查看: 20011|回复: 10
[Linux] 在imx6ul上SD烧写系统到NAND FLASH不成功
i.MX8MM通行证i.MX6UL通行证i.MX6Q通行证
发表于 2018-5-18 17:02:16 | 显示全部楼层 |阅读模式
U-Boot 2015.04-g3989e3c (Dec 14 2017 - 19:11:47)
CPU:   Freescale i.MX6UL rev1.1 at 396 MHz
CPU:   Temperature 40 C
Reset cause: POR
Board: MX6UL 14x14 EVK
I2C:   ready
DRAM:  256 MiB
Display: TFT70AB (800x480)
Video: 800x480x24
Error: no valid bmp image at 83800000 cfb_console.c
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc0 is current device
Net:   Phy 2 not found
PHY reset timed out
FEC0
Error: FEC0 address not set.
Normal Boot
reading boot.scr
update emmc.........
reading /bin/zImage
6219672 bytes read in 567 ms (10.5 MiB/s)
reading /bin/ramdisk.img.u
8158014 bytes read in 736 ms (10.6 MiB/s)
reading /bin/imx6ul-14x14-evk.dtb
38346 bytes read in 24 ms (1.5 MiB/s)
Kernel image @ 0x80800000 [ 0x000000 - 0x5ee798 ]
## Loading init Ramdisk from Legacy Image at 83800000 ...
   Image Name:   ramdisk
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    8157950 Bytes = 7.8 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 83000000
   Booting using the fdt blob at 0x83000000
   Using Device Tree in place at 83000000, end 8300c5c9
Starting kernel ...
[    0.000000] Linux version 3.14.38-6UL_ga-gd42029a (liyue@developer-RH2485-V2) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #2 SMP PREEMPT Tue Aug 8 08:24:30 CST 2017
[    0.000000] Machine model: Freescale i.MX6 UltraLite 14x14 EVK Board
[    0.000000] cma: CMA: reserved 64 MiB at 8c000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] PERCPU: Embedded 8 pages/cpu @8bdbf000 s8320 r8192 d16256 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
[    0.000000] Kernel command line: console=ttymxc0,115200 cma=64M rdinit=/linuxrc
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 174440K/262144K available (7657K kernel code, 452K rwdata, 2696K rodata, 388K init, 433K bss, 87704K reserved, 0K highmem)
[    0.000000]     vmalloc : 0x90800000 - 0xff000000   (1768 MB)
[    0.000000]     lowmem  : 0x80000000 - 0x90000000   ( 256 MB)
[    0.000000]     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
[    0.000000]     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
[    0.000000]       .text : 0x80008000 - 0x80a247f0   (10354 kB)
[    0.000000]       .init : 0x80a25000 - 0x80a86080   ( 389 kB)
[    0.000000]       .data : 0x80a88000 - 0x80af9040   ( 453 kB)
[    0.000000]        .bss : 0x80af904c - 0x80b655a4   ( 434 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Switching to timer-based delay loop
[    0.000017] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
[    0.002602] clocksource_of_init: no matching clocksources found
[    0.002966] Console: colour dummy device 80x30
[    0.003010] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[    0.003043] pid_max: default: 32768 minimum: 301
[    0.003454] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.003481] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.005280] CPU: Testing write buffer coherency: ok
[    0.005795] /cpus/cpu@0 missing clock-frequency property
[    0.005832] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005891] Setting up static identity map for 0x80745358 - 0x807453b0
[    0.040749] Brought up 1 CPUs
[    0.040784] SMP: Total of 1 processors activated (6.00 BogoMIPS).
[    0.040801] CPU: All CPU(s) started in SVC mode.
[    0.041777] devtmpfs: initialized
[    0.051990] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.052747] pinctrl core: initialized pinctrl subsystem
[    0.053662] regulator-dummy: no parameters
[    0.058848] NET: Registered protocol family 16
[    0.075332] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.076963] cpuidle: using governor ladder
[    0.076992] cpuidle: using governor menu
[    0.077275] Use WDOG1 as reset source
[    0.095411] syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
[    0.096114] vdd3p0: 2625 <--> 3400 mV at 3000 mV
[    0.096970] cpu: 725 <--> 1450 mV at 1150 mV
[    0.097848] vddsoc: 725 <--> 1450 mV at 1175 mV
[    0.103025] syscon 20e4000.iomuxc-gpr: regmap [mem 0x020e4000-0x020e7fff] registered
[    0.109605] syscon 21ac000.romcp: regmap [mem 0x021ac000-0x021affff] registered
[    0.111186] syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
[    0.118596] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.118626] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.122646] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[    0.125390] 20dc000.gpc supply pu not found, using dummy regulator
[    0.157363] bio: create slab <bio-0> at 0
[    0.164043] mxs-dma 1804000.dma-apbh: initialized
[    0.165004] can-3v3: 3300 mV
[    0.165553] VSD_3V3: 3300 mV
[    0.166315] usb_otg1_vbus: 5000 mV
[    0.166886] vref-3v3: 3300 mV
[    0.168181] gpio_dvfs: 1300 <--> 1400 mV at 1400 mV
[    0.169465] i2c-core: driver [max17135] using legacy suspend method
[    0.169490] i2c-core: driver [max17135] using legacy resume method
[    0.170729] SCSI subsystem initialized
[    0.172051] usbcore: registered new inte**ce driver usbfs
[    0.172249] usbcore: registered new inte**ce driver hub
[    0.172570] usbcore: registered new device driver usb
[    0.177384] i2c i2c-0: IMX I2C adapter registered
[    0.179867] i2c i2c-1: IMX I2C adapter registered
[    0.180177] Linux video capture inte**ce: v2.00
[    0.180373] pps_core: LinuxPPS API ver. 1 registered
[    0.180394] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.180458] PTP clock support registered
[    0.183166] MIPI CSI2 driver module loaded
[    0.183748] Advanced Linux Sound Architecture Driver Initialized.
[    0.185711] Bluetooth: Core ver 2.18
[    0.185835] NET: Registered protocol family 31
[    0.185857] Bluetooth: HCI device and connection manager initialized
[    0.185895] Bluetooth: HCI socket layer initialized
[    0.185925] Bluetooth: L2CAP socket layer initialized
[    0.186032] Bluetooth: SCO socket layer initialized
[    0.187011] cfg80211: Calling CRDA to update world regulatory domain
[    0.187887] Switched to clocksource mxc_timer1
[    0.212878] NET: Registered protocol family 2
[    0.214845] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[    0.214937] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[    0.215029] TCP: Hash tables configured (established 2048 bind 2048)
[    0.215148] TCP: reno registered
[    0.215182] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.215242] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.215835] NET: Registered protocol family 1
[    0.216581] RPC: Registered named UNIX socket transport module.
[    0.216609] RPC: Registered udp transport module.
[    0.216627] RPC: Registered tcp transport module.
[    0.216643] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.217164] Trying to unpack rootfs image as initramfs...
[    1.643124] Freeing initrd memory: 7960K (83801000 - 83fc7000)
[    1.645308] imx rpmsg driver is registered.
[    1.646910] Bus freq driver module loaded
[    1.649095] futex hash table entries: 256 (order: 2, 16384 bytes)
[    1.667498] VFS: Disk quotas dquot_6.5.2
[    1.668318] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.674214] NFS: Registering the id_resolver key type
[    1.674320] Key type id_resolver registered
[    1.674341] Key type id_legacy registered
[    1.674424] jffs2: version 2.2. (NAND) &#169; 2001-2006 Red Hat, Inc.
[    1.676285] fuse init (API version 7.22)
[    1.677509] msgmni has been set to 484
[    1.685600] io scheduler noop registered
[    1.685633] io scheduler deadline registered
[    1.686112] io scheduler cfq registered (default)
[    1.687124] imx-weim 21b8000.weim: Driver registered.
[    1.692849] backlight.9 supply power not found, using dummy regulator
[    1.696069] MIPI DSI driver module loaded
[    1.700562] 21c8000.lcdif supply lcd not found, using dummy regulator
[    1.705927] mxsfb 21c8000.lcdif: failed to find mxc display driver
[    1.715837] Console: switching to colour frame buffer device 100x30
[    1.722967] mxsfb 21c8000.lcdif: initialized
[    1.730555] imx-sdma 20ec000.sdma: no event needs to be remapped
[    1.730766] imx-sdma 20ec000.sdma: loaded firmware 3.1
[    1.738781] imx-sdma 20ec000.sdma: initialized
[    1.740225] Serial: IMX driver
[    1.740885] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58, base_baud = 5000000) is a IMX
[    2.493690] console [ttymxc0] enabled
[    2.499110] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59, base_baud = 5000000) is a IMX
[    2.509117] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60, base_baud = 5000000) is a IMX
[    2.518790] serial: Freescale lpuart driver
[    2.526763] imx sema4 driver is registered.
[    2.531260] [drm] Initialized drm 1.1.0 20060810
[    2.537049] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[    2.564620] brd: module loaded
[    2.579291] loop: module loaded
[    2.585974] spi_gpio spi4.15: gpio-miso property not found, switching to no-rx mode
[    2.604726] CAN device driver inte**ce
[    2.612093] flexcan 2090000.can: device registered (reg_base=90970000, irq=142)
[    2.622159] flexcan 2094000.can: device registered (reg_base=90978000, irq=143)
[    2.631771] 20b4000.ethernet supply phy not found, using dummy regulator
[    2.639860] pps pps0: new PPS source ptp0
[    2.644423] fec 20b4000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
[    2.653648] fec 20b4000.ethernet (unregistered net_device): Using random MAC address: 0e:bf:e7:70:dd:e1
[    2.663844] libphy: fec_enet_mii_bus: probed
[    2.670052] fec 20b4000.ethernet eth0: registered PHC device 0
[    2.677538] 2188000.ethernet supply phy not found, using dummy regulator
[    2.685567] pps pps1: new PPS source ptp1
[    2.690116] fec 2188000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
[    2.699242] fec 2188000.ethernet (unregistered net_device): Using random MAC address: 92:a6:c2:7e:13:67
[    2.710707] fec 2188000.ethernet eth1: registered PHC device 1
[    2.718304] PPP generic driver version 2.4.2
[    2.723133] PPP BSD Compression module registered
[    2.727967] PPP Deflate Compression module registered
[    2.733236] usbcore: registered new inte**ce driver asix
[    2.738853] usbcore: registered new inte**ce driver cdc_ether
[    2.744836] usbcore: registered new inte**ce driver cdc_eem
[    2.750802] usbcore: registered new inte**ce driver cdc_ncm
[    2.756494] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.763087] ehci-mxc: Freescale On-Chip EHCI Host driver
[    2.768937] usbcore: registered new inte**ce driver usb-storage
[    2.775301] usbcore: registered new inte**ce driver usbserial
[    2.781351] usbcore: registered new inte**ce driver usbserial_generic
[    2.788059] usbserial: USB Serial support registered for generic
[    2.794198] usbcore: registered new inte**ce driver ftdi_sio
[    2.800115] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.807551] usbcore: registered new inte**ce driver option
[    2.813287] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.820411] usbcore: registered new inte**ce driver pl2303
[    2.826127] usbserial: USB Serial support registered for pl2303
[    2.832286] usbcore: registered new inte**ce driver cdc_xr_usb_serial
[    2.838886] xr_usb_serial_common: Exar USB UART (serial port) driver
[    2.845390] usbcore: registered new inte**ce driver usb_ehset_test
[    2.853983] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[    2.869024] 2184200.usb supply vbus not found, using dummy regulator
[    2.879211] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    2.884196] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[    2.908064] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    2.915535] hub 1-0:1.0: USB hub found
[    2.919516] hub 1-0:1.0: 1 port detected
[    2.925747] mousedev: PS/2 mouse device common for all mice
[    2.933456] input: 20cc000.snvs-pwrkey as /devices/soc0/soc.0/2000000.aips-bus/20cc000.snvs-pwrkey/input/input0
[    2.944328] snvs_pwrkey 20cc000.snvs-pwrkey: i.MX snvs powerkey probed
[    2.951839] edt_ft5x06 0-0038: touchscreen probe failed
[    2.957141] edt_ft5x06: probe of 0-0038 failed with error -5
[    2.964943] input: iMX6UL TouchScreen Controller as /devices/virtual/input/input2
[    2.974506] <<-GTP-INFO->> GTP driver installing...
[    2.980202] <<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
[    2.986164] <<-GTP-INFO->> GTP Driver Built@17:24:12, Aug  7 2017
[    2.992399] <<-GTP-INFO->> GTP I2C Address: 0x5d
[    2.997099] 0-005d supply vdd_ana not found, using dummy regulator
[    3.003476] 0-005d supply vcc_i2c not found, using dummy regulator
[    3.009877] <<-GTP-INFO->> Guitar reset
[    3.139035] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    3.147106] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
[    3.155345] <<-GTP-INFO->> Guitar reset
[    3.278986] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    3.285973] <<-GTP-ERROR->> GTP i2c test failed time 1.
[    3.309040] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
[    3.317240] <<-GTP-INFO->> Guitar reset
[    3.438988] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    3.445975] <<-GTP-ERROR->> GTP i2c test failed time 2.
[    3.468976] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
[    3.477175] <<-GTP-INFO->> Guitar reset
[    3.598982] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    3.605968] <<-GTP-ERROR->> GTP i2c test failed time 3.
[    3.628956] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
[    3.637154] <<-GTP-INFO->> Guitar reset
[    3.758992] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    3.765978] <<-GTP-ERROR->> GTP i2c test failed time 4.
[    3.789003] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
[    3.797204] <<-GTP-INFO->> Guitar reset
[    3.918977] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    3.925962] <<-GTP-ERROR->> GTP i2c test failed time 5.
[    3.947916] <<-GTP-ERROR->> I2C communication ERROR!
[    3.952942] goodix-ts: probe of 0-005d failed with error -5
[    3.958931] i2c-core: driver [isl29023] using legacy suspend method
[    3.965225] i2c-core: driver [isl29023] using legacy resume method
[    3.972686] rtc-rx8010 0-0032: Unable to write register #23
[    3.978356] i2c i2c-0: probing for rx8010 failed
[    3.983023] rtc-rx8010: probe of 0-0032 failed with error -5
[    3.990102] snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
[    3.998796] i2c /dev entries driver
[    4.003536] IR NEC protocol handler initialized
[    4.008183] IR RC5(x) protocol handler initialized
[    4.012999] IR RC6 protocol handler initialized
[    4.017550] IR JVC protocol handler initialized
[    4.022135] IR Sony protocol handler initialized
[    4.026775] IR RC5 (streamzap) protocol handler initialized
[    4.032395] IR SANYO protocol handler initialized
[    4.037119] IR MCE Keyboard/mouse protocol handler initialized
[    4.045819] pxp-v4l2 pxp_v4l2.10: initialized
[    4.050752] usbcore: registered new inte**ce driver uvcvideo
[    4.056528] USB Video Class driver (1.1.1)
[    4.061752] i2c-core: driver [mag3110] using legacy suspend method
[    4.068036] i2c-core: driver [mag3110] using legacy resume method
[    4.075250] imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
[    4.083875] Bluetooth: HCI UART driver ver 2.2
[    4.088407] Bluetooth: HCI H4 protocol initialized
[    4.093224] Bluetooth: HCI BCSP protocol initialized
[    4.098242] Bluetooth: HCIATH3K protocol initialized
[    4.103443] usbcore: registered new inte**ce driver bcm203x
[    4.109475] usbcore: registered new inte**ce driver btusb
[    4.115161] usbcore: registered new inte**ce driver ath3k
[    4.120906] usbcore: registered new inte**ce driver rtk_btusb
[    4.127324] sdhci: Secure Digital Host Controller Inte**ce driver
[    4.133587] sdhci: Copyright(c) Pierre Ossman
[    4.138002] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.146217] mmc0: no vqmmc regulator found
[    4.187962] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[    4.212796] nand: No NAND device found
[    4.218827] gpmi-nand 1806000.gpmi-nand: driver registration failed: -19
[    4.246092] usbcore: registered new inte**ce driver usbhid
[    4.251887] usbhid: USB HID core driver
[    4.262536] wm8960 1-001a: Failed to issue reset
[    4.267404] wm8960: probe of 1-001a failed with error -5
[    4.275579] fsl-asrc 2034000.asrc: driver registered
[    4.288607] imx-wm8960 sound.14: failed to find codec platform device
[    4.295206] imx-wm8960: probe of sound.14 failed with error -22
[    4.304433] NET: Registered protocol family 26
[    4.309455] TCP: cubic registered
[    4.314423] NET: Registered protocol family 10
[    4.321688] sit: IPv6 over IPv4 tunneling driver
[    4.328345] NET: Registered protocol family 17
[    4.332983] can: controller area network core (rev 20120528 abi 9)
[    4.339510] NET: Registered protocol family 29
[    4.344043] can: raw protocol (rev 20120528)
[    4.348395] can: broadcast manager protocol (rev 20120528 t)
[    4.354102] can: netlink gateway (rev 20130117) max_hops=1
[    4.360581] Bluetooth: RFCOMM TTY layer initialized
[    4.365537] Bluetooth: RFCOMM socket layer initialized
[    4.370914] Bluetooth: RFCOMM ver 1.11
[    4.374717] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.380173] Bluetooth: BNEP filters: protocol multicast
[    4.385533] Bluetooth: BNEP socket layer initialized
[    4.390652] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[    4.396624] Bluetooth: HIDP socket layer initialized
[    4.401769] 8021q: 802.1Q VLAN Support v1.8
[    4.406127] Key type dns_resolver registered
[    4.412130] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
[    4.441825] gpio_dvfs: disabling
[    4.445103] vref-3v3: disabling
[    4.448479] usb_otg1_vbus: disabling
[    4.452181] can-3v3: disabling
[    4.455318] regulator-dummy: disabling
[    4.460135] imx mcc test is registered.
[    4.464894] snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-04 00:44:26 UTC (261866)
[    4.493465] ALSA device list:
[    4.496477]   No soundcards found.
[    4.501244] Freeing unused kernel memory: 388K (80a25000 - 80a86000)
mount: special device /dev/mmcblk0p1 does not exist
flash_erase: error!: /dev/mtd0
             error 2 (No such file or directory)
unable to create a temporary file
flash_erase: error!: /dev/mtd2
flash_erase: error!: /dev/mtd4
nandwrite: error!: /dev/mtd4
flash_erase: error!: /dev/mtd1
nandwrite: error!: /dev/mtd1
[    4.654189] mmc0: host does not support reading read-only switch. assuming write-enable.
[    4.679182] mmc0: new SD card at address e33b
flash_erase: error!: /dev/mtd3
             error 2 (No such [    4.690967] mmcblk0: mmc0:e33b SD01G 982 MiB
file or directory)
nandwrite: error!: /dev/mtd3
[    4.709733]  mmcblk0: p1
flash_erase: error!: /dev/mtd5
mount: special device /dev/mtdblock5 does not exist
tar: can't open '/run/mmc0/system/rootfs.tar.bz2': No such file or directory
umount: /run/nand: not mounted
umount: /run/mmc0: not mounted
Update Complete!!!!!!!
SD烧写系统到NAND FLASH不成功,有谁使用SD烧写系统过没吗?
发表于 2018-5-18 18:00:03 | 显示全部楼层
我这里可以烧写成功,你这个没有找不到nand分区,或者是挂载成功SD卡,建议你重来一遍制作烧写卡,确保卡制作好后sdrun和target目录里的内容,拨码1,4ON,其余OFF烧写。确定做了一边不好使,还不行的话,把target下的设备树换成system下的设备树文件。试试
看log里面一开始去找SD分区没找到 mount: special device /dev/mmcblk0p1 does not exist 但后面SD挂载成功了,感觉就是SD卡挂载没做好  详情 回复 发表于 2018-5-21 09:20
 楼主| 发表于 2018-5-21 09:20:51 | 显示全部楼层
Marss 发表于 2018-5-18 18:00
我这里可以烧写成功,你这个没有找不到nand分区,或者是挂载成功SD卡,建议你重来一遍制作烧写卡,确保卡制 ...
看log里面一开始去找SD分区没找到
 楼主| 发表于 2018-5-21 10:41:35 | 显示全部楼层
我又重新换了一张SD卡去烧写,好像可以烧写了,一开始烧写的时候去擦除NAND FLASH分区出错,后面还把文件系统给烧进去了
U-Boot 2015.04-g3779e6b (Aug 08 2017 - 08:40:55)
CPU:   Temperature 43 C
Reset cause: POR
I2C:   ready
DRAM:  256 MiB
Video: 800x480x24
In:    serial
Out:   serial
Err:   serial
PHY reset timed out
FEC0
Normal Boot
reading boot.scr
reading /bin/zImage
6219672 bytes read in 297 ms (20 MiB/s)
8183417 bytes read in 383 ms (20.4 MiB/s)
38334 bytes read in 30 ms (1.2 MiB/s)
   Image Name:   ramdisk
   Data Size:    8183353 Bytes = 7.8 MiB
   Using Device Tree in place at 83000000, end 8300c5bd
Starting kernel ...
[    0.000000] Memory: 174416K/262144K available (7657K kernel code, 452K rwdata, 2696K rodata, 388K init, 433K bss, 87728K reserved, 0K highmem)
[    0.002793] clocksource_of_init: no matching clocksources found
[    0.003166] Console: colour dummy device 80x30
[    0.003210] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[    0.003244] pid_max: default: 32768 minimum: 301
[    0.003658] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.003688] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.005509] CPU: Testing write buffer coherency: ok
[    0.006020] /cpus/cpu@0 missing clock-frequency property
[    0.006061] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.006119] Setting up static identity map for 0x80745358 - 0x807453b0
[    0.040765] Brought up 1 CPUs
[    0.040800] SMP: Total of 1 processors activated (6.00 BogoMIPS).
[    0.040817] CPU: All CPU(s) started in SVC mode.
[    0.041809] devtmpfs: initialized
[    0.052835] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.053637] pinctrl core: initialized pinctrl subsystem
[    0.054609] regulator-dummy: no parameters
[    0.059863] NET: Registered protocol family 16
[    0.077992] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.079706] cpuidle: using governor ladder
[    0.079738] cpuidle: using governor menu
[    0.080036] Use WDOG1 as reset source
[    0.099099] syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
[    0.099849] vdd3p0: 2625 <--> 3400 mV at 3000 mV
[    0.100749] cpu: 725 <--> 1450 mV at 1150 mV
[    0.101793] vddsoc: 725 <--> 1450 mV at 1175 mV
[    0.107198] syscon 20e4000.iomuxc-gpr: regmap [mem 0x020e4000-0x020e7fff] registered
[    0.114340] syscon 21ac000.romcp: regmap [mem 0x021ac000-0x021affff] registered
[    0.115858] syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
[    0.123860] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.123891] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.128083] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[    0.131019] 20dc000.gpc supply pu not found, using dummy regulator
[    0.164091] bio: create slab <bio-0> at 0
[    0.170829] mxs-dma 1804000.dma-apbh: initialized
[    0.171964] can-3v3: 3300 mV
[    0.172558] VSD_3V3: 3300 mV
[    0.173344] usb_otg1_vbus: 5000 mV
[    0.173945] vref-3v3: 3300 mV
[    0.175294] gpio_dvfs: 1300 <--> 1400 mV at 1400 mV
[    0.176649] i2c-core: driver [max17135] using legacy suspend method
[    0.176675] i2c-core: driver [max17135] using legacy resume method
[    0.178027] SCSI subsystem initialized
[    0.179274] usbcore: registered new inte**ce driver usbfs
[    0.179481] usbcore: registered new inte**ce driver hub
[    0.179806] usbcore: registered new device driver usb
[    0.184818] i2c i2c-0: IMX I2C adapter registered
[    0.187342] i2c i2c-1: IMX I2C adapter registered
[    0.187651] Linux video capture inte**ce: v2.00
[    0.187844] pps_core: LinuxPPS API ver. 1 registered
[    0.187865] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.187929] PTP clock support registered
[    0.190749] MIPI CSI2 driver module loaded
[    0.191350] Advanced Linux Sound Architecture Driver Initialized.
[    0.193631] Bluetooth: Core ver 2.18
[    0.193756] NET: Registered protocol family 31
[    0.193778] Bluetooth: HCI device and connection manager initialized
[    0.193817] Bluetooth: HCI socket layer initialized
[    0.193853] Bluetooth: L2CAP socket layer initialized
[    0.193970] Bluetooth: SCO socket layer initialized
[    0.195662] Switched to clocksource mxc_timer1
[    0.197401] cfg80211: Calling CRDA to update world regulatory domain
[    0.222164] NET: Registered protocol family 2
[    0.224159] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[    0.224250] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[    0.224341] TCP: Hash tables configured (established 2048 bind 2048)
[    0.224455] TCP: reno registered
[    0.224491] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.224547] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.225145] NET: Registered protocol family 1
[    0.226181] RPC: Registered named UNIX socket transport module.
[    0.226214] RPC: Registered udp transport module.
[    0.226233] RPC: Registered tcp transport module.
[    0.226250] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.226791] Trying to unpack rootfs image as initramfs...
[    1.733135] Freeing initrd memory: 7984K (83801000 - 83fcd000)
[    1.735508] imx rpmsg driver is registered.
[    1.737598] Bus freq driver module loaded
[    1.739708] futex hash table entries: 256 (order: 2, 16384 bytes)
[    1.758611] VFS: Disk quotas dquot_6.5.2
[    1.759345] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.765353] NFS: Registering the id_resolver key type
[    1.765459] Key type id_resolver registered
[    1.765483] Key type id_legacy registered
[    1.765571] jffs2: version 2.2. (NAND) &#169; 2001-2006 Red Hat, Inc.
[    1.767598] fuse init (API version 7.22)
[    1.768858] msgmni has been set to 484
[    1.777558] io scheduler noop registered
[    1.777591] io scheduler deadline registered
[    1.778081] io scheduler cfq registered (default)
[    1.779164] imx-weim 21b8000.weim: Driver registered.
[    1.785106] backlight.9 supply power not found, using dummy regulator
[    1.788387] MIPI DSI driver module loaded
[    1.792914] 21c8000.lcdif supply lcd not found, using dummy regulator
[    1.798384] mxsfb 21c8000.lcdif: failed to find mxc display driver
[    1.808922] Console: switching to colour frame buffer device 100x30
[    1.815614] mxsfb 21c8000.lcdif: initialized
[    1.823210] imx-sdma 20ec000.sdma: no event needs to be remapped
[    1.823420] imx-sdma 20ec000.sdma: loaded firmware 3.1
[    1.831454] imx-sdma 20ec000.sdma: initialized
[    1.832909] Serial: IMX driver
[    1.833568] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58, base_baud = 5000000) is a IMX
[    2.586372] console [ttymxc0] enabled
[    2.591737] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59, base_baud = 5000000) is a IMX
[    2.601744] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60, base_baud = 5000000) is a IMX
[    2.611422] serial: Freescale lpuart driver
[    2.619456] imx sema4 driver is registered.
[    2.623858] [drm] Initialized drm 1.1.0 20060810
[    2.629742] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[    2.657346] brd: module loaded
[    2.671932] loop: module loaded
[    2.678775] spi_gpio spi4.15: gpio-miso property not found, switching to no-rx mode
[    2.697560] CAN device driver inte**ce
[    2.704678] flexcan 2090000.can: device registered (reg_base=90970000, irq=142)
[    2.714766] flexcan 2094000.can: device registered (reg_base=90978000, irq=143)
[    2.724308] 20b4000.ethernet supply phy not found, using dummy regulator
[    2.732511] pps pps0: new PPS source ptp0
[    2.737164] fec 20b4000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
[    2.746372] fec 20b4000.ethernet (unregistered net_device): Using random MAC address: be:01:69:2e:92:3a
[    2.756569] libphy: fec_enet_mii_bus: probed
[    2.762639] fec 20b4000.ethernet eth0: registered PHC device 0
[    2.770238] 2188000.ethernet supply phy not found, using dummy regulator
[    2.778252] pps pps1: new PPS source ptp1
[    2.782724] fec 2188000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
[    2.791868] fec 2188000.ethernet (unregistered net_device): Using random MAC address: fa:fe:61:47:2c:92
[    2.803354] fec 2188000.ethernet eth1: registered PHC device 1
[    2.810948] PPP generic driver version 2.4.2
[    2.815877] PPP BSD Compression module registered
[    2.820643] PPP Deflate Compression module registered
[    2.825957] usbcore: registered new inte**ce driver asix
[    2.831520] usbcore: registered new inte**ce driver cdc_ether
[    2.837570] usbcore: registered new inte**ce driver cdc_eem
[    2.843497] usbcore: registered new inte**ce driver cdc_ncm
[    2.849239] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.855828] ehci-mxc: Freescale On-Chip EHCI Host driver
[    2.861640] usbcore: registered new inte**ce driver usb-storage
[    2.868073] usbcore: registered new inte**ce driver usbserial
[    2.874048] usbcore: registered new inte**ce driver usbserial_generic
[    2.880763] usbserial: USB Serial support registered for generic
[    2.886942] usbcore: registered new inte**ce driver ftdi_sio
[    2.892812] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.900285] usbcore: registered new inte**ce driver option
[    2.906018] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.913096] usbcore: registered new inte**ce driver pl2303
[    2.918847] usbserial: USB Serial support registered for pl2303
[    2.924962] usbcore: registered new inte**ce driver cdc_xr_usb_serial
[    2.931565] xr_usb_serial_common: Exar USB UART (serial port) driver
[    2.938107] usbcore: registered new inte**ce driver usb_ehset_test
[    2.946752] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[    2.961732] 2184200.usb supply vbus not found, using dummy regulator
[    2.972066] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    2.977106] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[    2.995839] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    3.003316] hub 1-0:1.0: USB hub found
[    3.007297] hub 1-0:1.0: 1 port detected
[    3.013442] mousedev: PS/2 mouse device common for all mice
[    3.021149] input: 20cc000.snvs-pwrkey as /devices/soc0/soc.0/2000000.aips-bus/20cc000.snvs-pwrkey/input/input0
[    3.032028] snvs_pwrkey 20cc000.snvs-pwrkey: i.MX snvs powerkey probed
[    3.039552] edt_ft5x06 0-0038: touchscreen probe failed
[    3.044850] edt_ft5x06: probe of 0-0038 failed with error -5
[    3.052771] input: iMX6UL TouchScreen Controller as /devices/virtual/input/input2
[    3.062323] <<-GTP-INFO->> GTP driver installing...
[    3.068025] <<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
[    3.073986] <<-GTP-INFO->> GTP Driver Built@17:24:12, Aug  7 2017
[    3.080228] <<-GTP-INFO->> GTP I2C Address: 0x5d
[    3.084929] 0-005d supply vdd_ana not found, using dummy regulator
[    3.091304] 0-005d supply vcc_i2c not found, using dummy regulator
[    3.097689] <<-GTP-INFO->> Guitar reset
[    3.226796] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    3.234857] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
[    3.243095] <<-GTP-INFO->> Guitar reset
[    3.366758] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    3.373743] <<-GTP-ERROR->> GTP i2c test failed time 1.
[    3.396821] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
[    3.405021] <<-GTP-INFO->> Guitar reset
[    3.526760] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    3.533746] <<-GTP-ERROR->> GTP i2c test failed time 2.
[    3.556759] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
[    3.564957] <<-GTP-INFO->> Guitar reset
[    3.686788] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    3.693775] <<-GTP-ERROR->> GTP i2c test failed time 3.
[    3.716755] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
[    3.724954] <<-GTP-INFO->> Guitar reset
[    3.846787] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    3.853773] <<-GTP-ERROR->> GTP i2c test failed time 4.
[    3.876758] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5! Process reset.
[    3.884957] <<-GTP-INFO->> Guitar reset
[    4.006768] <<-GTP-ERROR->> I2C Write: 0x8041, 1 bytes failed, errcode: -5!
[    4.013754] <<-GTP-ERROR->> GTP i2c test failed time 5.
[    4.035688] <<-GTP-ERROR->> I2C communication ERROR!
[    4.040715] goodix-ts: probe of 0-005d failed with error -5
[    4.046754] i2c-core: driver [isl29023] using legacy suspend method
[    4.053051] i2c-core: driver [isl29023] using legacy resume method
[    4.060510] rtc-rx8010 0-0032: Unable to write register #23
[    4.066181] i2c i2c-0: probing for rx8010 failed
[    4.070849] rtc-rx8010: probe of 0-0032 failed with error -5
[    4.077918] snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
[    4.086612] i2c /dev entries driver
[    4.091392] IR NEC protocol handler initialized
[    4.096039] IR RC5(x) protocol handler initialized
[    4.100856] IR RC6 protocol handler initialized
[    4.105409] IR JVC protocol handler initialized
[    4.109998] IR Sony protocol handler initialized
[    4.114641] IR RC5 (streamzap) protocol handler initialized
[    4.120260] IR SANYO protocol handler initialized
[    4.124986] IR MCE Keyboard/mouse protocol handler initialized
[    4.133694] pxp-v4l2 pxp_v4l2.10: initialized
[    4.138541] usbcore: registered new inte**ce driver uvcvideo
[    4.144318] USB Video Class driver (1.1.1)
[    4.149543] i2c-core: driver [mag3110] using legacy suspend method
[    4.155824] i2c-core: driver [mag3110] using legacy resume method
[    4.163062] imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
[    4.171695] Bluetooth: HCI UART driver ver 2.2
[    4.176227] Bluetooth: HCI H4 protocol initialized
[    4.181043] Bluetooth: HCI BCSP protocol initialized
[    4.186064] Bluetooth: HCIATH3K protocol initialized
[    4.191262] usbcore: registered new inte**ce driver bcm203x
[    4.197311] usbcore: registered new inte**ce driver btusb
[    4.203003] usbcore: registered new inte**ce driver ath3k
[    4.208746] usbcore: registered new inte**ce driver rtk_btusb
[    4.215195] sdhci: Secure Digital Host Controller Inte**ce driver
[    4.221461] sdhci: Copyright(c) Pierre Ossman
[    4.225875] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.234173] mmc0: no vqmmc regulator found
[    4.275744] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[    4.300685] nand: No NAND device found
[    4.304574] gpmi-nand 1806000.gpmi-nand: driver registration failed: -19
[    4.330037] usbcore: registered new inte**ce driver usbhid
[    4.335829] usbhid: USB HID core driver
[    4.346515] wm8960 1-001a: Failed to issue reset
[    4.351382] wm8960: probe of 1-001a failed with error -5
[    4.359982] fsl-asrc 2034000.asrc: driver registered
[    4.370562] mmc0: host does not support reading read-only switch. assuming write-enable.
[    4.381795] imx-wm8960 sound.14: failed to find codec platform device
[    4.388498] imx-wm8960: probe of sound.14 failed with error -22
[    4.400938] NET: Registered protocol family 26
[    4.406960] mmc0: new high speed SDHC card at address 0001
[    4.413715] TCP: cubic registered
[    4.418602] NET: Registered protocol family 10
[    4.424551] mmcblk0: mmc0:0001 SD 7.44 GiB
[    4.431647]  mmcblk0: p1
[    4.434713] sit: IPv6 over IPv4 tunneling driver
[    4.442407] NET: Registered protocol family 17
[    4.447109] can: controller area network core (rev 20120528 abi 9)
[    4.453491] NET: Registered protocol family 29
[    4.458150] can: raw protocol (rev 20120528)
[    4.462461] can: broadcast manager protocol (rev 20120528 t)
[    4.468233] can: netlink gateway (rev 20130117) max_hops=1
[    4.474436] Bluetooth: RFCOMM TTY layer initialized
[    4.479664] Bluetooth: RFCOMM socket layer initialized
[    4.484881] Bluetooth: RFCOMM ver 1.11
[    4.488741] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.494078] Bluetooth: BNEP filters: protocol multicast
[    4.499382] Bluetooth: BNEP socket layer initialized
[    4.504373] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[    4.510368] Bluetooth: HIDP socket layer initialized
[    4.515473] 8021q: 802.1Q VLAN Support v1.8
[    4.519854] Key type dns_resolver registered
[    4.525570] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
[    4.549595] gpio_dvfs: disabling
[    4.552870] vref-3v3: disabling
[    4.556145] usb_otg1_vbus: disabling
[    4.559750] can-3v3: disabling
[    4.562827] regulator-dummy: disabling
[    4.567659] imx mcc test is registered.
[    4.572241] snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-06 17:47:09 UTC (496029)
[    4.600330] ALSA device list:
[    4.603341]   No soundcards found.
[    4.608105] Freeing unused kernel memory: 388K (80a25000 - 80a86000)
flash_eraseall has been replaced by `flash_erase <mtddev> 0 0`; please use it
mtd: device "/dev/mtd0" can't be opened
Unable to open mtd device(s)
kobs-ng version : [ 1.3 ] git hash (unknown)
ROM Version 5
usage: kobs-ng [COMMAND] [ARGS]
Where [COMMAND] is one of:
  dump [-v] [KOBS] ........................ Verify/dump boot structures
    -v .................................... Verbose mode
  imgverify [-v] [KEY] <file> ............. Verify image validity
  init [-v] [KEY] [KOBS] <file> ........... Initialize boot structure &
                                            install bootstreams
    -x .................................... Add 1k-padding in the head
    -n .................................... Dry run (don't commit to flash)
    -w .................................... Commit to flash
  update [-v] [KEY] [KOBS] [-0|1] <file> .. Update a single bootstream
    -0|1 .................................. Update specified bootstream #
  extract [-v] [KEY] [KOBS] [-0|1] <file> . Extract a bootstream from flash
    -0|1 .................................. Extract specified bootstream #
  [KOBS] boot structures config options
    --chip_0_device_path=<path> .......... Device of boot (default /dev/mtd0)
    --chip_1_device_path=<path> .......... The second chip in case of multichip NAND
    --search_exponent=<value> ............ NCB field (default 2)
    --data_setup_time=<value> ............ NCB field (default 80)
    --data_hold_time=<value> ............. NCB field (default 60)
    --address_setup_time=<value> ......... NCB field (default 25)
    --data_sample_time=<value> ........... NCB field (default 6)
    --row_address_size=<value> ........... NCB field (default 3)
    --column_address_size=<value> ........ NCB field (default 2)
    --read_command_code1=<value> ......... NCB field (default 0x00)
    --read_command_code2=<value> ......... NCB field (default 0x30)
    --boot_stream_major_version=<value> .. NCB field (default 1)
    --boot_stream_minor_version=<value> .. NCB field (default 0)
    --boot_stream_sub_version=<value> .... NCB field (default 0)
    --ncb_version=<value> ................ NCB field (default 3)
   [KEY] key management related options
        -d ............................... Use device key (OTP) (not yet supported)
        -z ............................... Use key of all zeroes (default)
        -k<hexadecimalkey> ............... Use hex key of 16 bytes
bin/
bin/nice
bin/killall
bin/taskset
bin/kill
bin/login
bin/makemime
bin/hexdump
bin/cp
bin/setserial
bin/chattr
opt/qt4.8.5/lib/fonts/simsun.ttc
opt/qt4.8.5/lib/fonts/simhei.ttf
tar: write error: No space left on device
 楼主| 发表于 2018-5-23 13:14:11 | 显示全部楼层
原来没找到Nand Flash, 后来更换了下设备树,nand flash找到了,但还是烧录不成功。
CPU:   Temperature 46 C
Reset cause: POR
I2C:   ready
DRAM:  256 MiB
Video: 800x480x24
In:    serial
Out:   serial
Err:   serial
PHY reset timed out
FEC0
Normal Boot
reading boot.scr
reading /bin/zImage
6219672 bytes read in 295 ms (20.1 MiB/s)
8158075 bytes read in 380 ms (20.5 MiB/s)
41725 bytes read in 28 ms (1.4 MiB/s)
   Image Name:   ramdisk
   Data Size:    8158011 Bytes = 7.8 MiB
   Using Device Tree in place at 83000000, end 8300d2fc
Starting kernel ...
[    0.000000] PERCPU: Embedded 8 pages/cpu @8bdbe000 s8320 r8192 d16256 u32768
[    0.000000] Memory: 174432K/262144K available (7657K kernel code, 452K rwdata, 2696K rodata, 388K init, 433K bss, 87712K reserved, 0K highmem)
[    0.000016] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
[    0.002881] clocksource_of_init: no matching clocksources found
[    0.003259] Console: colour dummy device 80x30
[    0.003306] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[    0.003340] pid_max: default: 32768 minimum: 301
[    0.003757] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.003788] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.005541] CPU: Testing write buffer coherency: ok
[    0.006059] /cpus/cpu@0 missing clock-frequency property
[    0.006099] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.006159] Setting up static identity map for 0x80745358 - 0x807453b0
[    0.040750] Brought up 1 CPUs
[    0.040786] SMP: Total of 1 processors activated (6.00 BogoMIPS).
[    0.040802] CPU: All CPU(s) started in SVC mode.
[    0.041790] devtmpfs: initialized
[    0.051979] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.052756] pinctrl core: initialized pinctrl subsystem
[    0.053688] regulator-dummy: no parameters
[    0.058894] NET: Registered protocol family 16
[    0.075493] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.077121] cpuidle: using governor ladder
[    0.077154] cpuidle: using governor menu
[    0.077441] Use WDOG1 as reset source
[    0.094913] syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
[    0.095590] vdd3p0: 2625 <--> 3400 mV at 3000 mV
[    0.096463] cpu: 725 <--> 1450 mV at 1150 mV
[    0.097317] vddsoc: 725 <--> 1450 mV at 1175 mV
[    0.102460] syscon 20e4000.iomuxc-gpr: regmap [mem 0x020e4000-0x020e7fff] registered
[    0.108626] syscon 21ac000.romcp: regmap [mem 0x021ac000-0x021affff] registered
[    0.110050] syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
[    0.117622] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.117652] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.121539] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[    0.124255] 20dc000.gpc supply pu not found, using dummy regulator
[    0.156093] bio: create slab <bio-0> at 0
[    0.162812] mxs-dma 1804000.dma-apbh: initialized
[    0.163777] can-3v3: 3300 mV
[    0.164370] VSD_3V3: 3300 mV
[    0.164914] vref-3v3: 3300 mV
[    0.165424] vref-4v2: 4200 mV
[    0.165944] wifi-3v3: 3300 mV
[    0.167238] gpio_dvfs: 1300 <--> 1400 mV at 1400 mV
[    0.168518] i2c-core: driver [max17135] using legacy suspend method
[    0.168544] i2c-core: driver [max17135] using legacy resume method
[    0.169765] SCSI subsystem initialized
[    0.170966] usbcore: registered new inte**ce driver usbfs
[    0.171262] usbcore: registered new inte**ce driver hub
[    0.171588] usbcore: registered new device driver usb
[    0.175614] i2c i2c-0: IMX I2C adapter registered
[    0.178153] i2c i2c-1: IMX I2C adapter registered
[    0.178483] Linux video capture inte**ce: v2.00
[    0.178660] pps_core: LinuxPPS API ver. 1 registered
[    0.178682] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.178760] PTP clock support registered
[    0.181436] MIPI CSI2 driver module loaded
[    0.182023] Advanced Linux Sound Architecture Driver Initialized.
[    0.183989] Bluetooth: Core ver 2.18
[    0.184113] NET: Registered protocol family 31
[    0.184134] Bluetooth: HCI device and connection manager initialized
[    0.184174] Bluetooth: HCI socket layer initialized
[    0.184206] Bluetooth: L2CAP socket layer initialized
[    0.184284] Bluetooth: SCO socket layer initialized
[    0.185235] cfg80211: Calling CRDA to update world regulatory domain
[    0.186148] Switched to clocksource mxc_timer1
[    0.211305] NET: Registered protocol family 2
[    0.213254] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[    0.213336] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[    0.213428] TCP: Hash tables configured (established 2048 bind 2048)
[    0.213546] TCP: reno registered
[    0.213581] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.213638] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.214238] NET: Registered protocol family 1
[    0.214989] RPC: Registered named UNIX socket transport module.
[    0.215019] RPC: Registered udp transport module.
[    0.215037] RPC: Registered tcp transport module.
[    0.215056] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.215586] Trying to unpack rootfs image as initramfs...
[    1.643636] Freeing initrd memory: 7960K (83801000 - 83fc7000)
[    1.645751] imx rpmsg driver is registered.
[    1.647574] Bus freq driver module loaded
[    1.649543] futex hash table entries: 256 (order: 2, 16384 bytes)
[    1.668066] VFS: Disk quotas dquot_6.5.2
[    1.668792] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.674653] NFS: Registering the id_resolver key type
[    1.674775] Key type id_resolver registered
[    1.674797] Key type id_legacy registered
[    1.674885] jffs2: version 2.2. (NAND) &#169; 2001-2006 Red Hat, Inc.
[    1.676913] fuse init (API version 7.22)
[    1.678155] msgmni has been set to 484
[    1.686307] io scheduler noop registered
[    1.686341] io scheduler deadline registered
[    1.686829] io scheduler cfq registered (default)
[    1.687814] imx-weim 21b8000.weim: Driver registered.
[    1.693090] backlight.11 supply power not found, using dummy regulator
[    1.696384] MIPI DSI driver module loaded
[    1.700417] 21c8000.lcdif supply lcd not found, using dummy regulator
[    1.701900] mxsfb 21c8000.lcdif: failed to find mxc display driver
[    1.705945] Console: switching to colour frame buffer device 30x40
[    1.707816] mxsfb 21c8000.lcdif: initialized
[    1.715235] imx-sdma 20ec000.sdma: no event needs to be remapped
[    1.715446] imx-sdma 20ec000.sdma: loaded firmware 3.1
[    1.723999] imx-sdma 20ec000.sdma: initialized
[    1.725468] Serial: IMX driver
[    1.726112] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58, base_baud = 5000000) is a IMX
[    2.481799] console [ttymxc0] enabled
[    2.487269] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60, base_baud = 5000000) is a IMX
[    2.497066] serial: Freescale lpuart driver
[    2.505045] imx sema4 driver is registered.
[    2.509507] [drm] Initialized drm 1.1.0 20060810
[    2.515271] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[    2.543148] brd: module loaded
[    2.558080] loop: module loaded
[    2.564870] spi_gpio spi4.17: gpio-miso property not found, switching to no-rx mode
[    2.590851] spi_imx 2008000.ecspi: probed
[    2.603326] spi_imx 2010000.ecspi: probed
[    2.610020] CAN device driver inte**ce
[    2.617741] PPP generic driver version 2.4.2
[    2.622569] PPP BSD Compression module registered
[    2.627618] PPP Deflate Compression module registered
[    2.632909] usbcore: registered new inte**ce driver asix
[    2.638619] usbcore: registered new inte**ce driver cdc_ether
[    2.644622] usbcore: registered new inte**ce driver cdc_eem
[    2.650690] usbcore: registered new inte**ce driver cdc_ncm
[    2.656456] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.663015] ehci-mxc: Freescale On-Chip EHCI Host driver
[    2.668846] usbcore: registered new inte**ce driver usb-storage
[    2.675216] usbcore: registered new inte**ce driver usbserial
[    2.681268] usbcore: registered new inte**ce driver usbserial_generic
[    2.688003] usbserial: USB Serial support registered for generic
[    2.694149] usbcore: registered new inte**ce driver ftdi_sio
[    2.700199] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.707723] usbcore: registered new inte**ce driver option
[    2.713433] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.720582] usbcore: registered new inte**ce driver pl2303
[    2.726333] usbserial: USB Serial support registered for pl2303
[    2.732449] usbcore: registered new inte**ce driver cdc_xr_usb_serial
[    2.739053] xr_usb_serial_common: Exar USB UART (serial port) driver
[    2.745577] usbcore: registered new inte**ce driver usb_ehset_test
[    2.754124] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[    2.763424] 2184000.usb supply vbus not found, using dummy regulator
[    2.775663] 2184200.usb supply vbus not found, using dummy regulator
[    2.786062] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    2.791126] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[    2.816250] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    2.823800] hub 1-0:1.0: USB hub found
[    2.827791] hub 1-0:1.0: 1 port detected
[    2.834045] mousedev: PS/2 mouse device common for all mice
[    2.841844] input: 20cc000.snvs-pwrkey as /devices/soc0/soc.0/2000000.aips-bus/20cc000.snvs-pwrkey/input/input0
[    2.852764] snvs_pwrkey 20cc000.snvs-pwrkey: i.MX snvs powerkey probed
[    2.860300] edt_ft5x06 0-0038: touchscreen probe failed
[    2.865600] edt_ft5x06: probe of 0-0038 failed with error -5
[    2.872944] <<-GTP-INFO->> GTP driver installing...
[    2.878821] i2c-core: driver [isl29023] using legacy suspend method
[    2.885129] i2c-core: driver [isl29023] using legacy resume method
[    2.892639] rtc-rx8010 0-0032: Unable to write register #23
[    2.898407] i2c i2c-0: probing for rx8010 failed
[    2.903081] rtc-rx8010: probe of 0-0032 failed with error -5
[    2.910154] snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
[    2.918842] i2c /dev entries driver
[    2.923542] IR NEC protocol handler initialized
[    2.929446] IR RC5(x) protocol handler initialized
[    2.934275] IR RC6 protocol handler initialized
[    2.938886] IR JVC protocol handler initialized
[    2.943442] IR Sony protocol handler initialized
[    2.948114] IR RC5 (streamzap) protocol handler initialized
[    2.953707] IR SANYO protocol handler initialized
[    2.958464] IR MCE Keyboard/mouse protocol handler initialized
[    2.967293] pxp-v4l2 pxp_v4l2.12: initialized
[    2.972082] usbcore: registered new inte**ce driver uvcvideo
[    2.977936] USB Video Class driver (1.1.1)
[    2.983119] i2c-core: driver [mag3110] using legacy suspend method
[    2.989403] i2c-core: driver [mag3110] using legacy resume method
[    2.996631] imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
[    3.005171] Bluetooth: HCI UART driver ver 2.2
[    3.009719] Bluetooth: HCI H4 protocol initialized
[    3.014540] Bluetooth: HCI BCSP protocol initialized
[    3.019561] Bluetooth: HCIATH3K protocol initialized
[    3.024761] usbcore: registered new inte**ce driver bcm203x
[    3.030675] usbcore: registered new inte**ce driver btusb
[    3.036391] usbcore: registered new inte**ce driver ath3k
[    3.042094] usbcore: registered new inte**ce driver rtk_btusb
[    3.048670] sdhci: Secure Digital Host Controller Inte**ce driver
[    3.054885] sdhci: Copyright(c) Pierre Ossman
[    3.059323] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.067578] mmc0: no vqmmc regulator found
[    3.116229] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[    3.161493] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0x44
[    3.167944] nand: Micron MT29F32G08CBADBWP
[    3.172075] nand: 4096MiB, MLC, page size: 8192, OOB size: 744
[    3.178187] gpmi-nand 1806000.gpmi-nand:  Default ecc strength(52) is beyond our capability(40). Try to use maximum ecc strength controller
[    3.178187]  can support.
[    3.194231] gpmi-nand 1806000.gpmi-nand: enable the asynchronous EDO mode 5
[    3.201446] Scanning device for bad blocks
[    3.209140] Bad eraseblock 16 at 0x000002000000
[    3.214031] Bad eraseblock 17 at 0x000002200000
[    3.218699] mmc0: host does not support reading read-only switch. assuming write-enable.
[    3.227096] Bad eraseblock 18 at 0x000002400000
[    3.231934] Bad eraseblock 19 at 0x000002600000
[    3.240967] mmc0: new high speed SDHC card at address 0001
[    3.246552] Bad eraseblock 20 at 0x000002800000
[    3.251314] Bad eraseblock 21 at 0x000002a00000
[    3.257190] mmcblk0: mmc0:0001 SD 7.44 GiB
[    3.262271] Bad eraseblock 22 at 0x000002c00000
[    3.267873] Bad eraseblock 23 at 0x000002e00000
[    3.272632]  mmcblk0: p1
[    3.276932] Bad eraseblock 24 at 0x000003000000
[    3.281756] Bad eraseblock 25 at 0x000003200000
[    3.286659] Bad eraseblock 26 at 0x000003400000
[    3.291428] Bad eraseblock 27 at 0x000003600000
[    3.296341] Bad eraseblock 28 at 0x000003800000
[    3.301116] Bad eraseblock 29 at 0x000003a00000
[    3.305876] Bad eraseblock 30 at 0x000003c00000
[    3.310708] Bad eraseblock 31 at 0x000003e00000
[    3.315474] Bad eraseblock 32 at 0x000004000000
[    3.320384] Bad eraseblock 33 at 0x000004200000
[    3.325170] Bad eraseblock 34 at 0x000004400000
[    3.329996] Bad eraseblock 35 at 0x000004600000
[    3.334786] Bad eraseblock 36 at 0x000004800000
[    3.339592] Bad eraseblock 37 at 0x000004a00000
[    3.344358] Bad eraseblock 38 at 0x000004c00000
[    3.349170] Bad eraseblock 39 at 0x000004e00000
[    3.353949] Bad eraseblock 40 at 0x000005000000
[    3.358771] Bad eraseblock 41 at 0x000005200000
[    3.363554] Bad eraseblock 42 at 0x000005400000
[    3.368368] Bad eraseblock 43 at 0x000005600000
[    3.373146] Bad eraseblock 44 at 0x000005800000
[    3.377951] Bad eraseblock 45 at 0x000005a00000
[    3.382708] Bad eraseblock 46 at 0x000005c00000
[    3.387523] Bad eraseblock 47 at 0x000005e00000
[    3.392304] Bad eraseblock 48 at 0x000006000000
[    3.397113] Bad eraseblock 49 at 0x000006200000
[    3.401887] Bad eraseblock 50 at 0x000006400000
[    3.406698] Bad eraseblock 51 at 0x000006600000
[    3.411481] Bad eraseblock 52 at 0x000006800000
[    3.416243] Bad eraseblock 53 at 0x000006a00000
[    3.421001] Bad eraseblock 54 at 0x000006c00000
[    3.432747] Bad eraseblock 90 at 0x00000b400000
[    3.437512] Bad eraseblock 91 at 0x00000b600000
[    3.447119] Bad eraseblock 116 at 0x00000e800000
[    3.451987] Bad eraseblock 117 at 0x00000ea00000
[    3.456893] Bad eraseblock 118 at 0x00000ec00000
[    3.461758] Bad eraseblock 119 at 0x00000ee00000
[    3.466638] Bad eraseblock 120 at 0x00000f000000
[    3.471483] Bad eraseblock 121 at 0x00000f200000
[    3.476393] Bad eraseblock 122 at 0x00000f400000
[    3.481258] Bad eraseblock 123 at 0x00000f600000
[    3.486121] Bad eraseblock 124 at 0x00000f800000
[    3.491001] Bad eraseblock 125 at 0x00000fa00000
[    3.495844] Bad eraseblock 126 at 0x00000fc00000
[    3.500823] Bad eraseblock 127 at 0x00000fe00000
[    3.505699] Bad eraseblock 128 at 0x000010000000
[    3.510588] Bad eraseblock 129 at 0x000010200000
[    3.515435] Bad eraseblock 130 at 0x000010400000
[    3.520351] Bad eraseblock 131 at 0x000010600000
[    3.525223] Bad eraseblock 132 at 0x000010800000
[    3.530127] Bad eraseblock 133 at 0x000010a00000
[    3.534989] Bad eraseblock 134 at 0x000010c00000
[    3.539896] Bad eraseblock 135 at 0x000010e00000
[    3.544761] Bad eraseblock 136 at 0x000011000000
[    3.549646] Bad eraseblock 137 at 0x000011200000
[    3.554494] Bad eraseblock 138 at 0x000011400000
[    3.559406] Bad eraseblock 139 at 0x000011600000
[    3.564272] Bad eraseblock 140 at 0x000011800000
[    3.569180] Bad eraseblock 141 at 0x000011a00000
[    3.574042] Bad eraseblock 142 at 0x000011c00000
[    3.578941] Bad eraseblock 143 at 0x000011e00000
[    3.583807] Bad eraseblock 144 at 0x000012000000
[    3.588689] Bad eraseblock 145 at 0x000012200000
[    3.593540] Bad eraseblock 146 at 0x000012400000
[    3.598446] Bad eraseblock 147 at 0x000012600000
[    3.603312] Bad eraseblock 148 at 0x000012800000
[    3.608214] Bad eraseblock 149 at 0x000012a00000
[    3.613073] Bad eraseblock 150 at 0x000012c00000
[    3.617968] Bad eraseblock 151 at 0x000012e00000
[    3.622833] Bad eraseblock 152 at 0x000013000000
[    3.627710] Bad eraseblock 153 at 0x000013200000
[    3.632561] Bad eraseblock 154 at 0x000013400000
[    3.637468] Bad eraseblock 155 at 0x000013600000
[    3.642331] Bad eraseblock 156 at 0x000013800000
[    3.647235] Bad eraseblock 157 at 0x000013a00000
[    3.652100] Bad eraseblock 158 at 0x000013c00000
[    3.656998] Bad eraseblock 159 at 0x000013e00000
[    3.661872] Bad eraseblock 160 at 0x000014000000
[    3.666753] Bad eraseblock 161 at 0x000014200000
[    3.671598] Bad eraseblock 162 at 0x000014400000
[    3.676502] Bad eraseblock 163 at 0x000014600000
[    3.681367] Bad eraseblock 164 at 0x000014800000
[    3.686226] Bad eraseblock 165 at 0x000014a00000
[    3.691069] Bad eraseblock 166 at 0x000014c00000
[    3.695909] Bad eraseblock 167 at 0x000014e00000
[    3.700874] Bad eraseblock 168 at 0x000015000000
[    3.705750] Bad eraseblock 169 at 0x000015200000
[    3.710640] Bad eraseblock 170 at 0x000015400000
[    3.715483] Bad eraseblock 171 at 0x000015600000
[    3.720390] Bad eraseblock 172 at 0x000015800000
[    3.725252] Bad eraseblock 173 at 0x000015a00000
[    3.730163] Bad eraseblock 174 at 0x000015c00000
[    3.735034] Bad eraseblock 175 at 0x000015e00000
[    3.739935] Bad eraseblock 176 at 0x000016000000
[    3.744798] Bad eraseblock 177 at 0x000016200000
[    3.749678] Bad eraseblock 178 at 0x000016400000
[    3.754521] Bad eraseblock 179 at 0x000016600000
[    3.759431] Bad eraseblock 180 at 0x000016800000
[    3.764296] Bad eraseblock 181 at 0x000016a00000
[    3.769201] Bad eraseblock 182 at 0x000016c00000
[    3.774071] Bad eraseblock 183 at 0x000016e00000
[    3.778973] Bad eraseblock 184 at 0x000017000000
[    3.783840] Bad eraseblock 185 at 0x000017200000
[    3.788722] Bad eraseblock 186 at 0x000017400000
[    3.793573] Bad eraseblock 187 at 0x000017600000
[    3.798474] Bad eraseblock 188 at 0x000017800000
[    3.803338] Bad eraseblock 189 at 0x000017a00000
[    3.808246] Bad eraseblock 190 at 0x000017c00000
[    3.813113] Bad eraseblock 191 at 0x000017e00000
[    3.818015] Bad eraseblock 192 at 0x000018000000
[    3.822879] Bad eraseblock 193 at 0x000018200000
[    3.827768] Bad eraseblock 194 at 0x000018400000
[    3.832619] Bad eraseblock 195 at 0x000018600000
[    3.837525] Bad eraseblock 196 at 0x000018800000
[    3.842399] Bad eraseblock 197 at 0x000018a00000
[    3.847297] Bad eraseblock 198 at 0x000018c00000
[    3.852163] Bad eraseblock 199 at 0x000018e00000
[    3.857059] Bad eraseblock 200 at 0x000019000000
[    3.861923] Bad eraseblock 201 at 0x000019200000
[    3.866803] Bad eraseblock 202 at 0x000019400000
[    3.871651] Bad eraseblock 203 at 0x000019600000
[    3.876556] Bad eraseblock 204 at 0x000019800000
[    3.881424] Bad eraseblock 205 at 0x000019a00000
[    3.886275] Bad eraseblock 206 at 0x000019c00000
[    3.891121] Bad eraseblock 207 at 0x000019e00000
[    3.895966] Bad eraseblock 208 at 0x00001a000000
[    3.900950] Bad eraseblock 209 at 0x00001a200000
[    3.905824] Bad eraseblock 210 at 0x00001a400000
[    3.910715] Bad eraseblock 211 at 0x00001a600000
[    3.915567] Bad eraseblock 212 at 0x00001a800000
[    3.920487] Bad eraseblock 213 at 0x00001aa00000
[    3.925355] Bad eraseblock 214 at 0x00001ac00000
[    3.930264] Bad eraseblock 215 at 0x00001ae00000
[    3.935131] Bad eraseblock 216 at 0x00001b000000
[    3.940044] Bad eraseblock 217 at 0x00001b200000
[    3.944909] Bad eraseblock 218 at 0x00001b400000
[    3.949805] Bad eraseblock 219 at 0x00001b600000
[    3.954653] Bad eraseblock 220 at 0x00001b800000
[    3.959567] Bad eraseblock 221 at 0x00001ba00000
[    3.964426] Bad eraseblock 222 at 0x00001bc00000
[    3.969329] Bad eraseblock 223 at 0x00001be00000
[    3.974194] Bad eraseblock 224 at 0x00001c000000
[    3.979101] Bad eraseblock 225 at 0x00001c200000
[    3.983961] Bad eraseblock 226 at 0x00001c400000
[    3.988843] Bad eraseblock 227 at 0x00001c600000
[    3.993686] Bad eraseblock 228 at 0x00001c800000
[    3.998589] Bad eraseblock 229 at 0x00001ca00000
[    4.003454] Bad eraseblock 230 at 0x00001cc00000
[    4.008362] Bad eraseblock 231 at 0x00001ce00000
[    4.013230] Bad eraseblock 232 at 0x00001d000000
[    4.018123] Bad eraseblock 233 at 0x00001d200000
[    4.022991] Bad eraseblock 234 at 0x00001d400000
[    4.027866] Bad eraseblock 235 at 0x00001d600000
[    4.032704] Bad eraseblock 236 at 0x00001d800000
[    4.037615] Bad eraseblock 237 at 0x00001da00000
[    4.042477] Bad eraseblock 238 at 0x00001dc00000
[    4.047433] Bad eraseblock 239 at 0x00001de00000
[    4.052306] Bad eraseblock 240 at 0x00001e000000
[    4.057214] Bad eraseblock 241 at 0x00001e200000
[    4.062082] Bad eraseblock 242 at 0x00001e400000
[    4.066971] Bad eraseblock 243 at 0x00001e600000
[    4.071814] Bad eraseblock 244 at 0x00001e800000
[    4.076721] Bad eraseblock 245 at 0x00001ea00000
[    4.081589] Bad eraseblock 246 at 0x00001ec00000
[    4.086475] Bad eraseblock 247 at 0x00001ee00000
[    4.091323] Bad eraseblock 248 at 0x00001f000000
[    4.096266] Bad eraseblock 249 at 0x00001f200000
[    4.101146] Bad eraseblock 250 at 0x00001f400000
[    4.106017] Bad eraseblock 251 at 0x00001f600000
[    4.110911] Bad eraseblock 252 at 0x00001f800000
[    4.115755] Bad eraseblock 253 at 0x00001fa00000
[    4.120666] Bad eraseblock 254 at 0x00001fc00000
[    4.125537] Bad eraseblock 255 at 0x00001fe00000
[    4.130434] Bad eraseblock 256 at 0x000020000000
[    4.135300] Bad eraseblock 257 at 0x000020200000
[    4.140193] Bad eraseblock 258 at 0x000020400000
[    4.145058] Bad eraseblock 259 at 0x000020600000
[    4.149939] Bad eraseblock 260 at 0x000020800000
[    4.154788] Bad eraseblock 261 at 0x000020a00000
[    4.159700] Bad eraseblock 262 at 0x000020c00000
[    4.164566] Bad eraseblock 263 at 0x000020e00000
[    4.169469] Bad eraseblock 264 at 0x000021000000
[    4.174327] Bad eraseblock 265 at 0x000021200000
[    4.179230] Bad eraseblock 266 at 0x000021400000
[    4.184088] Bad eraseblock 267 at 0x000021600000
[    4.188966] Bad eraseblock 268 at 0x000021800000
[    4.193809] Bad eraseblock 269 at 0x000021a00000
[    4.198709] Bad eraseblock 270 at 0x000021c00000
[    4.203569] Bad eraseblock 271 at 0x000021e00000
[    4.208472] Bad eraseblock 272 at 0x000022000000
[    4.213341] Bad eraseblock 273 at 0x000022200000
[    4.218238] Bad eraseblock 274 at 0x000022400000
[    4.223104] Bad eraseblock 275 at 0x000022600000
[    4.227987] Bad eraseblock 276 at 0x000022800000
[    4.232831] Bad eraseblock 277 at 0x000022a00000
[    4.237731] Bad eraseblock 278 at 0x000022c00000
[    4.242603] Bad eraseblock 279 at 0x000022e00000
[    4.247511] Bad eraseblock 280 at 0x000023000000
[    4.252374] Bad eraseblock 281 at 0x000023200000
[    4.257279] Bad eraseblock 282 at 0x000023400000
[    4.262142] Bad eraseblock 283 at 0x000023600000
[    4.267024] Bad eraseblock 284 at 0x000023800000
[    4.271867] Bad eraseblock 285 at 0x000023a00000
[    4.276776] Bad eraseblock 286 at 0x000023c00000
[    4.281642] Bad eraseblock 287 at 0x000023e00000
[    4.286527] Bad eraseblock 288 at 0x000024000000
[    4.291366] Bad eraseblock 289 at 0x000024200000
[    4.296313] Bad eraseblock 290 at 0x000024400000
[    4.301190] Bad eraseblock 291 at 0x000024600000
[    4.306056] Bad eraseblock 292 at 0x000024800000
[    4.310939] Bad eraseblock 293 at 0x000024a00000
[    4.315787] Bad eraseblock 294 at 0x000024c00000
[    4.320694] Bad eraseblock 295 at 0x000024e00000
[    4.325559] Bad eraseblock 296 at 0x000025000000
[    4.330456] Bad eraseblock 297 at 0x000025200000
[    4.335320] Bad eraseblock 298 at 0x000025400000
[    4.340217] Bad eraseblock 299 at 0x000025600000
[    4.345076] Bad eraseblock 300 at 0x000025800000
[    4.349962] Bad eraseblock 301 at 0x000025a00000
[    4.354809] Bad eraseblock 302 at 0x000025c00000
[    4.359719] Bad eraseblock 303 at 0x000025e00000
[    4.364588] Bad eraseblock 304 at 0x000026000000
[    4.369489] Bad eraseblock 305 at 0x000026200000
[    4.374355] Bad eraseblock 306 at 0x000026400000
[    4.379262] Bad eraseblock 307 at 0x000026600000
[    4.384126] Bad eraseblock 308 at 0x000026800000
[    4.389011] Bad eraseblock 309 at 0x000026a00000
[    4.393853] Bad eraseblock 310 at 0x000026c00000
[    4.398761] Bad eraseblock 311 at 0x000026e00000
[    4.403627] Bad eraseblock 312 at 0x000027000000
[    4.408526] Bad eraseblock 313 at 0x000027200000
[    4.413382] Bad eraseblock 314 at 0x000027400000
[    4.418279] Bad eraseblock 315 at 0x000027600000
[    4.423146] Bad eraseblock 316 at 0x000027800000
[    4.428022] Bad eraseblock 317 at 0x000027a00000
[    4.432864] Bad eraseblock 318 at 0x000027c00000
[    4.437773] Bad eraseblock 319 at 0x000027e00000
[    4.442642] Bad eraseblock 320 at 0x000028000000
[    4.447550] Bad eraseblock 321 at 0x000028200000
[    4.452422] Bad eraseblock 322 at 0x000028400000
[    4.457325] Bad eraseblock 323 at 0x000028600000
[    4.462182] Bad eraseblock 324 at 0x000028800000
[    4.467066] Bad eraseblock 325 at 0x000028a00000
[    4.471902] Bad eraseblock 326 at 0x000028c00000
[    4.476806] Bad eraseblock 327 at 0x000028e00000
[    4.481666] Bad eraseblock 328 at 0x000029000000
[    4.486548] Bad eraseblock 329 at 0x000029200000
[    4.491387] Bad eraseblock 330 at 0x000029400000
[    4.496300] Bad eraseblock 331 at 0x000029600000
[    4.501175] Bad eraseblock 332 at 0x000029800000
[    4.506041] Bad eraseblock 333 at 0x000029a00000
[    4.510932] Bad eraseblock 334 at 0x000029c00000
[    4.515773] Bad eraseblock 335 at 0x000029e00000
[    4.520686] Bad eraseblock 336 at 0x00002a000000
[    4.525559] Bad eraseblock 337 at 0x00002a200000
[    4.530471] Bad eraseblock 338 at 0x00002a400000
[    4.535335] Bad eraseblock 339 at 0x00002a600000
[    4.540232] Bad eraseblock 340 at 0x00002a800000
[    4.545098] Bad eraseblock 341 at 0x00002aa00000
[    4.549977] Bad eraseblock 342 at 0x00002ac00000
[    4.554821] Bad eraseblock 343 at 0x00002ae00000
[    4.559729] Bad eraseblock 344 at 0x00002b000000
[    4.564591] Bad eraseblock 345 at 0x00002b200000
[    4.569493] Bad eraseblock 346 at 0x00002b400000
[    4.574358] Bad eraseblock 347 at 0x00002b600000
[    4.579258] Bad eraseblock 348 at 0x00002b800000
[    4.584127] Bad eraseblock 349 at 0x00002ba00000
[    4.589008] Bad eraseblock 350 at 0x00002bc00000
[    4.593852] Bad eraseblock 351 at 0x00002be00000
[    4.598759] Bad eraseblock 352 at 0x00002c000000
[    4.603625] Bad eraseblock 353 at 0x00002c200000
[    4.608529] Bad eraseblock 354 at 0x00002c400000
[    4.613393] Bad eraseblock 355 at 0x00002c600000
[    4.618301] Bad eraseblock 356 at 0x00002c800000
[    4.623170] Bad eraseblock 357 at 0x00002ca00000
[    4.628057] Bad eraseblock 358 at 0x00002cc00000
[    4.632904] Bad eraseblock 359 at 0x00002ce00000
[    4.637810] Bad eraseblock 360 at 0x00002d000000
[    4.642682] Bad eraseblock 361 at 0x00002d200000
[    4.647581] Bad eraseblock 362 at 0x00002d400000
[    4.652449] Bad eraseblock 363 at 0x00002d600000
[    4.657351] Bad eraseblock 364 at 0x00002d800000
[    4.662215] Bad eraseblock 365 at 0x00002da00000
[    4.667093] Bad eraseblock 366 at 0x00002dc00000
[    4.671937] Bad eraseblock 367 at 0x00002de00000
[    4.676842] Bad eraseblock 368 at 0x00002e000000
[    4.681709] Bad eraseblock 369 at 0x00002e200000
[    4.686591] Bad eraseblock 370 at 0x00002e400000
[    4.691431] Bad eraseblock 371 at 0x00002e600000
[    4.696350] Bad eraseblock 372 at 0x00002e800000
[    4.701226] Bad eraseblock 373 at 0x00002ea00000
[    4.706091] Bad eraseblock 374 at 0x00002ec00000
[    4.710985] Bad eraseblock 375 at 0x00002ee00000
[    4.715839] Bad eraseblock 376 at 0x00002f000000
[    4.720749] Bad eraseblock 377 at 0x00002f200000
[    4.725616] Bad eraseblock 378 at 0x00002f400000
[    4.730514] Bad eraseblock 379 at 0x00002f600000
[    4.735376] Bad eraseblock 380 at 0x00002f800000
[    4.740282] Bad eraseblock 381 at 0x00002fa00000
[    4.745149] Bad eraseblock 382 at 0x00002fc00000
[    4.750028] Bad eraseblock 383 at 0x00002fe00000
[    4.754873] Bad eraseblock 384 at 0x000030000000
[    4.759777] Bad eraseblock 385 at 0x000030200000
[    4.764641] Bad eraseblock 386 at 0x000030400000
[    4.769544] Bad eraseblock 387 at 0x000030600000
[    4.774408] Bad eraseblock 388 at 0x000030800000
[    4.779317] Bad eraseblock 389 at 0x000030a00000
[    4.784180] Bad eraseblock 390 at 0x000030c00000
[    4.789062] Bad eraseblock 391 at 0x000030e00000
[    4.793915] Bad eraseblock 392 at 0x000031000000
[    4.798823] Bad eraseblock 393 at 0x000031200000
[    4.803688] Bad eraseblock 394 at 0x000031400000
[    4.808590] Bad eraseblock 395 at 0x000031600000
[    4.813454] Bad eraseblock 396 at 0x000031800000
[    4.818357] Bad eraseblock 397 at 0x000031a00000
[    4.823223] Bad eraseblock 398 at 0x000031c00000
[    4.828100] Bad eraseblock 399 at 0x000031e00000
[    4.832949] Bad eraseblock 400 at 0x000032000000
[    4.837861] Bad eraseblock 401 at 0x000032200000
[    4.842731] Bad eraseblock 402 at 0x000032400000
[    4.847632] Bad eraseblock 403 at 0x000032600000
[    4.852495] Bad eraseblock 404 at 0x000032800000
[    4.857398] Bad eraseblock 405 at 0x000032a00000
[    4.862261] Bad eraseblock 406 at 0x000032c00000
[    4.867143] Bad eraseblock 407 at 0x000032e00000
[    4.871987] Bad eraseblock 408 at 0x000033000000
[    4.876888] Bad eraseblock 409 at 0x000033200000
[    4.881753] Bad eraseblock 410 at 0x000033400000
[    4.886639] Bad eraseblock 411 at 0x000033600000
[    4.891480] Bad eraseblock 412 at 0x000033800000
[    4.896450] Bad eraseblock 413 at 0x000033a00000
[    4.901321] Bad eraseblock 414 at 0x000033c00000
[    4.906207] Bad eraseblock 415 at 0x000033e00000
[    4.911054] Bad eraseblock 416 at 0x000034000000
[    4.915893] Bad eraseblock 417 at 0x000034200000
[    4.920805] Bad eraseblock 418 at 0x000034400000
[    4.925671] Bad eraseblock 419 at 0x000034600000
[    4.930578] Bad eraseblock 420 at 0x000034800000
[    4.935443] Bad eraseblock 421 at 0x000034a00000
[    4.940341] Bad eraseblock 422 at 0x000034c00000
[    4.945202] Bad eraseblock 423 at 0x000034e00000
[    4.950084] Bad eraseblock 424 at 0x000035000000
[    4.954926] Bad eraseblock 425 at 0x000035200000
[    4.959834] Bad eraseblock 426 at 0x000035400000
[    4.964698] Bad eraseblock 427 at 0x000035600000
[    4.969600] Bad eraseblock 428 at 0x000035800000
[    4.974466] Bad eraseblock 429 at 0x000035a00000
[    4.979362] Bad eraseblock 430 at 0x000035c00000
[    4.984230] Bad eraseblock 431 at 0x000035e00000
[    4.989115] Bad eraseblock 432 at 0x000036000000
[    4.993964] Bad eraseblock 433 at 0x000036200000
[    4.998869] Bad eraseblock 434 at 0x000036400000
[    5.003728] Bad eraseblock 435 at 0x000036600000
[    5.008630] Bad eraseblock 436 at 0x000036800000
[    5.013494] Bad eraseblock 437 at 0x000036a00000
[    5.018392] Bad eraseblock 438 at 0x000036c00000
[    5.023255] Bad eraseblock 439 at 0x000036e00000
[    5.028134] Bad eraseblock 440 at 0x000037000000
[    5.032976] Bad eraseblock 441 at 0x000037200000
[    5.037858] Bad eraseblock 442 at 0x000037400000
[    5.042701] Bad eraseblock 443 at 0x000037600000
[    5.047765] Bad eraseblock 444 at 0x000037800000
[    5.052643] Bad eraseblock 445 at 0x000037a00000
[    5.057559] Bad eraseblock 446 at 0x000037c00000
[    5.062430] Bad eraseblock 447 at 0x000037e00000
[    5.067326] Bad eraseblock 448 at 0x000038000000
[    5.072179] Bad eraseblock 449 at 0x000038200000
[    5.077100] Bad eraseblock 450 at 0x000038400000
[    5.081970] Bad eraseblock 451 at 0x000038600000
[    5.086862] Bad eraseblock 452 at 0x000038800000
[    5.091710] Bad eraseblock 453 at 0x000038a00000
[    5.096691] Bad eraseblock 454 at 0x000038c00000
[    5.101568] Bad eraseblock 455 at 0x000038e00000
[    5.106458] Bad eraseblock 456 at 0x000039000000
[    5.111306] Bad eraseblock 457 at 0x000039200000
[    5.116215] Bad eraseblock 458 at 0x000039400000
[    5.121087] Bad eraseblock 459 at 0x000039600000
[    5.125956] Bad eraseblock 460 at 0x000039800000
[    5.130863] Bad eraseblock 461 at 0x000039a00000
[    5.135736] Bad eraseblock 462 at 0x000039c00000
[    5.140636] Bad eraseblock 463 at 0x000039e00000
[    5.145504] Bad eraseblock 464 at 0x00003a000000
[    5.150404] Bad eraseblock 465 at 0x00003a200000
[    5.155280] Bad eraseblock 466 at 0x00003a400000
[    5.160164] Bad eraseblock 467 at 0x00003a600000
[    5.165006] Bad eraseblock 468 at 0x00003a800000
[    5.169916] Bad eraseblock 469 at 0x00003aa00000
[    5.174780] Bad eraseblock 470 at 0x00003ac00000
[    5.179682] Bad eraseblock 471 at 0x00003ae00000
[    5.184551] Bad eraseblock 472 at 0x00003b000000
[    5.189448] Bad eraseblock 473 at 0x00003b200000
[    5.194311] Bad eraseblock 474 at 0x00003b400000
[    5.199187] Bad eraseblock 475 at 0x00003b600000
[    5.204040] Bad eraseblock 476 at 0x00003b800000
[    5.208949] Bad eraseblock 477 at 0x00003ba00000
[    5.213814] Bad eraseblock 478 at 0x00003bc00000
[    5.218721] Bad eraseblock 479 at 0x00003be00000
[    5.223587] Bad eraseblock 480 at 0x00003c000000
[    5.228488] Bad eraseblock 481 at 0x00003c200000
[    5.233357] Bad eraseblock 482 at 0x00003c400000
[    5.238241] Bad eraseblock 483 at 0x00003c600000
[    5.243093] Bad eraseblock 484 at 0x00003c800000
[    5.248009] Bad eraseblock 485 at 0x00003ca00000
[    5.252872] Bad eraseblock 486 at 0x00003cc00000
[    5.257771] Bad eraseblock 487 at 0x00003ce00000
[    5.262637] Bad eraseblock 488 at 0x00003d000000
[    5.267539] Bad eraseblock 489 at 0x00003d200000
[    5.272405] Bad eraseblock 490 at 0x00003d400000
[    5.277289] Bad eraseblock 491 at 0x00003d600000
[    5.282136] Bad eraseblock 492 at 0x00003d800000
[    5.287023] Bad eraseblock 493 at 0x00003da00000
[    5.291869] Bad eraseblock 494 at 0x00003dc00000
[    5.296831] Bad eraseblock 495 at 0x00003de00000
[    5.301702] Bad eraseblock 496 at 0x00003e000000
[    5.306606] Bad eraseblock 497 at 0x00003e200000
[    5.311478] Bad eraseblock 498 at 0x00003e400000
[    5.316363] Bad eraseblock 499 at 0x00003e600000
[    5.321207] Bad eraseblock 500 at 0x00003e800000
[    5.326054] Bad eraseblock 501 at 0x00003ea00000
[    5.330974] Bad eraseblock 502 at 0x00003ec00000
[    5.335842] Bad eraseblock 503 at 0x00003ee00000
[    5.340748] Bad eraseblock 504 at 0x00003f000000
[    5.345610] Bad eraseblock 505 at 0x00003f200000
[    5.350515] Bad eraseblock 506 at 0x00003f400000
[    5.355378] Bad eraseblock 507 at 0x00003f600000
[    5.360266] Bad eraseblock 508 at 0x00003f800000
[    5.365107] Bad eraseblock 509 at 0x00003fa00000
[    5.370013] Bad eraseblock 510 at 0x00003fc00000
[    5.374878] Bad eraseblock 511 at 0x00003fe00000
[    5.379786] Bad eraseblock 512 at 0x000040000000
[    5.384646] Bad eraseblock 513 at 0x000040200000
[    5.389542] Bad eraseblock 514 at 0x000040400000
[    5.394400] Bad eraseblock 515 at 0x000040600000
[    5.399279] Bad eraseblock 516 at 0x000040800000
[    5.404123] Bad eraseblock 517 at 0x000040a00000
[    5.409030] Bad eraseblock 518 at 0x000040c00000
[    5.413892] Bad eraseblock 519 at 0x000040e00000
[    5.418792] Bad eraseblock 520 at 0x000041000000
[    5.423668] Bad eraseblock 521 at 0x000041200000
[    5.428569] Bad eraseblock 522 at 0x000041400000
[    5.433429] Bad eraseblock 523 at 0x000041600000
[    5.438318] Bad eraseblock 524 at 0x000041800000
[    5.443160] Bad eraseblock 525 at 0x000041a00000
[    5.448063] Bad eraseblock 526 at 0x000041c00000
[    5.452928] Bad eraseblock 527 at 0x000041e00000
[    5.457830] Bad eraseblock 528 at 0x000042000000
[    5.462696] Bad eraseblock 529 at 0x000042200000
[    5.467595] Bad eraseblock 530 at 0x000042400000
[    5.472458] Bad eraseblock 531 at 0x000042600000
[    5.477345] Bad eraseblock 532 at 0x000042800000
[    5.482192] Bad eraseblock 533 at 0x000042a00000
[    5.487083] Bad eraseblock 534 at 0x000042c00000
[    5.491932] Bad eraseblock 535 at 0x000042e00000
[    5.496898] Bad eraseblock 536 at 0x000043000000
[    5.501768] Bad eraseblock 537 at 0x000043200000
[    5.506673] Bad eraseblock 538 at 0x000043400000
[    5.511544] Bad eraseblock 539 at 0x000043600000
[    5.516427] Bad eraseblock 540 at 0x000043800000
[    5.521274] Bad eraseblock 541 at 0x000043a00000
[    5.526116] Bad eraseblock 542 at 0x000043c00000
[    5.531023] Bad eraseblock 543 at 0x000043e00000
[    5.535889] Bad eraseblock 544 at 0x000044000000
[    5.540791] Bad eraseblock 545 at 0x000044200000
[    5.545654] Bad eraseblock 546 at 0x000044400000
[    5.550552] Bad eraseblock 547 at 0x000044600000
[    5.555416] Bad eraseblock 548 at 0x000044800000
[    5.560296] Bad eraseblock 549 at 0x000044a00000
[    5.565134] Bad eraseblock 550 at 0x000044c00000
[    5.570040] Bad eraseblock 551 at 0x000044e00000
[    5.574907] Bad eraseblock 552 at 0x000045000000
[    5.579807] Bad eraseblock 553 at 0x000045200000
[    5.584666] Bad eraseblock 554 at 0x000045400000
[    5.589569] Bad eraseblock 555 at 0x000045600000
[    5.594435] Bad eraseblock 556 at 0x000045800000
[    5.599318] Bad eraseblock 557 at 0x000045a00000
[    5.604158] Bad eraseblock 558 at 0x000045c00000
[    5.609060] Bad eraseblock 559 at 0x000045e00000
[    5.613926] Bad eraseblock 560 at 0x000046000000
[    5.618823] Bad eraseblock 561 at 0x000046200000
[    5.623688] Bad eraseblock 562 at 0x000046400000
[    5.628589] Bad eraseblock 563 at 0x000046600000
[    5.633455] Bad eraseblock 564 at 0x000046800000
[    5.638334] Bad eraseblock 565 at 0x000046a00000
[    5.643180] Bad eraseblock 566 at 0x000046c00000
[    5.648082] Bad eraseblock 567 at 0x000046e00000
[    5.652955] Bad eraseblock 568 at 0x000047000000
[    5.657857] Bad eraseblock 569 at 0x000047200000
[    5.662718] Bad eraseblock 570 at 0x000047400000
[    5.667623] Bad eraseblock 571 at 0x000047600000
[    5.672488] Bad eraseblock 572 at 0x000047800000
[    5.677372] Bad eraseblock 573 at 0x000047a00000
[    5.682215] Bad eraseblock 574 at 0x000047c00000
[    5.687098] Bad eraseblock 575 at 0x000047e00000
[    5.691954] Bad eraseblock 576 at 0x000048000000
[    5.696922] Bad eraseblock 577 at 0x000048200000
[    5.701792] Bad eraseblock 578 at 0x000048400000
[    5.706696] Bad eraseblock 579 at 0x000048600000
[    5.711559] Bad eraseblock 580 at 0x000048800000
[    5.716442] Bad eraseblock 581 at 0x000048a00000
[    5.721287] Bad eraseblock 582 at 0x000048c00000
[    5.726168] Bad eraseblock 583 at 0x000048e00000
[    5.731034] Bad eraseblock 584 at 0x000049000000
[    5.735894] Bad eraseblock 585 at 0x000049200000
[    5.740791] Bad eraseblock 586 at 0x000049400000
[    5.745653] Bad eraseblock 587 at 0x000049600000
[    5.750552] Bad eraseblock 588 at 0x000049800000
[    5.755416] Bad eraseblock 589 at 0x000049a00000
[    5.760301] Bad eraseblock 590 at 0x000049c00000
[    5.765145] Bad eraseblock 591 at 0x000049e00000
[    5.770050] Bad eraseblock 592 at 0x00004a000000
[    5.774915] Bad eraseblock 593 at 0x00004a200000
[    5.779815] Bad eraseblock 594 at 0x00004a400000
[    5.784678] Bad eraseblock 595 at 0x00004a600000
[    5.789579] Bad eraseblock 596 at 0x00004a800000
[    5.794445] Bad eraseblock 597 at 0x00004aa00000
[    5.799328] Bad eraseblock 598 at 0x00004ac00000
[    5.804170] Bad eraseblock 599 at 0x00004ae00000
[    5.809072] Bad eraseblock 600 at 0x00004b000000
[    5.813934] Bad eraseblock 601 at 0x00004b200000
[    5.818830] Bad eraseblock 602 at 0x00004b400000
[    5.823691] Bad eraseblock 603 at 0x00004b600000
[    5.828598] Bad eraseblock 604 at 0x00004b800000
[    5.833459] Bad eraseblock 605 at 0x00004ba00000
[    5.838337] Bad eraseblock 606 at 0x00004bc00000
[    5.843181] Bad eraseblock 607 at 0x00004be00000
[    5.848082] Bad eraseblock 608 at 0x00004c000000
[    5.852947] Bad eraseblock 609 at 0x00004c200000
[    5.857849] Bad eraseblock 610 at 0x00004c400000
[    5.862716] Bad eraseblock 611 at 0x00004c600000
[    5.867622] Bad eraseblock 612 at 0x00004c800000
[    5.872493] Bad eraseblock 613 at 0x00004ca00000
[    5.877370] Bad eraseblock 614 at 0x00004cc00000
[    5.882218] Bad eraseblock 615 at 0x00004ce00000
[    5.887106] Bad eraseblock 616 at 0x00004d000000
[    5.891945] Bad eraseblock 617 at 0x00004d200000
[    5.896907] Bad eraseblock 618 at 0x00004d400000
[    5.901779] Bad eraseblock 619 at 0x00004d600000
[    5.906679] Bad eraseblock 620 at 0x00004d800000
[    5.911548] Bad eraseblock 621 at 0x00004da00000
[    5.916435] Bad eraseblock 622 at 0x00004dc00000
[    5.921287] Bad eraseblock 623 at 0x00004de00000
[    5.926166] Bad eraseblock 624 at 0x00004e000000
[    5.931031] Bad eraseblock 625 at 0x00004e200000
[    5.935897] Bad eraseblock 626 at 0x00004e400000
[    5.940795] Bad eraseblock 627 at 0x00004e600000
[    5.945660] Bad eraseblock 628 at 0x00004e800000
[    5.950554] Bad eraseblock 629 at 0x00004ea00000
[    5.955426] Bad eraseblock 630 at 0x00004ec00000
[    5.960316] Bad eraseblock 631 at 0x00004ee00000
[    5.965165] Bad eraseblock 632 at 0x00004f000000
[    5.970066] Bad eraseblock 633 at 0x00004f200000
[    5.974932] Bad eraseblock 634 at 0x00004f400000
[    5.979832] Bad eraseblock 635 at 0x00004f600000
[    5.984698] Bad eraseblock 636 at 0x00004f800000
[    5.989594] Bad eraseblock 637 at 0x00004fa00000
[    5.994463] Bad eraseblock 638 at 0x00004fc00000
[    5.999343] Bad eraseblock 639 at 0x00004fe00000
[    6.004185] Bad eraseblock 640 at 0x000050000000
[    6.009100] Bad eraseblock 641 at 0x000050200000
[    6.013964] Bad eraseblock 642 at 0x000050400000
[    6.018868] Bad eraseblock 643 at 0x000050600000
[    6.023729] Bad eraseblock 644 at 0x000050800000
[    6.028628] Bad eraseblock 645 at 0x000050a00000
[    6.033499] Bad eraseblock 646 at 0x000050c00000
[    6.038379] Bad eraseblock 647 at 0x000050e00000
[    6.043227] Bad eraseblock 648 at 0x000051000000
[    6.048161] Bad eraseblock 649 at 0x000051200000
[    6.053014] Bad eraseblock 650 at 0x000051400000
[    6.057925] Bad eraseblock 651 at 0x000051600000
[    6.062795] Bad eraseblock 652 at 0x000051800000
[    6.067701] Bad eraseblock 653 at 0x000051a00000
[    6.072568] Bad eraseblock 654 at 0x000051c00000
[    6.077446] Bad eraseblock 655 at 0x000051e00000
[    6.082289] Bad eraseblock 656 at 0x000052000000
[    6.087178] Bad eraseblock 657 at 0x000052200000
[    6.092022] Bad eraseblock 658 at 0x000052400000
[    6.096985] Bad eraseblock 659 at 0x000052600000
[    6.101854] Bad eraseblock 660 at 0x000052800000
[    6.106765] Bad eraseblock 661 at 0x000052a00000
[    6.111637] Bad eraseblock 662 at 0x000052c00000
[    6.116520] Bad eraseblock 663 at 0x000052e00000
[    6.121363] Bad eraseblock 664 at 0x000053000000
[    6.126248] Bad eraseblock 665 at 0x000053200000
[    6.131112] Bad eraseblock 666 at 0x000053400000
[    6.135970] Bad eraseblock 667 at 0x000053600000
[    6.140879] Bad eraseblock 668 at 0x000053800000
[    6.145743] Bad eraseblock 669 at 0x000053a00000
[    6.150647] Bad eraseblock 670 at 0x000053c00000
[    6.155518] Bad eraseblock 671 at 0x000053e00000
[    6.160425] Bad eraseblock 672 at 0x000054000000
[    6.165286] Bad eraseblock 673 at 0x000054200000
[    6.170169] Bad eraseblock 674 at 0x000054400000
[    6.175011] Bad eraseblock 675 at 0x000054600000
[    6.179920] Bad eraseblock 676 at 0x000054800000
[    6.184781] Bad eraseblock 677 at 0x000054a00000
[    6.189681] Bad eraseblock 678 at 0x000054c00000
[    6.194546] Bad eraseblock 679 at 0x000054e00000
[    6.199447] Bad eraseblock 680 at 0x000055000000
[    6.204313] Bad eraseblock 681 at 0x000055200000
[    6.209191] Bad eraseblock 682 at 0x000055400000
[    6.214034] Bad eraseblock 683 at 0x000055600000
[    6.218942] Bad eraseblock 684 at 0x000055800000
[    6.223807] Bad eraseblock 685 at 0x000055a00000
[    6.228713] Bad eraseblock 686 at 0x000055c00000
[    6.233583] Bad eraseblock 687 at 0x000055e00000
[    6.238486] Bad eraseblock 688 at 0x000056000000
[    6.243353] Bad eraseblock 689 at 0x000056200000
[    6.248239] Bad eraseblock 690 at 0x000056400000
[    6.253085] Bad eraseblock 691 at 0x000056600000
[    6.257974] Bad eraseblock 692 at 0x000056800000
[    6.262821] Bad eraseblock 693 at 0x000056a00000
[    6.267781] Bad eraseblock 694 at 0x000056c00000
[    6.272650] Bad eraseblock 695 at 0x000056e00000
[    6.277556] Bad eraseblock 696 at 0x000057000000
[    6.282430] Bad eraseblock 697 at 0x000057200000
[    6.287313] Bad eraseblock 698 at 0x000057400000
[    6.292169] Bad eraseblock 699 at 0x000057600000
[    6.297137] Bad eraseblock 700 at 0x000057800000
[    6.302015] Bad eraseblock 701 at 0x000057a00000
[    6.306923] Bad eraseblock 702 at 0x000057c00000
[    6.311794] Bad eraseblock 703 at 0x000057e00000
[    6.316702] Bad eraseblock 704 at 0x000058000000
[    6.321571] Bad eraseblock 705 at 0x000058200000
[    6.326451] Bad eraseblock 706 at 0x000058400000
[    6.331291] Bad eraseblock 707 at 0x000058600000
[    6.336170] Bad eraseblock 708 at 0x000058800000
[    6.341049] Bad eraseblock 709 at 0x000058a00000
[    6.345920] Bad eraseblock 710 at 0x000058c00000
[    6.350830] Bad eraseblock 711 at 0x000058e00000
[    6.355696] Bad eraseblock 712 at 0x000059000000
[    6.360598] Bad eraseblock 713 at 0x000059200000
[    6.365467] Bad eraseblock 714 at 0x000059400000
[    6.370373] Bad eraseblock 715 at 0x000059600000
[    6.375230] Bad eraseblock 716 at 0x000059800000
[    6.380117] Bad eraseblock 717 at 0x000059a00000
[    6.384970] Bad eraseblock 718 at 0x000059c00000
[    6.389872] Bad eraseblock 719 at 0x000059e00000
[    6.394742] Bad eraseblock 720 at 0x00005a000000
[    6.399652] Bad eraseblock 721 at 0x00005a200000
[    6.404517] Bad eraseblock 722 at 0x00005a400000
[    6.409429] Bad eraseblock 723 at 0x00005a600000
[    6.414295] Bad eraseblock 724 at 0x00005a800000
[    6.419175] Bad eraseblock 725 at 0x00005aa00000
[    6.424018] Bad eraseblock 726 at 0x00005ac00000
[    6.428924] Bad eraseblock 727 at 0x00005ae00000
[    6.433793] Bad eraseblock 728 at 0x00005b000000
[    6.438692] Bad eraseblock 729 at 0x00005b200000
[    6.443549] Bad eraseblock 730 at 0x00005b400000
[    6.448451] Bad eraseblock 731 at 0x00005b600000
[    6.453311] Bad eraseblock 732 at 0x00005b800000
[    6.458197] Bad eraseblock 733 at 0x00005ba00000
[    6.463039] Bad eraseblock 734 at 0x00005bc00000
[    6.467943] Bad eraseblock 735 at 0x00005be00000
[    6.472803] Bad eraseblock 736 at 0x00005c000000
[    6.477696] Bad eraseblock 737 at 0x00005c200000
[    6.482559] Bad eraseblock 738 at 0x00005c400000
[    6.487444] Bad eraseblock 739 at 0x00005c600000
[    6.492291] Bad eraseblock 740 at 0x00005c800000
[    6.497239] Bad eraseblock 741 at 0x00005ca00000
[    6.502086] Bad eraseblock 742 at 0x00005cc00000
[    6.507002] Bad eraseblock 743 at 0x00005ce00000
[    6.511867] Bad eraseblock 744 at 0x00005d000000
[    6.516770] Bad eraseblock 745 at 0x00005d200000
[    6.521636] Bad eraseblock 746 at 0x00005d400000
[    6.526535] Bad eraseblock 747 at 0x00005d600000
[    6.531402] Bad eraseblock 748 at 0x00005d800000
[    6.536249] Bad eraseblock 749 at 0x00005da00000
[    6.541099] Bad eraseblock 750 at 0x00005dc00000
[    6.545941] Bad eraseblock 751 at 0x00005de00000
[    6.550854] Bad eraseblock 752 at 0x00005e000000
[    6.555715] Bad eraseblock 753 at 0x00005e200000
[    6.560620] Bad eraseblock 754 at 0x00005e400000
[    6.565491] Bad eraseblock 755 at 0x00005e600000
[    6.570388] Bad eraseblock 756 at 0x00005e800000
[    6.575253] Bad eraseblock 757 at 0x00005ea00000
[    6.580136] Bad eraseblock 758 at 0x00005ec00000
[    6.584993] Bad eraseblock 759 at 0x00005ee00000
[    6.589899] Bad eraseblock 760 at 0x00005f000000
[    6.594759] Bad eraseblock 761 at 0x00005f200000
[    6.599660] Bad eraseblock 762 at 0x00005f400000
[    6.604526] Bad eraseblock 763 at 0x00005f600000
[    6.609428] Bad eraseblock 764 at 0x00005f800000
[    6.614293] Bad eraseblock 765 at 0x00005fa00000
[    6.619172] Bad eraseblock 766 at 0x00005fc00000
[    6.624015] Bad eraseblock 767 at 0x00005fe00000
[    6.628919] Bad eraseblock 768 at 0x000060000000
[    6.633787] Bad eraseblock 769 at 0x000060200000
[    6.638689] Bad eraseblock 770 at 0x000060400000
[    6.643548] Bad eraseblock 771 at 0x000060600000
[    6.648449] Bad eraseblock 772 at 0x000060800000
[    6.653319] Bad eraseblock 773 at 0x000060a00000
[    6.658203] Bad eraseblock 774 at 0x000060c00000
[    6.663053] Bad eraseblock 775 at 0x000060e00000
[    6.667956] Bad eraseblock 776 at 0x000061000000
[    6.672813] Bad eraseblock 777 at 0x000061200000
[    6.677720] Bad eraseblock 778 at 0x000061400000
[    6.682588] Bad eraseblock 779 at 0x000061600000
[    6.687472] Bad eraseblock 780 at 0x000061800000
[    6.692324] Bad eraseblock 781 at 0x000061a00000
[    6.697267] Bad eraseblock 782 at 0x000061c00000
[    6.702117] Bad eraseblock 783 at 0x000061e00000
[    6.707030] Bad eraseblock 784 at 0x000062000000
[    6.711900] Bad eraseblock 785 at 0x000062200000
[    6.716805] Bad eraseblock 786 at 0x000062400000
[    6.721665] Bad eraseblock 787 at 0x000062600000
[    6.726569] Bad eraseblock 788 at 0x000062800000
[    6.731431] Bad eraseblock 789 at 0x000062a00000
[    6.736280] Bad eraseblock 790 at 0x000062c00000
[    6.741131] Bad eraseblock 791 at 0x000062e00000
[    6.745974] Bad eraseblock 792 at 0x000063000000
[    6.750876] Bad eraseblock 793 at 0x000063200000
[    6.755741] Bad eraseblock 794 at 0x000063400000
[    6.760648] Bad eraseblock 795 at 0x000063600000
[    6.765514] Bad eraseblock 796 at 0x000063800000
[    6.770411] Bad eraseblock 797 at 0x000063a00000
[    6.775276] Bad eraseblock 798 at 0x000063c00000
[    6.780163] Bad eraseblock 799 at 0x000063e00000
[    6.785002] Bad eraseblock 800 at 0x000064000000
[    6.789909] Bad eraseblock 801 at 0x000064200000
[    6.794770] Bad eraseblock 802 at 0x000064400000
[    6.799672] Bad eraseblock 803 at 0x000064600000
[    6.804535] Bad eraseblock 804 at 0x000064800000
[    6.809437] Bad eraseblock 805 at 0x000064a00000
[    6.814309] Bad eraseblock 806 at 0x000064c00000
[    6.819194] Bad eraseblock 807 at 0x000064e00000
[    6.824034] Bad eraseblock 808 at 0x000065000000
[    6.828941] Bad eraseblock 809 at 0x000065200000
[    6.833807] Bad eraseblock 810 at 0x000065400000
[    6.838714] Bad eraseblock 811 at 0x000065600000
[    6.843577] Bad eraseblock 812 at 0x000065800000
[    6.848476] Bad eraseblock 813 at 0x000065a00000
[    6.853342] Bad eraseblock 814 at 0x000065c00000
[    6.858226] Bad eraseblock 815 at 0x000065e00000
[    6.863070] Bad eraseblock 816 at 0x000066000000
[    6.867978] Bad eraseblock 817 at 0x000066200000
[    6.872843] Bad eraseblock 818 at 0x000066400000
[    6.877749] Bad eraseblock 819 at 0x000066600000
[    6.882616] Bad eraseblock 820 at 0x000066800000
[    6.887497] Bad eraseblock 821 at 0x000066a00000
[    6.892340] Bad eraseblock 822 at 0x000066c00000
[    6.897290] Bad eraseblock 823 at 0x000066e00000
[    6.902131] Bad eraseblock 824 at 0x000067000000
[    6.907047] Bad eraseblock 825 at 0x000067200000
[    6.911916] Bad eraseblock 826 at 0x000067400000
[    6.916828] Bad eraseblock 827 at 0x000067600000
[    6.921691] Bad eraseblock 828 at 0x000067800000
[    6.926592] Bad eraseblock 829 at 0x000067a00000
[    6.931456] Bad eraseblock 830 at 0x000067c00000
[    6.936365] Bad eraseblock 831 at 0x000067e00000
[    6.941217] Bad eraseblock 832 at 0x000068000000
[    6.946065] Bad eraseblock 833 at 0x000068200000
[    6.950979] Bad eraseblock 834 at 0x000068400000
[    6.955851] Bad eraseblock 835 at 0x000068600000
[    6.960748] Bad eraseblock 836 at 0x000068800000
[    6.965612] Bad eraseblock 837 at 0x000068a00000
[    6.970510] Bad eraseblock 838 at 0x000068c00000
[    6.975371] Bad eraseblock 839 at 0x000068e00000
[    6.980250] Bad eraseblock 840 at 0x000069000000
[    6.985093] Bad eraseblock 841 at 0x000069200000
[    6.990001] Bad eraseblock 842 at 0x000069400000
[    6.994866] Bad eraseblock 843 at 0x000069600000
[    6.999768] Bad eraseblock 844 at 0x000069800000
[    7.004632] Bad eraseblock 845 at 0x000069a00000
[    7.009540] Bad eraseblock 846 at 0x000069c00000
[    7.014401] Bad eraseblock 847 at 0x000069e00000
[    7.019288] Bad eraseblock 848 at 0x00006a000000
[    7.024134] Bad eraseblock 849 at 0x00006a200000
[    7.029040] Bad eraseblock 850 at 0x00006a400000
[    7.033901] Bad eraseblock 851 at 0x00006a600000
[    7.038808] Bad eraseblock 852 at 0x00006a800000
[    7.043672] Bad eraseblock 853 at 0x00006aa00000
[    7.048623] Bad eraseblock 854 at 0x00006ac00000
[    7.053499] Bad eraseblock 855 at 0x00006ae00000
[    7.058388] Bad eraseblock 856 at 0x00006b000000
[    7.063233] Bad eraseblock 857 at 0x00006b200000
[    7.068145] Bad eraseblock 858 at 0x00006b400000
[    7.073016] Bad eraseblock 859 at 0x00006b600000
[    7.077917] Bad eraseblock 860 at 0x00006b800000
[    7.082783] Bad eraseblock 861 at 0x00006ba00000
[    7.087657] Bad eraseblock 862 at 0x00006bc00000
[    7.092502] Bad eraseblock 863 at 0x00006be00000
[    7.097437] Bad eraseblock 864 at 0x00006c000000
[    7.102286] Bad eraseblock 865 at 0x00006c200000
[    7.107201] Bad eraseblock 866 at 0x00006c400000
[    7.112067] Bad eraseblock 867 at 0x00006c600000
[    7.116967] Bad eraseblock 868 at 0x00006c800000
[    7.121843] Bad eraseblock 869 at 0x00006ca00000
[    7.126743] Bad eraseblock 870 at 0x00006cc00000
[    7.131612] Bad eraseblock 871 at 0x00006ce00000
[    7.136501] Bad eraseblock 872 at 0x00006d000000
[    7.141341] Bad eraseblock 873 at 0x00006d200000
[    7.146241] Bad eraseblock 874 at 0x00006d400000
[    7.151106] Bad eraseblock 875 at 0x00006d600000
[    7.155963] Bad eraseblock 876 at 0x00006d800000
[    7.160866] Bad eraseblock 877 at 0x00006da00000
[    7.165733] Bad eraseblock 878 at 0x00006dc00000
[    7.170635] Bad eraseblock 879 at 0x00006de00000
[    7.175501] Bad eraseblock 880 at 0x00006e000000
[    7.180396] Bad eraseblock 881 at 0x00006e200000
[    7.185255] Bad eraseblock 882 at 0x00006e400000
[    7.190142] Bad eraseblock 883 at 0x00006e600000
[    7.194982] Bad eraseblock 884 at 0x00006e800000
[    7.199896] Bad eraseblock 885 at 0x00006ea00000
[    7.204758] Bad eraseblock 886 at 0x00006ec00000
[    7.209655] Bad eraseblock 887 at 0x00006ee00000
[    7.214526] Bad eraseblock 888 at 0x00006f000000
[    7.219430] Bad eraseblock 889 at 0x00006f200000
[    7.224298] Bad eraseblock 890 at 0x00006f400000
[    7.229178] Bad eraseblock 891 at 0x00006f600000
[    7.234020] Bad eraseblock 892 at 0x00006f800000
[    7.238921] Bad eraseblock 893 at 0x00006fa00000
[    7.243785] Bad eraseblock 894 at 0x00006fc00000
[    7.248689] Bad eraseblock 895 at 0x00006fe00000
[    7.253560] Bad eraseblock 896 at 0x000070000000
[    7.258458] Bad eraseblock 897 at 0x000070200000
[    7.263322] Bad eraseblock 898 at 0x000070400000
[    7.268207] Bad eraseblock 899 at 0x000070600000
[    7.273054] Bad eraseblock 900 at 0x000070800000
[    7.277962] Bad eraseblock 901 at 0x000070a00000
[    7.282828] Bad eraseblock 902 at 0x000070c00000
[    7.287708] Bad eraseblock 903 at 0x000070e00000
[    7.292547] Bad eraseblock 904 at 0x000071000000
[    7.297514] Bad eraseblock 905 at 0x000071200000
[    7.302384] Bad eraseblock 906 at 0x000071400000
[    7.307270] Bad eraseblock 907 at 0x000071600000
[    7.312112] Bad eraseblock 908 at 0x000071800000
[    7.317018] Bad eraseblock 909 at 0x000071a00000
[    7.321882] Bad eraseblock 910 at 0x000071c00000
[    7.326780] Bad eraseblock 911 at 0x000071e00000
[    7.331647] Bad eraseblock 912 at 0x000072000000
[    7.336546] Bad eraseblock 913 at 0x000072200000
[    7.341414] Bad eraseblock 914 at 0x000072400000
[    7.346256] Bad eraseblock 915 at 0x000072600000
[    7.351106] Bad eraseblock 916 at 0x000072800000
[    7.355953] Bad eraseblock 917 at 0x000072a00000
[    7.360861] Bad eraseblock 918 at 0x000072c00000
[    7.365729] Bad eraseblock 919 at 0x000072e00000
[    7.370627] Bad eraseblock 920 at 0x000073000000
[    7.375493] Bad eraseblock 921 at 0x000073200000
[    7.380394] Bad eraseblock 922 at 0x000073400000
[    7.385259] Bad eraseblock 923 at 0x000073600000
[    7.390145] Bad eraseblock 924 at 0x000073800000
[    7.394989] Bad eraseblock 925 at 0x000073a00000
[    7.399893] Bad eraseblock 926 at 0x000073c00000
[    7.404754] Bad eraseblock 927 at 0x000073e00000
[    7.409659] Bad eraseblock 928 at 0x000074000000
[    7.414529] Bad eraseblock 929 at 0x000074200000
[    7.419433] Bad eraseblock 930 at 0x000074400000
[    7.424303] Bad eraseblock 931 at 0x000074600000
[    7.429182] Bad eraseblock 932 at 0x000074800000
[    7.434021] Bad eraseblock 933 at 0x000074a00000
[    7.438931] Bad eraseblock 934 at 0x000074c00000
[    7.443802] Bad eraseblock 935 at 0x000074e00000
[    7.448709] Bad eraseblock 936 at 0x000075000000
[    7.453574] Bad eraseblock 937 at 0x000075200000
[    7.458472] Bad eraseblock 938 at 0x000075400000
[    7.463336] Bad eraseblock 939 at 0x000075600000
[    7.468220] Bad eraseblock 940 at 0x000075800000
[    7.473068] Bad eraseblock 941 at 0x000075a00000
[    7.477972] Bad eraseblock 942 at 0x000075c00000
[    7.482845] Bad eraseblock 943 at 0x000075e00000
[    7.487739] Bad eraseblock 944 at 0x000076000000
[    7.492583] Bad eraseblock 945 at 0x000076200000
[    7.497554] Bad eraseblock 946 at 0x000076400000
[    7.502432] Bad eraseblock 947 at 0x000076600000
[    7.507326] Bad eraseblock 948 at 0x000076800000
[    7.512172] Bad eraseblock 949 at 0x000076a00000
[    7.517091] Bad eraseblock 950 at 0x000076c00000
[    7.521953] Bad eraseblock 951 at 0x000076e00000
[    7.526860] Bad eraseblock 952 at 0x000077000000
[    7.531731] Bad eraseblock 953 at 0x000077200000
[    7.536633] Bad eraseblock 954 at 0x000077400000
[    7.541498] Bad eraseblock 955 at 0x000077600000
[    7.546390] Bad eraseblock 956 at 0x000077800000
[    7.551230] Bad eraseblock 957 at 0x000077a00000
[    7.556074] Bad eraseblock 958 at 0x000077c00000
[    7.560980] Bad eraseblock 959 at 0x000077e00000
[    7.565846] Bad eraseblock 960 at 0x000078000000
[    7.570753] Bad eraseblock 961 at 0x000078200000
[    7.575629] Bad eraseblock 962 at 0x000078400000
[    7.580526] Bad eraseblock 963 at 0x000078600000
[    7.585392] Bad eraseblock 964 at 0x000078800000
[    7.590278] Bad eraseblock 965 at 0x000078a00000
[    7.595119] Bad eraseblock 966 at 0x000078c00000
[    7.600020] Bad eraseblock 967 at 0x000078e00000
[    7.604885] Bad eraseblock 968 at 0x000079000000
[    7.609782] Bad eraseblock 969 at 0x000079200000
[    7.614647] Bad eraseblock 970 at 0x000079400000
[    7.619552] Bad eraseblock 971 at 0x000079600000
[    7.624418] Bad eraseblock 972 at 0x000079800000
[    7.629300] Bad eraseblock 973 at 0x000079a00000
[    7.634144] Bad eraseblock 974 at 0x000079c00000
[    7.639048] Bad eraseblock 975 at 0x000079e00000
[    7.643917] Bad eraseblock 976 at 0x00007a000000
[    7.648821] Bad eraseblock 977 at 0x00007a200000
[    7.653691] Bad eraseblock 978 at 0x00007a400000
[    7.658595] Bad eraseblock 979 at 0x00007a600000
[    7.663458] Bad eraseblock 980 at 0x00007a800000
[    7.668344] Bad eraseblock 981 at 0x00007aa00000
[    7.673189] Bad eraseblock 982 at 0x00007ac00000
[    7.678100] Bad eraseblock 983 at 0x00007ae00000
[    7.682967] Bad eraseblock 984 at 0x00007b000000
[    7.687847] Bad eraseblock 985 at 0x00007b200000
[    7.692695] Bad eraseblock 986 at 0x00007b400000
[    7.697659] Bad eraseblock 987 at 0x00007b600000
[    7.702528] Bad eraseblock 988 at 0x00007b800000
[    7.707417] Bad eraseblock 989 at 0x00007ba00000
[    7.712263] Bad eraseblock 990 at 0x00007bc00000
[    7.717171] Bad eraseblock 991 at 0x00007be00000
[    7.722031] Bad eraseblock 992 at 0x00007c000000
[    7.726938] Bad eraseblock 993 at 0x00007c200000
[    7.731806] Bad eraseblock 994 at 0x00007c400000
[    7.736701] Bad eraseblock 995 at 0x00007c600000
[    7.741561] Bad eraseblock 996 at 0x00007c800000
[    7.746440] Bad eraseblock 997 at 0x00007ca00000
[    7.751289] Bad eraseblock 998 at 0x00007cc00000
[    7.756165] Bad eraseblock 999 at 0x00007ce00000
[    7.761032] Bad eraseblock 1000 at 0x00007d000000
[    7.765979] Bad eraseblock 1001 at 0x00007d200000
[    7.770964] Bad eraseblock 1002 at 0x00007d400000
[    7.775912] Bad eraseblock 1003 at 0x00007d600000
[    7.780903] Bad eraseblock 1004 at 0x00007d800000
[    7.785852] Bad eraseblock 1005 at 0x00007da00000
[    7.790817] Bad eraseblock 1006 at 0x00007dc00000
[    7.795756] Bad eraseblock 1007 at 0x00007de00000
[    7.800749] Bad eraseblock 1008 at 0x00007e000000
[    7.805706] Bad eraseblock 1009 at 0x00007e200000
[    7.810689] Bad eraseblock 1010 at 0x00007e400000
[    7.815640] Bad eraseblock 1011 at 0x00007e600000
[    7.820624] Bad eraseblock 1012 at 0x00007e800000
[    7.825578] Bad eraseblock 1013 at 0x00007ea00000
[    7.830538] Bad eraseblock 1014 at 0x00007ec00000
[    7.835465] Bad eraseblock 1015 at 0x00007ee00000
[    7.840463] Bad eraseblock 1016 at 0x00007f000000
[    7.845412] Bad eraseblock 1017 at 0x00007f200000
[    7.850393] Bad eraseblock 1018 at 0x00007f400000
[    7.855341] Bad eraseblock 1019 at 0x00007f600000
[    7.860327] Bad eraseblock 1020 at 0x00007f800000
[    7.865285] Bad eraseblock 1021 at 0x00007fa00000
[    7.870251] Bad eraseblock 1022 at 0x00007fc00000
[    7.875180] Bad eraseblock 1023 at 0x00007fe00000
[    7.880169] Bad eraseblock 1024 at 0x000080000000
[    7.885113] Bad eraseblock 1025 at 0x000080200000
[    7.890093] Bad eraseblock 1026 at 0x000080400000
[    7.895022] Bad eraseblock 1027 at 0x000080600000
[    7.900079] Bad eraseblock 1028 at 0x000080800000
[    7.905039] Bad eraseblock 1029 at 0x000080a00000
[    7.910010] Bad eraseblock 1030 at 0x000080c00000
[    7.914939] Bad eraseblock 1031 at 0x000080e00000
[    7.919935] Bad eraseblock 1032 at 0x000081000000
[    7.924890] Bad eraseblock 1033 at 0x000081200000
[    7.929886] Bad eraseblock 1034 at 0x000081400000
[    7.934847] Bad eraseblock 1035 at 0x000081600000
[    7.939839] Bad eraseblock 1036 at 0x000081800000
[    7.944800] Bad eraseblock 1037 at 0x000081a00000
[    7.949771] Bad eraseblock 1038 at 0x000081c00000
[    7.954706] Bad eraseblock 1039 at 0x000081e00000
[    7.959701] Bad eraseblock 1040 at 0x000082000000
[    7.964660] Bad eraseblock 1041 at 0x000082200000
[    7.969654] Bad eraseblock 1042 at 0x000082400000
[    7.974606] Bad eraseblock 1043 at 0x000082600000
[    7.979590] Bad eraseblock 1044 at 0x000082800000
[    7.984538] Bad eraseblock 1045 at 0x000082a00000
[    7.989504] Bad eraseblock 1046 at 0x000082c00000
[    7.994435] Bad eraseblock 1047 at 0x000082e00000
[    7.999418] Bad eraseblock 1048 at 0x000083000000
[    8.004374] Bad eraseblock 1049 at 0x000083200000
[    8.009357] Bad eraseblock 1050 at 0x000083400000
[    8.014304] Bad eraseblock 1051 at 0x000083600000
[    8.019288] Bad eraseblock 1052 at 0x000083800000
[    8.024254] Bad eraseblock 1053 at 0x000083a00000
[    8.029222] Bad eraseblock 1054 at 0x000083c00000
[    8.034148] Bad eraseblock 1055 at 0x000083e00000
[    8.039144] Bad eraseblock 1056 at 0x000084000000
[    8.044092] Bad eraseblock 1057 at 0x000084200000
[    8.049127] Bad eraseblock 1058 at 0x000084400000
[    8.054078] Bad eraseblock 1059 at 0x000084600000
[    8.059070] Bad eraseblock 1060 at 0x000084800000
[    8.064028] Bad eraseblock 1061 at 0x000084a00000
[    8.068991] Bad eraseblock 1062 at 0x000084c00000
[    8.073924] Bad eraseblock 1063 at 0x000084e00000
[    8.078917] Bad eraseblock 1064 at 0x000085000000
[    8.083870] Bad eraseblock 1065 at 0x000085200000
[    8.088839] Bad eraseblock 1066 at 0x000085400000
[    8.093775] Bad eraseblock 1067 at 0x000085600000
[    8.098825] Bad eraseblock 1068 at 0x000085800000
[    8.103782] Bad eraseblock 1069 at 0x000085a00000
[    8.108755] Bad eraseblock 1070 at 0x000085c00000
[    8.113691] Bad eraseblock 1071 at 0x000085e00000
[    8.118686] Bad eraseblock 1072 at 0x000086000000
[    8.123640] Bad eraseblock 1073 at 0x000086200000
[    8.128631] Bad eraseblock 1074 at 0x000086400000
[    8.133584] Bad eraseblock 1075 at 0x000086600000
[    8.138567] Bad eraseblock 1076 at 0x000086800000
[    8.143520] Bad eraseblock 1077 at 0x000086a00000
[    8.148491] Bad eraseblock 1078 at 0x000086c00000
[    8.153421] Bad eraseblock 1079 at 0x000086e00000
[    8.158423] Bad eraseblock 1080 at 0x000087000000
[    8.163372] Bad eraseblock 1081 at 0x000087200000
[    8.168369] Bad eraseblock 1082 at 0x000087400000
[    8.173324] Bad eraseblock 1083 at 0x000087600000
[    8.178312] Bad eraseblock 1084 at 0x000087800000
[    8.183266] Bad eraseblock 1085 at 0x000087a00000
[    8.188235] Bad eraseblock 1086 at 0x000087c00000
[    8.193164] Bad eraseblock 1087 at 0x000087e00000
[    8.198157] Bad eraseblock 1088 at 0x000088000000
[    8.203112] Bad eraseblock 1089 at 0x000088200000
[    8.208101] Bad eraseblock 1090 at 0x000088400000
[    8.213049] Bad eraseblock 1091 at 0x000088600000
[    8.218033] Bad eraseblock 1092 at 0x000088800000
[    8.222984] Bad eraseblock 1093 at 0x000088a00000
[    8.227956] Bad eraseblock 1094 at 0x000088c00000
[    8.232888] Bad eraseblock 1095 at 0x000088e00000
[    8.237884] Bad eraseblock 1096 at 0x000089000000
[    8.242836] Bad eraseblock 1097 at 0x000089200000
[    8.247823] Bad eraseblock 1098 at 0x000089400000
[    8.252778] Bad eraseblock 1099 at 0x000089600000
[    8.257767] Bad eraseblock 1100 at 0x000089800000
[    8.262719] Bad eraseblock 1101 at 0x000089a00000
[    8.267689] Bad eraseblock 1102 at 0x000089c00000
[    8.272618] Bad eraseblock 1103 at 0x000089e00000
[    8.277614] Bad eraseblock 1104 at 0x00008a000000
[    8.282573] Bad eraseblock 1105 at 0x00008a200000
[    8.287544] Bad eraseblock 1106 at 0x00008a400000
[    8.292475] Bad eraseblock 1107 at 0x00008a600000
[    8.297532] Bad eraseblock 1108 at 0x00008a800000
[    8.302489] Bad eraseblock 1109 at 0x00008aa00000
[    8.307454] Bad eraseblock 1110 at 0x00008ac00000
[    8.312389] Bad eraseblock 1111 at 0x00008ae00000
[    8.317390] Bad eraseblock 1112 at 0x00008b000000
[    8.322344] Bad eraseblock 1113 at 0x00008b200000
[    8.327325] Bad eraseblock 1114 at 0x00008b400000
[    8.332277] Bad eraseblock 1115 at 0x00008b600000
[    8.337269] Bad eraseblock 1116 at 0x00008b800000
[    8.342222] Bad eraseblock 1117 at 0x00008ba00000
[    8.347191] Bad eraseblock 1118 at 0x00008bc00000
[    8.352119] Bad eraseblock 1119 at 0x00008be00000
[    8.357109] Bad eraseblock 1120 at 0x00008c000000
[    8.362058] Bad eraseblock 1121 at 0x00008c200000
[    8.367045] Bad eraseblock 1122 at 0x00008c400000
[    8.371993] Bad eraseblock 1123 at 0x00008c600000
[    8.376984] Bad eraseblock 1124 at 0x00008c800000
[    8.381939] Bad eraseblock 1125 at 0x00008ca00000
[    8.386916] Bad eraseblock 1126 at 0x00008cc00000
[    8.391855] Bad eraseblock 1127 at 0x00008ce00000
[    8.396846] Bad eraseblock 1128 at 0x00008d000000
[    8.401798] Bad eraseblock 1129 at 0x00008d200000
[    8.406782] Bad eraseblock 1130 at 0x00008d400000
[    8.411736] Bad eraseblock 1131 at 0x00008d600000
[    8.416724] Bad eraseblock 1132 at 0x00008d800000
[    8.421674] Bad eraseblock 1133 at 0x00008da00000
[    8.426639] Bad eraseblock 1134 at 0x00008dc00000
[    8.431563] Bad eraseblock 1135 at 0x00008de00000
[    8.436549] Bad eraseblock 1136 at 0x00008e000000
[    8.441504] Bad eraseblock 1137 at 0x00008e200000
[    8.446489] Bad eraseblock 1138 at 0x00008e400000
[    8.451439] Bad eraseblock 1139 at 0x00008e600000
[    8.456421] Bad eraseblock 1140 at 0x00008e800000
[    8.461367] Bad eraseblock 1141 at 0x00008ea00000
[    8.466363] Bad eraseblock 1142 at 0x00008ec00000
[    8.471296] Bad eraseblock 1143 at 0x00008ee00000
[    8.476257] Bad eraseblock 1144 at 0x00008f000000
[    8.481212] Bad eraseblock 1145 at 0x00008f200000
[    8.486171] Bad eraseblock 1146 at 0x00008f400000
[    8.491102] Bad eraseblock 1147 at 0x00008f600000
[    8.496026] Bad eraseblock 1148 at 0x00008f800000
[    8.501076] Bad eraseblock 1149 at 0x00008fa00000
[    8.506039] Bad eraseblock 1150 at 0x00008fc00000
[    8.511035] Bad eraseblock 1151 at 0x00008fe00000
[    8.515984] Bad eraseblock 1152 at 0x000090000000
[    8.520954] Bad eraseblock 1153 at 0x000090200000
[    8.525891] Bad eraseblock 1154 at 0x000090400000
[    8.530879] Bad eraseblock 1155 at 0x000090600000
[    8.535833] Bad eraseblock 1156 at 0x000090800000
[    8.540818] Bad eraseblock 1157 at 0x000090a00000
[    8.545773] Bad eraseblock 1158 at 0x000090c00000
[    8.550752] Bad eraseblock 1159 at 0x000090e00000
[    8.555702] Bad eraseblock 1160 at 0x000091000000
[    8.560667] Bad eraseblock 1161 at 0x000091200000
[    8.565604] Bad eraseblock 1162 at 0x000091400000
[    8.570606] Bad eraseblock 1163 at 0x000091600000
[    8.575565] Bad eraseblock 1164 at 0x000091800000
[    8.580548] Bad eraseblock 1165 at 0x000091a00000
[    8.585501] Bad eraseblock 1166 at 0x000091c00000
[    8.590489] Bad eraseblock 1167 at 0x000091e00000
[    8.595436] Bad eraseblock 1168 at 0x000092000000
[    8.600405] Bad eraseblock 1169 at 0x000092200000
[    8.605333] Bad eraseblock 1170 at 0x000092400000
[    8.610329] Bad eraseblock 1171 at 0x000092600000
[    8.615287] Bad eraseblock 1172 at 0x000092800000
[    8.620284] Bad eraseblock 1173 at 0x000092a00000
[    8.625235] Bad eraseblock 1174 at 0x000092c00000
[    8.630220] Bad eraseblock 1175 at 0x000092e00000
[    8.635168] Bad eraseblock 1176 at 0x000093000000
[    8.640145] Bad eraseblock 1177 at 0x000093200000
[    8.645077] Bad eraseblock 1178 at 0x000093400000
[    8.650073] Bad eraseblock 1179 at 0x000093600000
[    8.655023] Bad eraseblock 1180 at 0x000093800000
[    8.660021] Bad eraseblock 1181 at 0x000093a00000
[    8.664973] Bad eraseblock 1182 at 0x000093c00000
[    8.669965] Bad eraseblock 1183 at 0x000093e00000
[    8.674916] Bad eraseblock 1184 at 0x000094000000
[    8.679874] Bad eraseblock 1185 at 0x000094200000
[    8.684800] Bad eraseblock 1186 at 0x000094400000
[    8.689776] Bad eraseblock 1187 at 0x000094600000
[    8.694710] Bad eraseblock 1188 at 0x000094800000
[    8.699762] Bad eraseblock 1189 at 0x000094a00000
[    8.704719] Bad eraseblock 1190 at 0x000094c00000
[    8.709715] Bad eraseblock 1191 at 0x000094e00000
[    8.714670] Bad eraseblock 1192 at 0x000095000000
[    8.719641] Bad eraseblock 1193 at 0x000095200000
[    8.724571] Bad eraseblock 1194 at 0x000095400000
[    8.729566] Bad eraseblock 1195 at 0x000095600000
[    8.734514] Bad eraseblock 1196 at 0x000095800000
[    8.739508] Bad eraseblock 1197 at 0x000095a00000
[    8.744457] Bad eraseblock 1198 at 0x000095c00000
[    8.749446] Bad eraseblock 1199 at 0x000095e00000
[    8.754397] Bad eraseblock 1200 at 0x000096000000
[    8.759367] Bad eraseblock 1201 at 0x000096200000
[    8.764307] Bad eraseblock 1202 at 0x000096400000
[    8.769295] Bad eraseblock 1203 at 0x000096600000
[    8.774254] Bad eraseblock 1204 at 0x000096800000
[    8.779245] Bad eraseblock 1205 at 0x000096a00000
[    8.784198] Bad eraseblock 1206 at 0x000096c00000
[    8.789187] Bad eraseblock 1207 at 0x000096e00000
[    8.794151] Bad eraseblock 1208 at 0x000097000000
[    8.799119] Bad eraseblock 1209 at 0x000097200000
[    8.804046] Bad eraseblock 1210 at 0x000097400000
[    8.809044] Bad eraseblock 1211 at 0x000097600000
[    8.813997] Bad eraseblock 1212 at 0x000097800000
[    8.818985] Bad eraseblock 1213 at 0x000097a00000
[    8.823939] Bad eraseblock 1214 at 0x000097c00000
[    8.828930] Bad eraseblock 1215 at 0x000097e00000
[    8.833890] Bad eraseblock 1216 at 0x000098000000
[    8.838862] Bad eraseblock 1217 at 0x000098200000
[    8.843801] Bad eraseblock 1218 at 0x000098400000
[    8.848801] Bad eraseblock 1219 at 0x000098600000
[    8.853753] Bad eraseblock 1220 at 0x000098800000
[    8.858742] Bad eraseblock 1221 at 0x000098a00000
[    8.863696] Bad eraseblock 1222 at 0x000098c00000
[    8.868684] Bad eraseblock 1223 at 0x000098e00000
[    8.873636] Bad eraseblock 1224 at 0x000099000000
[    8.878605] Bad eraseblock 1225 at 0x000099200000
[    8.883530] Bad eraseblock 1226 at 0x000099400000
[    8.888506] Bad eraseblock 1227 at 0x000099600000
[    8.893442] Bad eraseblock 1228 at 0x000099800000
[    8.898488] Bad eraseblock 1229 at 0x000099a00000
[    8.903443] Bad eraseblock 1230 at 0x000099c00000
[    8.908439] Bad eraseblock 1231 at 0x000099e00000
[    8.913387] Bad eraseblock 1232 at 0x00009a000000
[    8.918356] Bad eraseblock 1233 at 0x00009a200000
[    8.923289] Bad eraseblock 1234 at 0x00009a400000
[    8.928282] Bad eraseblock 1235 at 0x00009a600000
[    8.933240] Bad eraseblock 1236 at 0x00009a800000
[    8.938229] Bad eraseblock 1237 at 0x00009aa00000
[    8.943179] Bad eraseblock 1238 at 0x00009ac00000
[    8.948168] Bad eraseblock 1239 at 0x00009ae00000
[    8.953122] Bad eraseblock 1240 at 0x00009b000000
[    8.958095] Bad eraseblock 1241 at 0x00009b200000
[    8.963024] Bad eraseblock 1242 at 0x00009b400000
[    8.968018] Bad eraseblock 1243 at 0x00009b600000
[    8.972973] Bad eraseblock 1244 at 0x00009b800000
[    8.977968] Bad eraseblock 1245 at 0x00009ba00000
[    8.982921] Bad eraseblock 1246 at 0x00009bc00000
[    8.987904] Bad eraseblock 1247 at 0x00009be00000
[    8.992851] Bad eraseblock 1248 at 0x00009c000000
[    8.997824] Bad eraseblock 1249 at 0x00009c200000
[    9.002752] Bad eraseblock 1250 at 0x00009c400000
[    9.007743] Bad eraseblock 1251 at 0x00009c600000
[    9.012691] Bad eraseblock 1252 at 0x00009c800000
[    9.017679] Bad eraseblock 1253 at 0x00009ca00000
[    9.022638] Bad eraseblock 1254 at 0x00009cc00000
[    9.027628] Bad eraseblock 1255 at 0x00009ce00000
[    9.032586] Bad eraseblock 1256 at 0x00009d000000
[    9.037554] Bad eraseblock 1257 at 0x00009d200000
[    9.042479] Bad eraseblock 1258 at 0x00009d400000
[    9.047527] Bad eraseblock 1259 at 0x00009d600000
[    9.052487] Bad eraseblock 1260 at 0x00009d800000
[    9.057474] Bad eraseblock 1261 at 0x00009da00000
[    9.062427] Bad eraseblock 1262 at 0x00009dc00000
[    9.067417] Bad eraseblock 1263 at 0x00009de00000
[    9.072373] Bad eraseblock 1264 at 0x00009e000000
[    9.077341] Bad eraseblock 1265 at 0x00009e200000
[    9.082273] Bad eraseblock 1266 at 0x00009e400000
[    9.087248] Bad eraseblock 1267 at 0x00009e600000
[    9.092179] Bad eraseblock 1268 at 0x00009e800000
[    9.097233] Bad eraseblock 1269 at 0x00009ea00000
[    9.102195] Bad eraseblock 1270 at 0x00009ec00000
[    9.107184] Bad eraseblock 1271 at 0x00009ee00000
[    9.112134] Bad eraseblock 1272 at 0x00009f000000
[    9.117108] Bad eraseblock 1273 at 0x00009f200000
[    9.122038] Bad eraseblock 1274 at 0x00009f400000
[    9.127033] Bad eraseblock 1275 at 0x00009f600000
[    9.131987] Bad eraseblock 1276 at 0x00009f800000
[    9.136975] Bad eraseblock 1277 at 0x00009fa00000
[    9.141924] Bad eraseblock 1278 at 0x00009fc00000
[    9.146913] Bad eraseblock 1279 at 0x00009fe00000
[    9.151862] Bad eraseblock 1280 at 0x0000a0000000
[    9.156828] Bad eraseblock 1281 at 0x0000a0200000
[    9.161754] Bad eraseblock 1282 at 0x0000a0400000
[    9.166745] Bad eraseblock 1283 at 0x0000a0600000
[    9.171698] Bad eraseblock 1284 at 0x0000a0800000
[    9.176683] Bad eraseblock 1285 at 0x0000a0a00000
[    9.181631] Bad eraseblock 1286 at 0x0000a0c00000
[    9.186616] Bad eraseblock 1287 at 0x0000a0e00000
[    9.191574] Bad eraseblock 1288 at 0x0000a1000000
[    9.196540] Bad eraseblock 1289 at 0x0000a1200000
[    9.201471] Bad eraseblock 1290 at 0x0000a1400000
[    9.206472] Bad eraseblock 1291 at 0x0000a1600000
[    9.211429] Bad eraseblock 1292 at 0x0000a1800000
[    9.216412] Bad eraseblock 1293 at 0x0000a1a00000
[    9.221361] Bad eraseblock 1294 at 0x0000a1c00000
[    9.226354] Bad eraseblock 1295 at 0x0000a1e00000
[    9.231302] Bad eraseblock 1296 at 0x0000a2000000
[    9.236232] Bad eraseblock 1297 at 0x0000a2200000
[    9.241160] Bad eraseblock 1298 at 0x0000a2400000
[    9.246090] Bad eraseblock 1299 at 0x0000a2600000
[    9.251087] Bad eraseblock 1300 at 0x0000a2800000
[    9.256043] Bad eraseblock 1301 at 0x0000a2a00000
[    9.261022] Bad eraseblock 1302 at 0x0000a2c00000
[    9.265969] Bad eraseblock 1303 at 0x0000a2e00000
[    9.270957] Bad eraseblock 1304 at 0x0000a3000000
[    9.275909] Bad eraseblock 1305 at 0x0000a3200000
[    9.280873] Bad eraseblock 1306 at 0x0000a3400000
[    9.285807] Bad eraseblock 1307 at 0x0000a3600000
[    9.290779] Bad eraseblock 1308 at 0x0000a3800000
[    9.295725] Bad eraseblock 1309 at 0x0000a3a00000
[    9.300776] Bad eraseblock 1310 at 0x0000a3c00000
[    9.305741] Bad eraseblock 1311 at 0x0000a3e00000
[    9.310735] Bad eraseblock 1312 at 0x0000a4000000
[    9.315688] Bad eraseblock 1313 at 0x0000a4200000
[    9.320657] Bad eraseblock 1314 at 0x0000a4400000
[    9.470196] 9 ofpart partitions found on MTD device gpmi-nand
[    9.475976] Creating 9 MTD partitions on "gpmi-nand":
[    9.481115] 0x000000000000-0x000000400000 : "boot"
[    9.488812] 0x000000400000-0x000000600000 : "logo"
[    9.496512] 0x000000600000-0x000000800000 : "ENV"
[    9.503991] 0x000000800000-0x000000c00000 : "DTB"
[    9.511579] 0x000000c00000-0x000001400000 : "kernel"
[    9.519524] 0x000001400000-0x000001800000 : "DTBbak"
[    9.527178] 0x000001800000-0x000002000000 : "kernelbak"
[    9.534975] 0x000002000000-0x0000ff000000 : "rootfs"
[    9.543073] 0x0000ff000000-0x000100000000 : "reserved"
[    9.551063] gpmi-nand 1806000.gpmi-nand: driver registered.
[    9.561086] usbcore: registered new inte**ce driver usbhid
[    9.566791] usbhid: USB HID core driver
[    9.579187] wm8960 1-001a: Failed to issue reset
[    9.584065] wm8960: probe of 1-001a failed with error -5
[    9.591975] fsl-asrc 2034000.asrc: driver registered
[    9.604682] imx-wm8960 sound.16: failed to find codec platform device
[    9.611338] imx-wm8960: probe of sound.16 failed with error -22
[    9.620682] NET: Registered protocol family 26
[    9.625481] TCP: cubic registered
[    9.630470] NET: Registered protocol family 10
[    9.637281] sit: IPv6 over IPv4 tunneling driver
[    9.643877] NET: Registered protocol family 17
[    9.648556] can: controller area network core (rev 20120528 abi 9)
[    9.654938] NET: Registered protocol family 29
[    9.659469] can: raw protocol (rev 20120528)
[    9.663771] can: broadcast manager protocol (rev 20120528 t)
[    9.669515] can: netlink gateway (rev 20130117) max_hops=1
[    9.675744] Bluetooth: RFCOMM TTY layer initialized
[    9.680896] Bluetooth: RFCOMM socket layer initialized
[    9.686111] Bluetooth: RFCOMM ver 1.11
[    9.689968] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    9.695307] Bluetooth: BNEP filters: protocol multicast
[    9.700713] Bluetooth: BNEP socket layer initialized
[    9.705712] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[    9.711714] Bluetooth: HIDP socket layer initialized
[    9.716839] 8021q: 802.1Q VLAN Support v1.8
[    9.721376] Key type dns_resolver registered
[    9.727218] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
[    9.750080] gpio_dvfs: disabling
[    9.753359] wifi-3v3: disabling
[    9.756638] vref-3v3: disabling
[    9.759812] can-3v3: disabling
[    9.762891] regulator-dummy: disabling
[    9.767691] imx mcc test is registered.
[    9.773712] input: gpio-keys.9 as /devices/soc0/gpio-keys.9/input/input2
[    9.781283] snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-02 02:38:44 UTC (95924)
[    9.809921] ALSA device list:
[    9.812932]   No soundcards found.
[    9.817679] Freeing unused kernel memory: 388K (80a25000 - 80a86000)
[    9.965343] random: nonblocking pool is initialized
Erasing 2048 Kibyte @ 200000 -- 100 % complete
mtd: mtd size too small
mtd_init failed!
Erasing 2048 Kibyte @ 0 -- 100 % complete
Erasing 2048 Kibyte @ 600000 -- 100 % complete
Writing data to block 0 at offset 0x0
Writing data to block 1 at offset 0x200000
Writing data to block 2 at offset 0x400000
Writing data to block 3 at offset 0x600000
flash_erase: Skipping bad block at 00000000
flash_erase: Skipping bad block at 00200000
flash_erase: Skipping bad block at 00400000
flash_erase: Skipping bad block at 00600000
flash_erase: Skipping bad block at 00800000
flash_erase: Skipping bad block at 00a00000
flash_erase: Skipping bad block at 00c00000
flash_erase: Skipping bad block at 00e00000
flash_erase: Skipping bad block at 01000000
flash_erase: Skipping bad block at 01200000
flash_erase: Skipping bad block at 01400000
flash_erase: Skipping bad block at 01600000
flash_erase: Skipping bad block at 01800000
flash_erase: Skipping bad block at 01a00000
flash_erase: Skipping bad block at 01c00000
flash_erase: Skipping bad block at 01e00000
flash_erase: Skipping bad block at 02000000
flash_erase: Skipping bad block at 02200000
flash_erase: Skipping bad block at 02400000
flash_erase: Skipping bad block at 02600000
flash_erase: Skipping bad block at 02800000
flash_erase: Skipping bad block at 02a00000
flash_erase: Skipping bad block at 02c00000
flash_erase: Skipping bad block at 02e00000
flash_erase: Skipping bad block at 03000000
flash_erase: Skipping bad block at 03200000
flash_erase: Skipping bad block at 03400000
flash_erase: Skipping bad block at 03600000
flash_erase: Skipping bad block at 03800000
flash_erase: Skipping bad block at 03a00000
flash_erase: Skipping bad block at 03c00000
flash_erase: Skipping bad block at 03e00000
flash_erase: Skipping bad block at 04000000
flash_erase: Skipping bad block at 04200000
flash_erase: Skipping bad block at 04400000
flash_erase: Skipping bad block at 04600000
flash_erase: Skipping bad block at 04800000
flash_erase: Skipping bad block at 04a00000
flash_erase: Skipping bad block at 04c00000
Erasing 2048 Kibyte @ 9200000 --  3 % complete flash_erase: Skipping bad block at 09400000
flash_erase: Skipping bad block at 09600000
Erasing 2048 Kibyte @ c600000 --  4 % complete flash_erase: Skipping bad block at 0c800000
flash_erase: Skipping bad block at 0ca00000
flash_erase: Skipping bad block at 0cc00000
flash_erase: Skipping bad block at 0ce00000
flash_erase: Skipping bad block at 0d000000
flash_erase: Skipping bad block at 0d200000
flash_erase: Skipping bad block at 0d400000
flash_erase: Skipping bad block at 0d600000
flash_erase: Skipping bad block at 0d800000
flash_erase: Skipping bad block at 0da00000
flash_erase: Skipping bad block at 0dc00000
flash_erase: Skipping bad block at 0de00000
flash_erase: Skipping bad block at 0e000000
flash_erase: Skipping bad block at 0e200000
flash_erase: Skipping bad block at 0e400000
flash_erase: Skipping bad block at 0e600000
flash_erase: Skipping bad block at 0e800000
flash_erase: Skipping bad block at 0ea00000
flash_erase: Skipping bad block at 0ec00000
flash_erase: Skipping bad block at 0ee00000
flash_erase: Skipping bad block at 0f000000
flash_erase: Skipping bad block at 0f200000
flash_erase: Skipping bad block at 0f400000
flash_erase: Skipping bad block at 0f600000
flash_erase: Skipping bad block at 0f800000
flash_erase: Skipping bad block at 0fa00000
flash_erase: Skipping bad block at 0fc00000
flash_erase: Skipping bad block at 0fe00000
flash_erase: Skipping bad block at 10000000
flash_erase: Skipping bad block at 10200000
flash_erase: Skipping bad block at 10400000
flash_erase: Skipping bad block at 10600000
flash_erase: Skipping bad block at 10800000
flash_erase: Skipping bad block at 10a00000
flash_erase: Skipping bad block at 10c00000
flash_erase: Skipping bad block at 10e00000
flash_erase: Skipping bad block at 11000000
flash_erase: Skipping bad block at 11200000
flash_erase: Skipping bad block at 11400000
flash_erase: Skipping bad block at 11600000
flash_erase: Skipping bad block at 11800000
flash_erase: Skipping bad block at 11a00000
flash_erase: Skipping bad block at 11c00000
flash_erase: Skipping bad block at 11e00000
flash_erase: Skipping bad block at 12000000
flash_erase: Skipping bad block at 12200000
flash_erase: Skipping bad block at 12400000
flash_erase: Skipping bad block at 12600000
flash_erase: Skipping bad block at 12800000
flash_erase: Skipping bad block at 12a00000
flash_erase: Skipping bad block at 12c00000
flash_erase: Skipping bad block at 12e00000
flash_erase: Skipping bad block at 13000000
flash_erase: Skipping bad block at 13200000
flash_erase: Skipping bad block at 13400000
flash_erase: Skipping bad block at 13600000
flash_erase: Skipping bad block at 13800000
flash_erase: Skipping bad block at 13a00000
flash_erase: Skipping bad block at 13c00000
flash_erase: Skipping bad block at 13e00000
flash_erase: Skipping bad block at 14000000
flash_erase: Skipping bad block at 14200000
flash_erase: Skipping bad block at 14400000
flash_erase: Skipping bad block at 14600000
flash_erase: Skipping bad block at 14800000
flash_erase: Skipping bad block at 14a00000
flash_erase: Skipping bad block at 14c00000
flash_erase: Skipping bad block at 14e00000
flash_erase: Skipping bad block at 15000000
flash_erase: Skipping bad block at 15200000
flash_erase: Skipping bad block at 15400000
flash_erase: Skipping bad block at 15600000
flash_erase: Skipping bad block at 15800000
flash_erase: Skipping bad block at 15a00000
flash_erase: Skipping bad block at 15c00000
flash_erase: Skipping bad block at 15e00000
flash_erase: Skipping bad block at 16000000
flash_erase: Skipping bad block at 16200000
flash_erase: Skipping bad block at 16400000
flash_erase: Skipping bad block at 16600000
flash_erase: Skipping bad block at 16800000
flash_erase: Skipping bad block at 16a00000
flash_erase: Skipping bad block at 16c00000
flash_erase: Skipping bad block at 16e00000
flash_erase: Skipping bad block at 17000000
flash_erase: Skipping bad block at 17200000
flash_erase: Skipping bad block at 17400000
flash_erase: Skipping bad block at 17600000
flash_erase: Skipping bad block at 17800000
flash_erase: Skipping bad block at 17a00000
flash_erase: Skipping bad block at 17c00000
flash_erase: Skipping bad block at 17e00000
flash_erase: Skipping bad block at 18000000
flash_erase: Skipping bad block at 18200000
flash_erase: Skipping bad block at 18400000
flash_erase: Skipping bad block at 18600000
flash_erase: Skipping bad block at 18800000
flash_erase: Skipping bad block at 18a00000
flash_erase: Skipping bad block at 18c00000
flash_erase: Skipping bad block at 18e00000
flash_erase: Skipping bad block at 19000000
flash_erase: Skipping bad block at 19200000
flash_erase: Skipping bad block at 19400000
flash_erase: Skipping bad block at 19600000
flash_erase: Skipping bad block at 19800000
flash_erase: Skipping bad block at 19a00000
flash_erase: Skipping bad block at 19c00000
flash_erase: Skipping bad block at 19e00000
flash_erase: Skipping bad block at 1a000000
flash_erase: Skipping bad block at 1a200000
flash_erase: Skipping bad block at 1a400000
flash_erase: Skipping bad block at 1a600000
flash_erase: Skipping bad block at 1a800000
flash_erase: Skipping bad block at 1aa00000
flash_erase: Skipping bad block at 1ac00000
flash_erase: Skipping bad block at 1ae00000
flash_erase: Skipping bad block at 1b000000
flash_erase: Skipping bad block at 1b200000
flash_erase: Skipping bad block at 1b400000
flash_erase: Skipping bad block at 1b600000
flash_erase: Skipping bad block at 1b800000
flash_erase: Skipping bad block at 1ba00000
flash_erase: Skipping bad block at 1bc00000
flash_erase: Skipping bad block at 1be00000
flash_erase: Skipping bad block at 1c000000
flash_erase: Skipping bad block at 1c200000
flash_erase: Skipping bad block at 1c400000
flash_erase: Skipping bad block at 1c600000
flash_erase: Skipping bad block at 1c800000
flash_erase: Skipping bad block at 1ca00000
flash_erase: Skipping bad block at 1cc00000
flash_erase: Skipping bad block at 1ce00000
flash_erase: Skipping bad block at 1d000000
flash_erase: Skipping bad block at 1d200000
flash_erase: Skipping bad block at 1d400000
flash_erase: Skipping bad block at 1d600000
flash_erase: Skipping bad block at 1d800000
flash_erase: Skipping bad block at 1da00000
flash_erase: Skipping bad block at 1dc00000
flash_erase: Skipping bad block at 1de00000
flash_erase: Skipping bad block at 1e000000
flash_erase: Skipping bad block at 1e200000
flash_erase: Skipping bad block at 1e400000
flash_erase: Skipping bad block at 1e600000
flash_erase: Skipping bad block at 1e800000
flash_erase: Skipping bad block at 1ea00000
flash_erase: Skipping bad block at 1ec00000
flash_erase: Skipping bad block at 1ee00000
flash_erase: Skipping bad block at 1f000000
flash_erase: Skipping bad block at 1f200000
flash_erase: Skipping bad block at 1f400000
flash_erase: Skipping bad block at 1f600000
flash_erase: Skipping bad block at 1f800000
flash_erase: Skipping bad block at 1fa00000
flash_erase: Skipping bad block at 1fc00000
flash_erase: Skipping bad block at 1fe00000
flash_erase: Skipping bad block at 20000000
flash_erase: Skipping bad block at 20200000
flash_erase: Skipping bad block at 20400000
flash_erase: Skipping bad block at 20600000
flash_erase: Skipping bad block at 20800000
flash_erase: Skipping bad block at 20a00000
flash_erase: Skipping bad block at 20c00000
flash_erase: Skipping bad block at 20e00000
flash_erase: Skipping bad block at 21000000
flash_erase: Skipping bad block at 21200000
flash_erase: Skipping bad block at 21400000
flash_erase: Skipping bad block at 21600000
flash_erase: Skipping bad block at 21800000
flash_erase: Skipping bad block at 21a00000
flash_erase: Skipping bad block at 21c00000
flash_erase: Skipping bad block at 21e00000
flash_erase: Skipping bad block at 22000000
flash_erase: Skipping bad block at 22200000
flash_erase: Skipping bad block at 22400000
flash_erase: Skipping bad block at 22600000
flash_erase: Skipping bad block at 22800000
flash_erase: Skipping bad block at 22a00000
flash_erase: Skipping bad block at 22c00000
flash_erase: Skipping bad block at 22e00000
flash_erase: Skipping bad block at 23000000
flash_erase: Skipping bad block at 23200000
flash_erase: Skipping bad block at 23400000
flash_erase: Skipping bad block at 23600000
flash_erase: Skipping bad block at 23800000
flash_erase: Skipping bad block at 23a00000
flash_erase: Skipping bad block at 23c00000
flash_erase: Skipping bad block at 23e00000
flash_erase: Skipping bad block at 24000000
flash_erase: Skipping bad block at 24200000
flash_erase: Skipping bad block at 24400000
flash_erase: Skipping bad block at 24600000
flash_erase: Skipping bad block at 24800000
flash_erase: Skipping bad block at 24a00000
flash_erase: Skipping bad block at 24c00000
flash_erase: Skipping bad block at 24e00000
flash_erase: Skipping bad block at 25000000
flash_erase: Skipping bad block at 25200000
flash_erase: Skipping bad block at 25400000
flash_erase: Skipping bad block at 25600000
flash_erase: Skipping bad block at 25800000
flash_erase: Skipping bad block at 25a00000
flash_erase: Skipping bad block at 25c00000
flash_erase: Skipping bad block at 25e00000
flash_erase: Skipping bad block at 26000000
flash_erase: Skipping bad block at 26200000
flash_erase: Skipping bad block at 26400000
flash_erase: Skipping bad block at 26600000
flash_erase: Skipping bad block at 26800000
flash_erase: Skipping bad block at 26a00000
flash_erase: Skipping bad block at 26c00000
flash_erase: Skipping bad block at 26e00000
flash_erase: Skipping bad block at 27000000
flash_erase: Skipping bad block at 27200000
flash_erase: Skipping bad block at 27400000
flash_erase: Skipping bad block at 27600000
flash_erase: Skipping bad block at 27800000
flash_erase: Skipping bad block at 27a00000
flash_erase: Skipping bad block at 27c00000
flash_erase: Skipping bad block at 27e00000
flash_erase: Skipping bad block at 28000000
flash_erase: Skipping bad block at 28200000
flash_erase: Skipping bad block at 28400000
flash_erase: Skipping bad block at 28600000
flash_erase: Skipping bad block at 28800000
flash_erase: Skipping bad block at 28a00000
flash_erase: Skipping bad block at 28c00000
flash_erase: Skipping bad block at 28e00000
flash_erase: Skipping bad block at 29000000
flash_erase: Skipping bad block at 29200000
flash_erase: Skipping bad block at 29400000
flash_erase: Skipping bad block at 29600000
flash_erase: Skipping bad block at 29800000
flash_erase: Skipping bad block at 29a00000
flash_erase: Skipping bad block at 29c00000
flash_erase: Skipping bad block at 29e00000
flash_erase: Skipping bad block at 2a000000
flash_erase: Skipping bad block at 2a200000
flash_erase: Skipping bad block at 2a400000
flash_erase: Skipping bad block at 2a600000
flash_erase: Skipping bad block at 2a800000
flash_erase: Skipping bad block at 2aa00000
flash_erase: Skipping bad block at 2ac00000
flash_erase: Skipping bad block at 2ae00000
flash_erase: Skipping bad block at 2b000000
flash_erase: Skipping bad block at 2b200000
flash_erase: Skipping bad block at 2b400000
flash_erase: Skipping bad block at 2b600000
flash_erase: Skipping bad block at 2b800000
flash_erase: Skipping bad block at 2ba00000
flash_erase: Skipping bad block at 2bc00000
flash_erase: Skipping bad block at 2be00000
flash_erase: Skipping bad block at 2c000000
flash_erase: Skipping bad block at 2c200000
flash_erase: Skipping bad block at 2c400000
flash_erase: Skipping bad block at 2c600000
flash_erase: Skipping bad block at 2c800000
flash_erase: Skipping bad block at 2ca00000
flash_erase: Skipping bad block at 2cc00000
flash_erase: Skipping bad block at 2ce00000
flash_erase: Skipping bad block at 2d000000
flash_erase: Skipping bad block at 2d200000
flash_erase: Skipping bad block at 2d400000
flash_erase: Skipping bad block at 2d600000
flash_erase: Skipping bad block at 2d800000
flash_erase: Skipping bad block at 2da00000
flash_erase: Skipping bad block at 2dc00000
flash_erase: Skipping bad block at 2de00000
flash_erase: Skipping bad block at 2e000000
flash_erase: Skipping bad block at 2e200000
flash_erase: Skipping bad block at 2e400000
flash_erase: Skipping bad block at 2e600000
flash_erase: Skipping bad block at 2e800000
flash_erase: Skipping bad block at 2ea00000
flash_erase: Skipping bad block at 2ec00000
flash_erase: Skipping bad block at 2ee00000
flash_erase: Skipping bad block at 2f000000
flash_erase: Skipping bad block at 2f200000
flash_erase: Skipping bad block at 2f400000
flash_erase: Skipping bad block at 2f600000
flash_erase: Skipping bad block at 2f800000
flash_erase: Skipping bad block at 2fa00000
flash_erase: Skipping bad block at 2fc00000
flash_erase: Skipping bad block at 2fe00000
flash_erase: Skipping bad block at 30000000
flash_erase: Skipping bad block at 30200000
flash_erase: Skipping bad block at 30400000
flash_erase: Skipping bad block at 30600000
flash_erase: Skipping bad block at 30800000
flash_erase: Skipping bad block at 30a00000
flash_erase: Skipping bad block at 30c00000
flash_erase: Skipping bad block at 30e00000
flash_erase: Skipping bad block at 31000000
flash_erase: Skipping bad block at 31200000
flash_erase: Skipping bad block at 31400000
flash_erase: Skipping bad block at 31600000
flash_erase: Skipping bad block at 31800000
flash_erase: Skipping bad block at 31a00000
flash_erase: Skipping bad block at 31c00000
flash_erase: Skipping bad block at 31e00000
flash_erase: Skipping bad block at 32000000
flash_erase: Skipping bad block at 32200000
flash_erase: Skipping bad block at 32400000
flash_erase: Skipping bad block at 32600000
flash_erase: Skipping bad block at 32800000
flash_erase: Skipping bad block at 32a00000
flash_erase: Skipping bad block at 32c00000
flash_erase: Skipping bad block at 32e00000
flash_erase: Skipping bad block at 33000000
flash_erase: Skipping bad block at 33200000
flash_erase: Skipping bad block at 33400000
flash_erase: Skipping bad block at 33600000
flash_erase: Skipping bad block at 33800000
flash_erase: Skipping bad block at 33a00000
flash_erase: Skipping bad block at 33c00000
flash_erase: Skipping bad block at 33e00000
flash_erase: Skipping bad block at 34000000
flash_erase: Skipping bad block at 34200000
flash_erase: Skipping bad block at 34400000
flash_erase: Skipping bad block at 34600000
flash_erase: Skipping bad block at 34800000
flash_erase: Skipping bad block at 34a00000
flash_erase: Skipping bad block at 34c00000
flash_erase: Skipping bad block at 34e00000
flash_erase: Skipping bad block at 35000000
flash_erase: Skipping bad block at 35200000
flash_erase: Skipping bad block at 35400000
flash_erase: Skipping bad block at 35600000
flash_erase: Skipping bad block at 35800000
flash_erase: Skipping bad block at 35a00000
flash_erase: Skipping bad block at 35c00000
flash_erase: Skipping bad block at 35e00000
flash_erase: Skipping bad block at 36000000
flash_erase: Skipping bad block at 36200000
flash_erase: Skipping bad block at 36400000
flash_erase: Skipping bad block at 36600000
flash_erase: Skipping bad block at 36800000
flash_erase: Skipping bad block at 36a00000
flash_erase: Skipping bad block at 36c00000
flash_erase: Skipping bad block at 36e00000
flash_erase: Skipping bad block at 37000000
flash_erase: Skipping bad block at 37200000
flash_erase: Skipping bad block at 37400000
flash_erase: Skipping bad block at 37600000
flash_erase: Skipping bad block at 37800000
flash_erase: Skipping bad block at 37a00000
flash_erase: Skipping bad block at 37c00000
flash_erase: Skipping bad block at 37e00000
flash_erase: Skipping bad block at 38000000
flash_erase: Skipping bad block at 38200000
flash_erase: Skipping bad block at 38400000
flash_erase: Skipping bad block at 38600000
flash_erase: Skipping bad block at 38800000
flash_erase: Skipping bad block at 38a00000
flash_erase: Skipping bad block at 38c00000
flash_erase: Skipping bad block at 38e00000
flash_erase: Skipping bad block at 39000000
flash_erase: Skipping bad block at 39200000
flash_erase: Skipping bad block at 39400000
flash_erase: Skipping bad block at 39600000
flash_erase: Skipping bad block at 39800000
flash_erase: Skipping bad block at 39a00000
flash_erase: Skipping bad block at 39c00000
flash_erase: Skipping bad block at 39e00000
flash_erase: Skipping bad block at 3a000000
flash_erase: Skipping bad block at 3a200000
flash_erase: Skipping bad block at 3a400000
flash_erase: Skipping bad block at 3a600000
flash_erase: Skipping bad block at 3a800000
flash_erase: Skipping bad block at 3aa00000
flash_erase: Skipping bad block at 3ac00000
flash_erase: Skipping bad block at 3ae00000
flash_erase: Skipping bad block at 3b000000
flash_erase: Skipping bad block at 3b200000
flash_erase: Skipping bad block at 3b400000
flash_erase: Skipping bad block at 3b600000
flash_erase: Skipping bad block at 3b800000
flash_erase: Skipping bad block at 3ba00000
flash_erase: Skipping bad block at 3bc00000
flash_erase: Skipping bad block at 3be00000
flash_erase: Skipping bad block at 3c000000
flash_erase: Skipping bad block at 3c200000
flash_erase: Skipping bad block at 3c400000
flash_erase: Skipping bad block at 3c600000
flash_erase: Skipping bad block at 3c800000
flash_erase: Skipping bad block at 3ca00000
flash_erase: Skipping bad block at 3cc00000
flash_erase: Skipping bad block at 3ce00000
flash_erase: Skipping bad block at 3d000000
flash_erase: Skipping bad block at 3d200000
flash_erase: Skipping bad block at 3d400000
flash_erase: Skipping bad block at 3d600000
flash_erase: Skipping bad block at 3d800000
flash_erase: Skipping bad block at 3da00000
flash_erase: Skipping bad block at 3dc00000
flash_erase: Skipping bad block at 3de00000
flash_erase: Skipping bad block at 3e000000
flash_erase: Skipping bad block at 3e200000
flash_erase: Skipping bad block at 3e400000
flash_erase: Skipping bad block at 3e600000
flash_erase: Skipping bad block at 3e800000
flash_erase: Skipping bad block at 3ea00000
flash_erase: Skipping bad block at 3ec00000
flash_erase: Skipping bad block at 3ee00000
flash_erase: Skipping bad block at 3f000000
flash_erase: Skipping bad block at 3f200000
flash_erase: Skipping bad block at 3f400000
flash_erase: Skipping bad block at 3f600000
flash_erase: Skipping bad block at 3f800000
flash_erase: Skipping bad block at 3fa00000
flash_erase: Skipping bad block at 3fc00000
flash_erase: Skipping bad block at 3fe00000
flash_erase: Skipping bad block at 40000000
flash_erase: Skipping bad block at 40200000
flash_erase: Skipping bad block at 40400000
flash_erase: Skipping bad block at 40600000
flash_erase: Skipping bad block at 40800000
flash_erase: Skipping bad block at 40a00000
flash_erase: Skipping bad block at 40c00000
flash_erase: Skipping bad block at 40e00000
flash_erase: Skipping bad block at 41000000
flash_erase: Skipping bad block at 41200000
flash_erase: Skipping bad block at 41400000
flash_erase: Skipping bad block at 41600000
flash_erase: Skipping bad block at 41800000
flash_erase: Skipping bad block at 41a00000
flash_erase: Skipping bad block at 41c00000
flash_erase: Skipping bad block at 41e00000
flash_erase: Skipping bad block at 42000000
flash_erase: Skipping bad block at 42200000
flash_erase: Skipping bad block at 42400000
flash_erase: Skipping bad block at 42600000
flash_erase: Skipping bad block at 42800000
flash_erase: Skipping bad block at 42a00000
flash_erase: Skipping bad block at 42c00000
flash_erase: Skipping bad block at 42e00000
flash_erase: Skipping bad block at 43000000
flash_erase: Skipping bad block at 43200000
flash_erase: Skipping bad block at 43400000
flash_erase: Skipping bad block at 43600000
flash_erase: Skipping bad block at 43800000
flash_erase: Skipping bad block at 43a00000
flash_erase: Skipping bad block at 43c00000
flash_erase: Skipping bad block at 43e00000
flash_erase: Skipping bad block at 44000000
flash_erase: Skipping bad block at 44200000
flash_erase: Skipping bad block at 44400000
flash_erase: Skipping bad block at 44600000
flash_erase: Skipping bad block at 44800000
flash_erase: Skipping bad block at 44a00000
flash_erase: Skipping bad block at 44c00000
flash_erase: Skipping bad block at 44e00000
flash_erase: Skipping bad block at 45000000
flash_erase: Skipping bad block at 45200000
flash_erase: Skipping bad block at 45400000
flash_erase: Skipping bad block at 45600000
flash_erase: Skipping bad block at 45800000
flash_erase: Skipping bad block at 45a00000
flash_erase: Skipping bad block at 45c00000
flash_erase: Skipping bad block at 45e00000
flash_erase: Skipping bad block at 46000000
flash_erase: Skipping bad block at 46200000
flash_erase: Skipping bad block at 46400000
flash_erase: Skipping bad block at 46600000
flash_erase: Skipping bad block at 46800000
flash_erase: Skipping bad block at 46a00000
flash_erase: Skipping bad block at 46c00000
flash_erase: Skipping bad block at 46e00000
flash_erase: Skipping bad block at 47000000
flash_erase: Skipping bad block at 47200000
flash_erase: Skipping bad block at 47400000
flash_erase: Skipping bad block at 47600000
flash_erase: Skipping bad block at 47800000
flash_erase: Skipping bad block at 47a00000
flash_erase: Skipping bad block at 47c00000
flash_erase: Skipping bad block at 47e00000
flash_erase: Skipping bad block at 48000000
flash_erase: Skipping bad block at 48200000
flash_erase: Skipping bad block at 48400000
flash_erase: Skipping bad block at 48600000
flash_erase: Skipping bad block at 48800000
flash_erase: Skipping bad block at 48a00000
flash_erase: Skipping bad block at 48c00000
flash_erase: Skipping bad block at 48e00000
flash_erase: Skipping bad block at 49000000
flash_erase: Skipping bad block at 49200000
flash_erase: Skipping bad block at 49400000
flash_erase: Skipping bad block at 49600000
flash_erase: Skipping bad block at 49800000
flash_erase: Skipping bad block at 49a00000
flash_erase: Skipping bad block at 49c00000
flash_erase: Skipping bad block at 49e00000
flash_erase: Skipping bad block at 4a000000
flash_erase: Skipping bad block at 4a200000
flash_erase: Skipping bad block at 4a400000
flash_erase: Skipping bad block at 4a600000
flash_erase: Skipping bad block at 4a800000
flash_erase: Skipping bad block at 4aa00000
flash_erase: Skipping bad block at 4ac00000
flash_erase: Skipping bad block at 4ae00000
flash_erase: Skipping bad block at 4b000000
flash_erase: Skipping bad block at 4b200000
flash_erase: Skipping bad block at 4b400000
flash_erase: Skipping bad block at 4b600000
flash_erase: Skipping bad block at 4b800000
flash_erase: Skipping bad block at 4ba00000
flash_erase: Skipping bad block at 4bc00000
flash_erase: Skipping bad block at 4be00000
flash_erase: Skipping bad block at 4c000000
flash_erase: Skipping bad block at 4c200000
flash_erase: Skipping bad block at 4c400000
flash_erase: Skipping bad block at 4c600000
flash_erase: Skipping bad block at 4c800000
flash_erase: Skipping bad block at 4ca00000
flash_erase: Skipping bad block at 4cc00000
flash_erase: Skipping bad block at 4ce00000
flash_erase: Skipping bad block at 4d000000
flash_erase: Skipping bad block at 4d200000
flash_erase: Skipping bad block at 4d400000
flash_erase: Skipping bad block at 4d600000
flash_erase: Skipping bad block at 4d800000
flash_erase: Skipping bad block at 4da00000
flash_erase: Skipping bad block at 4dc00000
flash_erase: Skipping bad block at 4de00000
flash_erase: Skipping bad block at 4e000000
flash_erase: Skipping bad block at 4e200000
flash_erase: Skipping bad block at 4e400000
flash_erase: Skipping bad block at 4e600000
flash_erase: Skipping bad block at 4e800000
flash_erase: Skipping bad block at 4ea00000
flash_erase: Skipping bad block at 4ec00000
flash_erase: Skipping bad block at 4ee00000
flash_erase: Skipping bad block at 4f000000
flash_erase: Skipping bad block at 4f200000
flash_erase: Skipping bad block at 4f400000
flash_erase: Skipping bad block at 4f600000
flash_erase: Skipping bad block at 4f800000
flash_erase: Skipping bad block at 4fa00000
flash_erase: Skipping bad block at 4fc00000
flash_erase: Skipping bad block at 4fe00000
flash_erase: Skipping bad block at 50000000
flash_erase: Skipping bad block at 50200000
flash_erase: Skipping bad block at 50400000
flash_erase: Skipping bad block at 50600000
flash_erase: Skipping bad block at 50800000
flash_erase: Skipping bad block at 50a00000
flash_erase: Skipping bad block at 50c00000
flash_erase: Skipping bad block at 50e00000
flash_erase: Skipping bad block at 51000000
flash_erase: Skipping bad block at 51200000
flash_erase: Skipping bad block at 51400000
flash_erase: Skipping bad block at 51600000
flash_erase: Skipping bad block at 51800000
flash_erase: Skipping bad block at 51a00000
flash_erase: Skipping bad block at 51c00000
flash_erase: Skipping bad block at 51e00000
flash_erase: Skipping bad block at 52000000
flash_erase: Skipping bad block at 52200000
flash_erase: Skipping bad block at 52400000
flash_erase: Skipping bad block at 52600000
flash_erase: Skipping bad block at 52800000
flash_erase: Skipping bad block at 52a00000
flash_erase: Skipping bad block at 52c00000
flash_erase: Skipping bad block at 52e00000
flash_erase: Skipping bad block at 53000000
flash_erase: Skipping bad block at 53200000
flash_erase: Skipping bad block at 53400000
flash_erase: Skipping bad block at 53600000
flash_erase: Skipping bad block at 53800000
flash_erase: Skipping bad block at 53a00000
flash_erase: Skipping bad block at 53c00000
flash_erase: Skipping bad block at 53e00000
flash_erase: Skipping bad block at 54000000
flash_erase: Skipping bad block at 54200000
flash_erase: Skipping bad block at 54400000
flash_erase: Skipping bad block at 54600000
flash_erase: Skipping bad block at 54800000
flash_erase: Skipping bad block at 54a00000
flash_erase: Skipping bad block at 54c00000
flash_erase: Skipping bad block at 54e00000
flash_erase: Skipping bad block at 55000000
flash_erase: Skipping bad block at 55200000
flash_erase: Skipping bad block at 55400000
flash_erase: Skipping bad block at 55600000
flash_erase: Skipping bad block at 55800000
flash_erase: Skipping bad block at 55a00000
flash_erase: Skipping bad block at 55c00000
flash_erase: Skipping bad block at 55e00000
flash_erase: Skipping bad block at 56000000
flash_erase: Skipping bad block at 56200000
flash_erase: Skipping bad block at 56400000
flash_erase: Skipping bad block at 56600000
flash_erase: Skipping bad block at 56800000
flash_erase: Skipping bad block at 56a00000
flash_erase: Skipping bad block at 56c00000
flash_erase: Skipping bad block at 56e00000
flash_erase: Skipping bad block at 57000000
flash_erase: Skipping bad block at 57200000
flash_erase: Skipping bad block at 57400000
flash_erase: Skipping bad block at 57600000
flash_erase: Skipping bad block at 57800000
flash_erase: Skipping bad block at 57a00000
flash_erase: Skipping bad block at 57c00000
flash_erase: Skipping bad block at 57e00000
flash_erase: Skipping bad block at 58000000
flash_erase: Skipping bad block at 58200000
flash_erase: Skipping bad block at 58400000
flash_erase: Skipping bad block at 58600000
flash_erase: Skipping bad block at 58800000
flash_erase: Skipping bad block at 58a00000
flash_erase: Skipping bad block at 58c00000
flash_erase: Skipping bad block at 58e00000
flash_erase: Skipping bad block at 59000000
flash_erase: Skipping bad block at 59200000
flash_erase: Skipping bad block at 59400000
flash_erase: Skipping bad block at 59600000
flash_erase: Skipping bad block at 59800000
flash_erase: Skipping bad block at 59a00000
flash_erase: Skipping bad block at 59c00000
flash_erase: Skipping bad block at 59e00000
flash_erase: Skipping bad block at 5a000000
flash_erase: Skipping bad block at 5a200000
flash_erase: Skipping bad block at 5a400000
flash_erase: Skipping bad block at 5a600000
flash_erase: Skipping bad block at 5a800000
flash_erase: Skipping bad block at 5aa00000
flash_erase: Skipping bad block at 5ac00000
flash_erase: Skipping bad block at 5ae00000
flash_erase: Skipping bad block at 5b000000
flash_erase: Skipping bad block at 5b200000
flash_erase: Skipping bad block at 5b400000
flash_erase: Skipping bad block at 5b600000
flash_erase: Skipping bad block at 5b800000
flash_erase: Skipping bad block at 5ba00000
flash_erase: Skipping bad block at 5bc00000
flash_erase: Skipping bad block at 5be00000
flash_erase: Skipping bad block at 5c000000
flash_erase: Skipping bad block at 5c200000
flash_erase: Skipping bad block at 5c400000
flash_erase: Skipping bad block at 5c600000
flash_erase: Skipping bad block at 5c800000
flash_erase: Skipping bad block at 5ca00000
flash_erase: Skipping bad block at 5cc00000
flash_erase: Skipping bad block at 5ce00000
flash_erase: Skipping bad block at 5d000000
flash_erase: Skipping bad block at 5d200000
flash_erase: Skipping bad block at 5d400000
flash_erase: Skipping bad block at 5d600000
flash_erase: Skipping bad block at 5d800000
flash_erase: Skipping bad block at 5da00000
flash_erase: Skipping bad block at 5dc00000
flash_erase: Skipping bad block at 5de00000
flash_erase: Skipping bad block at 5e000000
flash_erase: Skipping bad block at 5e200000
flash_erase: Skipping bad block at 5e400000
flash_erase: Skipping bad block at 5e600000
flash_erase: Skipping bad block at 5e800000
flash_erase: Skipping bad block at 5ea00000
flash_erase: Skipping bad block at 5ec00000
flash_erase: Skipping bad block at 5ee00000
flash_erase: Skipping bad block at 5f000000
flash_erase: Skipping bad block at 5f200000
flash_erase: Skipping bad block at 5f400000
flash_erase: Skipping bad block at 5f600000
flash_erase: Skipping bad block at 5f800000
flash_erase: Skipping bad block at 5fa00000
flash_erase: Skipping bad block at 5fc00000
flash_erase: Skipping bad block at 5fe00000
flash_erase: Skipping bad block at 60000000
flash_erase: Skipping bad block at 60200000
flash_erase: Skipping bad block at 60400000
flash_erase: Skipping bad block at 60600000
flash_erase: Skipping bad block at 60800000
flash_erase: Skipping bad block at 60a00000
flash_erase: Skipping bad block at 60c00000
flash_erase: Skipping bad block at 60e00000
flash_erase: Skipping bad block at 61000000
flash_erase: Skipping bad block at 61200000
flash_erase: Skipping bad block at 61400000
flash_erase: Skipping bad block at 61600000
flash_erase: Skipping bad block at 61800000
flash_erase: Skipping bad block at 61a00000
flash_erase: Skipping bad block at 61c00000
flash_erase: Skipping bad block at 61e00000
flash_erase: Skipping bad block at 62000000
flash_erase: Skipping bad block at 62200000
flash_erase: Skipping bad block at 62400000
flash_erase: Skipping bad block at 62600000
flash_erase: Skipping bad block at 62800000
flash_erase: Skipping bad block at 62a00000
flash_erase: Skipping bad block at 62c00000
flash_erase: Skipping bad block at 62e00000
flash_erase: Skipping bad block at 63000000
flash_erase: Skipping bad block at 63200000
flash_erase: Skipping bad block at 63400000
flash_erase: Skipping bad block at 63600000
flash_erase: Skipping bad block at 63800000
flash_erase: Skipping bad block at 63a00000
flash_erase: Skipping bad block at 63c00000
flash_erase: Skipping bad block at 63e00000
flash_erase: Skipping bad block at 64000000
flash_erase: Skipping bad block at 64200000
flash_erase: Skipping bad block at 64400000
flash_erase: Skipping bad block at 64600000
flash_erase: Skipping bad block at 64800000
flash_erase: Skipping bad block at 64a00000
flash_erase: Skipping bad block at 64c00000
flash_erase: Skipping bad block at 64e00000
flash_erase: Skipping bad block at 65000000
flash_erase: Skipping bad block at 65200000
flash_erase: Skipping bad block at 65400000
flash_erase: Skipping bad block at 65600000
flash_erase: Skipping bad block at 65800000
flash_erase: Skipping bad block at 65a00000
flash_erase: Skipping bad block at 65c00000
flash_erase: Skipping bad block at 65e00000
flash_erase: Skipping bad block at 66000000
flash_erase: Skipping bad block at 66200000
flash_erase: Skipping bad block at 66400000
flash_erase: Skipping bad block at 66600000
flash_erase: Skipping bad block at 66800000
flash_erase: Skipping bad block at 66a00000
flash_erase: Skipping bad block at 66c00000
flash_erase: Skipping bad block at 66e00000
flash_erase: Skipping bad block at 67000000
flash_erase: Skipping bad block at 67200000
flash_erase: Skipping bad block at 67400000
flash_erase: Skipping bad block at 67600000
flash_erase: Skipping bad block at 67800000
flash_erase: Skipping bad block at 67a00000
flash_erase: Skipping bad block at 67c00000
flash_erase: Skipping bad block at 67e00000
flash_erase: Skipping bad block at 68000000
flash_erase: Skipping bad block at 68200000
flash_erase: Skipping bad block at 68400000
flash_erase: Skipping bad block at 68600000
flash_erase: Skipping bad block at 68800000
flash_erase: Skipping bad block at 68a00000
flash_erase: Skipping bad block at 68c00000
flash_erase: Skipping bad block at 68e00000
flash_erase: Skipping bad block at 69000000
flash_erase: Skipping bad block at 69200000
flash_erase: Skipping bad block at 69400000
flash_erase: Skipping bad block at 69600000
flash_erase: Skipping bad block at 69800000
flash_erase: Skipping bad block at 69a00000
flash_erase: Skipping bad block at 69c00000
flash_erase: Skipping bad block at 69e00000
flash_erase: Skipping bad block at 6a000000
flash_erase: Skipping bad block at 6a200000
flash_erase: Skipping bad block at 6a400000
flash_erase: Skipping bad block at 6a600000
flash_erase: Skipping bad block at 6a800000
flash_erase: Skipping bad block at 6aa00000
flash_erase: Skipping bad block at 6ac00000
flash_erase: Skipping bad block at 6ae00000
flash_erase: Skipping bad block at 6b000000
flash_erase: Skipping bad block at 6b200000
flash_erase: Skipping bad block at 6b400000
flash_erase: Skipping bad block at 6b600000
flash_erase: Skipping bad block at 6b800000
flash_erase: Skipping bad block at 6ba00000
flash_erase: Skipping bad block at 6bc00000
flash_erase: Skipping bad block at 6be00000
flash_erase: Skipping bad block at 6c000000
flash_erase: Skipping bad block at 6c200000
flash_erase: Skipping bad block at 6c400000
flash_erase: Skipping bad block at 6c600000
flash_erase: Skipping bad block at 6c800000
flash_erase: Skipping bad block at 6ca00000
flash_erase: Skipping bad block at 6cc00000
flash_erase: Skipping bad block at 6ce00000
flash_erase: Skipping bad block at 6d000000
flash_erase: Skipping bad block at 6d200000
flash_erase: Skipping bad block at 6d400000
flash_erase: Skipping bad block at 6d600000
flash_erase: Skipping bad block at 6d800000
flash_erase: Skipping bad block at 6da00000
flash_erase: Skipping bad block at 6dc00000
flash_erase: Skipping bad block at 6de00000
flash_erase: Skipping bad block at 6e000000
flash_erase: Skipping bad block at 6e200000
flash_erase: Skipping bad block at 6e400000
flash_erase: Skipping bad block at 6e600000
flash_erase: Skipping bad block at 6e800000
flash_erase: Skipping bad block at 6ea00000
flash_erase: Skipping bad block at 6ec00000
flash_erase: Skipping bad block at 6ee00000
flash_erase: Skipping bad block at 6f000000
flash_erase: Skipping bad block at 6f200000
flash_erase: Skipping bad block at 6f400000
flash_erase: Skipping bad block at 6f600000
flash_erase: Skipping bad block at 6f800000
flash_erase: Skipping bad block at 6fa00000
flash_erase: Skipping bad block at 6fc00000
flash_erase: Skipping bad block at 6fe00000
flash_erase: Skipping bad block at 70000000
flash_erase: Skipping bad block at 70200000
flash_erase: Skipping bad block at 70400000
flash_erase: Skipping bad block at 70600000
flash_erase: Skipping bad block at 70800000
flash_erase: Skipping bad block at 70a00000
flash_erase: Skipping bad block at 70c00000
flash_erase: Skipping bad block at 70e00000
flash_erase: Skipping bad block at 71000000
flash_erase: Skipping bad block at 71200000
flash_erase: Skipping bad block at 71400000
flash_erase: Skipping bad block at 71600000
flash_erase: Skipping bad block at 71800000
flash_erase: Skipping bad block at 71a00000
flash_erase: Skipping bad block at 71c00000
flash_erase: Skipping bad block at 71e00000
flash_erase: Skipping bad block at 72000000
flash_erase: Skipping bad block at 72200000
flash_erase: Skipping bad block at 72400000
flash_erase: Skipping bad block at 72600000
flash_erase: Skipping bad block at 72800000
flash_erase: Skipping bad block at 72a00000
flash_erase: Skipping bad block at 72c00000
flash_erase: Skipping bad block at 72e00000
flash_erase: Skipping bad block at 73000000
flash_erase: Skipping bad block at 73200000
flash_erase: Skipping bad block at 73400000
flash_erase: Skipping bad block at 73600000
flash_erase: Skipping bad block at 73800000
flash_erase: Skipping bad block at 73a00000
flash_erase: Skipping bad block at 73c00000
flash_erase: Skipping bad block at 73e00000
flash_erase: Skipping bad block at 74000000
flash_erase: Skipping bad block at 74200000
flash_erase: Skipping bad block at 74400000
flash_erase: Skipping bad block at 74600000
flash_erase: Skipping bad block at 74800000
flash_erase: Skipping bad block at 74a00000
flash_erase: Skipping bad block at 74c00000
flash_erase: Skipping bad block at 74e00000
flash_erase: Skipping bad block at 75000000
flash_erase: Skipping bad block at 75200000
flash_erase: Skipping bad block at 75400000
flash_erase: Skipping bad block at 75600000
flash_erase: Skipping bad block at 75800000
flash_erase: Skipping bad block at 75a00000
flash_erase: Skipping bad block at 75c00000
flash_erase: Skipping bad block at 75e00000
flash_erase: Skipping bad block at 76000000
flash_erase: Skipping bad block at 76200000
flash_erase: Skipping bad block at 76400000
flash_erase: Skipping bad block at 76600000
flash_erase: Skipping bad block at 76800000
flash_erase: Skipping bad block at 76a00000
flash_erase: Skipping bad block at 76c00000
flash_erase: Skipping bad block at 76e00000
flash_erase: Skipping bad block at 77000000
flash_erase: Skipping bad block at 77200000
flash_erase: Skipping bad block at 77400000
flash_erase: Skipping bad block at 77600000
flash_erase: Skipping bad block at 77800000
flash_erase: Skipping bad block at 77a00000
flash_erase: Skipping bad block at 77c00000
flash_erase: Skipping bad block at 77e00000
flash_erase: Skipping bad block at 78000000
flash_erase: Skipping bad block at 78200000
flash_erase: Skipping bad block at 78400000
flash_erase: Skipping bad block at 78600000
flash_erase: Skipping bad block at 78800000
flash_erase: Skipping bad block at 78a00000
flash_erase: Skipping bad block at 78c00000
flash_erase: Skipping bad block at 78e00000
flash_erase: Skipping bad block at 79000000
flash_erase: Skipping bad block at 79200000
flash_erase: Skipping bad block at 79400000
flash_erase: Skipping bad block at 79600000
flash_erase: Skipping bad block at 79800000
flash_erase: Skipping bad block at 79a00000
flash_erase: Skipping bad block at 79c00000
flash_erase: Skipping bad block at 79e00000
flash_erase: Skipping bad block at 7a000000
flash_erase: Skipping bad block at 7a200000
flash_erase: Skipping bad block at 7a400000
flash_erase: Skipping bad block at 7a600000
flash_erase: Skipping bad block at 7a800000
flash_erase: Skipping bad block at 7aa00000
flash_erase: Skipping bad block at 7ac00000
flash_erase: Skipping bad block at 7ae00000
flash_erase: Skipping bad block at 7b000000
flash_erase: Skipping bad block at 7b200000
flash_erase: Skipping bad block at 7b400000
flash_erase: Skipping bad block at 7b600000
flash_erase: Skipping bad block at 7b800000
flash_erase: Skipping bad block at 7ba00000
flash_erase: Skipping bad block at 7bc00000
flash_erase: Skipping bad block at 7be00000
flash_erase: Skipping bad block at 7c000000
flash_erase: Skipping bad block at 7c200000
flash_erase: Skipping bad block at 7c400000
flash_erase: Skipping bad block at 7c600000
flash_erase: Skipping bad block at 7c800000
flash_erase: Skipping bad block at 7ca00000
flash_erase: Skipping bad block at 7cc00000
flash_erase: Skipping bad block at 7ce00000
flash_erase: Skipping bad block at 7d000000
flash_erase: Skipping bad block at 7d200000
flash_erase: Skipping bad block at 7d400000
flash_erase: Skipping bad block at 7d600000
flash_erase: Skipping bad block at 7d800000
flash_erase: Skipping bad block at 7da00000
flash_erase: Skipping bad block at 7dc00000
flash_erase: Skipping bad block at 7de00000
flash_erase: Skipping bad block at 7e000000
flash_erase: Skipping bad block at 7e200000
flash_erase: Skipping bad block at 7e400000
flash_erase: Skipping bad block at 7e600000
flash_erase: Skipping bad block at 7e800000
flash_erase: Skipping bad block at 7ea00000
flash_erase: Skipping bad block at 7ec00000
flash_erase: Skipping bad block at 7ee00000
flash_erase: Skipping bad block at 7f000000
flash_erase: Skipping bad block at 7f200000
flash_erase: Skipping bad block at 7f400000
flash_erase: Skipping bad block at 7f600000
flash_erase: Skipping bad block at 7f800000
flash_erase: Skipping bad block at 7fa00000
flash_erase: Skipping bad block at 7fc00000
flash_erase: Skipping bad block at 7fe00000
flash_erase: Skipping bad block at 80000000
flash_erase: Skipping bad block at 80200000
flash_erase: Skipping bad block at 80400000
flash_erase: Skipping bad block at 80600000
flash_erase: Skipping bad block at 80800000
flash_erase: Skipping bad block at 80a00000
flash_erase: Skipping bad block at 80c00000
flash_erase: Skipping bad block at 80e00000
flash_erase: Skipping bad block at 81000000
flash_erase: Skipping bad block at 81200000
flash_erase: Skipping bad block at 81400000
flash_erase: Skipping bad block at 81600000
flash_erase: Skipping bad block at 81800000
flash_erase: Skipping bad block at 81a00000
flash_erase: Skipping bad block at 81c00000
flash_erase: Skipping bad block at 81e00000
flash_erase: Skipping bad block at 82000000
flash_erase: Skipping bad block at 82200000
flash_erase: Skipping bad block at 82400000
flash_erase: Skipping bad block at 82600000
flash_erase: Skipping bad block at 82800000
flash_erase: Skipping bad block at 82a00000
flash_erase: Skipping bad block at 82c00000
flash_erase: Skipping bad block at 82e00000
flash_erase: Skipping bad block at 83000000
flash_erase: Skipping bad block at 83200000
flash_erase: Skipping bad block at 83400000
flash_erase: Skipping bad block at 83600000
flash_erase: Skipping bad block at 83800000
flash_erase: Skipping bad block at 83a00000
flash_erase: Skipping bad block at 83c00000
flash_erase: Skipping bad block at 83e00000
flash_erase: Skipping bad block at 84000000
flash_erase: Skipping bad block at 84200000
flash_erase: Skipping bad block at 84400000
flash_erase: Skipping bad block at 84600000
flash_erase: Skipping bad block at 84800000
flash_erase: Skipping bad block at 84a00000
flash_erase: Skipping bad block at 84c00000
flash_erase: Skipping bad block at 84e00000
flash_erase: Skipping bad block at 85000000
flash_erase: Skipping bad block at 85200000
flash_erase: Skipping bad block at 85400000
flash_erase: Skipping bad block at 85600000
flash_erase: Skipping bad block at 85800000
flash_erase: Skipping bad block at 85a00000
flash_erase: Skipping bad block at 85c00000
flash_erase: Skipping bad block at 85e00000
flash_erase: Skipping bad block at 86000000
flash_erase: Skipping bad block at 86200000
flash_erase: Skipping bad block at 86400000
flash_erase: Skipping bad block at 86600000
flash_erase: Skipping bad block at 86800000
flash_erase: Skipping bad block at 86a00000
flash_erase: Skipping bad block at 86c00000
flash_erase: Skipping bad block at 86e00000
flash_erase: Skipping bad block at 87000000
flash_erase: Skipping bad block at 87200000
flash_erase: Skipping bad block at 87400000
flash_erase: Skipping bad block at 87600000
flash_erase: Skipping bad block at 87800000
flash_erase: Skipping bad block at 87a00000
flash_erase: Skipping bad block at 87c00000
flash_erase: Skipping bad block at 87e00000
flash_erase: Skipping bad block at 88000000
flash_erase: Skipping bad block at 88200000
flash_erase: Skipping bad block at 88400000
flash_erase: Skipping bad block at 88600000
flash_erase: Skipping bad block at 88800000
flash_erase: Skipping bad block at 88a00000
flash_erase: Skipping bad block at 88c00000
flash_erase: Skipping bad block at 88e00000
flash_erase: Skipping bad block at 89000000
flash_erase: Skipping bad block at 89200000
flash_erase: Skipping bad block at 89400000
flash_erase: Skipping bad block at 89600000
flash_erase: Skipping bad block at 89800000
flash_erase: Skipping bad block at 89a00000
flash_erase: Skipping bad block at 89c00000
flash_erase: Skipping bad block at 89e00000
flash_erase: Skipping bad block at 8a000000
flash_erase: Skipping bad block at 8a200000
flash_erase: Skipping bad block at 8a400000
flash_erase: Skipping bad block at 8a600000
flash_erase: Skipping bad block at 8a800000
flash_erase: Skipping bad block at 8aa00000
flash_erase: Skipping bad block at 8ac00000
flash_erase: Skipping bad block at 8ae00000
flash_erase: Skipping bad block at 8b000000
flash_erase: Skipping bad block at 8b200000
flash_erase: Skipping bad block at 8b400000
flash_erase: Skipping bad block at 8b600000
flash_erase: Skipping bad block at 8b800000
flash_erase: Skipping bad block at 8ba00000
flash_erase: Skipping bad block at 8bc00000
flash_erase: Skipping bad block at 8be00000
flash_erase: Skipping bad block at 8c000000
flash_erase: Skipping bad block at 8c200000
flash_erase: Skipping bad block at 8c400000
flash_erase: Skipping bad block at 8c600000
flash_erase: Skipping bad block at 8c800000
flash_erase: Skipping bad block at 8ca00000
flash_erase: Skipping bad block at 8cc00000
flash_erase: Skipping bad block at 8ce00000
flash_erase: Skipping bad block at 8d000000
flash_erase: Skipping bad block at 8d200000
flash_erase: Skipping bad block at 8d400000
flash_erase: Skipping bad block at 8d600000
flash_erase: Skipping bad block at 8d800000
flash_erase: Skipping bad block at 8da00000
flash_erase: Skipping bad block at 8dc00000
flash_erase: Skipping bad block at 8de00000
flash_erase: Skipping bad block at 8e000000
flash_erase: Skipping bad block at 8e200000
flash_erase: Skipping bad block at 8e400000
flash_erase: Skipping bad block at 8e600000
flash_erase: Skipping bad block at 8e800000
flash_erase: Skipping bad block at 8ea00000
flash_erase: Skipping bad block at 8ec00000
flash_erase: Skipping bad block at 8ee00000
flash_erase: Skipping bad block at 8f000000
flash_erase: Skipping bad block at 8f200000
flash_erase: Skipping bad block at 8f400000
flash_erase: Skipping bad block at 8f600000
flash_erase: Skipping bad block at 8f800000
flash_erase: Skipping bad block at 8fa00000
flash_erase: Skipping bad block at 8fc00000
flash_erase: Skipping bad block at 8fe00000
flash_erase: Skipping bad block at 90000000
flash_erase: Skipping bad block at 90200000
flash_erase: Skipping bad block at 90400000
flash_erase: Skipping bad block at 90600000
flash_erase: Skipping bad block at 90800000
flash_erase: Skipping bad block at 90a00000
flash_erase: Skipping bad block at 90c00000
flash_erase: Skipping bad block at 90e00000
flash_erase: Skipping bad block at 91000000
flash_erase: Skipping bad block at 91200000
flash_erase: Skipping bad block at 91400000
flash_erase: Skipping bad block at 91600000
flash_erase: Skipping bad block at 91800000
flash_erase: Skipping bad block at 91a00000
flash_erase: Skipping bad block at 91c00000
flash_erase: Skipping bad block at 91e00000
flash_erase: Skipping bad block at 92000000
flash_erase: Skipping bad block at 92200000
flash_erase: Skipping bad block at 92400000
flash_erase: Skipping bad block at 92600000
flash_erase: Skipping bad block at 92800000
flash_erase: Skipping bad block at 92a00000
flash_erase: Skipping bad block at 92c00000
flash_erase: Skipping bad block at 92e00000
flash_erase: Skipping bad block at 93000000
flash_erase: Skipping bad block at 93200000
flash_erase: Skipping bad block at 93400000
flash_erase: Skipping bad block at 93600000
flash_erase: Skipping bad block at 93800000
flash_erase: Skipping bad block at 93a00000
flash_erase: Skipping bad block at 93c00000
flash_erase: Skipping bad block at 93e00000
flash_erase: Skipping bad block at 94000000
flash_erase: Skipping bad block at 94200000
flash_erase: Skipping bad block at 94400000
flash_erase: Skipping bad block at 94600000
flash_erase: Skipping bad block at 94800000
flash_erase: Skipping bad block at 94a00000
flash_erase: Skipping bad block at 94c00000
flash_erase: Skipping bad block at 94e00000
flash_erase: Skipping bad block at 95000000
flash_erase: Skipping bad block at 95200000
flash_erase: Skipping bad block at 95400000
flash_erase: Skipping bad block at 95600000
flash_erase: Skipping bad block at 95800000
flash_erase: Skipping bad block at 95a00000
flash_erase: Skipping bad block at 95c00000
flash_erase: Skipping bad block at 95e00000
flash_erase: Skipping bad block at 96000000
flash_erase: Skipping bad block at 96200000
flash_erase: Skipping bad block at 96400000
flash_erase: Skipping bad block at 96600000
flash_erase: Skipping bad block at 96800000
flash_erase: Skipping bad block at 96a00000
flash_erase: Skipping bad block at 96c00000
flash_erase: Skipping bad block at 96e00000
flash_erase: Skipping bad block at 97000000
flash_erase: Skipping bad block at 97200000
flash_erase: Skipping bad block at 97400000
flash_erase: Skipping bad block at 97600000
flash_erase: Skipping bad block at 97800000
flash_erase: Skipping bad block at 97a00000
flash_erase: Skipping bad block at 97c00000
flash_erase: Skipping bad block at 97e00000
flash_erase: Skipping bad block at 98000000
flash_erase: Skipping bad block at 98200000
flash_erase: Skipping bad block at 98400000
flash_erase: Skipping bad block at 98600000
flash_erase: Skipping bad block at 98800000
flash_erase: Skipping bad block at 98a00000
flash_erase: Skipping bad block at 98c00000
flash_erase: Skipping bad block at 98e00000
flash_erase: Skipping bad block at 99000000
flash_erase: Skipping bad block at 99200000
flash_erase: Skipping bad block at 99400000
flash_erase: Skipping bad block at 99600000
flash_erase: Skipping bad block at 99800000
flash_erase: Skipping bad block at 99a00000
flash_erase: Skipping bad block at 99c00000
flash_erase: Skipping bad block at 99e00000
flash_erase: Skipping bad block at 9a000000
flash_erase: Skipping bad block at 9a200000
flash_erase: Skipping bad block at 9a400000
flash_erase: Skipping bad block at 9a600000
flash_erase: Skipping bad block at 9a800000
flash_erase: Skipping bad block at 9aa00000
flash_erase: Skipping bad block at 9ac00000
flash_erase: Skipping bad block at 9ae00000
flash_erase: Skipping bad block at 9b000000
flash_erase: Skipping bad block at 9b200000
flash_erase: Skipping bad block at 9b400000
flash_erase: Skipping bad block at 9b600000
flash_erase: Skipping bad block at 9b800000
flash_erase: Skipping bad block at 9ba00000
flash_erase: Skipping bad block at 9bc00000
flash_erase: Skipping bad block at 9be00000
flash_erase: Skipping bad block at 9c000000
flash_erase: Skipping bad block at 9c200000
flash_erase: Skipping bad block at 9c400000
flash_erase: Skipping bad block at 9c600000
flash_erase: Skipping bad block at 9c800000
flash_erase: Skipping bad block at 9ca00000
flash_erase: Skipping bad block at 9cc00000
flash_erase: Skipping bad block at 9ce00000
flash_erase: Skipping bad block at 9d000000
flash_erase: Skipping bad block at 9d200000
flash_erase: Skipping bad block at 9d400000
flash_erase: Skipping bad block at 9d600000
flash_erase: Skipping bad block at 9d800000
flash_erase: Skipping bad block at 9da00000
flash_erase: Skipping bad block at 9dc00000
flash_erase: Skipping bad block at 9de00000
flash_erase: Skipping bad block at 9e000000
flash_erase: Skipping bad block at 9e200000
flash_erase: Skipping bad block at 9e400000
flash_erase: Skipping bad block at 9e600000
flash_erase: Skipping bad block at 9e800000
flash_erase: Skipping bad block at 9ea00000
flash_erase: Skipping bad block at 9ec00000
flash_erase: Skipping bad block at 9ee00000
flash_erase: Skipping bad block at 9f000000
flash_erase: Skipping bad block at 9f200000
flash_erase: Skipping bad block at 9f400000
flash_erase: Skipping bad block at 9f600000
flash_erase: Skipping bad block at 9f800000
flash_erase: Skipping bad block at 9fa00000
flash_erase: Skipping bad block at 9fc00000
flash_erase: Skipping bad block at 9fe00000
flash_erase: Skipping bad block at a0000000
flash_erase: Skipping bad block at a0200000
flash_erase: Skipping bad block at a0400000
flash_erase: Skipping bad block at a0600000
flash_erase: Skipping bad block at a0800000
flash_erase: Skipping bad block at a0a00000
flash_erase: Skipping bad block at a0c00000
flash_erase: Skipping bad block at a0e00000
flash_erase: Skipping bad block at a1000000
flash_erase: Skipping bad block at a1200000
flash_erase: Skipping bad block at a1400000
flash_erase: Skipping bad block at a1600000
flash_erase: Skipping bad block at a1800000
flash_erase: Skipping bad block at a1a00000
flash_erase: Skipping bad block at a1c00000
flash_erase: Skipping bad block at a1e00000
flash_erase: Skipping bad block at a2000000
flash_erase: Skipping bad block at a2200000
flash_erase: Skipping bad block at a2400000
Erasing 2048 Kibyte @ f3400000 --[   21.327159] yaffs: dev is 32505863 name is "mtdblock7" rw
Erasing 2048 Kiby[   21.334304] yaffs: passed flags ""
Erasing 2048 Kibyte @ fce00000 -- 100 % complete
bin/
tar: can't make dir bin: Cannot allocate memory
bin/patch
tar: can't create directory 'bin': Cannot allocate memory
tar: can't create symlink from bin/patch to busybox: No such file or directory
bin/base64
tar: can't create symlink from bin/base64 to busybox: No such file or directory
bin/vlock
tar: can't create symlink from bin/vlock to busybox: No such file or directory
bin/printf
tar: can't create symlink from bin/printf to busybox: No such file or directory
bin/basename
tar: can't create symlink from bin/basename to busybox: No such file or directory
bin/realpath
tar: can't create symlink from bin/realpath to busybox: No such file or directory
bin/ls
tar: can't create symlink from bin/ls to busybox: No such file or directory
bin/rm
tar: can't create symlink from bin/rm to busybox: No such file or directory
bin/unzip
tar: can't create symlink from bin/unzip to busybox: No such file or directory
bin/dumpkmap
tar: can't create symlink from bin/dumpkmap to busybox: No such file or directory
bin/iptunnel
tar: can't create symlink from bin/iptunnel to busybox: No such file or directory
bin/fdflush
tar: can't create symlink from bin/fdflush to busybox: No such file or directory
bin/expr
tar: can't create symlink from bin/expr to busybox: No such file or directory
bin/unxz
tar: can't create symlink from bin/unxz to busybox: No such file or directory
bin/adduser
tar: can't create symlink from bin/adduser to busybox: No such file or directory
bin/hostid
tar: can't create symlink from bin/hostid to busybox: No such file or directory
bin/logger
tar: can't create symlink from bin/logger to busybox: No such file or directory
bin/nslookup
tar: can't create symlink from bin/nslookup to busybox: No such file or directory
bin/more
tar: can't create symlink from bin/more to busybox: No such file or directory
bin/bunzip2
tar: can't create symlink from bin/bunzip2 to busybox: No such file or directory
bin/id
tar: can't create symlink from bin/id to busybox: No such file or directory
bin/usleep
tar: can't create symlink from bin/usleep to busybox: No such file or directory
bin/hostname
tar: can't create symlink from bin/hostname to busybox: No such file or directory
bin/traceroute
tar: can't create symlink from bin/traceroute to busybox: No such file or directory
bin/candump
tar: can't open 'bin/candump': No such file or directory
Update Complete!!!!!!!
i.MX8MM通行证i.MX6UL通行证i.MX6Q通行证
 楼主| 发表于 2018-5-23 13:19:11 | 显示全部楼层
mtd_init failed!
 楼主| 发表于 2018-5-25 10:11:57 | 显示全部楼层
opt/qt4.8.5/
opt/qt4.8.5/lib/
opt/qt4.8.5/lib/libQtWebKit.la
opt/qt4.8.5/lib/libQtNetwork.so.4
opt/qt4.8.5/lib/libQtCore.so.4.8
opt/qt4.8.5/lib/libQtNetwork.la
opt/qt4.8.5/lib/fonts/
opt/qt4.8.5/lib/fonts/simsun.ttc
opt/qt4.8.5/lib/fonts/simhei.ttf
opt/qt4.8.5/lib/fonts/README
opt/qt4.8.5/lib/libQtCore.la
opt/qt4.8.5/lib/libQtGui.so
opt/qt4.8.5/lib/libQtCore.so.4.8.5
tar: write error: No space left on device
umount: /run/nand: not mounted
烧录又报空间不够
发表于 2018-6-2 09:59:09 | 显示全部楼层
提示制卡成功了吗?
发表于 2020-6-28 17:52:10 | 显示全部楼层
这个怎么说?nand提示emmc错误。。。。
U-Boot 2015.04 (Feb 20 2017 - 11:13:56)
CPU:   Freescale i.MX6UL rev1.1 at 396 MHz
CPU:   Temperature 45 C
Reset cause: POR
Board: MX6UL 14x14 EVK
I2C:   ready
DRAM:  256 MiB
Card did not respond to voltage select!
MMC init failed
Using default environment
Display: TFT70AB (800x480)
Video: 800x480x24
Error: no valid bmp image at 83800000 cfb_console.c
In:    serial
Out:   serial
Err:   serial
MMC: no card present
Net:   Phy 1 not found
PHY reset timed out
FEC1
Error: FEC1 address not set.
Normal Boot
** Bad device mmc 1 **
mmc boot..........
Booting from net ...
*** ERROR: `ethaddr' not set
Bad Linux ARM zImage magic!
---------------MAIN MENU---------------
1. Screen Type Menu
2. Change The Calibrate
0. Exit To Boot Shell
Enter your number:
您这个问题解决了吗?我遇到了和您一样的问题,想请教一下  详情 回复 发表于 2020-6-30 18:03
发表于 2020-6-29 08:37:21 | 显示全部楼层
应该是您做的烧写卡有问题,您可以检查一下制卡脚本是否选错,重新制卡试试
i.MX6UL通行证TCU通行证FCU11xx通行证FCU1201通行证AM335x通行证RK3506通行证
发表于 2020-6-30 18:03:56 | 显示全部楼层
GMT+8, 2026-9-23 21:46
