查看: 48144|回复: 1
[Linux] 新板子OTG烧写以后无法正常启动
i.MX6Q通行证i.MX6UL通行证RK3588通行证
发表于 2017-4-7 17:02:28 | 显示全部楼层 |阅读模式
终端打印如下信息:
U-Boot 2009.08 (Apr 06 2017 - 23:21:21)
U-Boot code: 278006E0 -> 27833200  BSS: -> 2786D348
CPU: Freescale i.MX6 family TO1.5 at 792 MHz
Thermal sensor with ratio = 173
Temperature:   32 C, calibration data 0x5484c969
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 264000000Hz
emi_slow clock: 132000000Hz
ddr clock     : 528000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6Q-SABRESD: unknown-board Board: 0x63015 [POR ]
Boot Device: MMC
I2C:   ready
RAM Configuration:
Bank #0: 10000000  1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
In:    serial
Out:   serial
Err:   serial
config_ipu_lvds_clk: freq = 497750400.
config_ipu_lvds_clk: set pll3_pfd1 clock to 504MHz, divider = 17.
Found PFUZE100! deviceid=10,revid=21
Net:   got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
### main_loop entered: bootdelay=3
### main_loop: bootcmd="booti mmc3"
Unknown command 'booti' - try 'help'
MX6Q SABRESD U-Boot >
发表于 2017-4-8 16:03:06 | 显示全部楼层
    请说明一下板子的具体型号,贴张核心板的照片并贴一张您用的烧写工具的图,另外您烧写的是我们的标准镜像吗
GMT+8, 2026-10-4 13:20
