查看: 30920|回复: 1
[Android] imx6q在Android下调试4G模块
发表于 2016-10-13 17:00:30 | 显示全部楼层 |阅读模式
Android版本4.4,板子是飞凌的imx6q(201505),4G模块为移远EC20,现在情况是基带版本出来了,能收到4G信号,也能上网了,但是没有电话跟短信的功能,有大神遇到过这种情况吗?出现这样的现象是系统没编译出功能呢?还是因为4G模块某个功能没调通而没出来功能?求Android大神解答
发表于 2016-10-14 10:54:47 | 显示全部楼层
您好,我们的板子上4G那没有引出那个音频设置来,所以电话打不来的,不过短信是可以用的,只需按照以下方法设置一下即可。From cd66b78cfd40bf9739a29bf3a970ba73ef789d83 Mon Sep 17 00:00:00 2001
Date: Fri, 8 Jul 2016 10:56:58 +0800
Subject: [PATCH 08/12] sport sms voice
.../frameworks/base/core/res/res/values/config.xml |    2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/device/fsl/sabresd_6dq/overlay/frameworks/base/core/res/res/values/config.xml b/device/fsl/sabresd_6dq/overlay/frameworks/base/core/res/res/values/config.xml
index 17a281f..1dd535f 100755
--- a/device/fsl/sabresd_6dq/overlay/frameworks/base/core/res/res/values/config.xml
+++ b/device/fsl/sabresd_6dq/overlay/frameworks/base/core/res/res/values/config.xml
@@ -184,7 +184,7 @@
     <integer name="config_undockedHdmiRotation">0</integer>
     <!-- This device is not "voice capable"; it's data-only. -->
-    <bool name="config_voice_capable">false</bool>
+    <bool name="config_voice_capable">true</bool>
     <!-- Max space (in MB) allocated to DownloadManager to store the downloaded files
          if they are to be stored in DownloadManager's data dir,
diff --git a/frameworks/base/core/res/res/values/config.xml b/frameworks/base/core/res/res/values/config.xml
index 965bc58..bd179e1 100755
--- a/frameworks/base/core/res/res/values/config.xml
+++ b/frameworks/base/core/res/res/values/config.xml
@@ -954,7 +954,7 @@
     <!-- If this value is true, Sms encoded as octet is decoded by utf8 decoder.
          If false, decoded by Latin decoder. -->
-    <bool name="config_sms_utf8_support">false</bool>
+    <bool name="config_sms_utf8_support">true</bool>
     <!-- If this value is true, The mms content-disposition field is supported correctly.
          If false, Content-disposition fragments are ignored -->
1.7.9.5
GMT+8, 2026-10-4 13:18
