查看: 26674|回复: 2
[Android] IMX6Q EIM问题!
i.MX6Q通行证i.MX6UL通行证
发表于 2018-7-4 11:16:52 | 显示全部楼层 |阅读模式
         * For EIM General Configuration registers.
         * CS0GCR1:
         *        GBC = 0; CSREC = 6; DSZ = 2; BL = 0;
         *        CREP = 1; CSEN = 1;
         *        EIM Operation Mode: MUM = 1
                SRD = SWR = 0.
         *                (Async write/Async page read, multiplexed)
         * CS0GCR2:
         *        ADH = 1
        writel(0x00610099, nor_reg);
        writel(0x00000001, nor_reg + 0x00000004);
         * For EIM Read Configuration registers.
         * CS0RCR1:
         *        RWSC = 1C;
         *        RADVA = 0; RADVN = 2;
         *        OEA = 2; OEN = 0;
         *        RCSA = 0; RCSN = 0
         * CS0RCR2:
         *        APR = 1 (Async Page Read);
         *        PAT = 4 (6 EIM clock sycles)
        writel(0x1C022000, nor_reg + 0x00000008);
        writel(0x0000C000, nor_reg + 0x0000000C);
         * For EIM Write Configuration registers.
         * CS0WCR1:
         *        WWSC = 20;
         *        WADVA = 0; WADVN = 1;
         *        WBEA = 1; WBEN = 2;
         *        WEA = 1; WEN = 6;
         *        WCSA = 1; WCSN = 2;
         * CS0WCR2:
         *        WBCDD = 0
        writel(0x1404a38e, nor_reg + 0x00000010);
        writel(0x00000000, nor_reg + 0x00000014);
        EIM端口配置如上,DA[15:0]数据线地址线复用。
        配置之前用示波器测出 片选CS0恒为低电平,按如上配置之后,片选CS0恒为高电平,请问是什么原因?谢谢。
发表于 2018-7-4 16:25:58 | 显示全部楼层
arch/arm/mach-mx6/board-mx6q_sabresd.c改这个文件,你改的auto文件
我也没修改auto,我是根据auto文件里面的eim配置重新写了一个驱动程序,然后动态加载进去的。  详情 回复 发表于 2018-7-4 16:37
i.MX6Q通行证i.MX6UL通行证
 楼主| 发表于 2018-7-4 16:37:55 | 显示全部楼层
GMT+8, 2026-9-20 07:48
