查看: 26445|回复: 1
[Linux] OK335xS开发板无法从SD启动
发表于 2019-4-21 19:39:02 | 显示全部楼层 |阅读模式
刚买的OK335xS开发板,按照说明使用create-sdcard.sh对SD卡进行了分区,把bin目录下的MLO、u-boot.img、uImage拷了进去,文件系统也进行了解压。
按照说明插SD卡,无法从SD启动。
1.kernel挂在文件系统错误信息显示如下:
[    3.152390] cpsw: Detected MACID = 50:8c:b1:1d:4e:f9
[    3.159876] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    3.168696] rtc-rx8010 2-0032: setting system clock to 2019-04-21 19:34:33 UTC (1555875273)
[    3.184472] EXT3-fs (mmcblk0p2): recovery required on readonly filesystem
[    3.191598] EXT3-fs (mmcblk0p2): write access will be enabled during recovery
[    4.068030] kjournald starting.  Commit interval 5 seconds
[    4.073864] EXT3-fs (mmcblk0p2): recovery complete
[    4.086914] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[    4.094169] VFS: Mounted root (ext3 filesystem) readonly on device 179:2.
[    4.102407] devtmpfs: error mounting -2
[    4.106823] Freeing init memory: 256K
2.通过板载的nandflash启动,发现BOOT(FAT32)分区可以查看到文件,rootfs(EXT3)的文件查不到,确认分区里已有文件系统文件;
root@ok335x:/media/mmcblk0p1# ls
2.txt       MLO         u-boot.img  uImage
root@ok335x:/media/mmcblk0p1# cd ../mmcblk0p2
root@ok335x:/media/mmcblk0p2# ls
请问有哪位大神遇到类似问题吗?
发表于 2019-4-22 13:06:05 | 显示全部楼层
重启一下
GMT+8, 2026-9-23 12:58
