查看: 14098|回复: 0
[Linux] 烧写Linux成功,启动花屏
发表于 2015-3-18 23:09:04 | 显示全部楼层 |阅读模式
按照用户手册一键烧写Linux,烧写成功(发出滴滴提示声),启动屏幕花屏,都是竖纹(我的是7寸屏,买来时装好的Linux系统,可以使用)
Nand flash 启动 DNW打印消息如下:
KK
U-Boot 1.1.6 (Sep 19 2014 - 10:00:03) for SMDK6410
**    Updated for OK6410  TE6410 Board  **
**    Version (2012-09-23)          **
CPU:     S3C6410 @532MHz
Board:   SMDK6410
DRAM:    256 MB
Flash:   0 kB
NAND:    1024 MB
In:      serial
Out:     serial
Err:     serial
NAND read: device 0 offset 0x500000, size 0x500000
5242880 bytes read: OK
Boot with zImage
Starting kernel ...
Linux version 3.0.1 (root@ubuntu) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #676 Fri Sep 19 10:39:58 CST 2014
Ignoring unrecognised tag 0x54410008
Kernel command line: root=/dev/mtdblock2 rootfstype=yaffs2 init=/linuxrc console=ttySAC0,115200
Memory: 196660k/196660k available, 65484k reserved, 0K highmem
Virtual kernel memory layout:
    vmalloc : 0xd0800000 - 0xf4000000   ( 568 MB)
    lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
      .init : 0xc0008000 - 0xc0036000   ( 184 kB)
      .text : 0xc0036000 - 0xc07d4434   (7802 kB)
      .data : 0xc07d6000 - 0xc082eaf0   ( 355 kB)
       .bss : 0xc082eb14 - 0xc08b1124   ( 522 kB)
SCSI subsystem initialized
------------[ cut here ]------------
WARNING: at drivers/gpio/gpiolib.c:101 gpio_ensure_requested+0x58/0x124()
---[ end trace da227214a82491b7 ]---
type=2000 audit(0.190:1): initialized
Hello, world
Creating 4 MTD partitions on "NAND 2GiB 1,8V 8-bit":
0x000000000000-0x000000200000 : "Bootloader"
0x000000500000-0x000001e00000 : "Kernel"
0x000001e00000-0x00000e600000 : "File System"
0x00000e600000-0x000040000000 : "User"
mcp2515 spi1.0: MCP251x didn't enter in conf mode after reset
mcp2515 spi1.0: probe failed
dm9000 dm9000.0: read wrong id 0x01010101
s3c_g2d_probe called
s3c_g2d_probe Success
FAT-fs (mmcblk0p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
Try to bring eth0 inte**ce up......Done
Starting Qtopia2, please waiting...
Please press Enter to activate this console. touch...
请提供技术支持,谢谢
GMT+8, 2026-10-4 12:20
