查看: 9517|回复: 1
[Linux] OKMX6UL-C(eMMC)SD卡启动失败
发表于 2018-4-4 10:34:37 | 显示全部楼层 |阅读模式
参考教程,将OKMX6UL-C(eMMC&Nand版)用户资料-20180102\Linux\tools\SD\启动\emmc\createSdcard-sdrun.tar.bz2加载到飞凌下载的虚拟机制作SD卡启动盘。整个过程没有出现异常
var/www/cgi-bin/test_cgi
version.txt
Buring th u-boot.imx to sdcard
129+0 records in
129+0 records out
132096 bytes (132 kB) copied, 0.260837 s, 506 kB/s
319+0 records in
319+0 records out
326656 bytes (327 kB) copied, 0.676397 s, 483 kB/s
Syncing....
Un-mount the partitions
Operation Finished
设置拨码后从SD卡启动时,linux内核挂在启动过程中,启动失败。请帮忙看一下是哪里出了问题?下面是启动log信息。
U-Boot 2015.04-g3989e3c (Dec 13 2017 - 16:33:25)
CPU:   Freescale i.MX6UL rev1.2 at 396 MHz
CPU:   Temperature 39 C
Reset cause: POR
Board: MX6UL 14x14 EVK
I2C:   ready
DRAM:  512 MiB
Display: TFT70AB (800x480)
Video: 800x480x24
Error: no valid bmp image at 83800000 cfb_console.c
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc0 is current device
Net:   FEC0
Error: FEC0 address not set.
Normal Boot
reading boot.scr
update firmware.........
reading /bin/zImage
6394952 bytes read in 360 ms (16.9 MiB/s)
reading /bin/imx6ul-14x14-evk.dtb
38342 bytes read in 24 ms (1.5 MiB/s)
Kernel image @ 0x80800000 [ 0x000000 - 0x619448 ]
## Flattened Device Tree blob at 83000000
   Booting using the fdt blob at 0x83000000
   Using Device Tree in place at 83000000, end 8300c5c5
Starting kernel ...
[    0.000000] Linux version 3.14.38-6UL_ga-00004-gc2cfa49 (hyj@developer-RH2485-V2) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #1 SMP PREEMPT Fri Dec 15 09:41:48 CST 2017
[    0.000000] Machine model: Freescale i.MX6 UltraLite 14x14 EVK Board
[    0.000000] cma: CMA: reserved 320 MiB at 8c000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] PERCPU: Embedded 8 pages/cpu @8bb3e000 s8832 r8192 d15744 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 125952
[    0.000000] Kernel command line: console=ttymxc0,115200 cma=320M root=/dev/mmcblk0p2
[    0.000000] Memory: 162936K/507904K available (7869K kernel code, 485K rwdata, 2780K rodata, 396K init, 433K bss, 344968K reserved, 0K highmem)
[    0.000000]     vmalloc : 0xa0800000 - 0xff000000   (1512 MB)
[    0.000000]     lowmem  : 0x80000000 - 0xa0000000   ( 512 MB)
[    0.000000]     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
[    0.000000]     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
[    0.000000]       .text : 0x80008000 - 0x80a6e630   (10650 kB)
[    0.000000]       .init : 0x80a6f000 - 0x80ad2280   ( 397 kB)
[    0.000000]       .data : 0x80ad4000 - 0x80b4d720   ( 486 kB)
[    0.000000]        .bss : 0x80b4d72c - 0x80bb9cb4   ( 434 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Switching to timer-based delay loop
[    0.000017] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
[    0.002592] clocksource_of_init: no matching clocksources found
[    0.002960] Console: colour dummy device 80x30
[    0.003007] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[    0.003040] pid_max: default: 32768 minimum: 301
[    0.003428] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.003457] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.004995] Initializing cgroup subsys net_cls
[    0.005084] CPU: Testing write buffer coherency: ok
[    0.005591] /cpus/cpu@0 missing clock-frequency property
[    0.005631] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005689] Setting up static identity map for 0x80778350 - 0x807783a8
[    0.040755] Brought up 1 CPUs
[    0.040790] SMP: Total of 1 processors activated (6.00 BogoMIPS).
[    0.040807] CPU: All CPU(s) started in SVC mode.
[    0.042127] devtmpfs: initialized
[    0.052526] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.053315] pinctrl core: initialized pinctrl subsystem
[    0.054222] regulator-dummy: no parameters
[    0.077918] NET: Registered protocol family 16
[    0.094360] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.095979] cpuidle: using governor ladder
[    0.096007] cpuidle: using governor menu
[    0.096315] Use WDOG1 as reset source
[    0.114876] syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
[    0.115591] vdd3p0: 2625 <--> 3400 mV at 3000 mV
[    0.116498] cpu: 725 <--> 1450 mV at 1150 mV
[    0.117375] vddsoc: 725 <--> 1450 mV at 1175 mV
[    0.122816] syscon 20e4000.iomuxc-gpr: regmap [mem 0x020e4000-0x020e7fff] registered
[    0.129909] syscon 21ac000.romcp: regmap [mem 0x021ac000-0x021affff] registered
[    0.131494] syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
[    0.139038] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.139068] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.143137] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[    0.145926] 20dc000.gpc supply pu not found, using dummy regulator
[    0.181357] bio: create slab <bio-0> at 0
[    0.188044] mxs-dma 1804000.dma-apbh: initialized
[    0.189036] can-3v3: 3300 mV
[    0.189622] VSD_3V3: 3300 mV
[    0.190409] usb_otg1_vbus: 5000 mV
[    0.190979] vref-3v3: 3300 mV
[    0.192533] gpio_dvfs: 1300 <--> 1400 mV at 1400 mV
[    0.193847] i2c-core: driver [max17135] using legacy suspend method
[    0.193872] i2c-core: driver [max17135] using legacy resume method
[    0.195136] SCSI subsystem initialized
[    0.196378] usbcore: registered new inte**ce driver usbfs
[    0.196549] usbcore: registered new inte**ce driver hub
[    0.196876] usbcore: registered new device driver usb
[    0.201864] i2c i2c-0: IMX I2C adapter registered
[    0.204377] i2c i2c-1: IMX I2C adapter registered
[    0.204673] Linux video capture inte**ce: v2.00
[    0.204864] pps_core: LinuxPPS API ver. 1 registered
[    0.204884] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.204969] PTP clock support registered
[    0.207749] MIPI CSI2 driver module loaded
[    0.208304] Advanced Linux Sound Architecture Driver Initialized.
[    0.210316] Bluetooth: Core ver 2.18
[    0.210451] NET: Registered protocol family 31
[    0.210472] Bluetooth: HCI device and connection manager initialized
[    0.210512] Bluetooth: HCI socket layer initialized
[    0.210543] Bluetooth: L2CAP socket layer initialized
[    0.210647] Bluetooth: SCO socket layer initialized
[    0.212554] Switched to clocksource mxc_timer1
[    0.214422] cfg80211: Calling CRDA to update world regulatory domain
[    0.238160] NET: Registered protocol family 2
[    0.240151] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.240277] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[    0.240435] TCP: Hash tables configured (established 4096 bind 4096)
[    0.240559] TCP: reno registered
[    0.240594] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.240653] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.241250] NET: Registered protocol family 1
[    0.242005] RPC: Registered named UNIX socket transport module.
[    0.242035] RPC: Registered udp transport module.
[    0.242055] RPC: Registered tcp transport module.
[    0.242073] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.245016] imx rpmsg driver is registered.
[    0.246626] Bus freq driver module loaded
[    0.248610] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.270672] VFS: Disk quotas dquot_6.5.2
[    0.271379] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.277563] NFS: Registering the id_resolver key type
[    0.277694] Key type id_resolver registered
[    0.277718] Key type id_legacy registered
[    0.277810] jffs2: version 2.2. (NAND) &#169; 2001-2006 Red Hat, Inc.
[    0.279688] fuse init (API version 7.22)
[    0.280912] msgmni has been set to 958
[    0.289301] io scheduler noop registered
[    0.289332] io scheduler deadline registered
[    0.289836] io scheduler cfq registered (default)
[    0.290892] imx-weim 21b8000.weim: Driver registered.
[    0.296951] backlight.9 supply power not found, using dummy regulator
[    0.300150] MIPI DSI driver module loaded
[    0.304673] 21c8000.lcdif supply lcd not found, using dummy regulator
[    0.305076] mxsfb 21c8000.lcdif: failed to find mxc display driver
[    0.305836] mxsfb 21c8000.lcdif: initialized
[    0.313721] imx-sdma 20ec000.sdma: no event needs to be remapped
[    0.313927] imx-sdma 20ec000.sdma: loaded firmware 3.1
[    0.321950] imx-sdma 20ec000.sdma: initialized
[    0.323642] Serial: IMX driver
[    0.324280] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58, base_baud = 5000000) is a IMX
[    1.065273] console [ttymxc0] enabled
[    1.070764] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59, base_baud = 5000000) is a IMX
[    1.080691] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60, base_baud = 5000000) is a IMX
[    1.090346] serial: Freescale lpuart driver
[    1.098511] imx sema4 driver is registered.
[    1.102975] [drm] Initialized drm 1.1.0 20060810
[    1.108709] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[    1.136633] brd: module loaded
[    1.151432] loop: module loaded
[    1.158476] spi_gpio spi4.15: gpio-miso property not found, switching to no-rx mode
[    1.170602] CAN device driver inte**ce
[    1.178052] flexcan 2090000.can: device registered (reg_base=a0968000, irq=142)
[    1.188225] flexcan 2094000.can: device registered (reg_base=a0970000, irq=143)
[    1.197804] 20b4000.ethernet supply phy not found, using dummy regulator
[    1.205958] pps pps0: new PPS source ptp0
[    1.210476] fec 20b4000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
[    1.219637] fec 20b4000.ethernet (unregistered net_device): Using random MAC address: 62:a3:20:90:c1:81
[    1.229826] libphy: fec_enet_mii_bus: probed
[    1.237995] fec 20b4000.ethernet eth0: registered PHC device 0
[    1.245690] 2188000.ethernet supply phy not found, using dummy regulator
[    1.253787] pps pps1: new PPS source ptp1
[    1.258215] fec 2188000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
[    1.267418] fec 2188000.ethernet (unregistered net_device): Using random MAC address: ca:44:70:18:35:d0
[    1.278953] fec 2188000.ethernet eth1: registered PHC device 1
[    1.286597] PPP generic driver version 2.4.2
[    1.291404] PPP BSD Compression module registered
[    1.296289] PPP Deflate Compression module registered
[    1.301587] usbcore: registered new inte**ce driver asix
[    1.307233] usbcore: registered new inte**ce driver cdc_ether
[    1.313294] usbcore: registered new inte**ce driver cdc_eem
[    1.319211] usbcore: registered new inte**ce driver cdc_ncm
[    1.324957] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.331512] ehci-mxc: Freescale On-Chip EHCI Host driver
[    1.337319] usbcore: registered new inte**ce driver usb-storage
[    1.343748] usbcore: registered new inte**ce driver usbserial
[    1.349720] usbcore: registered new inte**ce driver usbserial_generic
[    1.356436] usbserial: USB Serial support registered for generic
[    1.362649] usbcore: registered new inte**ce driver ftdi_sio
[    1.368530] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.376019] usbcore: registered new inte**ce driver option
[    1.381731] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.388872] usbcore: registered new inte**ce driver pl2303
[    1.394606] usbserial: USB Serial support registered for pl2303
[    1.400696] usbcore: registered new inte**ce driver cdc_xr_usb_serial
[    1.407289] xr_usb_serial_common: Exar USB UART (serial port) driver
[    1.413827] usbcore: registered new inte**ce driver usb_ehset_test
[    1.422426] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[    1.438810] 2184200.usb supply vbus not found, using dummy regulator
[    1.449086] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    1.454137] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[    1.472652] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    1.480143] hub 1-0:1.0: USB hub found
[    1.484126] hub 1-0:1.0: 1 port detected
[    1.490364] mousedev: PS/2 mouse device common for all mice
[    1.498112] input: 20cc000.snvs-pwrkey as /devices/soc0/soc.0/2000000.aips-bus/20cc000.snvs-pwrkey/input/input0
[    1.509069] snvs_pwrkey 20cc000.snvs-pwrkey: i.MX snvs powerkey probed
[    1.516602] edt_ft5x06 0-0038: touchscreen probe failed
[    1.521909] edt_ft5x06: probe of 0-0038 failed with error -5
[    1.529810] input: iMX6UL TouchScreen Controller as /devices/virtual/input/input2
[    1.539348] <<-GTP-INFO->> GTP driver installing...
[    1.545083] <<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
[    1.551050] <<-GTP-INFO->> GTP Driver Built@09:41:15, Dec 15 2017
[    1.557293] <<-GTP-INFO->> GTP I2C Address: 0x5d
[    1.562000] 0-005d supply vdd_ana not found, using dummy regulator
[    1.568407] 0-005d supply vcc_i2c not found, using dummy regulator
[    1.574770] <<-GTP-INFO->> Guitar reset
[    1.703686] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    1.711742] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
[    1.719990] <<-GTP-INFO->> Guitar reset
[    1.802669] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[    1.843669] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    1.850665] <<-GTP-ERROR->> GTP i2c test failed time 1.
[    1.873621] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
[    1.881825] <<-GTP-INFO->> Guitar reset
[    1.954963] hub 1-1:1.0: USB hub found
[    1.958955] hub 1-1:1.0: 4 ports detected
[    2.003703] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    2.010708] <<-GTP-ERROR->> GTP i2c test failed time 2.
[    2.033646] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
[    2.041850] <<-GTP-INFO->> Guitar reset
[    2.163655] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    2.170655] <<-GTP-ERROR->> GTP i2c test failed time 3.
[    2.193585] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
[    2.201788] <<-GTP-INFO->> Guitar reset
[    2.323632] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    2.330622] <<-GTP-ERROR->> GTP i2c test failed time 4.
[    2.353639] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
[    2.361844] <<-GTP-INFO->> Guitar reset
[    2.483623] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    2.490614] <<-GTP-ERROR->> GTP i2c test failed time 5.
[    2.512590] <<-GTP-ERROR->> I2C communication ERROR!
[    2.517632] goodix-ts: probe of 0-005d failed with error -5
[    2.523631] i2c-core: driver [isl29023] using legacy suspend method
[    2.529934] i2c-core: driver [isl29023] using legacy resume method
[    2.539932] rtc-rx8010 0-0032: Update timer was detected
[    2.548246] rtc-rx8010 0-0032: rtc core: registered rx8010 as rtc0
[    2.555971] snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc1
[    2.564686] i2c /dev entries driver
[    2.569436] IR NEC protocol handler initialized
[    2.574086] IR RC5(x) protocol handler initialized
[    2.578905] IR RC6 protocol handler initialized
[    2.583497] IR JVC protocol handler initialized
[    2.588055] IR Sony protocol handler initialized
[    2.592724] IR RC5 (streamzap) protocol handler initialized
[    2.598322] IR SANYO protocol handler initialized
[    2.603076] IR MCE Keyboard/mouse protocol handler initialized
[    2.611831] pxp-v4l2 pxp_v4l2.10: initialized
[    2.616709] usbcore: registered new inte**ce driver uvcvideo
[    2.622490] USB Video Class driver (1.1.1)
[    2.627759] i2c-core: driver [mag3110] using legacy suspend method
[    2.634053] i2c-core: driver [mag3110] using legacy resume method
[    2.641277] imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
[    2.649915] Bluetooth: HCI UART driver ver 2.2
[    2.654455] Bluetooth: HCI H4 protocol initialized
[    2.659277] Bluetooth: HCI BCSP protocol initialized
[    2.664299] Bluetooth: HCIATH3K protocol initialized
[    2.669512] usbcore: registered new inte**ce driver bcm203x
[    2.675445] usbcore: registered new inte**ce driver btusb
[    2.681143] usbcore: registered new inte**ce driver ath3k
[    2.686912] usbcore: registered new inte**ce driver rtk_btusb
[    2.693422] sdhci: Secure Digital Host Controller Inte**ce driver
[    2.699638] sdhci: Copyright(c) Pierre Ossman
[    2.704076] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.712285] mmc0: no vqmmc regulator found
[    2.762627] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[    2.774335] mmc1: no vqmmc regulator found
[    2.778485] mmc1: no vmmc regulator found
[    2.832605] mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[    2.844408] fsl-quadspi 21e0000.qspi: unrecognized JEDEC id ffffff
[    2.850743] fsl-quadspi 21e0000.qspi: Freescale QuadSPI probe failed
[    2.865696] mmc0: host does not support reading read-only switch. assuming write-enable.
[    2.874416] usbcore: registered new inte**ce driver usbhid
[    2.880025] usbhid: USB HID core driver
[    2.894478] mmc0: new high speed SDHC card at address aaaa
[    2.901340] mmcblk0: mmc0:aaaa SU04G 3.69 GiB
[    2.909444]  mmcblk0: p1 p2
[    2.916831] fsl-asrc 2034000.asrc: driver registered
[    2.944937] snd-soc-dummy snd-soc-dummy: ASoC: Failed to create platform debugfs directory
[    2.961015] imx-wm8960 sound.14: wm8960-hifi <-> 202c000.sai mapping ok
[    2.983072] imx-wm8960 sound.14: snd-soc-dummy-dai <-> 2034000.asrc mapping ok
[    2.993782] imx-wm8960 sound.14: wm8960-hifi <-> 202c000.sai mapping ok
[    3.014704] NET: Registered protocol family 26
[    3.019210] Netfilter messages via NETLINK v0.30.
[    3.024270] nfnl_acct: registering with nfnetlink.
[    3.029337] nf_conntrack version 0.5.0 (7665 buckets, 30660 max)
[    3.038446] ctnetlink v0.93: registering with nfnetlink.
[    3.044284] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
[    3.050969] mmc1: BKOPS_EN bit is not set
[    3.055099] nf_tables_compat: (c) 2012 Pablo Neira Ayuso <pablo@netfilter.org>
[    3.064097] xt_time: kernel timezone is -0000
[    3.070476] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.080652] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
[    3.089426] arp_tables: (C) 2002 David S. Miller
[    3.097645] TCP: cubic registered
[    3.103774] mmc1: new high speed DDR MMC card at address 0001
[    3.110883] NET: Registered protocol family 10
[    3.115606] mmcblk1: mmc1:0001 Q2J54A 3.64 GiB
[    3.123511] sit: IPv6 over IPv4 tunneling driver
[    3.130052] NET: Registered protocol family 17
[    3.134812] mmcblk1boot0: mmc1:0001 Q2J54A partition 1 2.00 MiB
[    3.141108] mmcblk1boot1: mmc1:0001 Q2J54A partition 2 2.00 MiB
[    3.147288] can: controller area network core (rev 20120528 abi 9)
[    3.154010] mmcblk1rpmb: mmc1:0001 Q2J54A partition 3 512 KiB
[    3.160648] NET: Registered protocol family 29
[    3.168096] can: raw protocol (rev 20120528)
[    3.172418] can: broadcast manager protocol (rev 20120528 t)
[    3.178350] can: netlink gateway (rev 20130117) max_hops=1
[    3.184147]  mmcblk1: p1 p2
[    3.189840] Bluetooth: RFCOMM TTY layer initialized
[    3.198140] Bluetooth: RFCOMM socket layer initialized
[    3.203560] Bluetooth: RFCOMM ver 1.11
[    3.207366] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.212973]  mmcblk1boot1: unknown partition table
[    3.219016] Bluetooth: BNEP filters: protocol multicast
[    3.226277] Bluetooth: BNEP socket layer initialized
[    3.231458]  mmcblk1boot0: unknown partition table
[    3.236386] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[    3.242368] Bluetooth: HIDP socket layer initialized
[    3.248369] 8021q: 802.1Q VLAN Support v1.8
[    3.252883] Key type dns_resolver registered
[    3.258687] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
[    3.286884] gpio_dvfs: disabling
[    3.290164] vref-3v3: disabling
[    3.293445] usb_otg1_vbus: disabling
[    3.297053] can-3v3: disabling
[    3.300133] regulator-dummy: disabling
[    3.304987] imx mcc test is registered.
[    3.310907] rtc-rx8010 0-0032: setting system clock to 1970-01-01 15:17:47 UTC (55067)
[    3.337924] ALSA device list:
[    3.340939]   #0: wm8960-audio
[    3.355404] EXT3-fs (mmcblk0p2): recovery required on readonly filesystem
[    3.362224] EXT3-fs (mmcblk0p2): write access will be enabled during recovery
[    5.369290] kjournald starting.  Commit interval 5 seconds
[    5.379351] EXT3-fs (mmcblk0p2): recovery complete
[    5.385133] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[    5.392108] VFS: Mounted root (ext3 filesystem) readonly on device 179:2.
[    5.401561] devtmpfs: mounted
[    5.406016] Freeing unused kernel memory: 396K (80a6f000 - 80ad2000)
Mounting /proc and /sys
Starting the hotplug events dispatcher udevd
Synthesizing initial hotplug even[    5.777506] udevd (107): /proc/107/oom_adj is deprecated, please use /proc/107/oom_score_adj instead.
ts
[    9.347315] random: nonblocking pool is initialized
[    9.477976] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Setting the hostname to freescale
Running depmod
depmod: can't change directory to '3.14.38-6UL_ga-00004-gc2cfa49': No such file or directory
Mounting filesystems
[   10.548474] EXT3-fs (mmcblk0p2): using internal journal
Starting inetd:
Starting syslogd and klogd
[   10.843924] flexcan 2090000.can can0: writing ctrl=0x0e312085
[   10.873766] flexcan 2094000.can can1: writing ctrl=0x0e312085
Reconfiguring network inte**ces... ifdown: inte**ce eth1 not configured
[   11.203542] fec 20b4000.ethernet eth0: Freescale FEC PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=20b4000.ethernet:01, irq=-1)
[   11.253282] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   11.413430] fec 2188000.ethernet eth1: Freescale FEC PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=20b4000.ethernet:02, irq=-1)
[   11.463243] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
RTNETLINK answers: File exists
done.
alsactl: parse:1655: Unable to open file '/data0/imx6_linux/alsa/tmp/share/alsa/init/00main': No such file or directory
alsactl: set_control:1267: failed to obtain info for control #55 (No such file or directory)
[   11.693447] Trying to free nonexistent resource <0000000087b00000-0000000087c76fff>
xres = 800, yres = 480
发表于 2018-4-14 09:55:37 | 显示全部楼层
    开发板启动已经完成了,启动没有问题
这句信息是卡在校准界面,接个屏幕校准一下或者在uboot菜单处选择跳过校准即可
GMT+8, 2026-10-4 15:20
