查看: 83801|回复: 13
[Linux] mfgtool烧录中途找不到设备
i.MX6Q通行证RK3588通行证
发表于 2019-11-21 16:50:46 | 显示全部楼层 |阅读模式
版主及各位好:
          我使用的是imx6dlsabresd开发板,mfgtool在台式机 win10 上,问题是mfgtool工具烧录过程中途停止,无法找到设备。如下图。
          整个烧录包是从另一个电脑上复制过来的,并且在另一个电脑上是可以正常烧录的。(另一电脑是win10,笔记本),请问这是什么问题,从哪儿入手解决。
         mfgtool.log的日志显示了错误内容:
ModuleID[2] LevelID[10]: *********MxHidDevice[00DF7E08] Jump to Ramkernel successfully!**********
ModuleID[2] LevelID[10]: CmdOperation[0], current state command has been finished and the last command is successful, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&PID_0061#5&3835c29a&0&7#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - end
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&PID_0061#5&3835c29a&0&7#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, _devices.size: 1
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, devInstPathToFind: USB\VID_15A2&PID_0061\5&3835C29A&0&7, _deviceInstanceID: USB\VID_15A2&PID_0061\5&3835C29A&0&7
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, Find the device
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT,[MxHidDeviceClass] vid_15a2&pid_0061, Hub:1-Port:7
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT, Notify
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume Arrive/Remove or Device Arrive/Remove
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, m_p_usb_port is not NULL, so only refresh
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume/Device Remove
ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceRemoveEvent.
ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device remove1
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent()-DEVICE_REMOVAL_EVT, hDevCanDeleteEvent has been set
ModuleID[2] LevelID[10]: delete MxHidDevice[00DF7E08]
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_066F&PID_37FF#5&3835c29a&0&7#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_066F&PID_37FF#5&3835c29a&0&7#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT,[Msc,DiskDeviceClass] vid_066f&pid_37ff, not handled
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - VOLUME_ARRIVAL_EVT(F)
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT(F)
ModuleID[2] LevelID[10]: VolumeDeviceClass::AddUsbDevice()  F
ModuleID[2] LevelID[10]: VolumeDeviceClass::AddUsbDevice() failed F
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT-Disk(F), Hub:0-Port:0
         目前未找到解决方法。请大家帮忙给看下。
发表于 2019-11-22 09:25:45 | 显示全部楼层
您看一下打印信息是否继续出现,如果有,可以等待一会,应该可以烧写完成,
在出现那个界面之后,串口的输出如下: starting kernel.... ...... No soundcards found. Freeing unused kernel memory: 384K (80912000 - 80972000) mmc3: new DDR MMC card at address 0001 mmcblk3: mm  详情 回复 发表于 2019-11-22 10:06
发表于 2019-11-22 10:01:36 | 显示全部楼层
还有可能是虚拟机弹出连接主机还是虚拟机的选项框,可以默认连接主机,或关闭虚拟机
没有找开虚拟机软件vmware,应该不是这个情况。并且在执行到上述步骤时,主机上会自动打开一个U盘(F:)的窗口。  详情 回复 发表于 2019-11-22 11:06
i.MX6Q通行证RK3588通行证
 楼主| 发表于 2019-11-22 10:06:41 | 显示全部楼层
在出现那个界面之后,串口的输出如下:
starting kernel....
mmcblk3: mmc3:0001 DG4008 7.28 GiB
mmcblk3boot0: mmc3:0001 DG4008 partition 1 4.00 MiB
mmcblk3boot1: mmc3:0001 DG4008 partition 2 4.00 MiB
mmcblk3rpmb: mmc3:0001 DG4008 partition 3 4.00 MiB
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
Starting UTP
mmcblk3: p1 p2 p3 < p5 p6 p7 p8 p9 p10 > p4
uuc 0.5 [built Sep 16 2016 02:36:28]
UTP: Waiting for device to appear
UTP: file/device node /dev/utp already exists
cpu_id is 0
usb 1-1.4: new high-speed USB device number 3 using ci_hdrc
几分钟后出现下面的输出。
random: nonblocking pool is initialized
停止了,不再有输出。烧录也没有完成。
i.MX6Q通行证RK3588通行证
 楼主| 发表于 2019-11-22 11:06:55 | 显示全部楼层
没有打开虚拟机软件vmware,应该不是这个情况。并且在执行到上述步骤时,主机上会自动打开一个U盘(F:)的窗口。
发表于 2019-11-22 17:24:34 | 显示全部楼层
您看看烧写工具是1G还是2G,是不是选错了,主机上有盘的弹窗没事,看看线有没有问题
不清楚您说的这个1G还是2G从哪里看? 能给说下查看方法吗?  详情 回复 发表于 2019-11-25 17:34
i.MX6Q通行证RK3588通行证
 楼主| 发表于 2019-11-25 17:34:23 | 显示全部楼层
发表于 2019-11-26 08:46:14 | 显示全部楼层
看emmc上是-8G(1G)还是-16G(2G)
i.MX6Q通行证RK3588通行证
 楼主| 发表于 2020-1-2 16:49:10 | 显示全部楼层
已经修复了,重装系统才解决。
UTP: Waiting for device to appear usb 1-1.1: new high-speed USB device number 3 using ci_hdrc 楼主你好,我的也是这个问题,你说的重装系统是指什么?我是imx6ull开发板。  详情 回复 发表于 2021-1-14 13:07
发表于 2021-1-14 13:07:57 | 显示全部楼层
liuhuilfh 发表于 2020-1-2 16:49
已经修复了,重装系统才解决。
wjy
mfgtools这个烧写工具在win10上的稳定性不好,在win10上失败概率较高,故如果不能正常使用可检查一下hid驱动是否正常安装,检查一下用的烧写线是不是数据线,如果都不行的话只能更换电脑或重新做电脑系统了。  详情 回复 发表于 2021-1-14 14:49
发表于 2021-1-14 14:49:17 | 显示全部楼层
GMT+8, 2026-10-4 13:20
