查看: 81832|回复: 1
[Linux] ov5640摄像头驱动程序
发表于 2019-3-17 18:58:49 | 显示全部楼层 |阅读模式
OKMX6X-C-Linux手册-V2.0-2018-03-30.pdf里面介绍了一个工具gstcamera,可以对焦。
af 自动对焦,sp0 对焦无穷远,sp255 对焦最近对焦距离。
手册里面说,输入sp0,sp100,sp255是指定焦距手动对焦,但是我实际测试,结果都是自动对焦。
从驱动程序看,存在问题。ioctl_send_command是响应sp命令的,但是,它调用了自动对焦配置函数ov5640_config_auto_focus()。
驱动程序应该怎么修改呢?应该联系谁呢?
linux-3.0.35\drivers\media\video\mxc\capture\ov5640.c
static int ioctl_send_command(struct v4l2_int_device *s, struct v4l2_send_command_control *vc) {
                int ret = -1;
                int retval1,retval2;
                u8 loca_val=0;
                ret = ov5640_set_idle_mode();
                if (0 != ret)
                        pr_err("error %d setting idle mode\n", ret);
                        ov5640_config_auto_focus();
                        switch (vc->id) {
                        case 101: //step to near
                                pr_debug("Stepping to near object\n");
                                retval1=ov5640_write_reg(REG_CMD_TAG, 0x01);
                                retval2=ov5640_write_reg(REG_CMD_MAIN, 0x05);
                                        if(retval1 == 0 && retval2 == 0)
                                                ret = 0;
                                                break;
                        case 102: //step to far
                                pr_debug("Stepping to far object\n");
                                retval1=ov5640_write_reg(REG_CMD_TAG, 0x02);
                                        ret = 0;
                                break;
                        case 103: //step to furthest
                                pr_debug("Stepping to furthest object\n");
                                retval1=ov5640_write_reg(REG_CMD_TAG, 0x03);
                                ret = 0;
                                        break;
                        case 104: //step to nearest
                                pr_debug("Stepping to nearest object\n");
                                retval1=ov5640_write_reg(REG_CMD_TAG, 0x04);
                                        ret = 0;
                                        break;
                        case 105: //step to specified position
                                pr_debug("Stepping to position: %d\n", vc->value0);
                                if(vc->value0 < 0 || vc->value0 > 255)
                                        return ret;
                                loca_val = vc->value0;
                                retval1=ov5640_write_reg(REG_CMD_TAG, 0x10);
                                retval2=ov5640_write_reg(REG_CMD_PARA0, loca_val);
                                ret=ov5640_write_reg(REG_CMD_MAIN, 0x05);
                                if(retval1 != 0 && retval2 != 0 && ret != 0)
                                        ret = -1;
                                break;
                        default:
                                break;
                return ret;
ov5640.zip
25.4 KB, 下载次数: 10, 下载积分: 贡献 1
发表于 2019-3-19 08:50:27 | 显示全部楼层
很抱歉,我们只测试过自动对焦,目前还没有修改手动对焦的方法
GMT+8, 2026-10-4 15:19
