查看: 6064|回复: 1
[Linux] 【求助】一键烧写Linux系统成功后,打开黑屏!
发表于 2018-3-22 10:44:41 | 显示全部楼层 |阅读模式
SD卡烧写成功,蜂鸣器声响。
转换为Nandflash启动后,显示白屏,之后进入黑屏状态。
并没有屏幕校准的界面,一直黑屏... ...
求助!谢谢。
附
DNW中的信息:
U-Boot 1.1.6 (Sep 25 2012 - 10:43:06) for SMDK6410
**    Updated for OK6410  TE6410 Board  **
**    Version (2012-09-23)          **
CPU:     S3C6410 @532MHz
Board:   SMDK6410
DRAM:    128 MB
Flash:   0 kB
NAND:    1024 MB
In:      serial
Out:     serial
Err:     serial
NAND read: device 0 offset 0x200000, size 0x500000
5242880 bytes read: OK
Boot with zImage
Starting kernel ...
Linux version 3.0.1 (root@forlinx) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #439 Sun Sep 23 13:36:30 CST 2012
Kernel command line: root=/dev/mtdblock2 rootfstype=yaffs2 init=/linuxrc nconsole=tty1 console=ttySAC0,115200 android.ril=s3c2410_serial1 lcdsize=43
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 67664k/67664k available, 63408k reserved, 0K highmem
Virtual kernel memory layout:
    vmalloc : 0xc8800000 - 0xf4000000   ( 696 MB)
    lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
      .init : 0xc0008000 - 0xc0034000   ( 176 kB)
      .text : 0xc0034000 - 0xc0702094   (6969 kB)
      .data : 0xc0704000 - 0xc0746390   ( 265 kB)
       .bss : 0xc07463b4 - 0xc07c3d40   ( 503 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:246 nr_irqs:246 246
console [ttySAC0] enabled
Calibrating delay loop... 528.79 BogoMIPS (lpj=2643968)
devtmpfs: initialized
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
PL080: IRQ 73, at c8804000, channels 0..8
PL080: IRQ 74, at c8806000, channels 8..16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
------------[ cut here ]------------
WARNING: at drivers/gpio/gpiolib.c:101 gpio_ensure_requested+0x58/0x124()
---[ end trace da227214a82491b7 ]---
usbcore: registered new inte**ce driver usbfs
usbcore: registered new inte**ce driver hub
Advanced Linux Sound Architecture Driver Version 1.0.23.
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
RPC: Registered named UNIX socket transport module.
audit: initializing netlink socket (disabled)
type=2000 audit(0.280:1): initialized
msgmni has been set to 132
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
LCD TYPE :: LTE480WV will be initialized
Console: switching to colour frame buffer device 60x34
s3c6400-uart.0: ttySAC0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10
s3c6400-uart.1: ttySAC1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10
s3c6400-uart.2: ttySAC2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10
s3c6400-uart.3: ttySAC3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10
Hello, world
NAND device: Manufacturer ID: 0x2c, Chip ID: 0x38 (Micron NAND 2GiB 1,8V 8-bit)
Creating 4 MTD partitions on "NAND 2GiB 1,8V 8-bit":
0x000000000000-0x000000200000 : "Bootloader"
0x000000200000-0x000000700000 : "Kernel"
0x000000700000-0x00000cf00000 : "User"
0x00000cf00000-0x000040000000 : "File System"
vcan: Virtual CAN inte**ce driver
slcan: serial line CAN inte**ce driver
slcan: 10 dynamic inte**ce channels.
CAN device driver inte**ce
mcp251x: setup gpio pins CS and External Int
mcp2515 spi1.0: MCP251x didn't enter in conf mode after reset
mcp2515 spi1.0: Probe failed
mcp2515 spi1.0: probe failed
dm9000 Ethernet Driver, V1.31
eth0: dm9000a at c881c000,c8c00004 IRQ 108 MAC: 08:90:00:a0:90:90 (platform data)
libertas_sdio: Libertas SDIO driver
libertas_sdio: Copyright Pierre Ossman
usbcore: registered new inte**ce driver rt73usb
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: S3C24XX OHCI
usb usb1: Manufacturer: Linux 3.0.1 ohci_hcd
usb usb1: SerialNumber: s3c24xx
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new inte**ce driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new inte**ce driver usb-storage
usbcore: registered new inte**ce driver usbserial
USB Serial support registered for generic
usbcore: registered new inte**ce driver usbserial_generic
USB Serial support registered for GSM modem (1-port)
usbcore: registered new inte**ce driver option
option: v0.7.2:USB Driver for GSM modems
usbcore: registered new inte**ce driver pl2303
dummy_hcd dummy_hcd: USB Host+Gadget Emulator, driver 02 May 2005
dummy_hcd dummy_hcd: Dummy host controller
dummy_hcd dummy_hcd: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Dummy host controller
usb usb2: Manufacturer: Linux 3.0.1 dummy_hcd
usb usb2: SerialNumber: dummy_hcd
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
input: gpio-keys as /devices/platform/gpio-keys/input/input0
input: s3c-keypad as /devices/platform/s3c-keypad/input/input1
S3C Touchscreen driver, (c) 2008 Samsung Electronics
S3C TouchScreen got loaded successfully : 12 bits
input: S3C TouchScreen as /devices/virtual/input/input2
i2c /dev entries driver
Linux video capture inte**ce: v2.00
gspca: main v2.10.0 registered
usbcore: registered new inte**ce driver benq
benq: registered
usbcore: registered new inte**ce driver conex
conex: registered
usbcore: registered new inte**ce driver cpia1
cpia1: registered
usbcore: registered new inte**ce driver etoms
etoms: registered
usbcore: registered new inte**ce driver finepix
finepix: registered
usbcore: registered new inte**ce driver jeilinj
jeilinj: registered
usbcore: registered new inte**ce driver mars
mars: registered
usbcore: registered new inte**ce driver mr97310a
mr97310a: registered
usbcore: registered new inte**ce driver ov519
ov519: registered
usbcore: registered new inte**ce driver ov534
ov534: registered
usbcore: registered new inte**ce driver ov534_9
ov534_9: registered
usbcore: registered new inte**ce driver pac207
pac207: registered
usbcore: registered new inte**ce driver pac7302
pac7302: registered
usbcore: registered new inte**ce driver pac7311
pac7311: registered
usbcore: registered new inte**ce driver sn9c2028
sn9c2028: registered
usbcore: registered new inte**ce driver sn9c20x
sn9c20x: registered
usbcore: registered new inte**ce driver sonixb
sonixb: registered
usbcore: registered new inte**ce driver sonixj
sonixj: registered
usbcore: registered new inte**ce driver spca500
spca500: registered
usbcore: registered new inte**ce driver spca501
spca501: registered
usbcore: registered new inte**ce driver spca505
spca505: registered
usbcore: registered new inte**ce driver spca506
spca506: registered
usbcore: registered new inte**ce driver spca508
spca508: registered
usbcore: registered new inte**ce driver spca561
spca561: registered
usbcore: registered new inte**ce driver spca1528
spca1528: registered
usbcore: registered new inte**ce driver sq905
sq905: registered
usbcore: registered new inte**ce driver sq905c
sq905c: registered
usbcore: registered new inte**ce driver sq930x
sq930x: registered
usbcore: registered new inte**ce driver sunplus
sunplus: registered
usbcore: registered new inte**ce driver stk014
stk014: registered
usbcore: registered new inte**ce driver stv0680
stv0680: registered
usbcore: registered new inte**ce driver t613
t613: registered
usbcore: registered new inte**ce driver tv8532
tv8532: registered
usbcore: registered new inte**ce driver vc032x
vc032x: registered
usbcore: registered new inte**ce driver zc3xx
zc3xx: registered
usbcore: registered new inte**ce driver ALi m5602
ALi m5602: registered
usbcore: registered new inte**ce driver STV06xx
STV06xx: registered
gspca_gl860: driver startup - version 0.9d10
usbcore: registered new inte**ce driver gspca_gl860
gspca_gl860: driver registered
s3c-fimc: info ov965x_init
cym s3c_mfc_mememap: addr:55af9000 size:1138688
S3C6400 MFC Driver, (c) 2007 Samsung Electronics
S3C PostProcessor Driver v3.12, (c) 2009 Samsung Electronics
S3C6410 TV encoder Driver, (c) 2008 Samsung Electronics
S3C6410 TV scaler Driver, (c) 2008 Samsung Electronics
S3C Rotator Driver, (c) 2008 Samsung Electronics
s3c_rotator_probe called
S3C JPEG Driver, (c) 2007 Samsung Electronics
s3c_g2d_probe called
s3c_g2d_probe Success
S3C G3D Driver, (c) 2007-2009 Samsung Electronics
S3C CMM Driver, (c) 2008 Samsung Electronics
usbcore: registered new inte**ce driver uvcvideo
USB Video Class driver (v0.1.0)
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
s3c-sdhci s3c-sdhci.1: clock source 2: mmc_bus (24000000 Hz)
usbhid: USB HID core driver
mmc0: new SDHC card at address 0007
mmcblk0: mmc0:0007 SD8GB 7.42 GiB
mmcblk0: p1
asoc: wm9713-hifi <-> samsung-ac97 mapping ok
ALSA device list:
  #0: smdk6410
TCP cubic registered
s3c-rtc s3c64xx-rtc: setting system clock to 2003-01-21 00:11:30 UTC (1043107890)
yaffs: passed flags ""
devtmpfs: error mounting -2
Freeing init memory: 176K
[<c003aca8>] (unwind_backtrace+0x0/0xfc) from [<c04a7f2c>] (dump_stack+0x18/0x1c)
[<c04a7f2c>] (dump_stack+0x18/0x1c) from [<c04a7f90>] (panic+0x60/0x1ac)
[<c04a7f90>] (panic+0x60/0x1ac) from [<c00345dc>] (init_post+0xc8/0x140)
[<c00345dc>] (init_post+0xc8/0x140) from [<c00084c8>] (kernel_init+0xf4/0x130)
[<c00084c8>] (kernel_init+0xf4/0x130) from [<c0035a34>] (kernel_thread_exit+0x0/0x8)
发表于 2018-3-28 14:47:48 | 显示全部楼层
    看您的信息是内核崩溃了,怀疑是烧写的镜像与开发板不对应,请确认您的ram的容量,128的与256的文件系统是不一样的,镜像可以试一下如下链接中的镜像:
http://bbs.witech.com.cn/forum.p ... &extra=page%3D1
使用OK6410-B光盘资料下载(256M内存版)
GMT+8, 2026-10-4 12:20
