查看: 48317|回复: 2
[Linux] 系统启动不成功
发表于 2017-3-30 10:49:47 | 显示全部楼层 |阅读模式
OKMX6X-C 由安卓系统变为linux+qt 系统,采用SD卡烧写,烧写成功,但是启动不成功,一直报如下错误信息,
usbcore: registered new inte**ce driver usb-storage
usbcore: registered new inte**ce driver usbserial
USB Serial support registered for GSM modem (1-port)
usbcore: registered new inte**ce driver option
option: v0.7.2:USB Driver for GSM modems
usbcore: registered new inte**ce driver pl2303
ARC USBOTG Device Controller driver (1 August 2005)
input: gpio-keys as /devices/platform/gpio-keys/input/input0
<<-GTP-INFO->> GTP driver installing...
<<-GTP-INFO->> GTP Driver Version: V2.2<2014/01/14>
<<-GTP-INFO->> GTP Driver Built@11:16:06, Oct 19 2016
<<-GTP-INFO->> GTP I2C Address: 0x5d
<<-GTP-INFO->> Guitar reset
<<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
<<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
usb 2-1: new high speed USB device number 2 using fsl-ehci
<<-GTP-ERROR->> GTP i2c test failed time 1.
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
<<-GTP-ERROR->> GTP i2c test failed time 2.
<<-GTP-ERROR->> GTP i2c test failed time 3.
usb 2-1.3: new high speed USB device number 3 using fsl-ehci
<<-GTP-ERROR->> GTP i2c test failed time 4.
<<-GTP-ERROR->> GTP i2c test failed time 5.
<<-GTP-ERROR->> I2C communication ERROR!
<<-GTP-ERROR->> I2C Read: 0x8140, 6 bytes failed, errcode: -5! Process reset.
<<-GTP-ERROR->> GTP read version failed
<<-GTP-ERROR->> Read version failed.
<<-GTP-ERROR->> I2C Read: 0x8047, 240 bytes failed, errcode: -5! Process reset.
发表于 2017-3-31 08:34:46 | 显示全部楼层
       OTG烧写可以启动吗?您用的是我们提供的出厂镜像吗?
发表于 2017-3-31 08:34:48 | 显示全部楼层
您这个lvds屏的触摸报的错,现在您默认的是lvds屏,您那边没有接屏导致i2c检测不到设备报的错,现在有两个方法,1是接上lvds屏再启动看还是这样吗,2您直接根据咱们linux手册上面修改显示屏的方案,将其改成别的屏体,再上电应该就不会报错了
技术支持邮箱:Hardware@forlinx.com
GMT+8, 2026-10-4 13:19
