  dwLoadAddress: 0x80030000
  dwJumpAddress: 0x80030000
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x100
  sgList[0].dwLength: 0x80
ID[1] {
  dwVersion: 0x1
  dwSignature: 0x43465348
  String: ''
  dwImageType: 0x2
  dwTtlSectors: 0x0
  dwLoadAddress: 0x0
  dwJumpAddress: 0x0
  dwStoreOffset: 0x0
chainInfo.dwLoadAddress: 0X00000000
chainInfo.dwFlashAddress: 0X00000000
chainInfo.dwLength: 0X00000000
[Eboot] ++InitializeDisplay()
[Eboot] --InitializeDisplay()
Press [ENTER] to download image stored on boot media, or [SPACE] to enter boot monitor.
Initiating image download in 0 seconds.
Starting auto-download ...
Erase  the block '0..3'
System ready!
Preparing for download...
IsCardInserted
f_mount return = 0x0
FileInfo.fsize = 0x2000
g_pDownPt = 0xA300211B
BL_IMAGE_TYPE_MANIFEST
BL_IMAGE_TYPE_UNKNOWN
Download BIN file information:
[0]: Base Address=0x0  Length=0x2000
Stepldr image
ImageStart = 0x0, ImageLength = 0x2000, LaunchAddr = 0x0
Completed file(s):
[0]: Address=0x0  Length=0x2000  Name="stepldr.nb0" Target=RAM
BP_Init  iSighForSlcMlc = 1
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 8192(0x2000), SECTORSPERBLOCK = 8(0x8), BYTESPERSECTOR = 2048(0x800)
dwImageLength = 0x2000
dwNumBlocks = 0x1
dwBlock(0x0) X g_FlashInfo.wSectorsPerBlock(0x8) = 0x0
dwBytesPerBlock : 16384
INFO: Step loader image stored to Smart Media.  Please Reboot.  Halting...
IsCardInserted
FileInfo.fsize = 0x5CB5B
g_pDownPt = 0xA305CB5B
BL_IMAGE_TYPE_BIN
[0]: Base Address=0x80030000  Length=0x5efe0
Eboot image
rom_offset=0x0.
ImageStart = 0x80030000, ImageLength = 0x5EFE0, LaunchAddr = 0x80081BC4
Completed file(s):
[0]: Address=0x80030000  Length=0x5EFE0  Name="" Target=RAM
ROMHDR at Address 80030044h
BP_Init  iSighForSlcMlc = 0
[FMD] --FMD_Init()
dwImageLength = 0x5efe0
dwNumBlocks = 0x1
dwBlock(0x2) X g_FlashInfo.wSectorsPerBlock(0x80) = 0x100
dwBytesPerBlock : 524288
TOC {
BootCfg {
  ConfigFlags: 0x20830
  BootDelay: 0x2
  ImageIndex: 1
  IP: 0.0.0.0
  Port: 0.0.0.0
ID[0] {
  dwVersion: 0x20004
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x5F
  dwJumpAddress: 0x80081BC4
  dwStoreOffset: 0x0
  sgList[0].dwLength: 0x5F
ID[1] {
  dwVersion: 0x1
  String: ''
  dwImageType: 0x2
  dwTtlSectors: 0x0
  dwLoadAddress: 0x0
  dwJumpAddress: 0x0
  dwStoreOffset: 0x0
INFO: Eboot image stored to Smart Media.  Please Reboot.  Halting...
Reserving Blocks [0x0 - 0x2] ...
...reserve complete.
Enter LowLevelFormat [0x3, 0x3ff].
WriteMBR: MBR block = 0x3.
Done.
BinFS format done.
IsCardInserted
FileInfo.fsize = 0x235E653
g_pDownPt = 0xA535E653
BL_IMAGE_TYPE_BIN
[0]: Base Address=0x80150000  Length=0x23f8b98
RAM image
rom_offset=0x0.
ImageStart = 0x80150000, ImageLength = 0x23F8B98, LaunchAddr = 0x8015768C
Completed file(s):
[0]: Address=0x80150000  Length=0x23F8B98  Name="" Target=RAM
ROMHDR at Address 80150044h
+WriteOSImageToBootMedia: g_dwTocEntry =1, ImageStart: 0x80150000, ImageLength: 0x23f8b98, LaunchAddr:0x8015768c
INFO: OEMLaunch: Found chain extenstion: '' @ 0x80150000
Writing single region/multi-region update, dwBINFSPartLength: 37718936
IsValidMBR: block = 0x0.
IsValidMBR: block = 0x1.
IsValidMBR: block = 0x2.
IsValidMBR: MBR sector = 0x180 (valid MBR)
OpenPartition: Partition Exists=0x0 for part 0x21.
CreatePartition: Enter CreatePartition for 0x21.
LastLogSector: Last log sector is: 0x1fdff.
CreatePartition: Start = 0x200, Num = 0x2400.
Log2Phys: Logical 0x200 -> Physical 0x380
BP_SetDataPointer at 0x0
Write OS to Nand Flash finished!!!
Updated TOC!
OpenPartition: Partition Exists=0x0 for part 0xb.
CreatePartition: Enter CreatePartition for 0xb.
FindFreeSector: FreeSector is: 0x2600 after processing part 0x21.
CreatePartition: Num sectors set to 0x1d700 to allow for compaction blocks.
CreatePartition: Start = 0x2600, Num = 0x1d700.
TOC {
BootCfg {
  BootDelay: 0x2
  ImageIndex: 1
  IP: 0.0.0.0
  Port: 0.0.0.0
ID[0] {
  dwVersion: 0x20004
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x5F
  dwStoreOffset: 0x0
ID[1] {
  dwVersion: 0x1
  String: ''
  dwImageType: 0x2
  dwTtlSectors: 0x23F9
  dwLoadAddress: 0x80150000
  dwJumpAddress: 0x8015768C
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x380
  sgList[0].dwLength: 0x23F9
waitforconnect
INFO: using TOC[1] dwJumpAddress: 0x8015768c
Success!
SpinForever...
发表于 2015-1-4 08:45:35 | 显示全部楼层
楼主,从打印信息看应该没问题,另外烧写wince后确实是蜂鸣器长鸣,这是正常的,从nandflash启动才会进入wince系统的,请详细阅读wince使用手册、、、、、:lol:lol:lol
RK3399通行证
 楼主| 发表于 2015-1-4 09:12:33 | 显示全部楼层
独家记忆 发表于 2015-1-4 08:45
楼主,从打印信息看应该没问题,另外烧写wince后确实是蜂鸣器长鸣,这是正常的,从nandflash启动才会进入wi ...
我有从nandflsh进入Win,但是在设置LCD分辨率这边卡住了,我设置好了,然后按下W保存,也保存成功了,我就按下S1重启,然后不对LCD进行设置,一直到最后输出好像正常,但是LCD还是白屏,请帮忙看下
WinCE 6.0 Steploader for SMDK6410
Launch Eboot...
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Apr 19 2012 08:52:01
Microsoft Windows CE Bootloader for the Samsung SMDK6410 Version 2.4 Built Apr 28 2013
[FMD] FMD_Init() : NUM_OF_BLOCKS = 2048
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 2048(0x800), SECTORSPERBLOCK = 128(0x80), BYTESPERSECTOR = 4096(0x1000)
Initiating image launch in 2 seconds.
Ethernet Boot Loader Configuration:
0) IP address: 0.0.0.0
1) Subnet mask: 255.255.255.0
2) DHCP: Disabled
3) Boot delay: 2 seconds
7) Program DM9000A MAC address (00:00:00:00:00:00)
8) KITL Configuration: DISABLED
A) Erase All Blocks
B) Mark Bad Block at Reserved Block
C) Clean Boot Option: FALSE
D) Download image now
E) Erase Reserved Block
R) Read Configuration
S) Lcd Resolution select(480x272)
U) DOWNLOAD image now(USB)
Enter your selection: s
0)3.5'LCD        320X240
1)4.3'LCD        480X272
2)5.6'LCD        640X480
3)7.0'LCD        800X480
4)8.0' & VGA        800X600
5)HDMI                1024X768
Select Lcd Resolution [0-5]: 1
2) DHCP: Disabled
A) Erase All Blocks
Enter your selection: w
Successfully Written
2) DHCP: Disabled
A) Erase All Blocks
Launch Eboot...
[FMD] --FMD_Init()
Initiating image launch in 0 seconds.
Launching image from boot media ...
OEMPlatformInit: IMAGE_TYPE_RAMIMAGE
Loading Kernel......
System ready!
INFO: *** Device Name 'SMDK64100' ***
INFO: Using static IP address 0000.
INFO: Using subnet mask 2525250.
waitforconnect
INFO: OEMLaunch: Jumping to Physical Address 0x5015768Ch (Virtual Address 0x8015768Ch)...
Windows CE Kernel for ARM (Thumb Enabled) Built on Sep 25 2009 at 11:04:23
[OAL] ++OEMInit()
[OAL] S3C6410_APLL_CLK   : 532000000
[OAL] ARMCLK : 532000000
[OAL] HCLK   : 133000000
[OAL] PCLK   : 66500000
[OAL] InitializeGPIO()
[OAL] InitializeCLKSource()
[OAL] InitializeCLKGating()
[OAL] InitializeBlockPower()
DCache: 128 sets, 4 ways, 32 line size, 16384 size
ICache: 128 sets, 4 ways, 32 line size, 16384 size
Arguments area has some values
+OALTimerInit( 1, 33249, 0 )
-OALIntrRequestSysIntr(irq = 38, sysIntr = 16)
[OAL] --OEMInit()
[FMD] --FMD_Init()
[FMD] FMD_OEMIoControl() : IOCTL_FMD_GET_INTE**CE
[FMD:ERR] FMD_OEMIoControl() : Unknown IOCTL (0x00071c24)
[OAL] Not Clear System Hive
[OAL] Not Clear User Hive
[PWRCON]  PWC_Init***
-OALIntrRequestSysIntr(irq = 11, sysIntr = 18)
-OALIntrRequestSysIntr(irq = 9, sysIntr = 19)
-OALIntrRequestSysIntr(irq = 40, sysIntr = 20)
-OALIntrRequestSysIntr(irq = 19, sysIntr = 21)
-OALIntrRequestSysIntr(irq = 23, sysIntr = 22)
-OALIntrRequestSysIntr(irq = 20, sysIntr = 23)
-OALIntrRequestSysIntr(irq = 88, sysIntr = 24)
-OALIntrRequestSysIntr(irq = 73, sysIntr = 25)
-OALIntrRequestSysIntr(irq = 74, sysIntr = 26)
[HSMMC0] Initializing the HSMMC Host Controller
-OALIntrRequestSysIntr(irq = 94, sysIntr = 27)
[HSMMC1] Initializing the HSMMC Host Controller
-OALIntrRequestSysIntr(irq = 7, sysIntr = 28)
-OALIntrRequestSysIntr(irq = 95, sysIntr = 29)
[HSMMC0] Card is Inserted!
[HSMMC1] Turn OFF the F/B delay control.
[HSMMC1] Card is Inserted!
WARN: OALIoCtlHalGetHWEntropy: Buffer too small
[HSMMC0] Setting for 1 bit mode , Clock Rate = 100000 Hz
ERR CMD:5 : ERR CMD:1 : [HSMMC1] Turn OFF the F/B delay control.
[HSMMC1] Setting for 1 bit mode , Clock Rate = 100000 Hz
ERR CMD:5 : ERR CMD:8 : ERR CMD:1 : ERR CMD:55 : [HSMMC1] CMD Timeout Error...
<DM9:++MiniportIntialize>
[dm9: The mapped address is D2DA0000]
[dm9: Chip signature is 0A469000]
<DM9:--MiniportIntialize>
[USB] dii.dwIrq = 96
-OALIntrRequestSysIntr(irq = 96, sysIntr = 30)
[SDBUS] SD Card Spec Version : 2.00
[SDBUS] SD/SDHC supports the high-speed mode.
[HSMMC0] Setting for 4 bit mode , Clock Rate = 50000000 Hz
Current Client "Serial_Class"
DEBUG: CreateSerialObject 3
-OALIntrRequestSysIntr(irq = 64, sysIntr = 31)
DEBUG: CreateSerialObject 2
-OALIntrRequestSysIntr(irq = 63, sysIntr = 32)
DEBUG: CreateSerialObject 1
-OALIntrRequestSysIntr(irq = 62, sysIntr = 33)
[USBH] HcdPdd_Init()
[USBH] ++InitializeOHCI()
[USBH] --InitializeOHCI() : Success
-OALIntrRequestSysIntr(irq = 13, sysIntr = 34)
-OALIntrRequestSysIntr(irq = 14, sysIntr = 36)
[MFC POWER] Power is up.
[MFC POWER] Power is down-OALIntrRequestSysIntr(irq = 26, sysIntr = 37)
MFC Interrupt has been initialized.
[MFC IOCTL_POWER_CAPABILITIES]
[MFC IOCTL_POWER_CAPABILITIES] leaving...
LED - DLL_PROCESS_ATTACH
ADC - DLL_PROCESS_ATTACH
BEE - DLL_PROCESS_ATTACH
TEM - DLL_PROCESS_ATTACH
-OALIntrRequestSysIntr(irq = 18, sysIntr = 38)
[DISPDRV] S3C6410Disp:Close FLprogressbar thread
[DISPDRV] S3C6410Disp::S3C6410Disp()
-OALIntrRequestSysIntr(irq = 21, sysIntr = 39)
2D Sysintr : 39
[DISPDRV:] S3C6410Disp() : m_pDispConReg->VIDTCON2 = 879df
[OAL] LcdWidth(480)  LcdHeight(272)
ChangeDisplaySetting>** changed rotation angle to 0
++[KEYBD]KeybdDriverInitializeAddresses
++[KEYBD]KeyMatrix::KeybdPowerOn
+Select all column
--[KEYBD]KeyMatrix::KeybdPowerOn
+[KEYBD]IsrThreadStart:
-[KEYBD]IsrThreadStart:
LayMgr.cpp: Layout Manager successfully initialized to  2
-OALIntrRequestSysIntr(irq = 100, sysIntr = 40)
-OALIntrRequestSysIntr(irq = 37, sysIntr = 41)
TIME=[a25a7]
+[KEYBD]IsrThreadProc
-OALIntrRequestSysIntr(irq = 32, sysIntr = 42)
+[KEYBD]Enter Infinite Loop
MSIM: IM_ReadRegistry read KB 5
Explorer(V2.0) taskbar thread started.
NDISPWR:: Found adapter [DM9CE1]
您的打印信息看着是没有问题的,可以考虑烧写Linux试试,看看是不是屏幕问题、、、、  详情 回复 发表于 2015-1-5 08:55
发表于 2015-1-5 08:55:24 | 显示全部楼层
hu000jun 发表于 2015-1-4 09:12
我有从nandflsh进入Win,但是在设置LCD分辨率这边卡住了,我设置好了,然后按下W保存,也保存成功了,我就 ...
您的打印信息看着是没有问题的,可以考虑烧写Linux试试,看看是不是屏幕问题、、、、:lol:lol:lol
RK3399通行证
 楼主| 发表于 2015-1-5 13:37:40 | 显示全部楼层
已经联系电话技术支持了,可能LCD有问题,需要返修,多谢啦!
楼主客气了、、、  详情 回复 发表于 2015-1-6 08:50
发表于 2015-1-6 08:50:21 | 显示全部楼层
楼主客气了、、、:lol:lol:lol
GMT+8, 2026-10-4 16:12
