查看: 6191|回复: 3
OK210 OV3640 运行demo,cam_test_forlinx显示照片很模糊,什么原因啊
发表于 2016-3-10 12:22:39 | 显示全部楼层 |阅读模式
 楼主| 发表于 2016-3-10 12:30:36 | 显示全部楼层
[root@FORLINX210]# /etc/init.d/rcS
mount: mounting none on /proc failed: Device or resource busy
mount: mounting none on /sys failed: Device or resource busy
mount: mounting none on /proc/bus/usb failed: Device or resource busy
[ 1525.544883] smdkc110-rtc smdkc110-rtc: rtc disabled, re-enabling
hwclock: settimeofday() failed: Invalid argument
No state is present for card smdk
Unknown hardware: "WM8960" "" "" "" ""
Hardware is initialized using a guess method
numid=31,iface=MIXER,name='Left ADC Volume ok210'
  ; type=INTEGER,access=rw------,values=1,min=0,max=255,step=0
  : values=255
numid=32,iface=MIXER,name='Right ADC Volume ok210'
  : values=255
[ 1525.700189] eth0: link down
[ 1525.701751] ADDRCONF(NETDEV_UP): eth0: link is not ready
Starting Qtopia2, please waiting...
[root@FORLINX210]# capacitor panel touch...
 楼主| 发表于 2016-3-10 13:22:08 | 显示全部楼层
[root@FORLINX210]# cam_test_forlinx
800x480 bpp:16 mmaped 0x40163000
[   26.459770] OV3640 0-003c: ov3640 has been probed
[   26.463035] OV3640 0-003c: fetching platform data
[   26.467684] OV3640 0-003c: parallel mode
[   26.475013] s3c-fimc-0 : fimc_cropcap_capture: No capture device.
[   26.481163] OV3640 0-003c: ov3640_init: camera initialization start
发表于 2016-4-16 16:49:26 | 显示全部楼层
我运行板子里面本来就有的cam_test_forlinx图片很清晰的,但是我编译飞凌给的资料的里面的程序再去运行,就很模糊。。。不知道楼主是不是也是这种情况啊?解决没
GMT+8, 2026-10-4 13:23
