查看: 13966|回复: 3
[Linux] 板子启动后,提示一个alasctl错误
发表于 2019-8-18 10:13:28 | 显示全部楼层 |阅读模式
开机后提示如下错误:
alsactl: parse:1655: Unable to open file '/data0/imx6_linux/alsa/tmp/share/alsa/init/00main': No such file or directory
alsactl: set_control:1267: failed to obtain info for control #55 (No such file or directory)
请问是哪里的问题?
发表于 2019-8-19 13:59:52 | 显示全部楼层
您好,登录系统前显示的错误吗,你能把报错位置的前后打印信息的截图发一下吗
NAND read: device 0 offset 0xa00000, size 0x800000 8388608 bytes read: OK NAND read: device 0 offset 0x840000, size 0x40000 262144 bytes read: OK Kernel image @ 0x80800000 [ 0x000000 - 0x627c5  详情 回复 发表于 2019-8-20 12:43
 楼主| 发表于 2019-8-20 12:43:30 | 显示全部楼层
飞凌-chongzi发表于2019-8-19 13:59
Kernel image @ 0x80800000 [ 0x000000 - 0x627c58 ]
## Flattened Device Tree blob at 83000000
   Booting using the fdt blob at 0x83000000
   Using Device Tree in place at 83000000, end 8300c5a3
Starting kernel ...
[    0.000000] Linux version 3.14.38-6UL_ga-00063-g138ff78 (liyue@developer-RH2485-V2) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #1 SMP PREEMPT Mon Dec 24 09:59:10 CST 2018
[    0.000000] Machine model: Freescale i.MX6 UltraLite 14x14 EVK Board
[    0.000000] cma: CMA: reserved 64 MiB at 8c000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] PERCPU: Embedded 8 pages/cpu @8bdbf000 s8832 r8192 d15744 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 60928
[    0.000000] Kernel command line: console=ttymxc0,115200 cma=64M root=/dev/mtdblock5 rootfstype=yaffs2,calibrate=y
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 165600K/245760K available (7947K kernel code, 482K rwdata, 2800K rodata, 396K init, 433K bss, 80160K reserved, 0K highmem)
[    0.000000]     vmalloc : 0x90800000 - 0xff000000   (1768 MB)
[    0.000000]     lowmem  : 0x80000000 - 0x90000000   ( 256 MB)
[    0.000000]     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
[    0.000000]     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
[    0.000000]       .text : 0x80008000 - 0x80a86f70   (10748 kB)
[    0.000000]       .init : 0x80a87000 - 0x80aea280   ( 397 kB)
[    0.000000]       .data : 0x80aec000 - 0x80b648a0   ( 483 kB)
[    0.000000]        .bss : 0x80b648ac - 0x80bd0e74   ( 434 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Switching to timer-based delay loop
[    0.000020] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
[    0.002564] clocksource_of_init: no matching clocksources found
[    0.002931] Console: colour dummy device 80x30
[    0.002978] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[    0.003009] pid_max: default: 32768 minimum: 301
[    0.003400] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.003430] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.004971] Initializing cgroup subsys net_cls
[    0.005062] CPU: Testing write buffer coherency: ok
[    0.005566] /cpus/cpu@0 missing clock-frequency property
[    0.005609] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005668] Setting up static identity map for 0x8078bcf8 - 0x8078bd50
[    0.040751] Brought up 1 CPUs
[    0.040790] SMP: Total of 1 processors activated (6.00 BogoMIPS).
[    0.040806] CPU: All CPU(s) started in SVC mode.
[    0.042124] devtmpfs: initialized
[    0.052587] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.053370] pinctrl core: initialized pinctrl subsystem
[    0.054266] regulator-dummy: no parameters
[    0.059615] NET: Registered protocol family 16
[    0.076109] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.077722] cpuidle: using governor ladder
[    0.077751] cpuidle: using governor menu
[    0.078118] Use WDOG1 as reset source
[    0.096304] syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
[    0.097004] vdd3p0: 2625 <--> 3400 mV at 3000 mV
[    0.097891] cpu: 725 <--> 1450 mV at 1150 mV
[    0.098725] vddsoc: 725 <--> 1450 mV at 1175 mV
[    0.103957] syscon 20e4000.iomuxc-gpr: regmap [mem 0x020e4000-0x020e7fff] registered
[    0.110596] syscon 21ac000.romcp: regmap [mem 0x021ac000-0x021affff] registered
[    0.112151] syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
[    0.118993] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.119025] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.123026] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[    0.125837] 20dc000.gpc supply pu not found, using dummy regulator
[    0.161345] bio: create slab <bio-0> at 0
[    0.168046] mxs-dma 1804000.dma-apbh: initialized
[    0.168973] can-3v3: 3300 mV
[    0.169539] VSD_3V3: 3300 mV
[    0.170329] usb_otg1_vbus: 5000 mV
[    0.170876] vref-3v3: 3300 mV
[    0.172362] gpio_dvfs: 1300 <--> 1400 mV at 1400 mV
[    0.173663] i2c-core: driver [max17135] using legacy suspend method
[    0.173689] i2c-core: driver [max17135] using legacy resume method
[    0.174930] SCSI subsystem initialized
[    0.176163] usbcore: registered new inte**ce driver usbfs
[    0.176347] usbcore: registered new inte**ce driver hub
[    0.176679] usbcore: registered new device driver usb
[    0.181471] i2c i2c-0: IMX I2C adapter registered
[    0.184040] i2c i2c-1: IMX I2C adapter registered
[    0.184329] Linux video capture inte**ce: v2.00
[    0.184535] pps_core: LinuxPPS API ver. 1 registered
[    0.184558] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.184639] PTP clock support registered
[    0.187322] MIPI CSI2 driver module loaded
[    0.187894] Advanced Linux Sound Architecture Driver Initialized.
[    0.189842] Bluetooth: Core ver 2.18
[    0.189982] NET: Registered protocol family 31
[    0.190004] Bluetooth: HCI device and connection manager initialized
[    0.190046] Bluetooth: HCI socket layer initialized
[    0.190076] Bluetooth: L2CAP socket layer initialized
[    0.190181] Bluetooth: SCO socket layer initialized
[    0.191180] cfg80211: Calling CRDA to update world regulatory domain
[    0.192316] Switched to clocksource mxc_timer1
[    0.217728] NET: Registered protocol family 2
[    0.219738] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[    0.219827] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[    0.219918] TCP: Hash tables configured (established 2048 bind 2048)
[    0.220040] TCP: reno registered
[    0.220081] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.220138] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.220714] NET: Registered protocol family 1
[    0.221474] RPC: Registered named UNIX socket transport module.
[    0.221506] RPC: Registered udp transport module.
[    0.221524] RPC: Registered tcp transport module.
[    0.221541] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.224427] imx rpmsg driver is registered.
[    0.226087] Bus freq driver module loaded
[    0.228051] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.247713] VFS: Disk quotas dquot_6.5.2
[    0.248437] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.254446] NFS: Registering the id_resolver key type
[    0.254573] Key type id_resolver registered
[    0.254595] Key type id_legacy registered
[    0.254681] jffs2: version 2.2. (NAND) &#169; 2001-2006 Red Hat, Inc.
[    0.256579] fuse init (API version 7.22)
[    0.257854] msgmni has been set to 451
[    0.266072] io scheduler noop registered
[    0.266104] io scheduler deadline registered
[    0.266595] io scheduler cfq registered (default)
[    0.267630] imx-weim 21b8000.weim: Driver registered.
[    0.273484] backlight.9 supply power not found, using dummy regulator
[    0.276629] MIPI DSI driver module loaded
[    0.280798] 21c8000.lcdif supply lcd not found, using dummy regulator
[    0.281313] mxsfb 21c8000.lcdif: failed to find mxc display driver
[    0.282089] mxsfb 21c8000.lcdif: initialized
[    0.289472] imx-sdma 20ec000.sdma: no event needs to be remapped
[    0.289683] imx-sdma 20ec000.sdma: loaded firmware 3.1
[    0.298339] imx-sdma 20ec000.sdma: initialized
[    0.299754] Serial: IMX driver
[    0.300397] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58, base_baud = 5000000) is a IMX
[    1.043693] console [ttymxc0] enabled
[    1.049098] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59, base_baud = 5000000) is a IMX
[    1.059017] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60, base_baud = 5000000) is a IMX
[    1.068666] serial: Freescale lpuart driver
[    1.074864] imx sema4 driver is registered.
[    1.079227] [drm] Initialized drm 1.1.0 20060810
[    1.085003] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[    1.112598] brd: module loaded
[    1.127546] loop: module loaded
[    1.134751] spi_gpio spi4.15: gpio-miso property not found, switching to no-rx mode
[    1.146816] CAN device driver inte**ce
[    1.154068] flexcan 2090000.can: device registered (reg_base=90960000, irq=142)
[    1.164088] flexcan 2094000.can: device registered (reg_base=90968000, irq=143)
[    1.173679] 20b4000.ethernet supply phy not found, using dummy regulator
[    1.181625] pps pps0: new PPS source ptp0
[    1.186272] fec 20b4000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
[    1.195409] fec 20b4000.ethernet (unregistered net_device): Using random MAC address: b2:56:5a:f5:00:3a
[    1.205587] libphy: fec_enet_mii_bus: probed
[    1.213729] fec 20b4000.ethernet eth0: registered PHC device 0
[    1.221198] 2188000.ethernet supply phy not found, using dummy regulator
[    1.229297] pps pps1: new PPS source ptp1
[    1.233875] fec 2188000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
[    1.243086] fec 2188000.ethernet (unregistered net_device): Using random MAC address: 6e:15:b1:8d:c2:10
[    1.254508] fec 2188000.ethernet eth1: registered PHC device 1
[    1.262023] PPP generic driver version 2.4.2
[    1.267014] PPP BSD Compression module registered
[    1.271758] PPP Deflate Compression module registered
[    1.277115] usbcore: registered new inte**ce driver asix
[    1.282747] usbcore: registered new inte**ce driver cdc_ether
[    1.288739] usbcore: registered new inte**ce driver cdc_eem
[    1.294754] usbcore: registered new inte**ce driver cdc_ncm
[    1.300519] GobiNet: Quectel_WCDMA&LTE_Linux&Android_GobiNet_Driver_V1.3.0
[    1.307658] usbcore: registered new inte**ce driver GobiNet
[    1.313394] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.319952] ehci-mxc: Freescale On-Chip EHCI Host driver
[    1.325783] usbcore: registered new inte**ce driver usb-storage
[    1.332154] usbcore: registered new inte**ce driver usbserial
[    1.338209] usbcore: registered new inte**ce driver usbserial_generic
[    1.344935] usbserial: USB Serial support registered for generic
[    1.351086] usbcore: registered new inte**ce driver ftdi_sio
[    1.357015] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.364526] usbcore: registered new inte**ce driver option
[    1.370253] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.377402] usbcore: registered new inte**ce driver pl2303
[    1.383153] usbserial: USB Serial support registered for pl2303
[    1.389277] usbcore: registered new inte**ce driver cdc_xr_usb_serial
[    1.395877] xr_usb_serial_common: Exar USB UART (serial port) driver
[    1.402442] usbcore: registered new inte**ce driver usb_ehset_test
[    1.410929] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[    1.427148] 2184200.usb supply vbus not found, using dummy regulator
[    1.437443] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    1.442509] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[    1.462415] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    1.469886] hub 1-0:1.0: USB hub found
[    1.473872] hub 1-0:1.0: 1 port detected
[    1.480015] mousedev: PS/2 mouse device common for all mice
[    1.487732] input: 20cc000.snvs-pwrkey as /devices/soc0/soc.0/2000000.aips-bus/20cc000.snvs-pwrkey/input/input0
[    1.498645] snvs_pwrkey 20cc000.snvs-pwrkey: i.MX snvs powerkey probed
[    1.505593] <<-GTP-INFO->> GTP driver installing...
[    1.511026] <<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
[    1.517118] <<-GTP-INFO->> GTP Driver Built@09:58:31, Dec 24 2018
[    1.523289] <<-GTP-INFO->> GTP I2C Address: 0x5d
[    1.527981] 0-005d supply vdd_ana not found, using dummy regulator
[    1.534388] 0-005d supply vcc_i2c not found, using dummy regulator
[    1.540696] <<-GTP-INFO->> Guitar reset
[    1.674571] <<-GTP-INFO->> IC Version: 911_1060
[    1.708718] <<-GTP-INFO->> X_MAX: 800, Y_MAX: 480, TRIGGER: 0x01
[    1.732485] <<-GTP-INFO->> create proc entry gt9xx_config success
[    1.739227] input: goodix-ts as /devices/virtual/input/input1
[    1.745697] <<-GTP-INFO->> GTP works in interrupt mode.
[    1.751772] edt_ft5x06 0-0038: touchscreen probe failed
[    1.757305] edt_ft5x06: probe of 0-0038 failed with error -5
[    1.766334] input: iMX6UL TouchScreen Controller as /devices/virtual/input/input3
[    1.778448] i2c-core: driver [isl29023] using legacy suspend method
[    1.784995] i2c-core: driver [isl29023] using legacy resume method
[    1.792529] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[    1.805329] rtc-rx8010 0-0032: Update timer was detected
[    1.813632] rtc-rx8010 0-0032: rtc core: registered rx8010 as rtc0
[    1.821177] snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc1
[    1.829888] i2c /dev entries driver
[    1.834743] IR NEC protocol handler initialized
[    1.839318] IR RC5(x) protocol handler initialized
[    1.844211] IR RC6 protocol handler initialized
[    1.848773] IR JVC protocol handler initialized
[    1.853853] IR Sony protocol handler initialized
[    1.858508] IR RC5 (streamzap) protocol handler initialized
[    1.864152] IR SANYO protocol handler initialized
[    1.868885] IR MCE Keyboard/mouse protocol handler initialized
[    1.877624] pxp-v4l2 pxp_v4l2.10: initialized
[    1.882491] usbcore: registered new inte**ce driver uvcvideo
[    1.888277] USB Video Class driver (1.1.1)
[    1.893494] i2c-core: driver [mag3110] using legacy suspend method
[    1.899716] i2c-core: driver [mag3110] using legacy resume method
[    1.906986] imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
[    1.915941] Bluetooth: HCI UART driver ver 2.2
[    1.920431] Bluetooth: HCI H4 protocol initialized
[    1.925374] Bluetooth: HCI BCSP protocol initialized
[    1.930370] Bluetooth: HCIATH3K protocol initialized
[    1.935631] usbcore: registered new inte**ce driver bcm203x
[    1.941498] usbcore: registered new inte**ce driver btusb
[    1.947530] usbcore: registered new inte**ce driver ath3k
[    1.955173] hub 1-1:1.0: USB hub found
[    1.959160] usbcore: registered new inte**ce driver rtk_btusb
[    1.965141] hub 1-1:1.0: 4 ports detected
[    1.969916] sdhci: Secure Digital Host Controller Inte**ce driver
[    1.976565] sdhci: Copyright(c) Pierre Ossman
[    1.981078] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.992550] mmc0: no vqmmc regulator found
[    2.042437] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[    2.065986] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[    2.072433] nand: Micron MT29F2G08ABAEAWP
[    2.076479] nand: 256MiB, SLC, page size: 2048, OOB size: 64
[    2.083442] gpmi-nand 1806000.gpmi-nand: enable the asynchronous EDO mode 5
[    2.090486] Scanning device for bad blocks
[    2.262661] usb 1-1.4: new high-speed USB device number 3 using ci_hdrc
[    2.299864] 6 ofpart partitions found on MTD device gpmi-nand
[    2.305699] Creating 6 MTD partitions on "gpmi-nand":
[    2.310809] 0x000000000000-0x000000400000 : "boot"
[    2.318394] 0x000000400000-0x000000600000 : "logo"
[    2.325818] 0x000000600000-0x000000700000 : "ENV"
[    2.333106] 0x000000700000-0x000000a00000 : "DTB"
[    2.340454] 0x000000a00000-0x000001200000 : "kernel"
[    2.348219] 0x000001200000-0x000010000000 : "rootfs"
[    2.356631] gpmi-nand 1806000.gpmi-nand: driver registered.
[    2.366731] usbcore: registered new inte**ce driver usbhid
[    2.372457] usbhid: USB HID core driver
[    2.391723] usb 1-1.4: Direct firmware load failed with error -2
[    2.398407] usb 1-1.4: Falling back to user helper
[    2.408726] fsl-asrc 2034000.asrc: driver registered
[    2.422871] snd-soc-dummy snd-soc-dummy: ASoC: Failed to create platform debugfs directory
[    2.432264] imx-wm8960 sound.14: wm8960-hifi <-> 202c000.sai mapping ok
[    2.440609] imx-wm8960 sound.14: snd-soc-dummy-dai <-> 2034000.asrc mapping ok
[    2.448152] imx-wm8960 sound.14: wm8960-hifi <-> 202c000.sai mapping ok
[    2.465545] NET: Registered protocol family 26
[    2.470052] Netfilter messages via NETLINK v0.30.
[    2.474923] nfnl_acct: registering with nfnetlink.
[    2.479881] nf_conntrack version 0.5.0 (3611 buckets, 14444 max)
[    2.487296] ctnetlink v0.93: registering with nfnetlink.
[    2.493041] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
[    2.499619] nf_tables_compat: (c) 2012 Pablo Neira Ayuso <pablo@netfilter.org>
[    2.507420] xt_time: kernel timezone is -0000
[    2.512614] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.518388] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
[    2.524968] arp_tables: (C) 2002 David S. Miller
[    2.529764] TCP: cubic registered
[    2.534642] NET: Registered protocol family 10
[    2.541286] sit: IPv6 over IPv4 tunneling driver
[    2.547718] NET: Registered protocol family 17
[    2.552252] can: controller area network core (rev 20120528 abi 9)
[    2.558738] NET: Registered protocol family 29
[    2.563404] can: raw protocol (rev 20120528)
[    2.567713] can: broadcast manager protocol (rev 20120528 t)
[    2.573520] can: netlink gateway (rev 20130117) max_hops=1
[    2.579730] Bluetooth: RFCOMM TTY layer initialized
[    2.584897] Bluetooth: RFCOMM socket layer initialized
[    2.590119] Bluetooth: RFCOMM ver 1.11
[    2.593987] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.599331] Bluetooth: BNEP filters: protocol multicast
[    2.604647] Bluetooth: BNEP socket layer initialized
[    2.609678] Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
[    2.615679] Bluetooth: HIDP socket layer initialized
[    2.620785] 8021q: 802.1Q VLAN Support v1.8
[    2.625200] Key type dns_resolver registered
[    2.646618] gpio_dvfs: disabling
[    2.649903] vref-3v3: disabling
[    2.653264] usb_otg1_vbus: disabling
[    2.656875] VSD_3V3: disabling
[    2.659955] can-3v3: disabling
[    2.663596] regulator-dummy: disabling
[    2.667862] imx mcc test is registered.
[    2.673926] rtc-rx8010 0-0032: setting system clock to 2019-08-20 12:36:00 UTC (1566304560)
[    2.701083] ALSA device list:
[    2.704184]   #0: wm8960-audio
[    2.708221] yaffs: dev is 32505861 name is "mtdblock5" ro
[    2.713855] yaffs: passed flags ""
[    2.754934] random: nonblocking pool is initialized
[    3.073004] VFS: Mounted root (yaffs2 filesystem) readonly on device 31:5.
[    3.081047] devtmpfs: mounted
[    3.084918] Freeing unused kernel memory: 396K (80a87000 - 80aea000)
Mounting /proc and /sys
Starting the hotplug events dispatcher udevd
Synthesizing initial hotplug events
[    3.577995] udevd (102): /proc/102/oom_adj is deprecated, please use /proc/102/oom_score_adj instead.
[    6.438120] 1-0030 supply DOVDD not found, using dummy regulator
[    6.466707] 1-0030 supply DVDD not found, using dummy regulator
[    6.502735] 1-0030 supply AVDD not found, using dummy regulator
[    6.632646] ov9650_read_reg:write reg error:reg=1c
[    6.637468] camera ov9650 is not found
[    7.126443] RTL871X: module init start
[    7.130224] RTL871X: rtl8723bu v4.3.16_14189.20150519_BTCOEX20150119-5844
[    7.192640] RTL871X: build time: Dec 24 2018 09:59:35
[    7.197728] RTL871X: rtl8723bu BT-Coex version = BTCOEX20150119-5844
[    7.785852] RTL871X: rtw_ndev_init(wlan0)
[    7.884974] usbcore: registered new inte**ce driver rtl8723bu
[    7.890838] RTL871X: module init ret=0
Setting the hostname to freescale
Mounting filesystems
Starting inetd:
Starting syslogd and klogd
[    9.442497] flexcan 2090000.can can0: writing ctrl=0x0e312085
[    9.473850] flexcan 2094000.can can1: writing ctrl=0x0e312085
Reconfiguring network inte**ces... ifdown: inte**ce lo not configured
ifdown: inte**ce eth0 not configured
ifdown: inte**ce eth1 not configured
RTNETLINK answers: File exists
[    9.743210] fec 20b4000.ethernet eth0: Freescale FEC PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=20b4000.ethernet:01, irq=-1)
[    9.792985] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    9.983220] fec 2188000.ethernet eth1: Freescale FEC PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=20b4000.ethernet:02, irq=-1)
[   10.032993] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
done.
calibrated
2019-08-20 12:36:08: (log.c.166) server started
Copyright (C) 2006-2016 Forlinx Embedded Technology Co., Ltd All Rights Reserved  www.forlinx.com
freescale login: [   11.879600] <<-GTP-INFO->> System resume.
[   11.893062] <<-GTP-INFO->> GTP wakeup sleep.
发表于 2019-8-21 09:10:52 | 显示全部楼层
这个是正常的,内核里面有些驱动没用上,或者一些外设地址没有找到,会有类似的信息,是正常的现象
GMT+8, 2026-10-4 14:13
