查看: 39737|回复: 1
[Linux] 文件系统无法读取
i.MX6UL通行证i.MX6Q通行证FCU11xx通行证
发表于 2019-1-21 13:36:57 | 显示全部楼层 |阅读模式
采用"OKMX6UL-C(eMMC&Nand版)用户资料-20181030"的源码,编译dtb后下载出现
[    2.260296] VFS: Cannot open root device "mtdblock5" or unknown-block(0,0): error -6
[    2.268278] Please append a correct "root=" boot option; here are the available partitions:
[    2.276772] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[   81.941092] random: nonblocking pool is initialized
默认的dtb能正确识别分区,不知道需要编译时注意什么
 楼主| 发表于 2019-1-21 15:17:10 | 显示全部楼层
没找到原因,不过环境重新安装编译后就可以了
GMT+8, 2026-10-4 15:20
