查看: 14225|回复: 8
内核编译出错
发表于 2016-12-14 16:40:29 | 显示全部楼层 |阅读模式
编译linux-2.6.28.7内核,报错误:
我编译<stdin>:1097:2:&#160;warning:&#160;#warning&#160;syscall&#160;fadvise64&#160;not&#160;implemented
<stdin>:1265:2:&#160;warning:&#160;#warning&#160;syscall&#160;migrate_pages&#160;not&#160;implemented
<stdin>:1321:2:&#160;warning:&#160;#warning&#160;syscall&#160;pselect6&#160;not&#160;implemented
<stdin>:1325:2:&#160;warning:&#160;#warning&#160;syscall&#160;ppoll&#160;not&#160;implemented
<stdin>:1365:2:&#160;warning:&#160;#warning&#160;syscall&#160;epoll_pwait&#160;not&#160;implemented
make[1]:***[vmlinux.o] error 1
make:***[vmlinux.o] error 2
发表于 2016-12-14 17:24:51 | 显示全部楼层
    请问您的开发环境是什么配置,跟我们标准环境一致吗
    您的报错网上有相关的解决方法,您参考一下
http://www.linuxidc.com/Linux/2012-02/53883.htm
你好,帮我看下问题吧谢谢。  详情 回复 发表于 2016-12-15 09:57
 楼主| 发表于 2016-12-15 00:07:47 | 显示全部楼层
你好,我的环境是ubuntu1404,linux-2.6.28.7和交叉编译链3.4.1全部拷的附带光盘中文件,怎么解决,谢谢。
 楼主| 发表于 2016-12-15 00:18:27 | 显示全部楼层
编译后的完整信息如下,谢谢,请给解决下,谢谢。
yan934@yan934:~/user/src/linux-2.6.28.7$ make zImage
  CHK     include/linux/version.h
make[1]: `include/asm-arm/mach-types.h' is up to date.
  CHK     include/linux/utsrelease.h
  SYMLINK include/asm -> include/asm-arm
  CALL    scripts/checksyscalls.sh
<stdin>:1097:2: warning: #warning syscall fadvise64 not implemented
<stdin>:1265:2: warning: #warning syscall migrate_pages not implemented
<stdin>:1321:2: warning: #warning syscall pselect6 not implemented
<stdin>:1325:2: warning: #warning syscall ppoll not implemented
<stdin>:1365:2: warning: #warning syscall epoll_pwait not implemented
  CHK     include/linux/compile.h
  LD      init/mounts.o
  LD      init/built-in.o
  LD      usr/built-in.o
  LD      arch/arm/kernel/built-in.o
  LD      arch/arm/mm/built-in.o
  LD      arch/arm/common/built-in.o
  LD      arch/arm/mach-s3c2410/built-in.o
  LD      arch/arm/mach-s3c2400/built-in.o
  LD      arch/arm/mach-s3c2412/built-in.o
  LD      arch/arm/mach-s3c2440/built-in.o
  LD      arch/arm/mach-s3c2442/built-in.o
  LD      arch/arm/mach-s3c2443/built-in.o
  LD      arch/arm/plat-s3c24xx/built-in.o
  LD      arch/arm/plat-s3c/built-in.o
  LD      arch/arm/nwfpe/nwfpe.o
  LD      arch/arm/nwfpe/built-in.o
  LD      kernel/irq/built-in.o
  LD      kernel/time/built-in.o
  LD      kernel/built-in.o
  LD      mm/built-in.o
  LD      fs/configfs/configfs.o
  LD      fs/configfs/built-in.o
  LD      fs/cramfs/cramfs.o
  LD      fs/cramfs/built-in.o
  LD      fs/devpts/devpts.o
  LD      fs/devpts/built-in.o
  LD      fs/exportfs/exportfs.o
  LD      fs/exportfs/built-in.o
  LD      fs/ext2/ext2.o
  LD      fs/ext2/built-in.o
  LD      fs/fat/fat.o
  LD      fs/fat/vfat.o
  LD      fs/fat/msdos.o
  LD      fs/fat/built-in.o
  LD      fs/isofs/isofs.o
  LD      fs/isofs/built-in.o
  LD      fs/jffs2/jffs2.o
  LD      fs/jffs2/built-in.o
  LD      fs/lockd/lockd.o
  LD      fs/lockd/built-in.o
  LD      fs/nfs/nfs.o
  LD      fs/nfs/built-in.o
  LD      fs/nfs_common/built-in.o
  LD      fs/nfsd/nfsd.o
  LD      fs/nfsd/built-in.o
  LD      fs/nls/built-in.o
  LD      fs/ntfs/built-in.o
  LD      fs/partitions/built-in.o
  LD      fs/proc/proc.o
  LD      fs/proc/built-in.o
  LD      fs/ramfs/ramfs.o
  LD      fs/ramfs/built-in.o
  LD      fs/romfs/romfs.o
  LD      fs/romfs/built-in.o
  LD      fs/sysfs/built-in.o
  LD      fs/udf/built-in.o
  LD      fs/yaffs2/yaffs.o
  LD      fs/yaffs2/built-in.o
  LD      fs/built-in.o
  LD      ipc/built-in.o
  LD      security/built-in.o
  LD      crypto/crypto.o
  LD      crypto/built-in.o
  LD      block/built-in.o
  LD      drivers/auxdisplay/built-in.o
  LD      drivers/base/power/built-in.o
  LD      drivers/base/built-in.o
  LD      drivers/block/built-in.o
  LD      drivers/block/aoe/built-in.o
  LD      drivers/cdrom/built-in.o
  LD      drivers/char/hw_random/rng-core.o
  LD      drivers/char/hw_random/built-in.o
  LD      drivers/char/built-in.o
  LD      drivers/crypto/built-in.o
  LD      drivers/firmware/built-in.o
  LD      drivers/gpio/built-in.o
  LD      drivers/gpu/drm/built-in.o
  LD      drivers/gpu/built-in.o
  LD      drivers/hid/hid.o
  LD      drivers/hid/hid-logitech.o
  LD      drivers/hid/usbhid/usbhid.o
  LD      drivers/hid/usbhid/built-in.o
  LD      drivers/hid/built-in.o
  LD      drivers/hwmon/built-in.o
  LD      drivers/i2c/algos/built-in.o
  LD      drivers/i2c/busses/built-in.o
  LD      drivers/i2c/chips/built-in.o
  LD      drivers/i2c/built-in.o
  LD      drivers/ide/ide-core.o
  LD      drivers/ide/ide-gd_mod.o
  LD      drivers/ide/ide-cd_mod.o
  LD      drivers/ide/built-in.o
  LD      drivers/idle/built-in.o
  LD      drivers/ieee1394/built-in.o
  LD      drivers/input/input-core.o
  LD      drivers/input/keyboard/built-in.o
  LD      drivers/input/mouse/built-in.o
  LD      drivers/input/touchscreen/built-in.o
  LD      drivers/input/built-in.o
  LD      drivers/input/serio/built-in.o
  LD      drivers/lguest/built-in.o
  LD      drivers/macintosh/built-in.o
  LD      drivers/media/common/tuners/built-in.o
  LD      drivers/media/common/built-in.o
  LD      drivers/media/video/built-in.o
  LD      drivers/media/built-in.o
  LD      drivers/mfd/built-in.o
  LD      drivers/misc/built-in.o
  LD      drivers/mmc/card/mmc_block.o
  LD      drivers/mmc/card/built-in.o
  LD      drivers/mmc/core/mmc_core.o
  LD      drivers/mmc/core/built-in.o
  LD      drivers/mmc/host/built-in.o
  LD      drivers/mmc/built-in.o
  LD      drivers/mtd/mtd.o
  LD      drivers/mtd/chips/built-in.o
  LD      drivers/mtd/devices/built-in.o
  LD      drivers/mtd/maps/built-in.o
  LD      drivers/mtd/nand/nand.o
  LD      drivers/mtd/nand/built-in.o
  LD      drivers/mtd/onenand/built-in.o
  LD      drivers/mtd/built-in.o
  LD      drivers/net/arm/built-in.o
  LD      drivers/net/wireless/built-in.o
  LD      drivers/net/built-in.o
  LD      drivers/parport/parport.o
  LD      drivers/parport/built-in.o
  LD      drivers/rtc/rtc-core.o
  LD      drivers/rtc/built-in.o
  LD      drivers/scsi/scsi_mod.o
  LD      drivers/scsi/arm/built-in.o
  LD      drivers/scsi/sd_mod.o
  LD      drivers/scsi/built-in.o
  LD      drivers/serial/built-in.o
  LD      drivers/usb/class/built-in.o
  LD      drivers/usb/core/usbcore.o
  LD      drivers/usb/core/built-in.o
  LD      drivers/usb/host/built-in.o
  LD      drivers/usb/misc/built-in.o
  LD      drivers/usb/mon/usbmon.o
  LD      drivers/usb/mon/built-in.o
  LD      drivers/usb/serial/usbserial.o
  LD      drivers/usb/serial/built-in.o
  LD      drivers/usb/storage/built-in.o
  LD      drivers/usb/built-in.o
  LD      drivers/video/fb.o
  LD      drivers/video/backlight/built-in.o
  LD      drivers/video/console/font.o
  LD      drivers/video/console/built-in.o
  LD      drivers/video/display/built-in.o
  LD      drivers/video/built-in.o
  LD      drivers/built-in.o
  LD      sound/soundcore.o
  LD      sound/oss/built-in.o
  LD      sound/built-in.o
  LD      firmware/built-in.o
  LD      net/802/built-in.o
  LD      net/core/built-in.o
  LD      net/ethernet/built-in.o
  LD      net/ipv4/built-in.o
  LD      net/netlink/built-in.o
  LD      net/packet/built-in.o
  LD      net/sched/built-in.o
  LD      net/sunrpc/sunrpc.o
  LD      net/sunrpc/built-in.o
  LD      net/unix/unix.o
  LD      net/unix/built-in.o
  LD      net/wireless/built-in.o
  LD      net/xfrm/built-in.o
  LD      net/built-in.o
  LD      arch/arm/lib/built-in.o
  AR      arch/arm/lib/lib.a
  LD      lib/zlib_deflate/zlib_deflate.o
  LD      lib/zlib_deflate/built-in.o
  LD      lib/zlib_inflate/zlib_inflate.o
  LD      lib/zlib_inflate/built-in.o
  LD      lib/built-in.o
  AR      lib/lib.a
  LD      vmlinux.o
  MODPOST vmlinux.o
vmlinux.o: No such file or directory
make[1]: *** [vmlinux.o] Error 1
make: *** [vmlinux.o] Error 2
 楼主| 发表于 2016-12-15 09:57:02 | 显示全部楼层
    您的报错网上有相关的解决方法,您参 ...
你好,帮我看下问题吧谢谢。
发表于 2016-12-15 11:28:09 | 显示全部楼层
du1234 发表于 2016-12-15 09:57
你好,帮我看下问题吧谢谢。
您打开Linux内核文件根目录下的Makefile,看看ARCH 是否已经改为 arm   CROSS_COMPILE 是否改为arm-fsl-linux-gnueabi-
按照视频,Makefile进行了修改, ARCH ?= arm CROSS_COMPILE ?= /home/yan934/usr/local/arm/3.4.1/bin/arm-linux- 谢谢。  详情 回复 发表于 2016-12-15 14:31
 楼主| 发表于 2016-12-15 14:31:36 | 显示全部楼层
飞凌-chongzi 发表于 2016-12-15 11:28
您打开Linux内核文件根目录下的Makefile,看看ARCH 是否已经改为 arm   CROSS_COMPILE 是否改为arm-fsl-li ...
按照视频,Makefile进行了修改,
ARCH                ?= arm
谢谢。
发表于 2016-12-15 14:54:00 | 显示全部楼层
不客气。。。。
按照视频,Makefile进行了修改, ARCH ?= arm CROSS_COMPILE ?= /home/yan934/usr/local/arm/3.4.1/bin/arm-linux- 还是不行 之前出的问题,也是对Makefile进行了相同的修改  详情 回复 发表于 2016-12-15 15:02
 楼主| 发表于 2016-12-15 15:02:53 | 显示全部楼层
按照视频,Makefile进行了修改,
ARCH                ?= arm
还是不行
GMT+8, 2026-10-4 13:19
