查看: 36717|回复: 3
[Linux] uBoot中环境变量无saveenv命令
发表于 2018-7-22 19:37:31 | 显示全部楼层 |阅读模式
最近烧写mmc,发现uboot内saveenv命令丢失,导致环境变量无法设置,请教了
md      - memory display
mii     - MII utility commands
mm      - memory modify (auto-incrementing address)
mmc     - MMC sub system
mmcinfo - display MMC info
mtest   - ** RAM read/write test
mw      - memory write (fill)
nfs     - boot image via network using NFS protocol
nm      - memory modify (constant address)
ping    - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
protect - enable or disable FLASH write protection
rarpboot- boot image via network using RARP/TFTP protocol
reset   - Perform RESET of the CPU
run     - run commands in an environment variable
setenv  - set environment variables
sf      - SPI flash sub-system
sleep   - delay execution for some time
source  - run script from memory
sspi    - SPI utility commands
tftpboot- boot image via network using TFTP protocol
version - print monitor version
发表于 2018-7-23 09:58:39 | 显示全部楼层
我们的uboot?您怎么弄的会缺失这个,重新烧写吧
 楼主| 发表于 2018-7-24 20:09:43 | 显示全部楼层
重新烧写结果一样,见了鬼了。
GMT+8, 2026-10-4 17:14
