查看: 13479|回复: 0
[Linux] 烧些裸机代码后led不亮
发表于 2015-9-14 23:08:59 | 显示全部楼层 |阅读模式
首先呢,我在uboot下直接加载到内存中,然后bootm0xc0008000灯是可以亮的,可是我在uboot下nand erase然后nand write到nand flash的0地址中,等就不亮了。。代码和编译后的汇编如下所示,请大牛帮助分析下下,谢谢
led_on.elf:     file format elf32-littlearm
Disassembly of section .text:
00000000 <_start>:
   0:   e59f0014    ldr r0, [pc, #20]   ; 1c <MAIN_LOOP+0x4>
   4:   e3a01001    mov r1, #1  ; 0x1
   8:   e5801000    str r1, [r0]
   c:   e59f000c    ldr r0, [pc, #12]   ; 20 <MAIN_LOOP+0x8>
  10:   e3a01000    mov r1, #0  ; 0x0
  14:   e5801000    str r1, [r0]
00000018 <MAIN_LOOP>:
  18:   eafffff8    b   0 <_start>
  1c:   7f008820    .word   0x7f008820
  20:   7f008824    .word   0x7f008824
Disassembly of section .ARM.attributes:
00000000 <.ARM.attributes>:
   0:   00001741    andeq   r1, r0, r1, asr #14
   4:   61656100    cmnvs   r5, r0, lsl #2
   8:   01006962    tsteq   r0, r2, ror #18
   c:   0000000d    andeq   r0, r0, sp
  10:   00543405    subseq  r3, r4, r5, lsl #8
  14:   01080206    tsteq   r8, r6, lsl #4
.text
.global _start
_start:
//设置GPMCON
    ldr     r0, =0x7F008820
    mov     r1, # 0x00000001
    str     r1, [r0]
//设置GPMDAT
    ldr     r0, =0x7F008824
    mov     r1,# 0x0
    str     r1, [r0]
MAIN_LOOP:
    B       _start
GMT+8, 2026-10-4 18:10
