查看: 12459|回复: 0
[Android] 烧写android或linux不能成功
发表于 2015-11-18 13:33:46 | 显示全部楼层 |阅读模式
出厂安装的是wince系统,现在想换成android系统。完全按照手册操作,但是不能成功,仍旧进入到wince系统。然后尝试烧写linux同样不行。请问是什么原因呢?
超级终端中的提示如下:
INFO: Boot configuration found. Boot config Version 3, Signature 1111705159
FMD_Init().
Incorrect ECC type setting
FMD_Init().
>>> Forcing cold boot (non-persistent registry and other data will be wiped) <<<
e139cd20 3be8 -> 20 cd 39 e1 e8 3b
e139cd20 3de8 -> 20 cd 39 e1 e8 3d
Hit space to enter configuration menu [55] 2...
Hit space to enter configuration menu [1055] 1...
OMAP_LCD_800W_480H.
OMAP_LCD_800W_480H.
Read Splashcreen image to flash memory
FMD_Init().
OALFlashStoreOpen: 2048 blocks, 64 sectors/block
OALFlashStoreOpen: 2048 bytes/sector, 18 reserved blocks
Splashcreen image read
g_eboot.bootDeviceType 3
Load NK image from flash memory
FMD_Init().
GMT+8, 2026-9-23 15:55
