查看: 55697|回复: 5
[Linux] SD卡烧写系统问题
发表于 2017-1-12 22:36:26 | 显示全部楼层 |阅读模式
我用SD卡烧写时候,按照教程制作好SD卡,拨码开关设置成1,4 on,其它off,可是没有烧写界面出来,请问是对SD卡有特殊要求吗?我的是金士顿的SD4/16G
 楼主| 发表于 2017-1-12 22:40:02 | 显示全部楼层
另外就是我不小心改了UBOOT里的一些变量,会不会和这个也有影响?
baudrate=115200
bootargs=console=ttymxc0,115200 rdinit=/linuxrc g_mass_storage.stall=0 g_mass_storage.removable=1 g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF g_mass_storage.iSerialNumber= clk_ignore_unused
bootargs_base=setenv bootargs console=ttymxc0,115200
bootargs_nfs=setenv bootargs ${bootargs} root=/dev/nfs ip=dhcp nfsrootdebug nfsroot=${serverip}:${nfsroot},v3,tcp fec_mac=${ethaddr} video=mxcfb0:dev=ldb,CVBS-TV,if=RGB666,bpp=16
bootcmd=run bootnand; run bootcmd_mfg
bootcmd_mfg=run mfgtool_args;bootz ${loadaddr} ${initrd_addr} ${fdt_addr};
bootcmd_net=run bootargs_base bootargs_nfs;bootm
bootdelay=3
bootdev=sd1
bootfile=zImage
bootnand=nand read ${loadaddr} 0x800000 0x800000;nand read ${fdt_addr} 0x700000 0x100000;bootz ${loadaddr} - ${fdt_addr};
console=ttymxc0
envaddr=00:11:22:33:44:55
ethact=FEC1
ethaddr=00:11:22:33:44:55
ethddr=00:11:22:33:44:55
ethprime=FEC
fdt_addr=0x83000000
fdt_high=0xffffffff
initrd_addr=0x83800000
initrd_high=0xffffffff
ipaddr=192.168.1.120
loadaddr=0x80800000
mfgtool_args=setenv bootargs console=${console},${baudrate} rdinit=/linuxrc g_mass_storage.stall=0 g_mass_storage.removable=1 g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF g_mass_storage.iSerialNumber="" clk_ignore_unused
nfsroot=/home/rootfs
panel=TFT43AB
serverip=192.168.1.110
splashimage=0x83800000
update_from_sd=run update_nand;
update_nand=mmc rescan;fatload mmc 0 ${loadaddr} /bin/zImage; fatload mmc 0 ${initrd_addr} /bin/ramdisk.img.u; fatload mmc 0 ${fdt_addr} /bin/imx6ul-14x14-evk.dtb; set bootargs console=${console},${baudrate} cma=64M rdinit=/linuxrc; bootz ${loadaddr} ${initrd_addr} ${fdt_addr};baudrate=115200
bootdelay=3
bootdev=sd1
bootfile=zImage
console=ttymxc0
ethact=FEC1
ethprime=FEC
fdt_addr=0x83000000
fdt_high=0xffffffff
loadaddr=0x80800000
panel=TFT43AB
发表于 2017-1-13 08:33:14 | 显示全部楼层
baudrate=115200
您好 :
       您具体是用的哪个型号的开发板,SD卡烧写完后,有没有再重新设置拨码开关,建议您查看一下,是不是烧写的console,因为console是没有图形界面的。
http://www.forlinx.com/60.htm 这款开发板。我烧的QT4。拨码开关没问题 烧写时候我也连着终端,上面提示信息还是Linux启动信息,而不是烧写信息。我之前修改UBOOT变量,系统崩溃了。  详情 回复 发表于 2017-1-13 09:22
 楼主| 发表于 2017-1-13 09:21:09 | 显示全部楼层
 楼主| 发表于 2017-1-13 09:22:23 | 显示全部楼层
飞凌-chongzi 发表于 2017-1-13 08:33
您好 :
       您具体是用的哪个型号的开发板,SD卡烧写完后,有没有再重新设置拨码开关,建议您查看一 ...
发表于 2017-1-13 09:37:57 | 显示全部楼层
烧写时候我也连着终端,上面提 ...
      我建议您烧写我们出厂自带的源码包,我们的开发板是不会有问题的。
GMT+8, 2026-10-4 13:16
