查看: 19592|回复: 0
[Linux] SD卡一键烧写No NAND device found!!!
发表于 2015-10-14 21:29:54 | 显示全部楼层 |阅读模式
我自己参照OK335x做了一个底板,做了两个板子用于调试,在做SD卡一键烧写系统时,一个板子正常烧写,正常启动内核,另外一块板子,烧写过程中始终碰到No NAND device found!!!,很是困惑。命令行烧写可以进入内核但会卡住,有版友碰到类似问题,提到run update_nand,我试过了,也任然是no devices available。
下面贴出启动的代码,希望有碰到这个问题的人给予解答
U-Boot SPL 2011.09 (Dec 06 2014 - 04:31:13)
Booting from MMC...
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2011.09 (Dec 06 2014 - 04:31:13)
I2C:   ready
DRAM:  512 MiB
WARNING: Caches not enabled
Did not find a recognized configuration, assuming General purpose EVM in Profile 0 with Daughter board
NAND:  HW ECC BCH16 Selected
nand_get_flash_type: unknown NAND device: Manufacturer ID: 0x24, Chip ID: 0x24
0 MiB
MMC:   OMAP SD/MMC: 0
*** Warning - readenv() failed, using default environment
391736 bytes read
---------------Begin update system to Nand---------------
reading MLO
100% complete
40431 bytes read
reading u-boot.img
100% complete
273752 bytes read
reading uImage
100% complete
3386312 bytes read
reading ubi.img
100% complete
48496640 bytes read
100% complete
391736 bytes read
--------------Update system to Nand success--------------
GMT+8, 2026-9-23 12:38
