查看: 20010|回复: 3
[Ubuntu] OK1012A ubuntu系统 无法安装mqsql
LS1012A通行证
发表于 2019-8-2 16:13:02 | 显示全部楼层 |阅读模式
安装了官方的源,APT-GET INSTALL之后 错误如下:
root@localhost:/etc/apt# apt-get install mysql-server
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
  libcgi-fast-perl libcgi-pm-perl libevent-core-2.1-6 libfcgi-perl libhtml-template-perl mysql-client-5.7 mysql-client-core-5.7 mysql-common mysql-server-5.7 mysql-server-core-5.7
Suggested packages:
  libipc-sharedcache-perl mailx tinyca
The following NEW packages will be installed:
  libcgi-fast-perl libcgi-pm-perl libevent-core-2.1-6 libfcgi-perl libhtml-template-perl mysql-client-5.7 mysql-client-core-5.7 mysql-common mysql-server mysql-server-5.7 mysql-server-core-5.7
0 upgraded, 11 newly installed, 0 to remove and 93 not upgraded.
Need to get 19.4 MB/19.7 MB of archives.
After this operation, 157 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Ign:1 http://us.ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 mysql-client-core-5.7 arm64 5.7.24-0ubuntu0.18.04.1
Ign:2 http://us.ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 mysql-client-5.7 arm64 5.7.24-0ubuntu0.18.04.1
Ign:3 http://us.ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 mysql-server-core-5.7 arm64 5.7.24-0ubuntu0.18.04.1
Ign:4 http://us.ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 mysql-server-5.7 arm64 5.7.24-0ubuntu0.18.04.1
Err:1 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 mysql-client-core-5.7 arm64 5.7.24-0ubuntu0.18.04.1 404  Not Found [IP: 91.189.91.11 80]
Err:2 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 mysql-client-5.7 arm64 5.7.24-0ubuntu0.18.04.1 404  Not Found [IP: 91.189.91.11 80]
Err:3 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 mysql-server-core-5.7 arm64 5.7.24-0ubuntu0.18.04.1 404  Not Found [IP: 91.189.91.11 80]
Err:4 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 mysql-server-5.7 arm64 5.7.24-0ubuntu0.18.04.1 404  Not Found [IP: 91.189.91.11 80]
Ign:5 http://us.ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 mysql-server all 5.7.24-0ubuntu0.18.04.1
Err:5 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 mysql-server all 5.7.24-0ubuntu0.18.04.1 404  Not Found [IP: 91.189.91.11 80]
E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/m/mysql-5.7/mysql-client-core-5.7_5.7.24-0ubuntu0.18.04.1_arm64.deb  404  Not Found [IP: 91.189.91.11 80]
E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/m/mysql-5.7/mysql-client-5.7_5.7.24-0ubuntu0.18.04.1_arm64.deb  404  Not Found [IP: 91.189.91.11 80]
E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/m/mysql-5.7/mysql-server-core-5.7_5.7.24-0ubuntu0.18.04.1_arm64.deb  404  Not Found [IP: 91.189.91.11 80]
E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/m/mysql-5.7/mysql-server-5.7_5.7.24-0ubuntu0.18.04.1_arm64.deb  404  Not Found [IP: 91.189.91.11 80]
E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/m/mysql-5.7/mysql-server_5.7.24-0ubuntu0.18.04.1_all.deb  404  Not Found [IP: 91.189.91.11 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
请教下, 怎么安装mysql
LS1012A通行证
 楼主| 发表于 2019-8-2 16:28:49 | 显示全部楼层
好像开发板不能使用电脑上的源,  不然什么都找不到
发表于 2019-8-6 16:16:35 | 显示全部楼层
因为1012没有移植MySQCL数据库,给您推荐一篇文章参考一下吧,希望对您有所帮助
https://baijiahao.baidu.com/s?id ... r=spider&for=pc
不行啊, 安装不上。  详情 回复 发表于 2019-8-8 18:31
LS1012A通行证
 楼主| 发表于 2019-8-8 18:31:13 | 显示全部楼层
https://baijiahao.baidu. ...
不行啊, 安装不上。 一直是搜搜出 这个版本  mysql-client-core-5.7 arm64 5.7.24-0ubuntu0.18.04.1
但是里面根本没这个版本的下载文件
GMT+8, 2026-10-3 15:23
