查看: 25636|回复: 2
[Linux] SD卡启动失败
i.MX6UL通行证XX18通行证
发表于 2018-6-4 21:28:52 | 显示全部楼层 |阅读模式
按照最新的资料OKxx18-C-Linux用户手册-V2.1-2018.04.24.pdf  第5.2章节的步骤进行操作,操作信息如下:
@ubuntu:~/OKxx18/mksdcard/4418$ sudo ./mksdcard4418.sh
This script will create a bootable SD card from custom or pre-built binaries.
The script must be run with root permissions and from the bin directory of
the SDK
Example:
$ sudo ./create-sdcard.sh
Formatting can be skipped if the SD card is already formatted and
partitioned properly.
1:   8       16   15558144 sdb
Enter Device Number: 1
sdb was selected
Checking the device is unmounted
df: /mnt/hgfs: Protocol error
Would you like to re-partition the drive anyways [y/n] : y
Now partitioning sdb ...
                Now ** 1 partitions
1+0 records in
1+0 records out
1024 bytes (1.0 kB, 1.0 KiB) copied, 0.00208383 s, 491 kB/s
DISK SIZE - 15931539456 bytes
sfdisk: unsupported unit 'M'
                Partitioning Boot
mkfs.fat 3.0.28 (2015-05-16)
/dev/sdb1: No such file or directory
Mount the partitions
mount: special device /dev/sdb1 does not exist
Emptying partitions
        Copying files now... will take minutes
Copying boot partition
Buring th sdfuse.bin to sdcard
628+1 records in
628+1 records out
322024 bytes (322 kB, 314 KiB) copied, 0.0573104 s, 5.6 MB/s
Syncing....
Un-mount the partitions
umount: boot: not mounted
Operation Finished
疑问如下:
1. 上述步骤是否正确?
2. 若正确的话,制作完后,未发现如何将文件拷贝到SD卡,没有对应的FAT32分区生成。
3. 尝试在windows系统下格式化SD卡,将指定的文件拷贝到SD卡中,插入开发板后,设置SD卡方式启动系统,发现串口无任何信息输出。
请问解决办法,谢谢!
发表于 2018-6-5 09:52:27 | 显示全部楼层
怀疑是你SD挂载没做好,建议重新格式化再做一遍,手册上的步骤都是正确的,一步步照着来就OK。最好在linux下做,另外windows下制作烧写卡我们没有特别对应的教程,如果有必要http://bbs.witech.com.cn/portal.php?mod=view&aid=161参照这个试下吧
i.MX6UL通行证XX18通行证
 楼主| 发表于 2018-6-17 17:17:34 | 显示全部楼层
谢谢,问题已解决。
ubuntu操作系统由16.04更换为12.04就可以了。
GMT+8, 2026-9-21 05:42
