查看: 16743|回复: 0
[Linux] ok335xS-II 3g不能上网
发表于 2016-2-25 11:19:07 | 显示全部楼层 |阅读模式
root@ok335x:~# 3g_test start_ums 3812
ZET-MF190
HW-E1750
HW-E261
ZET-AC582
ZET-AC2787
ZET-A356
FL-AD3812
root@ok335x:~#
root@ok335x:~#
root@ok335x:~# 3g_test FL-AD3812
start_ums or start_ppp or stop_ppp
root@ok335x:~# 3g_test start_ums FL-AD3812
wcdma-AD3812
pppd call wcdma-AD3812
Starting usb_modeswitch ...
No default vendor/product ID given. Aborting.
/forlinx/bin/3g_test: line 62: 1: command not found
SUCCESS:  starting usb_modeswitch.
start_usb_modeswitch
root@ok335x:~# lsusb
lsusb: cannot open "/usr/share/usb.ids", No such file or directory
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 002: ID 19d2:ffeb
Bus 002 Device 001: ID 1d6b:0002
root@ok335x:~# ifconfig
eth0      Link encap:Ethernet  HWaddr 68:C9:0B:E7:BC:00
          inet addr:192.168.0.232  Bcast:192.168.0.255  Mask:255.255.255.0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          collisions:0 txqueuelen:1000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:131 errors:0 dropped:0 overruns:0 frame:0
          TX packets:131 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:313127 (305.7 KiB)  TX bytes:313127 (305.7 KiB)
GMT+8, 2026-9-23 15:54
