查看: 38337|回复: 5
[Linux] imx6q-c板子想使用EIM接口,配置完,没反应 急急急!!!!!!!!
发表于 2018-2-9 16:21:08 | 显示全部楼层 |阅读模式
使用imx6q-c板子 现在想使用EIM接口传输数据 但是EIM接口配置完一直没有反应啊 我是将引脚配置放到arch/arm/mach-mx6/board-mx6q_sabresd.h中配置寄存器函数放到了arch/arm/mach-mx6/board-mx6q_sabresd.c里,有问题吗?
static void mx6q_setup_weimcs(void)
        void __iomem *nor_reg = MX6_IO_ADDRESS(WEIM_BASE_ADDR);
        void __iomem *ccm_reg = MX6_IO_ADDRESS(CCM_BASE_ADDR);
        unsigned int reg;
        struct clk *clk;
        u32 rate;
        /* CLKCTL_CCGR6: Set emi_slow_clock to be on in all modes */
        reg = readl(ccm_reg + 0x80);
        reg |= 0x00000C00;
        writel(reg, ccm_reg + 0x80);
        /* Timing settings below based upon datasheet for M29W256GL7AN6E
           These setting assume that the EIM_SLOW_CLOCK is set to 132 MHz */
        clk = clk_get(NULL, "emi_slow_clk");
        if (IS_ERR(clk))
                printk(KERN_ERR "emi_slow_clk not found\n");
        rate = clk_get_rate(clk);
        if (rate != 132000000)
                printk(KERN_ERR "Warning: emi_slow_clk not set to 132 MHz!"
                       " WEIM NOR timing may be incorrect!\n");
         * For EIM General Configuration registers.
         * CS0GCR1:
         *        GBC = 0; CSREC = 1; DSZ = 2; BL = 0;
         *        CREP = 1; CSEN = 1;
         *        EIM Operation Mode: MUM = SRD = SWR = 0.
         *                (Async write/Async page read, none multiplexed)
         * CS0GCR2:
         *        ADH = 1
        writel(0x00120081, nor_reg);
        writel(0x00000001, nor_reg + 0x00000004);
         * For EIM Read Configuration registers.
         * CS0RCR1:
         *        RWSC = 1C;
         *        RADVA = 0; RADVN = 2;
         *        OEA = 2; OEN = 0;
         *        RCSA = 0; RCSN = 0
         * CS0RCR2:
         *        APR = 1 (Async Page Read);
         *        PAT = 4 (6 EIM clock sycles)
        writel(0x1C022000, nor_reg + 0x00000008);
        writel(0x0000C000, nor_reg + 0x0000000C);
         * For EIM Write Configuration registers.
         * CS0WCR1:
         *        WWSC = 20;
         *        WADVA = 0; WADVN = 1;
         *        WBEA = 1; WBEN = 2;
         *        WEA = 1; WEN = 6;
         *        WCSA = 1; WCSN = 2;
         * CS0WCR2:
         *        WBCDD = 0
        writel(0x1404a38e, nor_reg + 0x00000010);
        writel(0x00000000, nor_reg + 0x00000014);
发表于 2018-2-9 17:18:01 | 显示全部楼层
配置放置没问题,建议你看一下CPU手册,eim总线相关章节,看一下配置,如果你参考是飞凌提供的例程的话 应该是没问题的。如果还有相关问题,联系负责你的销售人员。
飞凌提供的例子在哪?能发一份吗?  详情 回复 发表于 2018-2-10 09:01
 楼主| 发表于 2018-2-10 09:01:14 | 显示全部楼层
米哥V587 发表于 2018-2-9 17:18
配置放置没问题,建议你看一下CPU手册,eim总线相关章节,看一下配置,如果你参考是飞凌提供的例程的话 应 ...
飞凌提供的例子在哪?能发一份吗?
你好,请问这个问题解决了吗?  详情 回复 发表于 2018-7-11 10:50
i.MX6Q通行证
发表于 2018-4-27 15:57:10 | 显示全部楼层
你好,这个问题解决了吗
你好,请问这个问题解决了吗?  详情 回复 发表于 2018-7-11 10:52
i.MX6Q通行证i.MX6UL通行证
发表于 2018-7-11 10:50:42 | 显示全部楼层
XIAOAI 发表于 2018-2-10 09:01
飞凌提供的例子在哪?能发一份吗?
你好,请问这个问题解决了吗?
i.MX6Q通行证i.MX6UL通行证
发表于 2018-7-11 10:52:51 | 显示全部楼层
lingyi_cai 发表于 2018-4-27 15:57
你好,这个问题解决了吗
你好,请问这个问题解决了吗?
GMT+8, 2026-9-25 06:48
