查看: 30502|回复: 8
[Linux] 帮忙分析一下wifi传输问题出在哪里,现在没有调试方向了
i.MX6Q通行证i.MX6UL通行证AM335x通行证RK3506通行证
发表于 2016-12-16 10:49:18 | 显示全部楼层 |阅读模式
调试过程记录:
开发环境:OK335XD Linux3.2
现象:sftp传送文件过程中,ssh会话断开连接,iwconfig查看无线 Signal level变为2%,网络不通。
root@ok335x:/var/log # iwconfig wlan0
wlan0     IEEE 802.11bgn  ESSID:"SoftTest"  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency:2.422 GHz  Access Point: B0:95:8E:03:EE:C6
          Bit Rate:150 Mb/s   Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:****-****-****-****-****-****-****-****   Security mode:open
          Power Management:off
          Link Quality=2/100  Signal level=2/100  Noise level=0/100
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
root@ok335x:/var/log # ifconfig wlan0
wlan0     Link encap:Ethernet  HWaddr E8:4E:06:39:05:1E
          inet addr:192.168.99.108  Bcast:192.168.99.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:8148 errors:0 dropped:574 overruns:0 frame:0
          TX packets:4364 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:12604990 (12.0 MiB)  TX bytes:412895 (403.2 KiB)
分析:
1.连接有线网络eth0,使用sftp,多次传输文件未出现中断。(正常传输)
2.重新启用wifi(RTL8188CUS),断开有线,启用sftp传送文件,传输一会儿断线,wifi不能使用。(现象重现)
    SecureCRT的sftp上传失败后的信息:
    Failed to set the permissions or timestamp on the destination file: The operation was aborted because the channel closed.
    The sftp operation was aborted.
    关闭wpa进程:
    $killall -q wpa_supplicant
    前台方式打开wpa进程后无任何信息返回,没有任何连接过程。
    $wpa_supplicant -Dwext -iwlan0 -c/etc/wpa_supplicant.conf
^C
    CTRL-EVENT-TERMINATING - signal 2 received
    ioctl[SIOCSIWAP]: Operation not permitted
    重启系统:手动打开wpa进程的信息(正常情况都会出现这些信息)
    Trying to associate with b0:95:8e:03:ee:c6 (SSID='SoftTest' freq=2422 MHz)
    Associated with b0:95:8e:03:ee:c6
    WPA: Key negotiation completed with b0:95:8e:03:ee:c6 [PTK=CCMP GTK=CCMP]
    CTRL-EVENT-CONNECTED - Connection to b0:95:8e:03:ee:c6 completed (auth) [id=0 id_str=]
    至此,才能够重新连接wifi成功。
3.更换电源,现象相同(排除该问题)
发表于 2016-12-16 11:24:46 | 显示全部楼层
    您使用ssh服务的时候,网口与无线应该是发生了冲突,我们没有做这一块的控制,无线与有线是不能同时使用的,您可以自己对这一块做一下控制
都是做的单独测试。使用有线的时候。有线网络接口eth0 是被down掉的。 ifconfig 只有wlan0 和 lo。  详情 回复 发表于 2016-12-16 12:43
 楼主| 发表于 2016-12-16 12:43:30 | 显示全部楼层
飞凌-chongzi 发表于 2016-12-16 11:24
    您使用ssh服务的时候,网口与无线应该是发生了冲突,我们没有做这一块的控制,无线与有线是不 ...
发表于 2016-12-16 14:30:20 | 显示全部楼层
    eth0 down掉您是怎样使用有线的?
    您应该在使用网口的时候,不使用wlan0才对。
我意思就是单一使用的。使用无线时,eth0 down,wlan0 up  详情 回复 发表于 2016-12-16 14:49
 楼主| 发表于 2016-12-16 14:49:57 | 显示全部楼层
使用有线时  eth0 up ,wlan0 down
发表于 2016-12-16 15:20:00 | 显示全部楼层
    您给我们技术支持打个电话,咱们电话沟通吧
FTP服务器测试能够使用。上传文件还是相同问题。 [17:30:02] [R] 数据套接字错误 (10054): 连接被对等方重置 [17:30:08] [R] 传输失败  详情 回复 发表于 2016-12-16 17:32
 楼主| 发表于 2016-12-16 17:32:49 | 显示全部楼层
重新用你们提供的文件系统,FTP服务器测试能够使用。上传文件还是相同问题。
FLASHXP工具
[17:30:08] [R] 传输失败
root@ok335x:/home/forlinx# wpa_supplicant -iwlan0 -Dwext -c/etc/wpa_supplicant.conf
Authentication with b0:95:8e:03:ee:c6 timed out.[ 3567.535242] rtw_wx_set_mlme
[ 3567.542282] rtw_wx_set_mlme, cmd=1, reason=3
CTRL-EVENT-DISCONNECTED bssid=00:00:00:00:00:00 reason=0
CTRL-EVENT-DISCONNECTED bssid=b0:95:8e:03:ee:c6 reason=0
Authentication with 00:00:00:00:00:00 timed out.
Authentication with b0:95:8e:03:ee:c6 timed out.[ 3598.981045] rtw_wx_set_mlme
 楼主| 发表于 2016-12-22 09:17:45 | 显示全部楼层
{:2_25:}{:2_25:}
居然是飞凌提供的驱动有问题!!!!!
这个坑大了
XX18通行证AM335x通行证
发表于 2017-6-19 14:42:11 | 显示全部楼层
我遇到的问题和您是一样的,无法连上wifi,报错也是一样的,您确定好了是飞凌的驱动的问题吗?
GMT+8, 2026-10-4 13:26
