查看: 2688|回复: 2
usb 烧写 Linux version 2.6.28后启动不成功
发表于 2011-5-26 17:12:53 | 显示全部楼层 |阅读模式
Unable to mount root fs on unknown-block(31,2)
6410的板子启动信息里怎么还有写2410  2440的内容???
启动信息::
Err:     serial
NAND read: device 0 offset 0x100000, size 0x300000
3145728 bytes read: OK
Boot with zImage
Starting kernel ...
Uncompressing Linux............................................................................................................................................................... done, booting the kernel.
Linux version 2.6.28.6 (root@jkeqiang-desktop) (gcc version 4.2.2) #235 Wed Jan 19 17:43:31 CST 2011
CPU: ARMv6-compatible processor [410fb766] revision 6 (ARMv7), cr=00c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: SMDK6410
CPU S3C6410 (id 0x36410101)
S3C24XX Clocks, (c) 2004 Simtec Electronics
S3C64XX: HCLKx2=266000000, HCLK=133000000, PCLK=66500000
div1: 00000555
mout_epll: source is fout_epll (1), rate is 24000000
mmc_bus: source is dout_mpll (1), rate is 44333333
usb-host-bus: source is mout_epll (0), rate is 24000000
audio-bus0: source is mout_epll (0), rate is 24000000
audio-bus1: source is mout_epll (0), rate is 24000000
audio-bus2: source is mout_epll (0), rate is 24000000
s3c64xx: 15728640 bytes SDRAM reserved for fimc at 0x5073b000
s3c64xx: 8388608 bytes SDRAM reserved for pp at 0x5163b000
s3c64xx: 8388608 bytes SDRAM reserved for tv at 0x51e3b000
s3c64xx: 6291456 bytes SDRAM reserved for mfc at 0x5263b000
s3c64xx: 8388608 bytes SDRAM reserved for jpeg at 0x52c3b000
s3c64xx: 8388608 bytes SDRAM reserved for cmm at 0x5343b000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: root=/dev/mtdblock2 rootfstype=cramfs console=ttySAC0,115200
PID hash table entries: 1024 (order: 10, 4096 bytes)
s3c24xx_serial_init_ports: initialising ports=4...
console [ttySAC0] enabled
Memory: 256MB = 256MB total
Memory: 200064KB available (4600K code, 527K data, 148K init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 530.84 BogoMIPS (lpj=1327104)
net_namespace: 316 bytes
S3C6410: Initialising architecture
S3C DMA-pl080 Controller Driver, (c) 2006-2007 Samsung Electronics
Total 32 DMA channels will be initialized.
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
cfg80211: Using static regulatory domain info
cfg80211: Regulatory domain: US
        (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
        (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
        (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
cfg80211: Calling CRDA for country: US
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
yaffs Jan 19 2011 17:35:30 Installing.
msgmni has been set to 391
io scheduler noop registered
io scheduler anticipatory registered
S3C_LCD clock got enabled :: 133.000 Mhz
LCD TYPE :: L70T84 will be initialized
S3C G2D Init : Done
S3C G3D Driver, (c) 2007-2009 Samsung Electronics
s3c_g3d version : 0x1050000
S3C G3D Init : Done
S3C CMM Driver, (c) 2008 Samsung Electronics
Driver 'sd' needs updating - please use bus_type methods
S3C NAND Driver, (c) 2008 Samsung Electronics
select s3c_nand_oob_mlc_128
S3C NAND Driver is using hardware ECC.
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd5 (Samsung NAND 2GiB 3,3V 8-bit)
Creating 4 MTD partitions on "NAND 2GiB 3,3V 8-bit":
0x00000000-0x00040000 : "Bootloader"
0x00040000-0x00400000 : "Kernel"
0x00400000-0x05400000 : "Rootfs"
0x05400000-0x80000000 : "File System"
Samsung SoC SPI Driver loaded for SPI-0
        Max,Min-Speed [33250000, 129882]Hz
        Irq=80        IOmem=[0x7f00bfff-0x7f00b000]        DMA=[Rx-33, Tx-34]
Samsung SoC SPI Driver loaded for SPI-1
        Irq=81        IOmem=[0x7f00cfff-0x7f00c000]        DMA=[Rx-35, Tx-36]
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new interface driver usb-storage
s3c-udc : S3C HS USB OTG Device Driver, (c) 2008-2009 Samsung Electronics
s3c-udc : version 15 March 2009 (DMA Mode)
mice: PS/2 mouse device common for all mice
gpio keys driver.
input: gpio-keys as /class/input/input0
S3C Touchscreen driver, (c) 2008 Samsung Electronics
S3C TouchScreen got loaded successfully : 12 bits
input: S3C TouchScreen as /class/input/input1
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410_rtc: tick irq 34, alarm irq 92
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 377 KHz
[OV965X]ov965x_attach_adapter.
[CAM]s3c_fimc_register_camera,cam->id=0
parent clock for camera: 266.000 MHz, divisor: 11
[CAM]RESET CAM.[CAM]Reset and init reg!1cam->client=0
[CAM]Reset and init reg!3
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
sdhci: Secure Digital Host Controller Interface driver
s3c-sdhci s3c-sdhci.0: clock source 2: mmc_bus (44333333 Hz)
sdhci: card inserted.
s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (44333333 Hz)
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.18rc3.
ASoC version 0.13.2
WM9713/WM9714 SoC Audio Codec 0.15
playback: 1, capture : 1
asoc: AC97 HiFi <-> s3c64xx-ac97 mapping ok
mmc0: new high speed SDHC card at address e9eb
mmcblk0: mmc0:e9eb SD04G 3.69 GiB
mmcblk0: p1
[WM9713]Open speaker volume.
ALSA device list:
  #0: SMDK6400 (WM9713)
TCP cubic registered
can: controller area network core (rev 20081130 abi 8)
can: raw protocol (rev 20081130)
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
s3c2410-rtc s3c2410-rtc: hctosys: invalid date/time
mtd->size = 5000000 blocks = a0
cheaking bad block...............
................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................List of all partitions:
1f00             256 mtdblock0 (driver?)
1f01            3840 mtdblock1 (driver?)
1f02           81920 mtdblock2 (driver?)
1f03         2011136 mtdblock3 (driver?)
b300         3870720 mmcblk0 driver: mmcblk
  b301         3866624 mmcblk0p1
No filesystem could mount root, tried:  cramfs
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,2)
 楼主| 发表于 2011-5-26 17:18:12 | 显示全部楼层
配置256 ram 2g nand  按手册的步骤烧写。  mmc。bin是从坛子连接下载的。光盘离得mmc。bin运行不成功,其他映像都是光盘里的
发表于 2011-5-27 08:19:11 | 显示全部楼层
那就贴下烧写过程
建议用一键烧写,减少操作环节。
GMT+8, 2026-10-5 21:03
