查看: 54743|回复: 4
[Linux] 无法start kernel
发表于 2017-8-29 18:30:41 | 显示全部楼层 |阅读模式
U-Boot 2015.04 (Feb 20 2017 - 11:23:37)
CPU:   Freescale i.MX6UL rev1.1 at 396 MHz
CPU:   Temperature 43 C
Reset cause: POR
Board: MX6UL 14x14 EVK
I2C:   ready
DRAM:  256 MiB
NAND:  256 MiB
MMC:   FSL_SDHC: 0
Display: TFT70AB (800x480)
Video: 800x480x24
NAND read: device 0 offset 0x400000, size 0x80000
524288 bytes read: OK
display bmp cfb_console.c
In:    serial
Out:   serial
Err:   serial
Net:   FEC1
Error: FEC1 address not set.
Normal Boot
nand boot..........
NAND read: device 0 offset 0xa00000, size 0x800000
NAND read from offset a00000 failed -74
0 bytes read: ERROR
NAND read: device 0 offset 0x740000, size 0x40000
262144 bytes read: OK
Kernel image @ 0x80800000 [ 0x000000 - 0x5ca110 ]
## Flattened Device Tree blob at 83000000
   Booting using the fdt blob at 0x83000000
   Using Device Tree in place at 83000000, end 8300be2e
Starting kernel ...
data abort
pc : [<80800a08>]          lr : [<808009e4>]
reloc pc : [<9bfe0a04>]    lr : [<9bfe09e0>]
sp : 80dcb138  ip : 80dca10c     fp : 80dca110
r10: 80058001  r9 : 80800190     r8 : 00000000
r7 : 80ddb150  r6 : 80dcb150     r5 : 80008000  r4 : 80dca70c
r3 : 000010b4  r2 : 000000d2     r1 : 00000000  r0 : 80008000
Flags: nZCv  IRQs off  FIQs off  Mode SVC_32
Resetting CPU ...
resetting ...
CPU:   Temperature 49 C
Reset cause: WDOG
I2C:   ready
DRAM:  256 MiB
NAND:  256 MiB
MMC:   FSL_SDHC: 0
Video: 800x480x24
In:    serial
Out:   serial
Err:   serial
Net:   FEC1
Normal Boot
nand boot..........
0 bytes read: ERROR
Starting kernel ...
data abort
Resetting CPU ...
resetting ...
CPU:   Temperature 51 C
Reset cause: WDOG
I2C:   ready
DRAM:  256 MiB
NAND:  256 MiB
MMC:   FSL_SDHC: 0
Video: 800x480x24
In:    serial
Out:   serial
Err:   serial
Net:   FEC1
Normal Boot
Hit any key to stop autoboot:  2
哎什么意思嘛。。。nand256 ram256 OKMX6UL-C
 楼主| 发表于 2017-8-29 18:32:25 | 显示全部楼层
应该是内核有问题  但是是你们给的内核文件   百度云上下载下来 然后就按照文档otg 下载的  下载下来就这样了 重刷还是这样 没有任何办法刷了 10多次了
发表于 2017-8-30 10:02:08 | 显示全部楼层
qq422216549 发表于 2017-8-29 18:32
应该是内核有问题  但是是你们给的内核文件   百度云上下载下来 然后就按照文档otg 下载的  下载下来就这样 ...
    您发一张您使用的烧写工具的截图,并标注您使用的是哪一个脚本,我这里确认一下
    另外您可以试一下SD卡烧录,排除一下是工具的问题还是操作手法的问题
 楼主| 发表于 2017-8-30 14:43:46 | 显示全部楼层
你好  我已经解决这个问题了      不应该按照你们文档上写的走
首先插入otg 开发板开电 这是电脑才能正确识别到usb设备  打开vbs脚本开刷系统
等出现完成以后 不应该马上点stop退出软件   正确的做法是-----点stop 这时候开发板会重启  自动进入linux系统,不用管他,等一下超级终端会显示等待usb   这个时候继续点工具  还要进行一个刷rootfs的步骤   刷完以后才是真正的完了
断电  13on   成功进入linux
发表于 2017-9-1 19:33:36 | 显示全部楼层
首先插入otg 开发板开电 这是电脑才能正确 ...
    您用的什么型号的开发板,您的操作流程拍个视频发到邮箱吧,感觉您的描述比较奇怪,我这里确认一下,如果板子有问题的话,咱们好及时解决
GMT+8, 2026-10-4 14:13
