查看: 20937|回复: 1
[Linux] wince 烧Linux
i.MX6Q通行证i.MX6UL通行证
发表于 2017-7-6 16:31:38 | 显示全部楼层 |阅读模式
wince烧linux 烧写正常,但是]烧写后系统不能正常启动 调试输出卡死在
0x000001e00000-0x00000e600000 : "File System"
0x00000e600000-0x000040000000 : "User"
mcp2515 spi1.0: MCP251x didn't enter in conf mode after reset
mcp2515 spi1.0: probe failed
dm9000 dm9000.0: read wrong id 0x01010101
s3c_g2d_probe called
s3c_g2d_probe Success
[<c003cca8>] (unwind_backtrace+0x0/0xfc) from [<c054be44>] (dump_stack+0x18/0x1c)
[<c054be44>] (dump_stack+0x18/0x1c) from [<c054bea8>] (panic+0x60/0x1ac)
[<c054bea8>] (panic+0x60/0x1ac) from [<c00365dc>] (init_post+0xc8/0x140)
[<c00365dc>] (init_post+0xc8/0x140) from [<c00084c8>] (kernel_init+0xf4/0x130)
[<c00084c8>] (kernel_init+0xf4/0x130) from [<c0037a34>] (kernel_thread_exit+0x0/0x8)
发表于 2017-7-7 08:48:08 | 显示全部楼层
您好,在从WINCE烧写Linux时,请先使用WINCE的EBOOT格式化一遍FLASH后再进行烧写。
技术支持邮箱:wince@forlinx.com
GMT+8, 2026-10-4 12:21
