查看: 19454|回复: 5
[Linux] 内核启动异常。报错:omap_i2c omap_i2c.2: controller timed out
发表于 2015-5-9 17:59:59 | 显示全部楼层 |阅读模式
做项目,使用了ok335xd的核心板,自己花的底板,启动linux内核的时候卡住了
串口一直输出:omap_i2c omap_i2c.2: controller timed out
 楼主| 发表于 2015-5-9 18:01:04 | 显示全部楼层
[    3.070327] input: ft5x0x_ts as /devices/virtual/input/input1
[    4.230119] omap_i2c omap_i2c.2: controller timed out
[    4.235440] msg ft5x0x_read_reg i2c read error: -110
[    5.239926] omap_i2c omap_i2c.2: controller timed out
[    5.259931] msg ft5x0x_read_reg i2c read error: -110
[    6.259929] omap_i2c omap_i2c.2: controller timed out
[    6.279935] msg ft5x0x_read_reg i2c read error: -110
[    6.286096] rtc-ds1307: probe of 1-0068 failed with error -5
[    6.292078] Linux video capture inte**ce: v2.00
[    6.297210] usbcore: registered new inte**ce driver uvcvideo
[    6.303227] USB Video Class driver (1.1.1)
[    7.299932] omap_i2c omap_i2c.2: controller timed out
[    8.299930] omap_i2c omap_i2c.2: controller timed out
[    9.319924] omap_i2c omap_i2c.2: controller timed out
[   10.339925] omap_i2c omap_i2c.2: controller timed out
[   11.359924] omap_i2c omap_i2c.2: controller timed out
[   12.379922] omap_i2c omap_i2c.2: controller timed out
[   13.399924] omap_i2c omap_i2c.2: controller timed out
[   14.419924] omap_i2c omap_i2c.2: controller timed out
[   14.440790] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[   14.447121] Bluetooth: HCI UART driver ver 2.2
[   14.451788] Bluetooth: HCI H4 protocol initialized
[   14.456780] Bluetooth: HCILL protocol initialized
[   14.462598] cpuidle: using governor ladder
[   14.467018] cpuidle: using governor menu
[   14.475561] usbcore: registered new inte**ce driver usbhid
[   14.481426] usbhid: USB HID core driver
[   14.485925] logger: created 256K log 'log_main'
[   14.491081] logger: created 256K log 'log_events'
[   14.496111] logger: created 256K log 'log_radio'
[   14.501084] logger: created 256K log 'log_system'
[   14.506636] tiadc tiadc: attached adc driver
[   14.511709] usbcore: registered new inte**ce driver snd-usb-audio
[   15.509935] omap_i2c omap_i2c.2: controller timed out
[   15.515261] _regulator_get: 2-001b supply IOVDD not found, using dummy regulator
[   15.523069] _regulator_get: 2-001b supply DVDD not found, using dummy regulator
[   15.530754] _regulator_get: 2-001b supply AVDD not found, using dummy regulator
[   15.538414] _regulator_get: 2-001b supply DRVDD not found, using dummy regulator
[   15.549052] asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
[   16.549940] omap_i2c omap_i2c.2: controller timed out
[   17.549926] omap_i2c omap_i2c.2: controller timed out
[   18.569926] omap_i2c omap_i2c.2: controller timed out
[   19.589923] omap_i2c omap_i2c.2: controller timed out
[   20.609925] omap_i2c omap_i2c.2: controller timed out
[   21.629922] omap_i2c omap_i2c.2: controller timed out
[   22.649924] omap_i2c omap_i2c.2: controller timed out
[   23.669922] omap_i2c omap_i2c.2: controller timed out
[   24.689922] omap_i2c omap_i2c.2: controller timed out
[   25.709921] omap_i2c omap_i2c.2: controller timed out
[   26.729923] omap_i2c omap_i2c.2: controller timed out
[   27.749921] omap_i2c omap_i2c.2: controller timed out
[   28.769922] omap_i2c omap_i2c.2: controller timed out
[   29.789922] omap_i2c omap_i2c.2: controller timed out
[   30.809922] omap_i2c omap_i2c.2: controller timed out
[   31.829923] omap_i2c omap_i2c.2: controller timed out
发表于 2015-10-16 19:58:48 | 显示全部楼层
你可可看看你的i2c总线上拉没有,我出现过这个问题,就是两条线没有上拉
发表于 2015-12-29 08:56:25 | 显示全部楼层
楼主看下是不是原来IIC总线上的设备你给去掉了,但是驱动没有去掉啊,这个一般是做底板时去掉了音频模块,但是音频驱动没有去掉引起的
GMT+8, 2026-9-23 15:54
