查看: 5674|回复: 1
6410 串口,没字节最高位自动给过滤了
发表于 2015-2-27 17:49:24 | 显示全部楼层 |阅读模式
[code]
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <termios.h>
#include <errno.h>
main()
int fd;
int i;
int len;
int n = 0;
int m=0;
unsigned char read_buf[256];
unsigned char write_buf[256];
struct termios opt;
write_buf[0]=0xFF;
fd = open("/dev/ttySAC2", O_RDWR | O_NOCTTY); //默认为阻塞读方式
if(fd == -1)
perror("open serial 0\n");
exit(0);
tcgetattr(fd, &opt);
cfsetispeed(&opt, B9600);
cfsetospeed(&opt, B9600);
if(tcsetattr(fd, TCSANOW, &opt) != 0 )
perror("tcsetattr error");
return -1;
opt.c_cflag &= ~CSIZE;
opt.c_cflag |= CS8;
opt.c_cflag &= ~CSTOPB;
opt.c_cflag &= ~PARENB;
//opt.c_cflag &= ~INPCK;
opt.c_cflag |= (CLOCAL | CREAD);
opt.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG);
opt.c_oflag &= ~OPOST;
opt.c_oflag &= ~(ONLCR | OCRNL); //添加的
//ISTRIP
 楼主| 发表于 2015-2-27 17:50:28 | 显示全部楼层
  1. #include <stdio.h>
  2. #include <stdlib.h>
  3. #include <unistd.h>
  4. #include <sys/types.h>
  5. #include <sys/stat.h>
  6. #include <fcntl.h>
  7. #include <termios.h>
  8. #include <errno.h>
  9. main()
  10. {
  11. int fd;
  12. int i;
  13. int len;
  14. int n = 0;
  15. int m=0;
  16. unsigned char read_buf[256];
  17. unsigned char write_buf[256];
  18. struct termios opt;
  19. write_buf[0]=0xFF;
  20. fd = open("/dev/ttySAC2", O_RDWR | O_NOCTTY); //默认为阻塞读方式
  21. if(fd == -1)
  22. {
  23. perror("open serial 0\n");
  24. exit(0);
  25. }
  26. tcgetattr(fd, &opt);
  27. cfsetispeed(&opt, B9600);
  28. cfsetospeed(&opt, B9600);
  29. if(tcsetattr(fd, TCSANOW, &opt) != 0 )
  30. {
  31. perror("tcsetattr error");
  32. return -1;
  33. }
  34. opt.c_cflag &= ~CSIZE;
  35. opt.c_cflag |= CS8;
  36. opt.c_cflag &= ~CSTOPB;
  37. opt.c_cflag &= ~PARENB;
  38. //opt.c_cflag &= ~INPCK;
  39. opt.c_cflag |= (CLOCAL | CREAD);
  40. /*
  41. opt.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG);
  42. opt.c_oflag &= ~OPOST;
  43. opt.c_oflag &= ~(ONLCR | OCRNL); //添加的
  44. //ISTRIP
  45.         opt.c_iflag &= ~(ICRNL | INLCR);
  46. opt.c_iflag &= ~(IXON | IXOFF | IXANY); //添加的
  47. */
  48. opt.c_cc[VTIME] = 0;
  49. opt.c_cc[VMIN] = 0;
  50. tcflush(fd, TCIOFLUSH);
  51. printf("configure complete\n");
  52. if(tcsetattr(fd, TCSANOW, &opt) != 0)
  53. {
  54. perror("serial error");
  55. return -1;
  56. }
  57. printf("start send and receive data\n");
  58. while(1)
  59. {
  60. n = 0;
  61. len = 0;
  62. m = write(fd, write_buf, 1);
  63. printf("write %02X chars\n",write_buf[0]);
  64. while( (n = read(fd, read_buf, 1)) > 0 )
  65. {
  66.         printf("read len is %d \n ",n);
  67. for(i = len; i < (len + n); i++)
  68. {
  69. write_buf[i] = read_buf[i - len];
  70. }
  71. len += n;
  72. printf("recive char is :%02X \n", read_buf[0]);
  73. }
  74. sleep(2);
  75. }
  76. }
将串口扩展板,的串口2 的 2 和3 短接,自发自收即
  1. [root@FORLINX6410]# ./acom
  2. configure complete
  3. start send and receive data
  4. write FF chars
  5. write FF chars
  6. read len is 1
  7. recive char is :7F
  8. write 7F chars
  9. read len is 1
  10. recive char is :7F
  11. ^C
结果就是,每个字节的最高位,自动给过滤了
代码中,变量是  无符号的,,应该没啥问题了,,硬件啥有啥特别注意的?
还是其他地方有啥没注意到呢?
GMT+8, 2026-9-29 16:46
