查看: 56289|回复: 12
[Linux] 开发板启动太慢
LS1012A通行证LS1043A\46A通行证A40i/T3/T507/T527通行证i.MX8MM通行证i.MX6UL通行证
发表于 2019-11-25 09:56:18 | 显示全部楼层 |阅读模式
最近发现imx8mm的开发板太慢了,要两三分钟才能完全启动。
查了一个/var/log/syslog,发现下边有个可疑的地方:
Jun 20 18:00:16 ftthings connmand[3322]: eth0 {add} route 192.168.2.1 gw 0.0.0.0 scope 253 <LINK>
Jun 20 18:00:16 ftthings connmand[3322]: eth0 {add} route 192.168.1.1 gw 192.168.2.1 scope 0 <UNIVERSE>
Jun 20 18:00:16 ftthings connmand[3322]: eth0 {add} route 212.227.81.55 gw 192.168.2.1 scope 0 <UNIVERSE>
Jun 20 18:00:17 ftthings connmand[3322]: eth0 {del} route 212.227.81.55 gw 192.168.2.1 scope 0 <UNIVERSE>
Jun 20 18:00:17 ftthings kernel: [   10.138362] rtk_btusb: btusb_flush add delay
Jun 20 18:00:17 ftthings kernel: [   10.152782] rtk_btusb: btusb_close
Jun 20 18:00:17 ftthings kernel: [   10.173838] rtk_btcoex: Close BTCOEX
Jun 20 18:00:17 ftthings kernel: [   10.177443] rtk_btcoex: release udp socket
Jun 20 18:00:17 ftthings kernel: [   10.181619] rtk_btcoex: -x
Jun 20 18:00:17 ftthings avahi-daemon[3269]: Joining mDNS multicast group on inte**ce eth0.IPv6 with address fe80::24da:baff:fe4d:4359.
Jun 20 18:00:17 ftthings avahi-daemon[3269]: New relevant inte**ce eth0.IPv6 for mDNS.
Jun 20 18:00:17 ftthings avahi-daemon[3269]: Registering new address record for fe80::24da:baff:fe4d:4359 on eth0.*.
Jun 20 18:00:17 ftthings kernel: [   10.484743] EXT4-fs (mmcblk2p2): resizing filesystem from 786432 to 1890768 blocks
Jun 20 18:00:17 ftthings kernel: [   10.571189] EXT4-fs (mmcblk2p2): resized filesystem to 1890768
Jun 20 18:01:01 ftthings crond[3213]: (*system*) RELOAD (/etc/crontab)
Jun 20 18:01:01 ftthings crond[3213]: (root) RELOAD (/var/spool/cron/root)
Jun 20 18:01:46 ftthings kernel: [   99.899455] random: crng init done
Jun 20 18:01:46 ftthings kernel: [   99.902876] random: 7 urandom warning(s) missed due to ratelimiting
Jun 20 18:01:47 ftthings kernel: [  100.338164] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Jun 20 18:01:47 ftthings kernel: [  100.353701] Bridge firewalling registered
Jun 20 18:01:47 ftthings kernel: [  100.373152] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
Jun 20 18:01:47 ftthings kernel: [  100.422084] ip_tables: (C) 2000-2006 Netfilter Core Team
Jun 20 18:01:47 ftthings kernel: [  100.431457] audit: type=1325 audit(1561024907.436:3): table=filter family=2 entries=0
Jun 20 18:01:47 ftthings kernel: [  100.506427] audit: type=1300 audit(1561024907.436:3): arch=c00000b7 syscall=273 success=yes exit=0 a0=0 a1=419fd0 a2=0 a3=0 items=0 ppid=5 pid=3$
Jun 20 18:01:47 ftthings kernel: [  100.532042] audit: type=1327 audit(1561024907.436:3): proctitle=2F7362696E2F6D6F6470726F6265002D71002D2D0069707461626C655F66696C746572
Jun 20 18:01:47 ftthings kernel: [  100.550021] audit: type=1325 audit(1561024907.552:4): table=nat family=2 entries=0
Jun 20 18:01:47 ftthings kernel: [  100.622969] audit: type=1300 audit(1561024907.552:4): arch=c00000b7 syscall=273 success=yes exit=0 a0=1 a1=419fd0 a2=0 a3=1 items=0 ppid=5 pid=3$
Jun 20 18:01:47 ftthings kernel: [  100.648662] audit: type=1327 audit(1561024907.552:4): proctitle=2F7362696E2F6D6F6470726F6265002D71002D2D0069707461626C655F6E6174
Jun 20 18:01:47 ftthings kernel: [  100.719598] audit: type=1325 audit(1561024907.724:5): table=nat family=2 entries=5
Jun 20 18:01:47 ftthings kernel: [  100.727308] audit: type=1300 audit(1561024907.724:5): arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=d2eea20 items=0 ppid=3549 $
Jun 20 18:01:47 ftthings kernel: [  100.756091] audit: type=1327 audit(1561024907.724:5): proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4E00444F434B$
Jun 20 18:01:47 ftthings kernel: [  100.769635] audit: type=1325 audit(1561024907.736:6): table=filter family=2 entries=4
random: crng init done这一行,crng花了近100秒才启动。
在网上查了一下,是说启动的时候需要补熵,要rng-tools这个工具,但是提供的源码里没有这个,我们又编译不出来同样版本的。
所以能不能给编译一下这个工具呀
buildroot位置在:
Target packages->Hardware handling->rng-tools
发表于 2019-11-25 11:19:22 | 显示全部楼层
是linux系统吗
是的,是你们提供的源码 在OK8MM-linux-fs下少了rng-tools的文件,把这个加进来估计就可以了  详情 回复 发表于 2019-11-25 11:36
 楼主| 发表于 2019-11-25 11:36:49 | 显示全部楼层
是的,是你们提供的源码
发表于 2019-11-25 11:49:16 | 显示全部楼层
您是用到这个做什么吗,这个不影响正常的操作吧,系统起来后登录root就可以使用了,random: crng init done产生数据一般不会用到吧
我自己移了个docker过来,开机自动运行docker,发现docker要很长时间才能完全启动,所以就一步一步排查,看是哪里阻塞了,就找到这个地方来了  详情 回复 发表于 2019-11-25 11:52
 楼主| 发表于 2019-11-25 11:52:40 | 显示全部楼层
zhichao 发表于 2019-11-25 11:49
您是用到这个做什么吗,这个不影响正常的操作吧,系统起来后登录root就可以使用了,random: crng init done ...
发表于 2019-11-25 13:23:25 | 显示全部楼层
docker运行慢和random: crng init done没什么关系,再查找一下是什么原因造成的吧
 楼主| 发表于 2019-11-25 13:43:08 | 显示全部楼层
Jun 20 18:00:17 ftthings avahi-daemon[3294]: Registering new address record for fe80::44d9:fdff:fe04:88aa on eth0.*.
Jun 20 18:00:18 ftthings connmand[3317]: eth0 {del} route 212.227.81.55 gw 192.168.2.1 scope 0 <UNIVERSE>
Jun 20 18:01:01 ftthings crond[3288]: (root) RELOAD (/var/spool/cron/root)
Jun 20 18:01:42 ftthings kernel: [   95.777659] random: crng init done
Jun 20 18:01:42 ftthings kernel: [   95.781093] random: 7 urandom warning(s) missed due to ratelimiting
Jun 20 18:01:44 ftthings kernel: [   97.528343] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Jun 20 18:01:44 ftthings kernel: [   97.544079] Bridge firewalling registered
Jun 20 18:01:44 ftthings kernel: [   97.562560] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
Jun 20 18:01:44 ftthings kernel: [   97.607601] ip_tables: (C) 2000-2006 Netfilter Core Team
Jun 20 18:01:44 ftthings kernel: [   97.617015] audit: type=1325 audit(1561024904.744:3): table=filter family=2 entries=0
Jun 20 18:01:44 ftthings kernel: [   97.665704] audit: type=1300 audit(1561024904.744:3): arch=c00000b7 syscall=273 success=yes exit=0 a0=0 a1=419fd0 a2=0 a3=0 items=0 ppid=33 pid=$
Jun 20 18:01:44 ftthings kernel: [   97.691422] audit: type=1327 audit(1561024904.744:3): proctitle=2F7362696E2F6D6F6470726F6265002D71002D2D0069707461626C655F66696C746572
Jun 20 18:01:44 ftthings kernel: [   97.704196] audit: type=1325 audit(1561024904.832:4): table=nat family=2 entries=0
Jun 20 18:01:44 ftthings kernel: [   97.777690] audit: type=1300 audit(1561024904.832:4): arch=c00000b7 syscall=273 success=yes exit=0 a0=1 a1=419fd0 a2=0 a3=1 items=0 ppid=33 pid=$
Jun 20 18:01:44 ftthings kernel: [   97.803351] audit: type=1327 audit(1561024904.832:4): proctitle=2F7362696E2F6D6F6470726F6265002D71002D2D0069707461626C655F6E6174
Jun 20 18:01:45 ftthings kernel: [   97.867549] audit: type=1325 audit(1561024904.996:5): table=nat family=2 entries=5
Jun 20 18:01:45 ftthings kernel: [   97.875259] audit: type=1300 audit(1561024904.996:5): arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=1a9ea20 items=0 ppid=3564 $
Jun 20 18:01:45 ftthings kernel: [   97.902541] audit: type=1327 audit(1561024904.996:5): proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4E00444F434B$
Jun 20 18:01:45 ftthings kernel: [   97.915934] audit: type=1325 audit(1561024905.008:6): table=filter family=2 entries=4
Jun 20 18:01:45 ftthings connmand[3317]: docker0 {create} index 5 type 1 <ETHER>
Jun 20 18:01:45 ftthings connmand[3317]: docker0 {update} flags 4098 <DOWN>
Jun 20 18:01:45 ftthings connmand[3317]: docker0 {newlink} index 5 address 9A:89:9B:C8:36:9F mtu 1500
Jun 20 18:01:45 ftthings connmand[3317]: docker0 {newlink} index 5 operstate 2 <DOWN>
Jun 20 18:01:45 ftthings connmand[3317]: docker0 {newlink} index 5 address 02:42:4F:2F:90:FC mtu 1500
Jun 20 18:01:45 ftthings connmand[3317]: docker0 {add} address 172.17.0.1/16 label docker0 family 2
Jun 20 18:01:45 ftthings avahi-daemon[3294]: Joining mDNS multicast group on inte**ce docker0.IPv4 with address 172.17.0.1.
Jun 20 18:01:45 ftthings connmand[3317]: docker0 {update} flags 4099 <UP>
Jun 20 18:01:45 ftthings connmand[3317]: docker0 {add} route 172.17.0.0 gw 0.0.0.0 scope 253 <LINK>
Jun 20 18:01:45 ftthings avahi-daemon[3294]: New relevant inte**ce docker0.IPv4 for mDNS.
Jun 20 18:01:45 ftthings avahi-daemon[3294]: Registering new address record for 172.17.0.1 on docker0.IPv4.
Jun 20 18:01:45 ftthings kernel: [   98.468929] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
目前猜测是的关系,docker启动是在crng init done之后进行吧,
crng花了近90秒
 楼主| 发表于 2019-11-25 13:53:35 | 显示全部楼层
看其他机器上的log,systemd要等crng init done后才启动,所以我想可能的原因就是这里。正常情况下,有鼠标或是键盘的话不存在这个问题,但是我们的板子上没有接这些外设,所以内核一直在等
 楼主| 发表于 2019-11-25 13:55:48 | 显示全部楼层
看一下这个
https://www.toradex.com/community/questions/18861/random-number-generator-hangs-for-a-long-time.html
好像是类似的问题
发表于 2019-11-25 17:40:40 | 显示全部楼层
我对比了一下原版打印信息,你是不是改了网络方面的设置了,而且crng init done没有出现在开机的打印信息中,只会在开机后出现,不会影响开机启动的程序,应该是你修改的内容影响的
 楼主| 发表于 2019-11-26 17:17:28 | 显示全部楼层
我恢复到出厂的版本,然后把docker自启动,你可以看一下,应该还是卡在
Nov 26 17:11:39 okmx8mm kernel: random: crng init done
这一步花了2分18秒
-- Logs begin at Thu 2019-06-20 18:00:11 CST, end at Tue 2019-11-26 17:11:49 CST. --
Jun 20 18:00:11 okmx8mm kernel: Booting Linux on physical CPU 0x0
Jun 20 18:00:11 okmx8mm kernel: Linux version 4.14.78 (forlinx@ubuntu) (gcc version 7.3.0 (GCC)) #1 SMP PREEMPT Mon Nov 25 14:09:54 AWST 2019
Jun 20 18:00:11 okmx8mm kernel: Boot CPU: AArch64 Processor [410fd034]
Jun 20 18:00:11 okmx8mm kernel: Machine model: Forlinx i.MX8MM EVK board
Jun 20 18:00:11 okmx8mm kernel: earlycon: ec_imx6q0 at MMIO 0x0000000030890000 (options '115200')
Jun 20 18:00:11 okmx8mm kernel: bootconsole [ec_imx6q0] enabled
Jun 20 18:00:11 okmx8mm kernel: efi: Getting EFI parameters from FDT:
Jun 20 18:00:11 okmx8mm kernel: efi: UEFI not found.
Jun 20 18:00:11 okmx8mm kernel: Reserved memory: created CMA memory pool at 0x0000000056000000, size 640 MiB
Jun 20 18:00:11 okmx8mm kernel: OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
Jun 20 18:00:11 okmx8mm kernel: NUMA: No NUMA configuration found
Jun 20 18:00:11 okmx8mm kernel: NUMA: Faking a node at [mem 0x0000000000000000-0x00000000bfffffff]
Jun 20 18:00:11 okmx8mm kernel: NUMA: NODE_DATA [mem 0xbffbef00-0xbffc0cff]
Jun 20 18:00:11 okmx8mm kernel: Zone ranges:
Jun 20 18:00:11 okmx8mm kernel:   DMA      [mem 0x0000000040000000-0x00000000bfffffff]
Jun 20 18:00:11 okmx8mm kernel:   Normal   empty
Jun 20 18:00:11 okmx8mm kernel: Movable zone start for each node
Jun 20 18:00:11 okmx8mm kernel: Early memory node ranges
Jun 20 18:00:11 okmx8mm kernel:   node   0: [mem 0x0000000040000000-0x00000000b7ffffff]
Jun 20 18:00:11 okmx8mm kernel:   node   0: [mem 0x00000000b8400000-0x00000000bfffffff]
Jun 20 18:00:11 okmx8mm kernel: Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
Jun 20 18:00:11 okmx8mm kernel: On node 0 totalpages: 523264
Jun 20 18:00:11 okmx8mm kernel:   DMA zone: 8192 pages used for memmap
Jun 20 18:00:11 okmx8mm kernel:   DMA zone: 0 pages reserved
Jun 20 18:00:11 okmx8mm kernel:   DMA zone: 523264 pages, LIFO batch:31
Jun 20 18:00:11 okmx8mm kernel: psci: probing for conduit method from DT.
Jun 20 18:00:11 okmx8mm kernel: psci: PSCIv1.1 detected in firmware.
Jun 20 18:00:11 okmx8mm kernel: psci: Using standard PSCI v0.2 function IDs
Jun 20 18:00:11 okmx8mm kernel: psci: MIGRATE_INFO_TYPE not supported.
Jun 20 18:00:11 okmx8mm kernel: psci: SMC Calling Convention v1.1
Jun 20 18:00:11 okmx8mm kernel: percpu: Embedded 24 pages/cpu @ffff80007ff59000 s57624 r8192 d32488 u98304
Jun 20 18:00:11 okmx8mm kernel: pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
Jun 20 18:00:11 okmx8mm kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Jun 20 18:00:11 okmx8mm kernel: Detected VIPT I-cache on CPU0
Jun 20 18:00:11 okmx8mm kernel: CPU features: enabling workaround for ARM erratum 845719
Jun 20 18:00:11 okmx8mm kernel: Speculative Store Bypass Disable mitigation not required
Jun 20 18:00:11 okmx8mm kernel: Built 1 zonelists, mobility grouping on.  Total pages: 515072
Jun 20 18:00:11 okmx8mm kernel: Policy zone: DMA
Jun 20 18:00:11 okmx8mm kernel: Kernel command line: console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200 root=/dev/mmcblk2p2 rootwait rw
Jun 20 18:00:11 okmx8mm kernel: PID hash table entries: 4096 (order: 3, 32768 bytes)
Jun 20 18:00:11 okmx8mm kernel: Memory: 1368128K/2093056K available (12540K kernel code, 1172K rwdata, 4688K rodata, 768K init, 427K bss, 69568K reserved, 655360K cma-reserved)
Jun 20 18:00:11 okmx8mm kernel: Virtual kernel memory layout:
Jun 20 18:00:11 okmx8mm kernel:     modules : 0xffff000000000000 - 0xffff000008000000   (   128 MB)
Jun 20 18:00:11 okmx8mm kernel:     vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000   (129022 GB)
Jun 20 18:00:11 okmx8mm kernel:       .text : 0xffff000008080000 - 0xffff000008cc0000   ( 12544 KB)
Jun 20 18:00:11 okmx8mm kernel:     .rodata : 0xffff000008cc0000 - 0xffff000009160000   (  4736 KB)
Jun 20 18:00:11 okmx8mm kernel:       .init : 0xffff000009160000 - 0xffff000009220000   (   768 KB)
Jun 20 18:00:11 okmx8mm kernel:       .data : 0xffff000009220000 - 0xffff000009345200   (  1173 KB)
Jun 20 18:00:11 okmx8mm kernel:        .bss : 0xffff000009345200 - 0xffff0000093aff38   (   428 KB)
Jun 20 18:00:11 okmx8mm kernel:     fixed   : 0xffff7dfffe7f9000 - 0xffff7dfffec00000   (  4124 KB)
Jun 20 18:00:11 okmx8mm kernel:     PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000   (    16 MB)
Jun 20 18:00:11 okmx8mm kernel:     vmemmap : 0xffff7e0000000000 - 0xffff800000000000   (  2048 GB maximum)
Jun 20 18:00:11 okmx8mm kernel:               0xffff7e0000000000 - 0xffff7e0002000000   (    32 MB actual)
Jun 20 18:00:11 okmx8mm kernel:     memory  : 0xffff800000000000 - 0xffff800080000000   (  2048 MB)
Jun 20 18:00:11 okmx8mm kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Jun 20 18:00:11 okmx8mm kernel: Preemptible hierarchical RCU implementation.
Jun 20 18:00:11 okmx8mm kernel:         RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
Jun 20 18:00:11 okmx8mm kernel:         Tasks RCU enabled.
Jun 20 18:00:11 okmx8mm kernel: RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Jun 20 18:00:11 okmx8mm kernel: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Jun 20 18:00:11 okmx8mm kernel: GICv3: GIC: Using split EOI/Deactivate mode
Jun 20 18:00:11 okmx8mm kernel: GICv3: no VLPI support, no direct LPI support
Jun 20 18:00:11 okmx8mm kernel: ITS: No ITS available, not enabling LPIs
Jun 20 18:00:11 okmx8mm kernel: GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
Jun 20 18:00:11 okmx8mm kernel: i.MX8MM clock driver init done
Jun 20 18:00:11 okmx8mm kernel: arch_timer: cp15 timer(s) running at 8.00MHz (phys).
Jun 20 18:00:11 okmx8mm kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
Jun 20 18:00:11 okmx8mm kernel: sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
Jun 20 18:00:11 okmx8mm kernel: system counter timer init
Jun 20 18:00:11 okmx8mm kernel: clocksource: imx sysctr: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
Jun 20 18:00:11 okmx8mm kernel: Console: colour dummy device 80x25
Jun 20 18:00:11 okmx8mm kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
Jun 20 18:00:11 okmx8mm kernel: pid_max: default: 32768 minimum: 301
Jun 20 18:00:11 okmx8mm kernel: Security Framework initialized
Jun 20 18:00:11 okmx8mm kernel: Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
Jun 20 18:00:11 okmx8mm kernel: Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
Jun 20 18:00:11 okmx8mm kernel: Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
Jun 20 18:00:11 okmx8mm kernel: Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
Jun 20 18:00:11 okmx8mm kernel: ASID allocator initialised with 32768 entries
Jun 20 18:00:11 okmx8mm kernel: Hierarchical SRCU implementation.
Jun 20 18:00:11 okmx8mm kernel: Cannot find MU entry in device tree
Jun 20 18:00:11 okmx8mm kernel: CPU identified as i.MX8MM, silicon rev 1.0
Jun 20 18:00:11 okmx8mm kernel: EFI services will not be available.
Jun 20 18:00:11 okmx8mm kernel: smp: Bringing up secondary CPUs ...
Jun 20 18:00:11 okmx8mm kernel: Detected VIPT I-cache on CPU1
Jun 20 18:00:11 okmx8mm kernel: GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
Jun 20 18:00:11 okmx8mm kernel: CPU1: Booted secondary processor [410fd034]
Jun 20 18:00:11 okmx8mm kernel: Detected VIPT I-cache on CPU2
Jun 20 18:00:11 okmx8mm kernel: GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
Jun 20 18:00:11 okmx8mm kernel: CPU2: Booted secondary processor [410fd034]
Jun 20 18:00:11 okmx8mm kernel: Detected VIPT I-cache on CPU3
Jun 20 18:00:11 okmx8mm kernel: GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
Jun 20 18:00:11 okmx8mm kernel: CPU3: Booted secondary processor [410fd034]
Jun 20 18:00:11 okmx8mm kernel: smp: Brought up 1 node, 4 CPUs
Jun 20 18:00:11 okmx8mm kernel: SMP: Total of 4 processors activated.
Jun 20 18:00:11 okmx8mm kernel: CPU features: detected feature: GIC system register CPU inte**ce
Jun 20 18:00:11 okmx8mm kernel: CPU features: detected feature: 32-bit EL0 Support
Jun 20 18:00:11 okmx8mm kernel: CPU features: detected feature: Kernel page table isolation (KPTI)
Jun 20 18:00:11 okmx8mm kernel: CPU: All CPU(s) started at EL2
Jun 20 18:00:11 okmx8mm kernel: alternatives: patching kernel code
Jun 20 18:00:11 okmx8mm kernel: devtmpfs: initialized
Jun 20 18:00:11 okmx8mm kernel: random: get_random_u32 called from bucket_table_alloc+0x108/0x260 with crng_init=0
Jun 20 18:00:11 okmx8mm kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Jun 20 18:00:11 okmx8mm kernel: futex hash table entries: 1024 (order: 5, 131072 bytes)
Jun 20 18:00:11 okmx8mm kernel: pinctrl core: initialized pinctrl subsystem
Jun 20 18:00:11 okmx8mm kernel: DMI not present or invalid.
Jun 20 18:00:11 okmx8mm kernel: NET: Registered protocol family 16
Jun 20 18:00:11 okmx8mm kernel: cpuidle: using governor menu
Jun 20 18:00:11 okmx8mm kernel: vdso: 2 pages (1 code @ ffff000008cc6000, 1 data @ ffff000009224000)
Jun 20 18:00:11 okmx8mm kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Jun 20 18:00:11 okmx8mm kernel: DMA: preallocated 256 KiB pool for atomic allocations
Jun 20 18:00:11 okmx8mm kernel: Serial: AMBA PL011 UART driver
Jun 20 18:00:11 okmx8mm kernel: imx8mm-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
Jun 20 18:00:11 okmx8mm kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Jun 20 18:00:11 okmx8mm kernel: ACPI: Interpreter disabled.
Jun 20 18:00:11 okmx8mm kernel: vgaarb: loaded
Jun 20 18:00:11 okmx8mm kernel: SCSI subsystem initialized
Jun 20 18:00:11 okmx8mm kernel: libata version 3.00 loaded.
Jun 20 18:00:11 okmx8mm kernel: usbcore: registered new inte**ce driver usbfs
Jun 20 18:00:11 okmx8mm kernel: usbcore: registered new inte**ce driver hub
Jun 20 18:00:11 okmx8mm kernel: usbcore: registered new device driver usb
Jun 20 18:00:11 okmx8mm kernel: usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: usb_phy_generic usbphynop2: usbphynop2 supply vcc not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: bd71837 0-004b: Device ID=0xA1
Jun 20 18:00:11 okmx8mm kernel: bd71837 0-004b: gpio_intr = 3
Jun 20 18:00:11 okmx8mm kernel: bd71837 0-004b: chip_irq=73
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck1'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: Buck[1] Set Ramp = 1250
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck2'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: Buck[2] Set Ramp = 1250
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck3'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck4'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck5'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck6'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck7'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck8'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'ldo1'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'ldo2'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'ldo3'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'ldo4'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'ldo5'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'ldo6'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'ldo7'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: Buck1: DVS Run-Idle-Susp[0 - 0 - 0].
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: bd71837_buck1234_dvs_init(): not found selector for Run voltage [0]
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: bd71837_buck1234_dvs_init(): not found selector for Idle voltage [0]
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: bd71837_buck1234_dvs_init(): not found selector for Susp voltage [0]
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: Buck2: DVS Run-Idle-Susp[0 - 0 - 0].
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: Buck3: DVS Run-Idle-Susp[0 - 0 - 0].
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: Buck4: DVS Run-Idle-Susp[0 - 0 - 0].
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-0: IMX I2C adapter registered
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-0: can't use DMA, using PIO instead.
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-1: IMX I2C adapter registered
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-1: can't use DMA, using PIO instead.
Jun 20 18:00:11 okmx8mm kernel: BD71837:bd71837_pmic_interrupt() in.
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-2: IMX I2C adapter registered
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-2: can't use DMA, using PIO instead.
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-3: IMX I2C adapter registered
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-3: can't use DMA, using PIO instead.
Jun 20 18:00:11 okmx8mm kernel: media: Linux media inte**ce: v0.10
Jun 20 18:00:11 okmx8mm kernel: Linux video capture inte**ce: v2.00
Jun 20 18:00:11 okmx8mm kernel: pps_core: LinuxPPS API ver. 1 registered
Jun 20 18:00:11 okmx8mm kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Jun 20 18:00:11 okmx8mm kernel: PTP clock support registered
Jun 20 18:00:11 okmx8mm kernel: EDAC MC: Ver: 3.0.0
Jun 20 18:00:11 okmx8mm kernel: dmi: Firmware registration failed.
Jun 20 18:00:11 okmx8mm kernel: MU is ready for cross core communication!
Jun 20 18:00:11 okmx8mm kernel: virtio_rpmsg_bus virtio0: rpmsg host is online
Jun 20 18:00:11 okmx8mm kernel: BD71837:IRQ_WDOG
Jun 20 18:00:11 okmx8mm kernel: imx rpmsg driver is registered.
Jun 20 18:00:11 okmx8mm kernel: Advanced Linux Sound Architecture Driver Initialized.
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: Core ver 2.22
Jun 20 18:00:11 okmx8mm kernel: NET: Registered protocol family 31
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: HCI device and connection manager initialized
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: HCI socket layer initialized
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: L2CAP socket layer initialized
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: SCO socket layer initialized
Jun 20 18:00:11 okmx8mm kernel: clocksource: Switched to clocksource arch_sys_counter
Jun 20 18:00:11 okmx8mm kernel: VFS: Disk quotas dquot_6.6.0
Jun 20 18:00:11 okmx8mm kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jun 20 18:00:11 okmx8mm kernel: pnp: PnP ACPI: disabled
Jun 20 18:00:11 okmx8mm kernel: NET: Registered protocol family 2
Jun 20 18:00:11 okmx8mm kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Jun 20 18:00:11 okmx8mm kernel: TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
Jun 20 18:00:11 okmx8mm kernel: TCP: Hash tables configured (established 16384 bind 16384)
Jun 20 18:00:11 okmx8mm kernel: UDP hash table entries: 1024 (order: 3, 32768 bytes)
Jun 20 18:00:11 okmx8mm kernel: UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
Jun 20 18:00:11 okmx8mm kernel: RPC: Registered named UNIX socket transport module.
Jun 20 18:00:11 okmx8mm kernel: RPC: Registered udp transport module.
Jun 20 18:00:11 okmx8mm kernel: RPC: Registered tcp transport module.
Jun 20 18:00:11 okmx8mm kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Jun 20 18:00:11 okmx8mm kernel: PCI: CLS 0 bytes, default 128
Jun 20 18:00:11 okmx8mm kernel: hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Jun 20 18:00:11 okmx8mm kernel: kvm [1]: 8-bit VMID
Jun 20 18:00:11 okmx8mm kernel: kvm [1]: GICv3: no GICV resource entry
Jun 20 18:00:11 okmx8mm kernel: kvm [1]: disabling GICv2 emulation
Jun 20 18:00:11 okmx8mm kernel: kvm [1]: GIC system register CPU inte**ce enabled
Jun 20 18:00:11 okmx8mm kernel: kvm [1]: vgic interrupt IRQ1
Jun 20 18:00:11 okmx8mm kernel: kvm [1]: Hyp mode initialized successfully
Jun 20 18:00:11 okmx8mm kernel: audit: initializing netlink subsys (disabled)
Jun 20 18:00:11 okmx8mm kernel: audit: type=2000 audit(0.868:1): state=initialized audit_enabled=0 res=1
Jun 20 18:00:11 okmx8mm kernel: workingset: timestamp_bits=44 max_order=19 bucket_order=0
Jun 20 18:00:11 okmx8mm kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jun 20 18:00:11 okmx8mm kernel: NFS: Registering the id_resolver key type
Jun 20 18:00:11 okmx8mm kernel: Key type id_resolver registered
Jun 20 18:00:11 okmx8mm kernel: Key type id_legacy registered
Jun 20 18:00:11 okmx8mm kernel: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Jun 20 18:00:11 okmx8mm kernel: jffs2: version 2.2. (NAND) &#169; 2001-2006 Red Hat, Inc.
Jun 20 18:00:11 okmx8mm kernel: 9p: Installing v9fs 9p2000 file system support
Jun 20 18:00:11 okmx8mm kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
Jun 20 18:00:11 okmx8mm kernel: io scheduler noop registered
Jun 20 18:00:11 okmx8mm kernel: io scheduler cfq registered (default)
Jun 20 18:00:11 okmx8mm kernel: io scheduler mq-deadline registered
Jun 20 18:00:11 okmx8mm kernel: io scheduler kyber registered
Jun 20 18:00:11 okmx8mm kernel: pwm-backlight backlight@0: backlight@0 supply power not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: imx-sdma 30bd0000.dma-controller: no iram assigned, using external mem
Jun 20 18:00:11 okmx8mm kernel: imx-sdma 30bd0000.dma-controller: Falling back to user helper
Jun 20 18:00:11 okmx8mm kernel: imx-sdma 302c0000.dma-controller: no iram assigned, using external mem
Jun 20 18:00:11 okmx8mm kernel: imx-sdma 302b0000.dma-controller: no iram assigned, using external mem
Jun 20 18:00:11 okmx8mm kernel: mxs-dma 33000000.dma-apbh: initialized
Jun 20 18:00:11 okmx8mm kernel: Bus freq driver module loaded
Jun 20 18:00:11 okmx8mm kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Jun 20 18:00:11 okmx8mm kernel: 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 27, base_baud = 5000000) is a IMX
Jun 20 18:00:11 okmx8mm kernel: 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 28, base_baud = 5000000) is a IMX
Jun 20 18:00:11 okmx8mm kernel: 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 29, base_baud = 1500000) is a IMX
Jun 20 18:00:11 okmx8mm kernel: console [ttymxc1] enabled
Jun 20 18:00:11 okmx8mm kernel: bootconsole [ec_imx6q0] disabled
Jun 20 18:00:11 okmx8mm kernel: [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
Jun 20 18:00:11 okmx8mm kernel: [drm] No driver support for vblank timestamp query.
Jun 20 18:00:11 okmx8mm kernel: imx-drm display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops)
Jun 20 18:00:11 okmx8mm kernel: imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
Jun 20 18:00:11 okmx8mm kernel: panel-**-dsi 32e10000.mipi_dsi.0: 32e10000.mipi_dsi.0 supply power not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: imx-drm display-subsystem: bound 32e10000.mipi_dsi (ops imx_sec_dsim_ops)
Jun 20 18:00:11 okmx8mm kernel: imx-drm display-subsystem: fb0:  frame buffer device
Jun 20 18:00:11 okmx8mm kernel: [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
Jun 20 18:00:11 okmx8mm kernel: brd: module loaded
Jun 20 18:00:11 okmx8mm kernel: loop: module loaded
Jun 20 18:00:11 okmx8mm kernel: random: fast init done
Jun 20 18:00:11 okmx8mm kernel: fsl-flexspi 30bb0000.flexspi: w25q128 (16384 Kbytes)
Jun 20 18:00:11 okmx8mm kernel: slram: not enough parameters.
Jun 20 18:00:11 okmx8mm kernel: spi_imx 30820000.ecspi: probed
Jun 20 18:00:11 okmx8mm kernel: spi_imx 30830000.ecspi: probed
Jun 20 18:00:11 okmx8mm kernel: libphy: Fixed MDIO Bus: probed
Jun 20 18:00:11 okmx8mm kernel: NXP PHY: loading NXP PHY driver: [autonomous mode]
Jun 20 18:00:11 okmx8mm kernel: tun: Universal TUN/TAP device driver, 1.6
Jun 20 18:00:11 okmx8mm kernel: CAN device driver inte**ce
Jun 20 18:00:11 okmx8mm kernel: fec 30be0000.ethernet: 30be0000.ethernet supply phy not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: pps pps0: new PPS source ptp0
Jun 20 18:00:11 okmx8mm kernel: libphy: fec_enet_mii_bus: probed
Jun 20 18:00:11 okmx8mm kernel: fec 30be0000.ethernet eth0: registered PHC device 0
Jun 20 18:00:11 okmx8mm kernel: e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
Jun 20 18:00:11 okmx8mm kernel: e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Jun 20 18:00:11 okmx8mm kernel: igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
Jun 20 18:00:11 okmx8mm kernel: igb: Copyright (c) 2007-2014 Intel Corporation.
Jun 20 18:00:11 okmx8mm kernel: igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
Jun 20 18:00:11 okmx8mm kernel: igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
Jun 20 18:00:11 okmx8mm kernel: sky2: driver version 1.30
Jun 20 18:00:11 okmx8mm kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jun 20 18:00:11 okmx8mm kernel: ehci-pci: EHCI PCI platform driver
Jun 20 18:00:11 okmx8mm kernel: ehci-platform: EHCI generic platform driver
Jun 20 18:00:11 okmx8mm kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jun 20 18:00:11 okmx8mm kernel: ohci-pci: OHCI PCI platform driver
Jun 20 18:00:11 okmx8mm kernel: ohci-platform: OHCI generic platform driver
Jun 20 18:00:11 okmx8mm kernel: usbcore: registered new inte**ce driver usb-storage
Jun 20 18:00:11 okmx8mm kernel: usbcore: registered new inte**ce driver usb_ehset_test
Jun 20 18:00:11 okmx8mm kernel: usbmisc_imx 32e40200.usbmisc: 32e40200.usbmisc supply vbus-wakeup not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: usbmisc_imx 32e50200.usbmisc: 32e50200.usbmisc supply vbus-wakeup not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: imx_usb 32e50000.usb: 32e50000.usb supply vbus not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: ci_hdrc ci_hdrc.1: EHCI Host Controller
Jun 20 18:00:11 okmx8mm kernel: ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
Jun 20 18:00:11 okmx8mm kernel: ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
Jun 20 18:00:11 okmx8mm kernel: hub 1-0:1.0: USB hub found
Jun 20 18:00:11 okmx8mm kernel: hub 1-0:1.0: 1 port detected
Jun 20 18:00:11 okmx8mm kernel: input: InputEmulator as /devices/virtual/input/input0
Jun 20 18:00:11 okmx8mm kernel: i2c /dev entries driver
Jun 20 18:00:11 okmx8mm kernel: mxc_mipi-csi 32e30000.mipi_csi: 32e30000.mipi_csi supply mipi-phy not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: mxc_mipi-csi 32e30000.mipi_csi: mipi csi v4l2 device registered
Jun 20 18:00:11 okmx8mm kernel: CSI: Registered sensor subdevice: mxc_mipi-csi.0
Jun 20 18:00:11 okmx8mm kernel: mxc_mipi-csi 32e30000.mipi_csi: lanes: 2, hs_settle: 13, clk_settle: 2, wclk: 1, freq: 333000000
Jun 20 18:00:11 okmx8mm kernel: ov5640_mipi 3-003c: 3-003c supply DOVDD not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: ov5640_mipi 3-003c: 3-003c supply DVDD not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: ov5640_mipi 3-003c: 3-003c supply AVDD not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: ov5640_mipi 3-003c: Read reg error: reg=300a
Jun 20 18:00:11 okmx8mm kernel: ov5640_mipi 3-003c: Camera is not found
Jun 20 18:00:11 okmx8mm kernel: imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
Jun 20 18:00:11 okmx8mm kernel: sdhci: Secure Digital Host Controller Inte**ce driver
Jun 20 18:00:11 okmx8mm kernel: sdhci: Copyright(c) Pierre Ossman
Jun 20 18:00:11 okmx8mm kernel: Synopsys Designware ** Card Inte**ce Driver
Jun 20 18:00:11 okmx8mm kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Jun 20 18:00:11 okmx8mm kernel: mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA
Jun 20 18:00:11 okmx8mm kernel: sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
Jun 20 18:00:11 okmx8mm kernel: mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
Jun 20 18:00:11 okmx8mm kernel: usb 1-1: new high-speed USB device number 2 using ci_hdrc
Jun 20 18:00:11 okmx8mm kernel: mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
Jun 20 18:00:11 okmx8mm kernel: galcore: clk_get vg clock failed, disable vg!
Jun 20 18:00:11 okmx8mm kernel: Galcore version 6.2.4.163672
Jun 20 18:00:11 okmx8mm kernel: mmc2: new HS200 MMC card at address 0001
Jun 20 18:00:11 okmx8mm kernel: mmcblk2: mmc2:0001 DG4008 7.28 GiB
Jun 20 18:00:11 okmx8mm kernel: mmcblk2boot0: mmc2:0001 DG4008 partition 1 4.00 MiB
Jun 20 18:00:11 okmx8mm kernel: mmcblk2boot1: mmc2:0001 DG4008 partition 2 4.00 MiB
Jun 20 18:00:11 okmx8mm kernel: mmcblk2rpmb: mmc2:0001 DG4008 partition 3 4.00 MiB
Jun 20 18:00:11 okmx8mm kernel:  mmcblk2: p1 p2
Jun 20 18:00:11 okmx8mm kernel: hub 1-1:1.0: USB hub found
Jun 20 18:00:11 okmx8mm kernel: hantrodec 0 : module inserted. Major = 240
Jun 20 18:00:11 okmx8mm kernel: hantrodec 1 : module inserted. Major = 240
Jun 20 18:00:11 okmx8mm kernel: hx280enc: module inserted. Major <239>
Jun 20 18:00:11 okmx8mm kernel: ledtrig-cpu: registered to indicate activity on CPUs
Jun 20 18:00:11 okmx8mm kernel: caam 30900000.caam: ERA source: CCBVID.
Jun 20 18:00:11 okmx8mm kernel: caam 30900000.caam: device ID = 0x0a16040100000000 (Era 9)
Jun 20 18:00:11 okmx8mm kernel: caam 30900000.caam: job rings = 3, qi = 0, dpaa2 = no
Jun 20 18:00:11 okmx8mm kernel: hub 1-1:1.0: 4 ports detected
Jun 20 18:00:11 okmx8mm kernel: caam_jr 30901000.jr0: Entropy delay = 3200
Jun 20 18:00:11 okmx8mm kernel: caam_jr 30901000.jr0: Entropy delay = 3600
Jun 20 18:00:11 okmx8mm kernel: caam_jr 30901000.jr0: Instantiated RNG4 SH0.
Jun 20 18:00:11 okmx8mm kernel: caam_jr 30901000.jr0: Instantiated RNG4 SH1.
Jun 20 18:00:11 okmx8mm kernel: caam algorithms registered in /proc/crypto
Jun 20 18:00:11 okmx8mm kernel: caam_jr 30901000.jr0: registering rng-caam
Jun 20 18:00:11 okmx8mm kernel: caam 30900000.caam: caam pkc algorithms registered in /proc/crypto
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: blkkey_ex: 2 keystore units available
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 64-bit clear key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 64-bit black key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] f1 60 47 88 6f 1d e4 87
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] d7 5d 6f 45 a6 1f 19 f9
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 128-bit clear key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 128-bit black key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] 2b 28 b7 22 36 f4 6b ef
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 16 e3 f7 6a 7d 71 aa 28
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 192-bit clear key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] 10 11 12 13 14 15 16 17
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 192-bit black key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] 55 54 44 df 41 7b fa a2
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] e8 58 bd 5c 35 36 f5 84
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] 8a 5a 0c db 97 c0 4d 21
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] b1 8d fb 41 3c 7b 65 1b
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 256-bit clear key:
Jun 20 18:00:11 okmx8mm kernel: usb 1-1.1: new high-speed USB device number 3 using ci_hdrc
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 256-bit black key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] 1e f6 fd 73 6e da 1b 10
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 1c 68 42 15 70 c8 d7 24
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] 85 78 d3 28 36 0f ae 7e
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] 88 ec 87 1c c7 05 25 b8
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 64-bit unwritten blob:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0032] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0040] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0048] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0056] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0064] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0072] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0080] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0088] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 128-bit unwritten blob:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 196-bit unwritten blob:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 256-bit unwritten blob:
Jun 20 18:00:11 okmx8mm kernel: usb 1-1.4: new high-speed USB device number 4 using ci_hdrc
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 64-bit black key in blob:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] a2 ba b2 c3 10 ba 8c 4f
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 85 5a 58 b5 4c 34 d4 68
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] a1 21 2e b7 1a b0 da f2
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] eb 12 68 2c 53 40 66 ac
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0032] db 96 0b 92 7c fb dc 75
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0040] d0 25 f1 aa e3 a1 c6 4b
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0048] 37 43 13 04 91 f6 fa a1
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 128-bit black key in blob:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] e8 14 ab 2c ca 79 87 e1
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 3a 69 99 8d 8c 6f fe ca
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] c2 aa 57 1e a6 b8 c4 a5
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] df 53 ab 40 11 4d 7f 25
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0032] c7 68 3f 1e 67 4d b4 8b
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0040] 4e 2f de a2 d3 28 cc 25
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0048] 19 ce 6a 38 37 3e 34 1e
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0056] a3 e1 b7 8e e4 12 c3 4c
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 192-bit black key in blob:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] 9a 0f 77 a3 38 d4 32 d5
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 6b 0c fd d0 0a ba 37 6c
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] 04 10 bb 9b 2e 77 ae 26
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] 56 9d 86 1b 21 bd 2b 80
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0032] f5 9d 82 39 3c 01 2b 19
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0040] ed 32 2c 02 74 97 45 e8
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0048] c8 67 45 33 cf 63 b6 0c
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0056] 9d ee f6 52 35 01 92 aa
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0064] e3 74 dd cd 98 16 6f 43
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 256-bit black key in blob:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] 10 15 a0 04 4d 55 a7 4c
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] d1 b2 e8 ee 34 5d 3a 72
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] 19 1d 92 2a 5b da 9b 25
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] ae 80 be d9 10 91 f4 50
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0032] 21 1c e5 c4 14 d7 e6 ee
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0040] 13 78 2c a5 ec 98 5a 59
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0048] 62 19 37 91 da 4d 25 19
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0056] 04 56 08 9a c2 ef 29 2d
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0064] 62 8c b0 6c 1f 94 65 06
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0072] ea 57 c2 1f 59 92 9b 1b
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: restored 64-bit black key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] d9 7d cf d6 eb 08 b9 d8
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] e4 f1 5a ea 93 e9 84 68
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: restored 128-bit black key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: restored 192-bit black key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] a2 c0 f5 03 58 9e 94 86
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] b7 16 92 a9 0f e8 b6 a0
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: restored 256-bit black key:
Jun 20 18:00:11 okmx8mm kernel: caam-snvs 30370000.caam-snvs: can't get snvs clock
Jun 20 18:00:11 okmx8mm kernel: caam-snvs 30370000.caam-snvs: violation handlers armed - non-secure state
Jun 20 18:00:11 okmx8mm kernel: usbcore: registered new inte**ce driver usbhid
Jun 20 18:00:11 okmx8mm kernel: usbhid: USB HID core driver
Jun 20 18:00:11 okmx8mm kernel: fsl-micfil-dai 30080000.micfil: GET IRQ: 41
Jun 20 18:00:11 okmx8mm kernel: fsl-micfil-dai 30080000.micfil: GET IRQ: 42
Jun 20 18:00:11 okmx8mm kernel: fsl-micfil-dai 30080000.micfil: GET IRQ: 43
Jun 20 18:00:11 okmx8mm kernel: fsl-micfil-dai 30080000.micfil: GET IRQ: 44
Jun 20 18:00:11 okmx8mm kernel: imx-wm8960 sound: wm8960-hifi <-> 30020000.sai mapping ok
Jun 20 18:00:11 okmx8mm kernel: imx-wm8960 sound: ASoC: no source widget found for ASRC-Playback
Jun 20 18:00:11 okmx8mm kernel: imx-wm8960 sound: ASoC: Failed to add route ASRC-Playback -> direct -> CPU-Playback
Jun 20 18:00:11 okmx8mm kernel: imx-wm8960 sound: ASoC: no sink widget found for ASRC-Capture
Jun 20 18:00:11 okmx8mm kernel: imx-wm8960 sound: ASoC: Failed to add route CPU-Capture -> direct -> ASRC-Capture
Jun 20 18:00:11 okmx8mm kernel: imx-wm8960 sound: ASoC: no DMI vendor name!
Jun 20 18:00:11 okmx8mm kernel: imx-micfil sound-micfil: snd-soc-dummy-dai <-> 30080000.micfil mapping ok
Jun 20 18:00:11 okmx8mm kernel: imx-micfil sound-micfil: ASoC: no DMI vendor name!
Jun 20 18:00:11 okmx8mm kernel: NET: Registered protocol family 26
Jun 20 18:00:11 okmx8mm kernel: NET: Registered protocol family 10
Jun 20 18:00:11 okmx8mm kernel: Segment Routing with IPv6
Jun 20 18:00:11 okmx8mm kernel: NET: Registered protocol family 17
Jun 20 18:00:11 okmx8mm kernel: can: controller area network core (rev 20170425 abi 9)
Jun 20 18:00:11 okmx8mm kernel: NET: Registered protocol family 29
Jun 20 18:00:11 okmx8mm kernel: can: raw protocol (rev 20170425)
Jun 20 18:00:11 okmx8mm kernel: can: broadcast manager protocol (rev 20170425 t)
Jun 20 18:00:11 okmx8mm kernel: can: netlink gateway (rev 20170425) max_hops=1
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: RFCOMM TTY layer initialized
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: RFCOMM socket layer initialized
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: RFCOMM ver 1.11
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: BNEP filters: protocol multicast
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: BNEP socket layer initialized
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: HIDP socket layer initialized
Jun 20 18:00:11 okmx8mm kernel: 9pnet: Installing 9P2000 support
Jun 20 18:00:11 okmx8mm kernel: Key type dns_resolver registered
Jun 20 18:00:11 okmx8mm kernel: registered taskstats version 1
Jun 20 18:00:11 okmx8mm kernel: cpu cpu0: registered imx8mq-cpufreq
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie 33800000.pcie: 33800000.pcie supply epdev_on not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: OF: PCI: host bridge /pcie@0x33800000 ranges:
Jun 20 18:00:11 okmx8mm kernel: OF: PCI:   No bus range found for /pcie@0x33800000, using [bus 00-ff]
Jun 20 18:00:11 okmx8mm kernel: OF: PCI:    IO 0x1ff80000..0x1ff8ffff -> 0x00000000
Jun 20 18:00:11 okmx8mm kernel: OF: PCI:   MEM 0x18000000..0x1fefffff -> 0x18000000
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie 33800000.pcie: Initialize PHY with EXT REfCLK!.
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie 33800000.pcie: PHY Initialization End!.
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie 33800000.pcie: pcie phy pll is locked.
Jun 20 18:00:11 okmx8mm kernel: usb 1-1.1: USB disconnect, device number 3
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie 33800000.pcie: phy link never came up
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie 33800000.pcie: failed to initialize host
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie 33800000.pcie: unable to add pcie port.
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie: probe of 33800000.pcie failed with error -110
Jun 20 18:00:11 okmx8mm kernel: input: gpio-keys as /devices/platform/gpio-keys/input/input2
Jun 20 18:00:11 okmx8mm kernel: hctosys: unable to open rtc device (rtc0)
Jun 20 18:00:11 okmx8mm kernel: WLAN_EN: disabling
Jun 20 18:00:11 okmx8mm kernel: VSD_3V3: disabling
Jun 20 18:00:11 okmx8mm kernel: usb_otg1_vbus: disabling
Jun 20 18:00:11 okmx8mm kernel: ALSA device list:
Jun 20 18:00:11 okmx8mm kernel:   #0: wm8960-audio
Jun 20 18:00:11 okmx8mm kernel:   #1: imx-audio-micfil
Jun 20 18:00:11 okmx8mm kernel: EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. Opts: (null)
Jun 20 18:00:11 okmx8mm kernel: VFS: Mounted root (ext4 filesystem) on device 179:2.
Jun 20 18:00:11 okmx8mm kernel: devtmpfs: mounted
Jun 20 18:00:11 okmx8mm kernel: Freeing unused kernel memory: 768K
Jun 20 18:00:11 okmx8mm systemd[1]: System time before build time, advancing clock.
Jun 20 18:00:11 okmx8mm systemd[1]: systemd 237 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
Jun 20 18:00:11 okmx8mm systemd[1]: Detected architecture arm64.
Jun 20 18:00:11 okmx8mm systemd[1]: Set hostname to <okmx8mm>.
Jun 20 18:00:11 okmx8mm systemd[1]: File /lib/systemd/system/systemd-journald.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
Jun 20 18:00:11 okmx8mm systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
Jun 20 18:00:11 okmx8mm kernel: random: systemd: uninitialized urandom read (16 bytes read)
Jun 20 18:00:11 okmx8mm systemd[1]: Reached target Remote File Systems.
Jun 20 18:00:11 okmx8mm systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Jun 20 18:00:11 okmx8mm systemd[1]: Reached target Swap.
Jun 20 18:00:11 okmx8mm systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Jun 20 18:00:11 okmx8mm systemd[1]: Reached target Host and Network Name Lookups.
Jun 20 18:00:11 okmx8mm kernel: EXT4-fs (mmcblk2p2): re-mounted. Opts: (null)
Jun 20 18:00:11 okmx8mm systemd-journald[2480]: Journal started
Jun 20 18:00:11 okmx8mm systemd-journald[2480]: Runtime journal (/run/log/journal/94e1df36640a446a9b3bdbc917b10519) is 8.0M, max 64.0M, 56.0M free.
Jun 20 18:00:11 okmx8mm systemd-modules-load[1913]: Module 'galcore' is builtin
Jun 20 18:00:11 okmx8mm systemd-vconsole-setup[2479]: KD_FONT_OP_GET failed while trying to get the font metadata: Function not implemented
Jun 20 18:00:11 okmx8mm systemd-vconsole-setup[2479]: Fonts will not be copied to remaining consoles
Jun 20 18:00:11 okmx8mm systemd[1]: Started Create list of required static device nodes for the current kernel.
Jun 20 18:00:11 okmx8mm systemd[1]: Started Remount Root and Kernel File Systems.
Jun 20 18:00:11 okmx8mm systemd[1]: Started Load Kernel Modules.
Jun 20 18:00:11 okmx8mm systemd[1]: Started Setup Virtual Console.
Jun 20 18:00:11 okmx8mm systemd[1]: Mounted Kernel Debug File System.
Jun 20 18:00:11 okmx8mm systemd[1]: Starting Apply Kernel Variables...
Jun 20 18:00:11 okmx8mm systemd-sysctl[2483]: Couldn't write 'fq_codel' to 'net/core/default_qdisc', ignoring: No such file or directory
Jun 20 18:00:11 okmx8mm systemd[1]: Mounting Kernel Configuration File System...
Jun 20 18:00:11 okmx8mm systemd[1]: Starting Create Static Device Nodes in /dev...
Jun 20 18:00:11 okmx8mm systemd[1]: Starting Flush Journal to Persistent Storage...
Jun 20 18:00:12 okmx8mm systemd[1]: Started udev Coldplug all Devices.
Jun 20 18:00:12 okmx8mm systemd[1]: Started Apply Kernel Variables.
Jun 20 18:00:12 okmx8mm systemd[1]: Mounted Kernel Configuration File System.
Jun 20 18:00:12 okmx8mm systemd[1]: Started Create Static Device Nodes in /dev.
Jun 20 18:00:12 okmx8mm systemd[1]: Reached target Local File Systems (Pre).
Jun 20 18:00:12 okmx8mm systemd[1]: Reached target Containers.
Jun 20 18:00:12 okmx8mm systemd[1]: Mounting /var/volatile...
Jun 20 18:00:12 okmx8mm systemd[1]: Starting udev Kernel Device Manager...
Jun 20 18:00:12 okmx8mm systemd[1]: Mounted /var/volatile.
Jun 20 18:00:12 okmx8mm systemd-journald[2480]: Runtime journal (/run/log/journal/94e1df36640a446a9b3bdbc917b10519) is 8.0M, max 64.0M, 56.0M free.
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Load/Save Random Seed...
Jun 20 18:00:12 okmx8mm systemd[1]: Reached target Local File Systems.
Jun 20 18:00:12 okmx8mm systemd[1]: Started udev Kernel Device Manager.
Jun 20 18:00:12 okmx8mm systemd[1]: Started Flush Journal to Persistent Storage.
Jun 20 18:00:12 okmx8mm systemd[1]: Started Load/Save Random Seed.
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Create Volatile Files and Directories...
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Start Psplash Boot Screen...
Jun 20 18:00:12 okmx8mm systemd-tmpfiles[3025]: "/var/log" already exists and is not a directory.
Jun 20 18:00:12 okmx8mm systemd-tmpfiles[3025]: "/var/tmp" already exists and is not a directory.
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Network Service...
Jun 20 18:00:12 okmx8mm systemd[1]: Started Create Volatile Files and Directories.
Jun 20 18:00:12 okmx8mm systemd[1]: Started Start Psplash Boot Screen.
Jun 20 18:00:12 okmx8mm systemd-networkd[3027]: Enumeration completed
Jun 20 18:00:12 okmx8mm systemd-networkd[3027]: lo: Removing non-existent address: ::1/128 (valid forever), ignoring
Jun 20 18:00:12 okmx8mm systemd[1]: Started Network Service.
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Wait for Network to be Configured...
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Network Time Synchronization...
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Jun 20 18:00:12 okmx8mm systemd[1]: Found device /dev/ttymxc1.
Jun 20 18:00:12 okmx8mm systemd[1]: Started Update UTMP about System Boot/Shutdown.
Jun 20 18:00:12 okmx8mm kernel: edt_ft5x06 3-0038: touchscreen probe failed
Jun 20 18:00:12 okmx8mm kernel: rtc-rx8010 1-0032: rtc core: registered rx8010 as rtc0
Jun 20 18:00:12 okmx8mm kernel: imx-sdma 302c0000.dma-controller: loaded firmware 4.4
Jun 20 18:00:12 okmx8mm kernel: imx-sdma 302b0000.dma-controller: loaded firmware 4.4
Jun 20 18:00:12 okmx8mm kernel: imx-sdma 30bd0000.dma-controller: loaded firmware 4.4
Jun 20 18:00:12 okmx8mm systemd-udevd[3015]: Failed to apply ACL on /dev/video0: Operation not supported
Jun 20 18:00:12 okmx8mm systemd[1]: Created slice system-systemd\x2dbacklight.slice.
Jun 20 18:00:12 okmx8mm systemd-udevd[3034]: Failed to apply ACL on /dev/dri/card0: Operation not supported
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight@0...
Jun 20 18:00:12 okmx8mm systemd[1]: Started Load/Save Screen Backlight Brightness of backlight:backlight@0.
Jun 20 18:00:12 okmx8mm systemd-udevd[3021]: Failed to apply ACL on /dev/snd/pcmC1D0c: Operation not supported
Jun 20 18:00:12 okmx8mm systemd-networkd-wait-online[3029]: ignoring: lo
Jun 20 18:00:12 okmx8mm systemd-timesyncd[3031]: System clock time unset or jumped backwards, restoring from recorded timestamp: Tue 2019-11-26 17:08:52 CST
Nov 26 17:08:52 okmx8mm systemd-udevd[3023]: Failed to apply ACL on /dev/snd/controlC1: Operation not supported
Nov 26 17:08:52 okmx8mm systemd[1]: Started Network Time Synchronization.
Nov 26 17:08:52 okmx8mm systemd-udevd[3021]: Failed to apply ACL on /dev/snd/pcmC0D0c: Operation not supported
Nov 26 17:08:52 okmx8mm systemd-udevd[3035]: Failed to apply ACL on /dev/snd/pcmC0D0p: Operation not supported
Nov 26 17:08:52 okmx8mm systemd-udevd[3019]: Failed to apply ACL on /dev/snd/controlC0: Operation not supported
Nov 26 17:08:52 okmx8mm root[3079]: udev/mount.sh [/dev/mtdblock0] is blacklisted, ignoring
Nov 26 17:08:52 okmx8mm systemd[1]: Reached target System Time Synchronized.
Nov 26 17:08:52 okmx8mm systemd[1]: Reached target System Initialization.
Nov 26 17:08:52 okmx8mm systemd[1]: Starting Docker Socket for the API.
Nov 26 17:08:52 okmx8mm root[3109]: udev/mount.sh [/dev/loop2] is blacklisted, ignoring
Nov 26 17:08:52 okmx8mm systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Nov 26 17:08:52 okmx8mm root[3123]: udev/mount.sh [/dev/loop7] is blacklisted, ignoring
Nov 26 17:08:52 okmx8mm systemd[1]: logrotate.timer: Not using persistent file timestamp Wed 2019-11-27 00:30:17 CST as it is in the future.
Nov 26 17:08:52 okmx8mm systemd[1]: Started Daily rotation of log files.
Nov 26 17:08:52 okmx8mm root[3121]: udev/mount.sh [/dev/loop0] is blacklisted, ignoring
Nov 26 17:08:52 okmx8mm systemd[1]: Listening on dropbear.socket.
Nov 26 17:08:52 okmx8mm systemd[1]: Starting Console System Startup Logging...
Nov 26 17:08:52 okmx8mm systemd[1]: Listening on D-Bus System Message Bus Socket.
Nov 26 17:08:52 okmx8mm root[3134]: udev/mount.sh [/dev/loop4] is blacklisted, ignoring
Nov 26 17:08:52 okmx8mm root[3148]: udev/mount.sh [/dev/loop1] is blacklisted, ignoring
Nov 26 17:08:53 okmx8mm root[3151]: udev/mount.sh [/dev/loop3] is blacklisted, ignoring
Nov 26 17:08:53 okmx8mm root[3133]: udev/mount.sh [/dev/loop5] is blacklisted, ignoring
Nov 26 17:08:53 okmx8mm systemd[1]: Started Daily Cleanup of Temporary Directories.
Nov 26 17:08:53 okmx8mm systemd[1]: Reached target Timers.
Nov 26 17:08:53 okmx8mm systemd[1]: Listening on RPCbind Server Activation Socket.
Nov 26 17:08:53 okmx8mm root[3183]: udev/mount.sh [/dev/ram10] is blacklisted, ignoring
Nov 26 17:08:53 okmx8mm root[3184]: udev/mount.sh [/dev/ram14] is blacklisted, ignoring
Nov 26 17:08:53 okmx8mm root[3160]: udev/mount.sh [/dev/loop6] is blacklisted, ignoring
Nov 26 17:08:53 okmx8mm systemd[1]: Listening on Docker Socket for the API.
Nov 26 17:08:53 okmx8mm root[3185]: udev/mount.sh [/dev/ram0] is blacklisted, ignoring
Nov 26 17:08:53 okmx8mm systemd[1]: Started Console System Startup Logging.
Nov 26 17:08:53 okmx8mm root[3181]: udev/mount.sh [/dev/ram1] is blacklisted, ignoring
Nov 26 17:08:53 okmx8mm root[3196]: udev/mount.sh [/dev/ram15] is blacklisted, ignoring
Nov 26 17:08:53 okmx8mm systemd[1]: Reached target Sockets.
Nov 26 17:08:53 okmx8mm systemd[1]: Reached target Basic System.
Nov 26 17:08:53 okmx8mm root[3213]: udev/mount.sh [/dev/ram12] is blacklisted, ignoring
Nov 26 17:08:53 okmx8mm systemd[1]: Started Configuration for i.MX GPU (Former rc_gpu.S).
Nov 26 17:08:53 okmx8mm root[3240]: udev/mount.sh [/dev/ram3] is blacklisted, ignoring
Nov 26 17:08:53 okmx8mm systemd[1]: Starting Telephony service...
Nov 26 17:08:53 okmx8mm root[3230]: udev/mount.sh [/dev/ram5] is blacklisted, ignoring
Nov 26 17:08:53 okmx8mm systemd[1]: Starting LSB: Set system clock...
Nov 26 17:08:53 okmx8mm ofonod[3241]: oFono version 1.22
Nov 26 17:08:53 okmx8mm kernel: rtk_btusb: Realtek Bluetooth USB driver ver 3.1.abb7701.20181012-134852
Nov 26 17:08:53 okmx8mm kernel: rtk_btcoex: rtk_btcoex_init: version: 1.2
Nov 26 17:08:53 okmx8mm kernel: rtk_btcoex: create workqueue
Nov 26 17:08:53 okmx8mm root[3243]: udev/mount.sh [/dev/ram13] is blacklisted, ignoring
Nov 26 17:08:53 okmx8mm root[3247]: udev/mount.sh [/dev/ram11] is blacklisted, ignoring
Nov 26 17:08:53 okmx8mm kernel: rtk_btcoex: Coex over UDP
Nov 26 17:08:53 okmx8mm hwclock.sh[3248]: System time was Tue Nov 26 17:08:53 CST 2019.
Nov 26 17:08:53 okmx8mm hwclock.sh[3248]: Setting the System Clock using the Hardware Clock as reference...
Nov 26 17:08:53 okmx8mm systemd[1]: Starting Save/Restore Sound Card State...
Nov 26 17:09:04 okmx8mm root[3257]: udev/mount.sh [/dev/ram4] is blacklisted, ignoring
Nov 26 17:09:04 okmx8mm hwclock.sh[3248]: System Clock set. System local time is now Tue Nov 26 17:09:04 CST 2019.
Nov 26 17:09:04 okmx8mm root[3265]: udev/mount.sh [/dev/ram6] is blacklisted, ignoring
Nov 26 17:09:04 okmx8mm root[3271]: udev/mount.sh [/dev/ram8] is blacklisted, ignoring
Nov 26 17:09:04 okmx8mm root[3269]: udev/mount.sh [/dev/ram9] is blacklisted, ignoring
Nov 26 17:09:04 okmx8mm root[3268]: udev/mount.sh [/dev/ram2] is blacklisted, ignoring
Nov 26 17:09:04 okmx8mm root[3276]: udev/mount.sh [/dev/ram7] is blacklisted, ignoring
Nov 26 17:09:04 okmx8mm systemd-udevd[3017]: Failed to apply ACL on /dev/snd/timer: Operation not supported
Nov 26 17:09:04 okmx8mm kernel: rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
Nov 26 17:09:04 okmx8mm systemd[1]: Starting Login Service...
Nov 26 17:09:04 okmx8mm systemd[1]: Starting System Logging Service...
Nov 26 17:09:04 okmx8mm systemd-logind[3281]: New seat seat0.
Nov 26 17:09:04 okmx8mm systemd[1]: Starting LSB: run bluez5-obex daemon...
Nov 26 17:09:04 okmx8mm systemd-networkd-wait-online[3029]: ignoring: lo
Nov 26 17:09:04 okmx8mm obexd[3301]: Starting Obexd.
Nov 26 17:09:04 okmx8mm systemd[1]: Started Periodic Command Scheduler.
Nov 26 17:09:04 okmx8mm systemd-logind[3281]: Watching system buttons on /dev/input/event0 (InputEmulator)
Nov 26 17:09:04 okmx8mm systemd[1]: Started Job spooling tools.
Nov 26 17:09:04 okmx8mm systemd[1]: Started Updates psplash to basic.
Nov 26 17:09:04 okmx8mm systemd[1]: Started TEE Supplicant.
Nov 26 17:09:04 okmx8mm tee-supplicant[3309]: ERR [3309] TEES:main:663: failed to find an OP-TEE supplicant device
Nov 26 17:09:04 okmx8mm systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Nov 26 17:09:04 okmx8mm systemd[1]: Starting Network Time Service (one-shot ntpdate mode)...
Nov 26 17:09:04 okmx8mm systemd[1]: Starting RPC Bind Service...
Nov 26 17:09:04 okmx8mm systemd[1]: Started D-Bus System Message Bus.
Nov 26 17:09:04 okmx8mm systemd[1]: Started Login Service.
Nov 26 17:09:04 okmx8mm kernel: usbcore: registered new inte**ce driver rtl8723bu
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInte**ceNumber 0
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: patch_add
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: auto suspend is disabled
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: pid = 0xb720
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: patch_add: Reset gEVersion to 0xff
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: btusb_probe: done
Nov 26 17:09:04 okmx8mm kernel: usbcore: registered new inte**ce driver rtk_btusb
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: btusb_open start pm_usage_cnt(0x1)
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: btusb_open hdev->promisc ==0
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: download_patch start
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: chip type value: 0x00
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: HCI reset.
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: read_ver_rsp->lmp_subver = 0x8723
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: read_ver_rsp->hci_rev = 0xb
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: patch_entry->lmp_sub = 0x8723
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: load_firmware start
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: lmp_version = 0x8723
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: config filename rtl8723bu_config
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: no bdaddr file /opt/bdaddr
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: config offset 00f4,length 08
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: config offset 01e3,length 01
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: config offset 00db,length 01
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: 55 ab 23 87 13 00 f4 00 08 01 00 00 00 05 50 00
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: 00 e3 01 01 04 db 00 01 42
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: Config file length 25, new length 25
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: fw name is  rtl8723b_fw
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: This is not 8723a, use new patch style!
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: rtk_get_eversion: gEVersion 255
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: eversion->status = 0x0, eversion->version = 0x1
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: load_firmware: New gEVersion 1
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 1
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: lmp_version is 8723, project_id is 8723, match!
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: fw_version = 0x1e6ca747
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: number_of_total_patch = 2
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: chipID 2
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: patch_length 0x58f0
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: start_offset 0x000058c0
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: Svn version:    19897
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: Coexistence: BTCOEX_20171128-6d50
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: buf_len = 0x5909
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: fw: exists, config file: exists
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: load_firmware done
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: download_data start
Nov 26 17:09:04 okmx8mm systemd[1]: Starting Connection service...
Nov 26 17:09:04 okmx8mm systemd[3338]: connman.service: Executable /usr/lib/connman/wired-setup missing, skipping: No such file or directory
Nov 26 17:09:04 okmx8mm systemd[1]: Started LSB: Set system clock.
Nov 26 17:09:04 okmx8mm systemd[1]: Started Save/Restore Sound Card State.
Nov 26 17:09:04 okmx8mm systemd[1]: Started System Logging Service.
Nov 26 17:09:04 okmx8mm systemd[1]: Started LSB: run bluez5-obex daemon.
Nov 26 17:09:04 okmx8mm systemd[1]: tee-supplicant.service: Main process exited, code=exited, status=1/FAILURE
Nov 26 17:09:04 okmx8mm systemd[1]: tee-supplicant.service: Failed with result 'exit-code'.
Nov 26 17:09:04 okmx8mm systemd[1]: Started Network Time Service (one-shot ntpdate mode).
Nov 26 17:09:04 okmx8mm systemd[1]: Started RPC Bind Service.
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: download_data done
Nov 26 17:09:04 okmx8mm systemd[1]: Started Telephony service.
Nov 26 17:09:04 okmx8mm systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: read_ver_rsp->lmp_subver = 0xa747
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: read_ver_rsp->hci_rev = 0x1e6c
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: Rtk patch end 0
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: btusb_open set HCI_RUNNING
Nov 26 17:09:04 okmx8mm kernel: rtk_btcoex: Open BTCOEX
Nov 26 17:09:04 okmx8mm kernel: rtk_btcoex: create_udpsocket: connect_port: 30001
Nov 26 17:09:04 okmx8mm kernel: rtk_btcoex: send msg INVITE_REQ with len:11
Nov 26 17:09:04 okmx8mm systemd[1]: Started Connection service.
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: btusb_open end  pm_usage_cnt(0x0)
Nov 26 17:09:04 okmx8mm kernel: Atheros 8031 ethernet 30be0000.ethernet-1:01: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=30be0000.ethernet-1:01, irq=POLL)
Nov 26 17:09:04 okmx8mm kernel: rtk_btcoex: BTCOEX hci_rev 0x1e6c
Nov 26 17:09:04 okmx8mm kernel: rtk_btcoex: BTCOEX lmp_subver 0xa747
Nov 26 17:09:04 okmx8mm systemd[1]: Starting Hostname Service...
Nov 26 17:09:04 okmx8mm kernel: rtk_btusb: btusb_notify: hci0 evt 3
Nov 26 17:09:04 okmx8mm systemd[1]: Starting WPA supplicant...
Nov 26 17:09:04 okmx8mm systemd[1]: Starting Bluetooth service...
Nov 26 17:09:04 okmx8mm systemd[1]: Starting Kernel Logging Service...
Nov 26 17:09:04 okmx8mm wpa_supplicant[3348]: Successfully initialized wpa_supplicant
Nov 26 17:09:04 okmx8mm systemd[1]: Reached target Sound Card.
Nov 26 17:09:04 okmx8mm systemd[1]: Started WPA supplicant.
Nov 26 17:09:04 okmx8mm systemd[1]: Started Bluetooth service.
Nov 26 17:09:04 okmx8mm systemd[1]: Reached target Bluetooth.
Nov 26 17:09:04 okmx8mm systemd[1]: Reached target Network.
Nov 26 17:09:05 okmx8mm systemd[1]: Starting Permit User Sessions...
Nov 26 17:09:05 okmx8mm systemd[1]: Started NFS status monitor for NFSv2/3 locking..
Nov 26 17:09:05 okmx8mm rpc.statd[3353]: sm-notify: Version 2.1.1 starting
Nov 26 17:09:05 okmx8mm rpc.statd[3353]: sm-notify: No hosts to notify; exiting
Nov 26 17:09:05 okmx8mm systemd[1]: Starting Lightning Fast Webserver With Light System Requirements...
Nov 26 17:09:05 okmx8mm lighttpd[3355]: Syntax OK
Nov 26 17:09:05 okmx8mm systemd[1]: Starting /etc/rc.local Compatibility...
Nov 26 17:09:05 okmx8mm systemd[1]: Started Vsftpd ftp daemon.
Nov 26 17:09:05 okmx8mm systemd[1]: Starting telnetd...
Nov 26 17:09:05 okmx8mm systemd[1]: Started Update psplash to network.
Nov 26 17:09:05 okmx8mm systemd[1]: Starting Terminate Psplash Boot Screen...
Nov 26 17:09:05 okmx8mm systemd[1]: Started Permit User Sessions.
Nov 26 17:09:05 okmx8mm systemd[1]: Started Lightning Fast Webserver With Light System Requirements.
Nov 26 17:09:05 okmx8mm systemd[1]: Started Kernel Logging Service.
Nov 26 17:09:05 okmx8mm lighttpd[3362]: 2019-11-26 17:09:05: (../../lighttpd-1.4.48/src/server.c.1412) server started (lighttpd/1.4.48)
Nov 26 17:09:05 okmx8mm systemd[1]: Started /etc/rc.local Compatibility.
Nov 26 17:09:05 okmx8mm systemd[1]: Started telnetd.
Nov 26 17:09:05 okmx8mm systemd[1]: Started Terminate Psplash Boot Screen.
Nov 26 17:09:05 okmx8mm systemd[1]: Started Hostname Service.
Nov 26 17:09:05 okmx8mm systemd[1]: Started Serial Getty on ttymxc1.
Nov 26 17:09:05 okmx8mm systemd[1]: Starting Weston Wayland Compositor (on tty7)...
Nov 26 17:09:05 okmx8mm systemd-udevd[3367]: setting owner of /dev/vcs7 to uid=0, gid=5 failed: No such file or directory
Nov 26 17:09:05 okmx8mm systemd[1]: Started Getty on tty1.
Nov 26 17:09:05 okmx8mm systemd[1]: Reached target Login Prompts.
Nov 26 17:09:05 okmx8mm systemd[1]: Started Weston Wayland Compositor (on tty7).
Nov 26 17:09:05 okmx8mm systemd[1]: Starting weston-touch-calibrator...
Nov 26 17:09:05 okmx8mm systemd[1]: Starting Matrix GUI...
Nov 26 17:09:05 okmx8mm systemd[1]: Created slice User Slice of root.
Nov 26 17:09:05 okmx8mm matrix-gui-2.0[3378]: /
Nov 26 17:09:05 okmx8mm systemd[1]: Starting User Manager for UID 0...
Nov 26 17:09:05 okmx8mm kernel: audit: type=1006 audit(1574759345.432:2): pid=3384 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
Nov 26 17:09:05 okmx8mm systemd-logind[3281]: New session c1 of user root.
Nov 26 17:09:05 okmx8mm systemd[1]: Started Session c1 of user root.
Nov 26 17:09:05 okmx8mm systemd-logind[3281]: Failed to apply ACLs: Operation not supported
Nov 26 17:09:05 okmx8mm systemd[3384]: Reached target Sockets.
Nov 26 17:09:05 okmx8mm systemd[3384]: Reached target Timers.
Nov 26 17:09:05 okmx8mm systemd[3384]: Reached target Paths.
Nov 26 17:09:05 okmx8mm systemd[3384]: Reached target Basic System.
Nov 26 17:09:05 okmx8mm systemd[3384]: Reached target Default.
Nov 26 17:09:05 okmx8mm systemd[3384]: Startup finished in 57ms.
Nov 26 17:09:05 okmx8mm systemd[1]: Started User Manager for UID 0.
Nov 26 17:09:05 okmx8mm matrix-gui-2.0[3378]: Starting Matrix GUI application.
Nov 26 17:09:05 okmx8mm systemd[1]: Started Matrix GUI.
Nov 26 17:09:05 okmx8mm weston-launch[3375]: Wrong panel position:
Nov 26 17:09:05 okmx8mm weston-launch[3375]: could not load cursor 'dnd-move'
Nov 26 17:09:05 okmx8mm weston-launch[3375]: could not load cursor 'dnd-copy'
Nov 26 17:09:05 okmx8mm weston-launch[3375]: could not load cursor 'dnd-none'
Nov 26 17:09:06 okmx8mm cal.sh[3376]: could not load cursor 'dnd-move'
Nov 26 17:09:06 okmx8mm cal.sh[3376]: could not load cursor 'dnd-copy'
Nov 26 17:09:06 okmx8mm cal.sh[3376]: could not load cursor 'dnd-none'
Nov 26 17:09:06 okmx8mm cal.sh[3376]: No devices listed.
Nov 26 17:09:06 okmx8mm systemd[1]: Started weston-touch-calibrator.
Nov 26 17:09:06 okmx8mm systemd-networkd-wait-online[3029]: ignoring: lo
Nov 26 17:09:06 okmx8mm kernel: fec 30be0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
Nov 26 17:09:06 okmx8mm systemd-networkd[3027]: eth0: Gained carrier
Nov 26 17:09:06 okmx8mm kernel: 8021q: 802.1Q VLAN Support v1.8
Nov 26 17:09:06 okmx8mm kernel: rtk_btusb: btusb_flush add delay
Nov 26 17:09:06 okmx8mm kernel: rtk_btusb: btusb_close
Nov 26 17:09:06 okmx8mm kernel: rtk_btcoex: Close BTCOEX
Nov 26 17:09:06 okmx8mm kernel: rtk_btcoex: release udp socket
Nov 26 17:09:06 okmx8mm kernel: rtk_btcoex: -x
Nov 26 17:09:06 okmx8mm kernel: usb 1-1.1: new high-speed USB device number 5 using ci_hdrc
Nov 26 17:09:07 okmx8mm kernel: cdc_ether 1-1.1:2.0 wwan0: register 'cdc_ether' at usb-ci_hdrc.1-1.1, Mobile Broadband Network Device, 02:1e:10:1f:00:00
Nov 26 17:09:07 okmx8mm kernel: usbcore: registered new inte**ce driver usbserial
Nov 26 17:09:07 okmx8mm kernel: usbcore: registered new inte**ce driver usbserial_generic
Nov 26 17:09:07 okmx8mm kernel: usbserial: USB Serial support registered for generic
Nov 26 17:09:07 okmx8mm kernel: usbcore: registered new inte**ce driver option
Nov 26 17:09:07 okmx8mm kernel: usbserial: USB Serial support registered for GSM modem (1-port)
Nov 26 17:09:07 okmx8mm kernel: usbcore: registered new inte**ce driver cdc_ether
Nov 26 17:09:07 okmx8mm kernel: option 1-1.1:2.2: GSM modem (1-port) converter detected
Nov 26 17:09:07 okmx8mm kernel: usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB0
Nov 26 17:09:07 okmx8mm kernel: option 1-1.1:2.3: GSM modem (1-port) converter detected
Nov 26 17:09:07 okmx8mm kernel: usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB1
Nov 26 17:09:07 okmx8mm kernel: option 1-1.1:2.4: GSM modem (1-port) converter detected
Nov 26 17:09:07 okmx8mm kernel: usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB2
Nov 26 17:09:07 okmx8mm kernel: option 1-1.1:2.5: GSM modem (1-port) converter detected
Nov 26 17:09:07 okmx8mm kernel: usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB3
Nov 26 17:09:07 okmx8mm kernel: option 1-1.1:2.6: GSM modem (1-port) converter detected
Nov 26 17:09:07 okmx8mm kernel: usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB4
Nov 26 17:09:07 okmx8mm systemd-networkd-wait-online[3029]: ignoring: lo
Nov 26 17:09:07 okmx8mm systemd-timesyncd[3031]: Network configuration changed, trying to establish connection.
Nov 26 17:09:07 okmx8mm systemd[1]: Started Wait for Network to be Configured.
Nov 26 17:09:07 okmx8mm systemd[1]: Reached target Network is Online.
Nov 26 17:09:07 okmx8mm systemd[1]: Starting Docker Application Container Engine...
Nov 26 17:09:08 okmx8mm systemd-networkd[3027]: eth0: Gained IPv6LL
Nov 26 17:09:11 okmx8mm systemd-timesyncd[3031]: Synchronized to time server 120.25.115.20:123 (ntp1.aliyun.com).
Nov 26 17:09:21 okmx8mm systemd[1]: Created slice system-dropbear.slice.
Nov 26 17:09:21 okmx8mm systemd[1]: Started SSH Per-Connection Server (192.168.2.101:56599).
Nov 26 17:11:39 okmx8mm kernel: random: crng init done
Nov 26 17:11:39 okmx8mm kernel: random: 7 urandom warning(s) missed due to ratelimiting
Nov 26 17:11:39 okmx8mm dockerd[3511]: time="2019-11-26T17:11:39.941820972+08:00" level=info msg="libcontainerd: started new docker-containerd process" pid=3535
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="starting containerd" module=containerd revision=9b55aab90508bd389d7654c4baf173a981477d55 version=docker-17.12.1-ce
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.content.v1.content"..." module=containerd type=io.containerd.content.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.snapshotter.v1.btrfs"..." module=containerd type=io.containerd.snapshotter.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=warning msg="failed to load plugin io.containerd.snapshotter.v1.btrfs" error="path /var/lib/docker/containerd/daemon/io.containerd.snapshotter.v1.btrfs must be a btrfs filesystem to be used with the btrfs snapshotter" module=containerd
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.snapshotter.v1.overlayfs"..." module=containerd type=io.containerd.snapshotter.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.metadata.v1.bolt"..." module=containerd type=io.containerd.metadata.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=warning msg="could not use snapshotter btrfs in metadata plugin" error="path /var/lib/docker/containerd/daemon/io.containerd.snapshotter.v1.btrfs must be a btrfs filesystem to be used with the btrfs snapshotter" module="containerd/io.containerd.metadata.v1.bolt"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.differ.v1.walking"..." module=containerd type=io.containerd.differ.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.gc.v1.scheduler"..." module=containerd type=io.containerd.gc.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.containers"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.content"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.diff"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.events"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.healthcheck"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.images"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.leases"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.namespaces"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.snapshots"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.monitor.v1.cgroups"..." module=containerd type=io.containerd.monitor.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.runtime.v1.linux"..." module=containerd type=io.containerd.runtime.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.tasks"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.version"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.introspection"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg=serving... address="/var/run/docker/containerd/docker-containerd-debug.sock" module="containerd/debug"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg=serving... address="/var/run/docker/containerd/docker-containerd.sock" module="containerd/grpc"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40+08:00" level=info msg="containerd successfully booted in 0.016680s" module=containerd
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40.150065876+08:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40.200715362+08:00" level=info msg="Graph migration to content-addressability took 0.00 seconds"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40.201664697+08:00" level=warning msg="Your kernel does not support cgroup cfs period"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40.201771568+08:00" level=warning msg="Your kernel does not support cgroup cfs quotas"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40.201812066+08:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40.201867064+08:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40.201914312+08:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40.201953310+08:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40.201993933+08:00" level=warning msg="Your kernel does not support cgroup blkio throttle.read_bps_device"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40.202044056+08:00" level=warning msg="Your kernel does not support cgroup blkio throttle.write_bps_device"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40.202086679+08:00" level=warning msg="Your kernel does not support cgroup blkio throttle.read_iops_device"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40.202133927+08:00" level=warning msg="Your kernel does not support cgroup blkio throttle.write_iops_device"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40.204503577+08:00" level=info msg="Loading containers: start."
Nov 26 17:11:40 okmx8mm kernel: bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Nov 26 17:11:40 okmx8mm kernel: Bridge firewalling registered
Nov 26 17:11:40 okmx8mm kernel: nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
Nov 26 17:11:40 okmx8mm kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Nov 26 17:11:40 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=0
Nov 26 17:11:40 okmx8mm kernel: audit: type=1325 audit(1574759500.380:3): table=filter family=2 entries=0
Nov 26 17:11:40 okmx8mm audit[3582]: SYSCALL arch=c00000b7 syscall=273 success=yes exit=0 a0=0 a1=419fd0 a2=0 a3=0 items=0 ppid=77 pid=3582 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="modprobe" exe="/bin/kmod" key=(null)
Nov 26 17:11:40 okmx8mm audit: PROCTITLE proctitle=2F7362696E2F6D6F6470726F6265002D71002D2D0069707461626C655F66696C746572
Nov 26 17:11:40 okmx8mm kernel: audit: type=1300 audit(1574759500.380:3): arch=c00000b7 syscall=273 success=yes exit=0 a0=0 a1=419fd0 a2=0 a3=0 items=0 ppid=77 pid=3582 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="modprobe" exe="/bin/kmod" key=(null)
Nov 26 17:11:40 okmx8mm kernel: audit: type=1327 audit(1574759500.380:3): proctitle=2F7362696E2F6D6F6470726F6265002D71002D2D0069707461626C655F66696C746572
Nov 26 17:11:40 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=0
Nov 26 17:11:40 okmx8mm kernel: audit: type=1325 audit(1574759500.480:4): table=nat family=2 entries=0
Nov 26 17:11:40 okmx8mm audit[3590]: SYSCALL arch=c00000b7 syscall=273 success=yes exit=0 a0=1 a1=419fd0 a2=0 a3=1 items=0 ppid=77 pid=3590 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="modprobe" exe="/bin/kmod" key=(null)
Nov 26 17:11:40 okmx8mm audit: PROCTITLE proctitle=2F7362696E2F6D6F6470726F6265002D71002D2D0069707461626C655F6E6174
Nov 26 17:11:40 okmx8mm kernel: audit: type=1300 audit(1574759500.480:4): arch=c00000b7 syscall=273 success=yes exit=0 a0=1 a1=419fd0 a2=0 a3=1 items=0 ppid=77 pid=3590 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="modprobe" exe="/bin/kmod" key=(null)
Nov 26 17:11:40 okmx8mm kernel: audit: type=1327 audit(1574759500.480:4): proctitle=2F7362696E2F6D6F6470726F6265002D71002D2D0069707461626C655F6E6174
Nov 26 17:11:40 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=5
Nov 26 17:11:40 okmx8mm audit[3610]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=31e95a20 items=0 ppid=3511 pid=3610 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:40 okmx8mm kernel: audit: type=1325 audit(1574759500.656:5): table=nat family=2 entries=5
Nov 26 17:11:40 okmx8mm kernel: audit: type=1300 audit(1574759500.656:5): arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=31e95a20 items=0 ppid=3511 pid=3610 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:40 okmx8mm kernel: audit: type=1327 audit(1574759500.656:5): proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4E00444F434B4552
Nov 26 17:11:40 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4E00444F434B4552
Nov 26 17:11:40 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=4
Nov 26 17:11:40 okmx8mm kernel: audit: type=1325 audit(1574759500.672:6): table=filter family=2 entries=4
Nov 26 17:11:40 okmx8mm audit[3612]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=3fae4900 items=0 ppid=3511 pid=3612 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:40 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D740066696C746572002D4E00444F434B4552
Nov 26 17:11:40 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=6
Nov 26 17:11:40 okmx8mm audit[3614]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=9415ad0 items=0 ppid=3511 pid=3614 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:40 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D740066696C746572002D4E00444F434B45522D49534F4C4154494F4E
Nov 26 17:11:40 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=8
Nov 26 17:11:40 okmx8mm audit[3616]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=2fb9360 items=0 ppid=3511 pid=3616 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:40 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4100444F434B45522D49534F4C4154494F4E002D6A0052455455524E
Nov 26 17:11:40 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=9
Nov 26 17:11:40 okmx8mm audit[3617]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=17c53d90 items=0 ppid=3511 pid=3617 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:40 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D740066696C746572002D5000464F52574152440044524F50
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40.738789764+08:00" level=warning msg="Could not load necessary modules for IPSEC rules: Running modprobe xfrm_user failed with message: `modprobe: WARNING: Module xfrm_user not found in directory /lib/modules/4.14.78`, error: exit status 1"
Nov 26 17:11:40 okmx8mm dockerd[3511]: time="2019-11-26T17:11:40.755505309+08:00" level=warning msg="Could not load necessary modules for Conntrack: Running modprobe nf_conntrack_netlink failed with message: `modprobe: WARNING: Module nf_conntrack_netlink not found in directory /lib/modules/4.14.78`, error: exit status 1"
Nov 26 17:11:40 okmx8mm systemd-timesyncd[3031]: Network configuration changed, trying to establish connection.
Nov 26 17:11:40 okmx8mm systemd-timesyncd[3031]: Synchronized to time server 120.25.115.20:123 (ntp1.aliyun.com).
Nov 26 17:11:40 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=7
Nov 26 17:11:40 okmx8mm audit[3629]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=de508f0 items=0 ppid=3511 pid=3629 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:40 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4900504F5354524F5554494E47002D73003137322E31372E302E302F31360000002D6F00646F636B657230002D6A004D415351554552414445
Nov 26 17:11:40 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=8
Nov 26 17:11:40 okmx8mm audit[3641]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=5e3440 items=0 ppid=3511 pid=3641 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:40 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4900444F434B4552002D6900646F636B657230002D6A0052455455524E
Nov 26 17:11:40 okmx8mm audit[3644]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=1cb724d0 items=0 ppid=3511 pid=3644 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:40 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6900646F636B657230002D6F00646F636B657230002D6A00414343455054
Nov 26 17:11:40 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=10
Nov 26 17:11:40 okmx8mm audit[3646]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=2ec0f650 items=0 ppid=3511 pid=3646 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:40 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6900646F636B6572300000002D6F00646F636B657230002D6A00414343455054
Nov 26 17:11:40 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=9
Nov 26 17:11:40 okmx8mm audit[3648]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=37ed0270 items=0 ppid=3511 pid=3648 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:40 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4100505245524F5554494E47002D6D006164647274797065002D2D6473742D74797065004C4F43414C002D6A00444F434B4552
Nov 26 17:11:41 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=10
Nov 26 17:11:41 okmx8mm audit[3650]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=47d6440 items=0 ppid=3511 pid=3650 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D41004F5554505554002D6D006164647274797065002D2D6473742D74797065004C4F43414C002D6A00444F434B45520000002D2D647374003132372E302E302E302F38
Nov 26 17:11:41 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=11
Nov 26 17:11:41 okmx8mm audit[3652]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=2eda57c0 items=0 ppid=3511 pid=3652 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6F00646F636B657230002D6A00444F434B4552
Nov 26 17:11:41 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=12
Nov 26 17:11:41 okmx8mm audit[3654]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=22b268f0 items=0 ppid=3511 pid=3654 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6F00646F636B657230002D6D00636F6E6E747261636B002D2D637473746174650052454C415445442C45535441424C4953484544002D6A00414343455054
Nov 26 17:11:41 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=13
Nov 26 17:11:41 okmx8mm audit[3656]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=18804c50 items=0 ppid=3511 pid=3656 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6A00444F434B45522D49534F4C4154494F4E
Nov 26 17:11:41 okmx8mm systemd-timesyncd[3031]: Network configuration changed, trying to establish connection.
Nov 26 17:11:41 okmx8mm systemd-timesyncd[3031]: Synchronized to time server 120.25.115.20:123 (ntp1.aliyun.com).
Nov 26 17:11:41 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=11
Nov 26 17:11:41 okmx8mm audit[3658]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=5ef8050 items=0 ppid=3511 pid=3658 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4400504F5354524F5554494E47002D73003137322E31372E302E302F31360000002D6F00646F636B657230002D6A004D415351554552414445
Nov 26 17:11:41 okmx8mm audit[3660]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=3af78860 items=0 ppid=3511 pid=3660 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4400444F434B4552002D6900646F636B657230002D6A0052455455524E
Nov 26 17:11:41 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=14
Nov 26 17:11:41 okmx8mm audit[3662]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=128a3e60 items=0 ppid=3511 pid=3662 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4400464F5257415244002D6900646F636B657230002D6F00646F636B657230002D6A00414343455054
Nov 26 17:11:41 okmx8mm audit[3664]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=446fcf0 items=0 ppid=3511 pid=3664 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4400464F5257415244002D6900646F636B6572300000002D6F00646F636B657230002D6A00414343455054
Nov 26 17:11:41 okmx8mm audit[3667]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=87ebb70 items=0 ppid=3511 pid=3667 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4400464F5257415244002D6F00646F636B657230002D6A00444F434B4552
Nov 26 17:11:41 okmx8mm audit[3670]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=3cca7a80 items=0 ppid=3511 pid=3670 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4400464F5257415244002D6F00646F636B657230002D6D00636F6E6E747261636B002D2D637473746174650052454C415445442C45535441424C4953484544002D6A00414343455054
Nov 26 17:11:41 okmx8mm dockerd[3511]: time="2019-11-26T17:11:41.289557387+08:00" level=info msg="Default bridge (docker0) is assigned with an IP address 172.17.0.0/16. Daemon option --bip can be used to set a preferred IP address"
Nov 26 17:11:41 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=9
Nov 26 17:11:41 okmx8mm audit[3672]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=35594c90 items=0 ppid=3511 pid=3672 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4900504F5354524F5554494E47002D73003137322E31372E302E302F31360000002D6F00646F636B657230002D6A004D415351554552414445
Nov 26 17:11:41 okmx8mm audit[3674]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=35c0d7e0 items=0 ppid=3511 pid=3674 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4900444F434B4552002D6900646F636B657230002D6A0052455455524E
Nov 26 17:11:41 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=10
Nov 26 17:11:41 okmx8mm audit[3677]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=21af4650 items=0 ppid=3511 pid=3677 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6900646F636B657230002D6F00646F636B657230002D6A00414343455054
Nov 26 17:11:41 okmx8mm audit[3679]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=24b497c0 items=0 ppid=3511 pid=3679 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6900646F636B6572300000002D6F00646F636B657230002D6A00414343455054
Nov 26 17:11:41 okmx8mm audit[3685]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=15ed9940 items=0 ppid=3511 pid=3685 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit[3687]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=2deb7a60 items=0 ppid=3511 pid=3687 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit[3689]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=2e580e60 items=0 ppid=3511 pid=3689 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4400464F5257415244002D6A00444F434B45522D49534F4C4154494F4E
Nov 26 17:11:41 okmx8mm audit[3690]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=2ece8c50 items=0 ppid=3511 pid=3690 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit[3692]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=1b278710 items=0 ppid=3511 pid=3692 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D740066696C746572002D4E00444F434B45522D55534552
Nov 26 17:11:41 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=16
Nov 26 17:11:41 okmx8mm audit[3694]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=5633fa0 items=0 ppid=3511 pid=3694 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4100444F434B45522D55534552002D6A0052455455524E
Nov 26 17:11:41 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=17
Nov 26 17:11:41 okmx8mm audit[3696]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=5 a1=0 a2=40 a3=1af9e110 items=0 ppid=3511 pid=3696 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:11:41 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6A00444F434B45522D55534552
Nov 26 17:11:41 okmx8mm dockerd[3511]: time="2019-11-26T17:11:41+08:00" level=info msg="shim docker-containerd-shim started" address="/containerd-shim/moby/d087cd0be2634034d92c40c1cc11f0fc3e469d682db88dc954262d52c7c81be8/shim.sock" debug=false module="containerd/tasks" pid=3707
Nov 26 17:11:41 okmx8mm dockerd[3511]: time="2019-11-26T17:11:41+08:00" level=info msg="shim docker-containerd-shim started" address="/containerd-shim/moby/1d5d437e578d96ff1c397f8a378d66d4a898c0cfd3b83c89b2f42ad9b8ae0ed5/shim.sock" debug=false module="containerd/tasks" pid=3710
Nov 26 17:11:42 okmx8mm dockerd[3511]: time="2019-11-26T17:11:42.319115879+08:00" level=info msg="Loading containers: done."
Nov 26 17:11:42 okmx8mm dockerd[3511]: time="2019-11-26T17:11:42.416395872+08:00" level=info msg="Docker daemon" commit=7390fc6 graphdriver(s)=overlay2 version=17.12.1-ce
Nov 26 17:11:42 okmx8mm dockerd[3511]: time="2019-11-26T17:11:42.419159722+08:00" level=info msg="Daemon has completed initialization"
Nov 26 17:11:42 okmx8mm dockerd[3511]: time="2019-11-26T17:11:42.445693913+08:00" level=info msg="API listen on /var/run/docker.sock"
Nov 26 17:11:42 okmx8mm systemd[1]: Started Docker Application Container Engine.
Nov 26 17:11:42 okmx8mm systemd[1]: Started helloworld.
Nov 26 17:11:42 okmx8mm systemd[1]: Reached target Multi-User System.
Nov 26 17:11:42 okmx8mm systemd[1]: Starting Update UTMP about System Runlevel Changes...
Nov 26 17:11:42 okmx8mm systemd[1]: Started Update UTMP about System Runlevel Changes.
Nov 26 17:11:42 okmx8mm systemd[1]: Startup finished in 3.813s (kernel) + 2min 39.105s (userspace) = 2min 42.919s.
Nov 26 17:11:43 okmx8mm helloworld.sh[3813]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
Nov 26 17:11:45 okmx8mm helloworld.sh[3813]: Interactive keyboard handling in terminal not available.
Nov 26 17:11:45 okmx8mm helloworld.sh[3813]: Now playing /home/forlinx/audio/test.mp3
Nov 26 17:11:48 okmx8mm helloworld.sh[3813]: Prerolling...
Nov 26 17:11:48 okmx8mm helloworld.sh[3813]: ====== BEEP: 4.4.4 build on Jun 21 2019 06:49:05. ======
Nov 26 17:11:48 okmx8mm helloworld.sh[3813]:         Core: MP3 decoder Wrapper  build on Jan 11 2018 10:20:25
Nov 26 17:11:48 okmx8mm helloworld.sh[3813]:  file: /usr/lib/imx-mm/audio-codec/wrap/lib_mp3d_wrap_arm_elinux.so.3
Nov 26 17:11:49 okmx8mm helloworld.sh[3813]: CODEC: BLN_MAD-MMCODECS_MP3D_ARM_02.13.01_ARMV8  build on Jan 11 2018 10:05:45.
Nov 26 17:11:49 okmx8mm helloworld.sh[3813]: ===!!! Current pulsesink device is alsa_output.platform-sound.stereo-fallback !!!===
Nov 26 17:11:49 okmx8mm helloworld.sh[3813]: Redistribute latency...
LS1012A通行证LS1043A\46A通行证A40i/T3/T507/T527通行证i.MX8MM通行证i.MX6UL通行证
 楼主| 发表于 2019-11-26 17:31:52 | 显示全部楼层
这个crng init的随机数发生器,如果在启动过程中,按下开发板上的VOL+,HOME或是VOL-任何一个键,就能马上结束。
下边的log文件就是我在启动过程中按下vol+键生成的,可以看到crng init done花了不到20秒,
所以我感觉在文件系统里加上rng-tools就可以解决这个问题
-- Logs begin at Thu 2019-06-20 18:00:11 CST, end at Tue 2019-11-26 17:24:07 CST. --
Jun 20 18:00:11 okmx8mm kernel: Booting Linux on physical CPU 0x0
Jun 20 18:00:11 okmx8mm kernel: Linux version 4.14.78 (forlinx@ubuntu) (gcc version 7.3.0 (GCC)) #1 SMP PREEMPT Mon Nov 25 14:09:54 AWST 2019
Jun 20 18:00:11 okmx8mm kernel: Boot CPU: AArch64 Processor [410fd034]
Jun 20 18:00:11 okmx8mm kernel: Machine model: Forlinx i.MX8MM EVK board
Jun 20 18:00:11 okmx8mm kernel: earlycon: ec_imx6q0 at MMIO 0x0000000030890000 (options '115200')
Jun 20 18:00:11 okmx8mm kernel: bootconsole [ec_imx6q0] enabled
Jun 20 18:00:11 okmx8mm kernel: efi: Getting EFI parameters from FDT:
Jun 20 18:00:11 okmx8mm kernel: efi: UEFI not found.
Jun 20 18:00:11 okmx8mm kernel: Reserved memory: created CMA memory pool at 0x0000000056000000, size 640 MiB
Jun 20 18:00:11 okmx8mm kernel: OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
Jun 20 18:00:11 okmx8mm kernel: NUMA: No NUMA configuration found
Jun 20 18:00:11 okmx8mm kernel: NUMA: Faking a node at [mem 0x0000000000000000-0x00000000bfffffff]
Jun 20 18:00:11 okmx8mm kernel: NUMA: NODE_DATA [mem 0xbffbef00-0xbffc0cff]
Jun 20 18:00:11 okmx8mm kernel: Zone ranges:
Jun 20 18:00:11 okmx8mm kernel:   DMA      [mem 0x0000000040000000-0x00000000bfffffff]
Jun 20 18:00:11 okmx8mm kernel:   Normal   empty
Jun 20 18:00:11 okmx8mm kernel: Movable zone start for each node
Jun 20 18:00:11 okmx8mm kernel: Early memory node ranges
Jun 20 18:00:11 okmx8mm kernel:   node   0: [mem 0x0000000040000000-0x00000000b7ffffff]
Jun 20 18:00:11 okmx8mm kernel:   node   0: [mem 0x00000000b8400000-0x00000000bfffffff]
Jun 20 18:00:11 okmx8mm kernel: Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
Jun 20 18:00:11 okmx8mm kernel: On node 0 totalpages: 523264
Jun 20 18:00:11 okmx8mm kernel:   DMA zone: 8192 pages used for memmap
Jun 20 18:00:11 okmx8mm kernel:   DMA zone: 0 pages reserved
Jun 20 18:00:11 okmx8mm kernel:   DMA zone: 523264 pages, LIFO batch:31
Jun 20 18:00:11 okmx8mm kernel: psci: probing for conduit method from DT.
Jun 20 18:00:11 okmx8mm kernel: psci: PSCIv1.1 detected in firmware.
Jun 20 18:00:11 okmx8mm kernel: psci: Using standard PSCI v0.2 function IDs
Jun 20 18:00:11 okmx8mm kernel: psci: MIGRATE_INFO_TYPE not supported.
Jun 20 18:00:11 okmx8mm kernel: psci: SMC Calling Convention v1.1
Jun 20 18:00:11 okmx8mm kernel: percpu: Embedded 24 pages/cpu @ffff80007ff59000 s57624 r8192 d32488 u98304
Jun 20 18:00:11 okmx8mm kernel: pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
Jun 20 18:00:11 okmx8mm kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Jun 20 18:00:11 okmx8mm kernel: Detected VIPT I-cache on CPU0
Jun 20 18:00:11 okmx8mm kernel: CPU features: enabling workaround for ARM erratum 845719
Jun 20 18:00:11 okmx8mm kernel: Speculative Store Bypass Disable mitigation not required
Jun 20 18:00:11 okmx8mm kernel: Built 1 zonelists, mobility grouping on.  Total pages: 515072
Jun 20 18:00:11 okmx8mm kernel: Policy zone: DMA
Jun 20 18:00:11 okmx8mm kernel: Kernel command line: console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200 root=/dev/mmcblk2p2 rootwait rw
Jun 20 18:00:11 okmx8mm kernel: PID hash table entries: 4096 (order: 3, 32768 bytes)
Jun 20 18:00:11 okmx8mm kernel: Memory: 1368128K/2093056K available (12540K kernel code, 1172K rwdata, 4688K rodata, 768K init, 427K bss, 69568K reserved, 655360K cma-reserved)
Jun 20 18:00:11 okmx8mm kernel: Virtual kernel memory layout:
Jun 20 18:00:11 okmx8mm kernel:     modules : 0xffff000000000000 - 0xffff000008000000   (   128 MB)
Jun 20 18:00:11 okmx8mm kernel:     vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000   (129022 GB)
Jun 20 18:00:11 okmx8mm kernel:       .text : 0xffff000008080000 - 0xffff000008cc0000   ( 12544 KB)
Jun 20 18:00:11 okmx8mm kernel:     .rodata : 0xffff000008cc0000 - 0xffff000009160000   (  4736 KB)
Jun 20 18:00:11 okmx8mm kernel:       .init : 0xffff000009160000 - 0xffff000009220000   (   768 KB)
Jun 20 18:00:11 okmx8mm kernel:       .data : 0xffff000009220000 - 0xffff000009345200   (  1173 KB)
Jun 20 18:00:11 okmx8mm kernel:        .bss : 0xffff000009345200 - 0xffff0000093aff38   (   428 KB)
Jun 20 18:00:11 okmx8mm kernel:     fixed   : 0xffff7dfffe7f9000 - 0xffff7dfffec00000   (  4124 KB)
Jun 20 18:00:11 okmx8mm kernel:     PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000   (    16 MB)
Jun 20 18:00:11 okmx8mm kernel:     vmemmap : 0xffff7e0000000000 - 0xffff800000000000   (  2048 GB maximum)
Jun 20 18:00:11 okmx8mm kernel:               0xffff7e0000000000 - 0xffff7e0002000000   (    32 MB actual)
Jun 20 18:00:11 okmx8mm kernel:     memory  : 0xffff800000000000 - 0xffff800080000000   (  2048 MB)
Jun 20 18:00:11 okmx8mm kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Jun 20 18:00:11 okmx8mm kernel: Preemptible hierarchical RCU implementation.
Jun 20 18:00:11 okmx8mm kernel:         RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
Jun 20 18:00:11 okmx8mm kernel:         Tasks RCU enabled.
Jun 20 18:00:11 okmx8mm kernel: RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Jun 20 18:00:11 okmx8mm kernel: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Jun 20 18:00:11 okmx8mm kernel: GICv3: GIC: Using split EOI/Deactivate mode
Jun 20 18:00:11 okmx8mm kernel: GICv3: no VLPI support, no direct LPI support
Jun 20 18:00:11 okmx8mm kernel: ITS: No ITS available, not enabling LPIs
Jun 20 18:00:11 okmx8mm kernel: GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
Jun 20 18:00:11 okmx8mm kernel: i.MX8MM clock driver init done
Jun 20 18:00:11 okmx8mm kernel: arch_timer: cp15 timer(s) running at 8.00MHz (phys).
Jun 20 18:00:11 okmx8mm kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
Jun 20 18:00:11 okmx8mm kernel: sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
Jun 20 18:00:11 okmx8mm kernel: system counter timer init
Jun 20 18:00:11 okmx8mm kernel: clocksource: imx sysctr: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
Jun 20 18:00:11 okmx8mm kernel: Console: colour dummy device 80x25
Jun 20 18:00:11 okmx8mm kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
Jun 20 18:00:11 okmx8mm kernel: pid_max: default: 32768 minimum: 301
Jun 20 18:00:11 okmx8mm kernel: Security Framework initialized
Jun 20 18:00:11 okmx8mm kernel: Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
Jun 20 18:00:11 okmx8mm kernel: Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
Jun 20 18:00:11 okmx8mm kernel: Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
Jun 20 18:00:11 okmx8mm kernel: Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
Jun 20 18:00:11 okmx8mm kernel: ASID allocator initialised with 32768 entries
Jun 20 18:00:11 okmx8mm kernel: Hierarchical SRCU implementation.
Jun 20 18:00:11 okmx8mm kernel: Cannot find MU entry in device tree
Jun 20 18:00:11 okmx8mm kernel: CPU identified as i.MX8MM, silicon rev 1.0
Jun 20 18:00:11 okmx8mm kernel: EFI services will not be available.
Jun 20 18:00:11 okmx8mm kernel: smp: Bringing up secondary CPUs ...
Jun 20 18:00:11 okmx8mm kernel: Detected VIPT I-cache on CPU1
Jun 20 18:00:11 okmx8mm kernel: GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
Jun 20 18:00:11 okmx8mm kernel: CPU1: Booted secondary processor [410fd034]
Jun 20 18:00:11 okmx8mm kernel: Detected VIPT I-cache on CPU2
Jun 20 18:00:11 okmx8mm kernel: GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
Jun 20 18:00:11 okmx8mm kernel: CPU2: Booted secondary processor [410fd034]
Jun 20 18:00:11 okmx8mm kernel: Detected VIPT I-cache on CPU3
Jun 20 18:00:11 okmx8mm kernel: GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
Jun 20 18:00:11 okmx8mm kernel: CPU3: Booted secondary processor [410fd034]
Jun 20 18:00:11 okmx8mm kernel: smp: Brought up 1 node, 4 CPUs
Jun 20 18:00:11 okmx8mm kernel: SMP: Total of 4 processors activated.
Jun 20 18:00:11 okmx8mm kernel: CPU features: detected feature: GIC system register CPU inte**ce
Jun 20 18:00:11 okmx8mm kernel: CPU features: detected feature: 32-bit EL0 Support
Jun 20 18:00:11 okmx8mm kernel: CPU features: detected feature: Kernel page table isolation (KPTI)
Jun 20 18:00:11 okmx8mm kernel: CPU: All CPU(s) started at EL2
Jun 20 18:00:11 okmx8mm kernel: alternatives: patching kernel code
Jun 20 18:00:11 okmx8mm kernel: devtmpfs: initialized
Jun 20 18:00:11 okmx8mm kernel: random: get_random_u32 called from bucket_table_alloc+0x108/0x260 with crng_init=0
Jun 20 18:00:11 okmx8mm kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Jun 20 18:00:11 okmx8mm kernel: futex hash table entries: 1024 (order: 5, 131072 bytes)
Jun 20 18:00:11 okmx8mm kernel: pinctrl core: initialized pinctrl subsystem
Jun 20 18:00:11 okmx8mm kernel: DMI not present or invalid.
Jun 20 18:00:11 okmx8mm kernel: NET: Registered protocol family 16
Jun 20 18:00:11 okmx8mm kernel: cpuidle: using governor menu
Jun 20 18:00:11 okmx8mm kernel: vdso: 2 pages (1 code @ ffff000008cc6000, 1 data @ ffff000009224000)
Jun 20 18:00:11 okmx8mm kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Jun 20 18:00:11 okmx8mm kernel: DMA: preallocated 256 KiB pool for atomic allocations
Jun 20 18:00:11 okmx8mm kernel: Serial: AMBA PL011 UART driver
Jun 20 18:00:11 okmx8mm kernel: imx8mm-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
Jun 20 18:00:11 okmx8mm kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Jun 20 18:00:11 okmx8mm kernel: ACPI: Interpreter disabled.
Jun 20 18:00:11 okmx8mm kernel: vgaarb: loaded
Jun 20 18:00:11 okmx8mm kernel: SCSI subsystem initialized
Jun 20 18:00:11 okmx8mm kernel: libata version 3.00 loaded.
Jun 20 18:00:11 okmx8mm kernel: usbcore: registered new inte**ce driver usbfs
Jun 20 18:00:11 okmx8mm kernel: usbcore: registered new inte**ce driver hub
Jun 20 18:00:11 okmx8mm kernel: usbcore: registered new device driver usb
Jun 20 18:00:11 okmx8mm kernel: usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: usb_phy_generic usbphynop2: usbphynop2 supply vcc not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: bd71837 0-004b: Device ID=0xA1
Jun 20 18:00:11 okmx8mm kernel: bd71837 0-004b: gpio_intr = 3
Jun 20 18:00:11 okmx8mm kernel: bd71837 0-004b: chip_irq=73
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck1'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: Buck[1] Set Ramp = 1250
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck2'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: Buck[2] Set Ramp = 1250
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck3'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck4'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck5'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck6'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck7'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'buck8'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'ldo1'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'ldo2'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'ldo3'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'ldo4'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'ldo5'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'ldo6'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: regulator register name 'ldo7'
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: Buck1: DVS Run-Idle-Susp[0 - 0 - 0].
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: bd71837_buck1234_dvs_init(): not found selector for Run voltage [0]
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: bd71837_buck1234_dvs_init(): not found selector for Idle voltage [0]
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: bd71837_buck1234_dvs_init(): not found selector for Susp voltage [0]
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: Buck2: DVS Run-Idle-Susp[0 - 0 - 0].
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: Buck3: DVS Run-Idle-Susp[0 - 0 - 0].
Jun 20 18:00:11 okmx8mm kernel: bd71837-pmic bd71837-pmic: Buck4: DVS Run-Idle-Susp[0 - 0 - 0].
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-0: IMX I2C adapter registered
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-0: can't use DMA, using PIO instead.
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-1: IMX I2C adapter registered
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-1: can't use DMA, using PIO instead.
Jun 20 18:00:11 okmx8mm kernel: BD71837:bd71837_pmic_interrupt() in.
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-2: IMX I2C adapter registered
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-2: can't use DMA, using PIO instead.
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-3: IMX I2C adapter registered
Jun 20 18:00:11 okmx8mm kernel: i2c i2c-3: can't use DMA, using PIO instead.
Jun 20 18:00:11 okmx8mm kernel: media: Linux media inte**ce: v0.10
Jun 20 18:00:11 okmx8mm kernel: Linux video capture inte**ce: v2.00
Jun 20 18:00:11 okmx8mm kernel: pps_core: LinuxPPS API ver. 1 registered
Jun 20 18:00:11 okmx8mm kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Jun 20 18:00:11 okmx8mm kernel: PTP clock support registered
Jun 20 18:00:11 okmx8mm kernel: EDAC MC: Ver: 3.0.0
Jun 20 18:00:11 okmx8mm kernel: dmi: Firmware registration failed.
Jun 20 18:00:11 okmx8mm kernel: MU is ready for cross core communication!
Jun 20 18:00:11 okmx8mm kernel: virtio_rpmsg_bus virtio0: rpmsg host is online
Jun 20 18:00:11 okmx8mm kernel: BD71837:IRQ_WDOG
Jun 20 18:00:11 okmx8mm kernel: BD71837:IRQ_ON_REQ
Jun 20 18:00:11 okmx8mm kernel: imx rpmsg driver is registered.
Jun 20 18:00:11 okmx8mm kernel: Advanced Linux Sound Architecture Driver Initialized.
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: Core ver 2.22
Jun 20 18:00:11 okmx8mm kernel: NET: Registered protocol family 31
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: HCI device and connection manager initialized
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: HCI socket layer initialized
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: L2CAP socket layer initialized
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: SCO socket layer initialized
Jun 20 18:00:11 okmx8mm kernel: clocksource: Switched to clocksource arch_sys_counter
Jun 20 18:00:11 okmx8mm kernel: VFS: Disk quotas dquot_6.6.0
Jun 20 18:00:11 okmx8mm kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jun 20 18:00:11 okmx8mm kernel: pnp: PnP ACPI: disabled
Jun 20 18:00:11 okmx8mm kernel: NET: Registered protocol family 2
Jun 20 18:00:11 okmx8mm kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Jun 20 18:00:11 okmx8mm kernel: TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
Jun 20 18:00:11 okmx8mm kernel: TCP: Hash tables configured (established 16384 bind 16384)
Jun 20 18:00:11 okmx8mm kernel: UDP hash table entries: 1024 (order: 3, 32768 bytes)
Jun 20 18:00:11 okmx8mm kernel: UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
Jun 20 18:00:11 okmx8mm kernel: RPC: Registered named UNIX socket transport module.
Jun 20 18:00:11 okmx8mm kernel: RPC: Registered udp transport module.
Jun 20 18:00:11 okmx8mm kernel: RPC: Registered tcp transport module.
Jun 20 18:00:11 okmx8mm kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Jun 20 18:00:11 okmx8mm kernel: PCI: CLS 0 bytes, default 128
Jun 20 18:00:11 okmx8mm kernel: hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Jun 20 18:00:11 okmx8mm kernel: kvm [1]: 8-bit VMID
Jun 20 18:00:11 okmx8mm kernel: kvm [1]: GICv3: no GICV resource entry
Jun 20 18:00:11 okmx8mm kernel: kvm [1]: disabling GICv2 emulation
Jun 20 18:00:11 okmx8mm kernel: kvm [1]: GIC system register CPU inte**ce enabled
Jun 20 18:00:11 okmx8mm kernel: kvm [1]: vgic interrupt IRQ1
Jun 20 18:00:11 okmx8mm kernel: kvm [1]: Hyp mode initialized successfully
Jun 20 18:00:11 okmx8mm kernel: audit: initializing netlink subsys (disabled)
Jun 20 18:00:11 okmx8mm kernel: audit: type=2000 audit(0.888:1): state=initialized audit_enabled=0 res=1
Jun 20 18:00:11 okmx8mm kernel: workingset: timestamp_bits=44 max_order=19 bucket_order=0
Jun 20 18:00:11 okmx8mm kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jun 20 18:00:11 okmx8mm kernel: NFS: Registering the id_resolver key type
Jun 20 18:00:11 okmx8mm kernel: Key type id_resolver registered
Jun 20 18:00:11 okmx8mm kernel: Key type id_legacy registered
Jun 20 18:00:11 okmx8mm kernel: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Jun 20 18:00:11 okmx8mm kernel: jffs2: version 2.2. (NAND) &#169; 2001-2006 Red Hat, Inc.
Jun 20 18:00:11 okmx8mm kernel: 9p: Installing v9fs 9p2000 file system support
Jun 20 18:00:11 okmx8mm kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
Jun 20 18:00:11 okmx8mm kernel: io scheduler noop registered
Jun 20 18:00:11 okmx8mm kernel: io scheduler cfq registered (default)
Jun 20 18:00:11 okmx8mm kernel: io scheduler mq-deadline registered
Jun 20 18:00:11 okmx8mm kernel: io scheduler kyber registered
Jun 20 18:00:11 okmx8mm kernel: pwm-backlight backlight@0: backlight@0 supply power not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: imx-sdma 30bd0000.dma-controller: no iram assigned, using external mem
Jun 20 18:00:11 okmx8mm kernel: imx-sdma 30bd0000.dma-controller: Falling back to user helper
Jun 20 18:00:11 okmx8mm kernel: imx-sdma 302c0000.dma-controller: no iram assigned, using external mem
Jun 20 18:00:11 okmx8mm kernel: imx-sdma 302b0000.dma-controller: no iram assigned, using external mem
Jun 20 18:00:11 okmx8mm kernel: mxs-dma 33000000.dma-apbh: initialized
Jun 20 18:00:11 okmx8mm kernel: Bus freq driver module loaded
Jun 20 18:00:11 okmx8mm kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Jun 20 18:00:11 okmx8mm kernel: 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 27, base_baud = 5000000) is a IMX
Jun 20 18:00:11 okmx8mm kernel: 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 28, base_baud = 5000000) is a IMX
Jun 20 18:00:11 okmx8mm kernel: 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 29, base_baud = 1500000) is a IMX
Jun 20 18:00:11 okmx8mm kernel: console [ttymxc1] enabled
Jun 20 18:00:11 okmx8mm kernel: bootconsole [ec_imx6q0] disabled
Jun 20 18:00:11 okmx8mm kernel: [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
Jun 20 18:00:11 okmx8mm kernel: [drm] No driver support for vblank timestamp query.
Jun 20 18:00:11 okmx8mm kernel: imx-drm display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops)
Jun 20 18:00:11 okmx8mm kernel: imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
Jun 20 18:00:11 okmx8mm kernel: panel-**-dsi 32e10000.mipi_dsi.0: 32e10000.mipi_dsi.0 supply power not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: imx-drm display-subsystem: bound 32e10000.mipi_dsi (ops imx_sec_dsim_ops)
Jun 20 18:00:11 okmx8mm kernel: imx-drm display-subsystem: fb0:  frame buffer device
Jun 20 18:00:11 okmx8mm kernel: [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
Jun 20 18:00:11 okmx8mm kernel: brd: module loaded
Jun 20 18:00:11 okmx8mm kernel: loop: module loaded
Jun 20 18:00:11 okmx8mm kernel: random: fast init done
Jun 20 18:00:11 okmx8mm kernel: fsl-flexspi 30bb0000.flexspi: w25q128 (16384 Kbytes)
Jun 20 18:00:11 okmx8mm kernel: slram: not enough parameters.
Jun 20 18:00:11 okmx8mm kernel: spi_imx 30820000.ecspi: probed
Jun 20 18:00:11 okmx8mm kernel: spi_imx 30830000.ecspi: probed
Jun 20 18:00:11 okmx8mm kernel: libphy: Fixed MDIO Bus: probed
Jun 20 18:00:11 okmx8mm kernel: NXP PHY: loading NXP PHY driver: [autonomous mode]
Jun 20 18:00:11 okmx8mm kernel: tun: Universal TUN/TAP device driver, 1.6
Jun 20 18:00:11 okmx8mm kernel: CAN device driver inte**ce
Jun 20 18:00:11 okmx8mm kernel: fec 30be0000.ethernet: 30be0000.ethernet supply phy not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: pps pps0: new PPS source ptp0
Jun 20 18:00:11 okmx8mm kernel: libphy: fec_enet_mii_bus: probed
Jun 20 18:00:11 okmx8mm kernel: fec 30be0000.ethernet eth0: registered PHC device 0
Jun 20 18:00:11 okmx8mm kernel: e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
Jun 20 18:00:11 okmx8mm kernel: e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Jun 20 18:00:11 okmx8mm kernel: igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
Jun 20 18:00:11 okmx8mm kernel: igb: Copyright (c) 2007-2014 Intel Corporation.
Jun 20 18:00:11 okmx8mm kernel: igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
Jun 20 18:00:11 okmx8mm kernel: igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
Jun 20 18:00:11 okmx8mm kernel: sky2: driver version 1.30
Jun 20 18:00:11 okmx8mm kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jun 20 18:00:11 okmx8mm kernel: ehci-pci: EHCI PCI platform driver
Jun 20 18:00:11 okmx8mm kernel: ehci-platform: EHCI generic platform driver
Jun 20 18:00:11 okmx8mm kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jun 20 18:00:11 okmx8mm kernel: ohci-pci: OHCI PCI platform driver
Jun 20 18:00:11 okmx8mm kernel: ohci-platform: OHCI generic platform driver
Jun 20 18:00:11 okmx8mm kernel: usbcore: registered new inte**ce driver usb-storage
Jun 20 18:00:11 okmx8mm kernel: usbcore: registered new inte**ce driver usb_ehset_test
Jun 20 18:00:11 okmx8mm kernel: usbmisc_imx 32e40200.usbmisc: 32e40200.usbmisc supply vbus-wakeup not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: usbmisc_imx 32e50200.usbmisc: 32e50200.usbmisc supply vbus-wakeup not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: imx_usb 32e50000.usb: 32e50000.usb supply vbus not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: ci_hdrc ci_hdrc.1: EHCI Host Controller
Jun 20 18:00:11 okmx8mm kernel: ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
Jun 20 18:00:11 okmx8mm kernel: ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
Jun 20 18:00:11 okmx8mm kernel: hub 1-0:1.0: USB hub found
Jun 20 18:00:11 okmx8mm kernel: hub 1-0:1.0: 1 port detected
Jun 20 18:00:11 okmx8mm kernel: input: InputEmulator as /devices/virtual/input/input0
Jun 20 18:00:11 okmx8mm kernel: i2c /dev entries driver
Jun 20 18:00:11 okmx8mm kernel: mxc_mipi-csi 32e30000.mipi_csi: 32e30000.mipi_csi supply mipi-phy not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: mxc_mipi-csi 32e30000.mipi_csi: mipi csi v4l2 device registered
Jun 20 18:00:11 okmx8mm kernel: CSI: Registered sensor subdevice: mxc_mipi-csi.0
Jun 20 18:00:11 okmx8mm kernel: mxc_mipi-csi 32e30000.mipi_csi: lanes: 2, hs_settle: 13, clk_settle: 2, wclk: 1, freq: 333000000
Jun 20 18:00:11 okmx8mm kernel: ov5640_mipi 3-003c: 3-003c supply DOVDD not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: ov5640_mipi 3-003c: 3-003c supply DVDD not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: ov5640_mipi 3-003c: 3-003c supply AVDD not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: ov5640_mipi 3-003c: Read reg error: reg=300a
Jun 20 18:00:11 okmx8mm kernel: ov5640_mipi 3-003c: Camera is not found
Jun 20 18:00:11 okmx8mm kernel: imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
Jun 20 18:00:11 okmx8mm kernel: sdhci: Secure Digital Host Controller Inte**ce driver
Jun 20 18:00:11 okmx8mm kernel: sdhci: Copyright(c) Pierre Ossman
Jun 20 18:00:11 okmx8mm kernel: Synopsys Designware ** Card Inte**ce Driver
Jun 20 18:00:11 okmx8mm kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Jun 20 18:00:11 okmx8mm kernel: mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA
Jun 20 18:00:11 okmx8mm kernel: sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
Jun 20 18:00:11 okmx8mm kernel: mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
Jun 20 18:00:11 okmx8mm kernel: usb 1-1: new high-speed USB device number 2 using ci_hdrc
Jun 20 18:00:11 okmx8mm kernel: mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
Jun 20 18:00:11 okmx8mm kernel: galcore: clk_get vg clock failed, disable vg!
Jun 20 18:00:11 okmx8mm kernel: Galcore version 6.2.4.163672
Jun 20 18:00:11 okmx8mm kernel: mmc2: new HS200 MMC card at address 0001
Jun 20 18:00:11 okmx8mm kernel: mmcblk2: mmc2:0001 DG4008 7.28 GiB
Jun 20 18:00:11 okmx8mm kernel: mmcblk2boot0: mmc2:0001 DG4008 partition 1 4.00 MiB
Jun 20 18:00:11 okmx8mm kernel: mmcblk2boot1: mmc2:0001 DG4008 partition 2 4.00 MiB
Jun 20 18:00:11 okmx8mm kernel: mmcblk2rpmb: mmc2:0001 DG4008 partition 3 4.00 MiB
Jun 20 18:00:11 okmx8mm kernel:  mmcblk2: p1 p2
Jun 20 18:00:11 okmx8mm kernel: hub 1-1:1.0: USB hub found
Jun 20 18:00:11 okmx8mm kernel: hub 1-1:1.0: 4 ports detected
Jun 20 18:00:11 okmx8mm kernel: hantrodec 0 : module inserted. Major = 240
Jun 20 18:00:11 okmx8mm kernel: hantrodec 1 : module inserted. Major = 240
Jun 20 18:00:11 okmx8mm kernel: hx280enc: module inserted. Major <239>
Jun 20 18:00:11 okmx8mm kernel: ledtrig-cpu: registered to indicate activity on CPUs
Jun 20 18:00:11 okmx8mm kernel: caam 30900000.caam: ERA source: CCBVID.
Jun 20 18:00:11 okmx8mm kernel: caam 30900000.caam: device ID = 0x0a16040100000000 (Era 9)
Jun 20 18:00:11 okmx8mm kernel: caam 30900000.caam: job rings = 3, qi = 0, dpaa2 = no
Jun 20 18:00:11 okmx8mm kernel: caam_jr 30901000.jr0: Entropy delay = 3200
Jun 20 18:00:11 okmx8mm kernel: caam_jr 30901000.jr0: Entropy delay = 3600
Jun 20 18:00:11 okmx8mm kernel: caam_jr 30901000.jr0: Instantiated RNG4 SH0.
Jun 20 18:00:11 okmx8mm kernel: caam_jr 30901000.jr0: Instantiated RNG4 SH1.
Jun 20 18:00:11 okmx8mm kernel: caam algorithms registered in /proc/crypto
Jun 20 18:00:11 okmx8mm kernel: caam_jr 30901000.jr0: registering rng-caam
Jun 20 18:00:11 okmx8mm kernel: caam 30900000.caam: caam pkc algorithms registered in /proc/crypto
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: blkkey_ex: 2 keystore units available
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 64-bit clear key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 64-bit black key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] 26 47 c9 b5 68 f0 21 cd
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 2f 05 c1 d2 f3 c7 6a c5
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 128-bit clear key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 128-bit black key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] 18 fa 49 f3 a2 61 d4 65
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] b9 48 8b 30 3f 26 3b 67
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 192-bit clear key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] 10 11 12 13 14 15 16 17
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 192-bit black key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] 80 43 7d 42 69 22 6c bd
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 23 9d 83 b8 d3 39 b6 8c
Jun 20 18:00:11 okmx8mm kernel: usb 1-1.1: new high-speed USB device number 3 using ci_hdrc
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] b8 14 62 ce 4f 24 b8 7a
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] a0 7a e2 66 13 f9 dd b7
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 256-bit clear key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 256-bit black key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] 2f 8e 71 f9 d0 b0 7c c6
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 7c 38 8d e9 89 c6 38 23
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] e1 71 f0 70 09 a4 a8 3f
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] 1b 95 23 65 11 98 9e cf
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 64-bit unwritten blob:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0032] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0040] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0048] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0056] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0064] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0072] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0080] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0088] 00 00 00 00 00 00 00 00
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 128-bit unwritten blob:
Jun 20 18:00:11 okmx8mm kernel: usb 1-1.4: new high-speed USB device number 4 using ci_hdrc
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 196-bit unwritten blob:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 256-bit unwritten blob:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 64-bit black key in blob:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] cd 3f 1e ac fe 9d b1 71
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 97 ee 03 11 b5 34 d8 33
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] f6 bd 1c 11 e4 1e 67 99
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] 23 04 df 9f cf 4a 21 43
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0032] 6e 9e ef 40 60 dc 5c a6
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0040] a9 10 c1 f1 5d 58 97 f1
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0048] d6 f2 43 57 b6 7c ba 69
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 128-bit black key in blob:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] 82 b3 7f 70 cf 57 23 e1
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 6d 64 7a bd 61 2a 13 3f
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] 5b d9 7a 9c 2d 97 b2 53
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] 35 77 a1 35 5e 6a b8 f1
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0032] 94 88 97 53 57 67 6a d6
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0040] 1e be f0 38 1b b9 31 18
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0048] 4f 14 70 e4 b9 d8 11 87
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0056] 01 2b 90 b2 e6 62 ee 46
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 192-bit black key in blob:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] ac 0e 07 ae 8e 1e ae 6f
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] e3 89 61 7f bd 3f fd 11
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] 65 f6 1a 8d 41 30 46 61
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] 1f cf 69 26 4e 1e e2 58
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0032] f6 e0 27 6e 1c 3b bc 27
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0040] 15 d9 8b e9 f3 3d 21 a7
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0048] 44 46 66 a7 1c a9 21 1a
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0056] 20 c6 c8 3b c8 cd 7e 97
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0064] 17 56 37 1f 54 77 39 7c
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: 256-bit black key in blob:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] 98 ee 16 d3 d8 5e e8 89
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 60 9a 55 b3 36 e6 fd e8
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] bc 4d 29 67 f2 19 56 9a
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] ff 78 ea 11 02 be cd a1
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0032] ef 31 36 2a c6 a9 a4 43
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0040] dd 04 74 06 4c 9a 52 cf
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0048] ac f3 87 04 18 4f 8f 62
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0056] 75 be 33 2e 21 51 f7 69
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0064] aa ee 7e 0d 6d a6 18 3e
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0072] 2a 3e d5 84 3f 43 ad a6
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: restored 64-bit black key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0000] d1 4e c9 58 07 4d 9a 66
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0008] 34 87 83 ff b4 bf 51 21
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: restored 128-bit black key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: restored 192-bit black key:
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0016] 69 54 cb 3a ac c4 60 96
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: [0024] b9 96 1d f3 a7 dd 46 9c
Jun 20 18:00:11 okmx8mm kernel: platform caam_sm: restored 256-bit black key:
Jun 20 18:00:11 okmx8mm kernel: caam-snvs 30370000.caam-snvs: can't get snvs clock
Jun 20 18:00:11 okmx8mm kernel: caam-snvs 30370000.caam-snvs: violation handlers armed - non-secure state
Jun 20 18:00:11 okmx8mm kernel: usbcore: registered new inte**ce driver usbhid
Jun 20 18:00:11 okmx8mm kernel: usbhid: USB HID core driver
Jun 20 18:00:11 okmx8mm kernel: fsl-micfil-dai 30080000.micfil: GET IRQ: 41
Jun 20 18:00:11 okmx8mm kernel: fsl-micfil-dai 30080000.micfil: GET IRQ: 42
Jun 20 18:00:11 okmx8mm kernel: fsl-micfil-dai 30080000.micfil: GET IRQ: 43
Jun 20 18:00:11 okmx8mm kernel: fsl-micfil-dai 30080000.micfil: GET IRQ: 44
Jun 20 18:00:11 okmx8mm kernel: imx-wm8960 sound: wm8960-hifi <-> 30020000.sai mapping ok
Jun 20 18:00:11 okmx8mm kernel: imx-wm8960 sound: ASoC: no source widget found for ASRC-Playback
Jun 20 18:00:11 okmx8mm kernel: imx-wm8960 sound: ASoC: Failed to add route ASRC-Playback -> direct -> CPU-Playback
Jun 20 18:00:11 okmx8mm kernel: imx-wm8960 sound: ASoC: no sink widget found for ASRC-Capture
Jun 20 18:00:11 okmx8mm kernel: imx-wm8960 sound: ASoC: Failed to add route CPU-Capture -> direct -> ASRC-Capture
Jun 20 18:00:11 okmx8mm kernel: imx-wm8960 sound: ASoC: no DMI vendor name!
Jun 20 18:00:11 okmx8mm kernel: imx-micfil sound-micfil: snd-soc-dummy-dai <-> 30080000.micfil mapping ok
Jun 20 18:00:11 okmx8mm kernel: imx-micfil sound-micfil: ASoC: no DMI vendor name!
Jun 20 18:00:11 okmx8mm kernel: NET: Registered protocol family 26
Jun 20 18:00:11 okmx8mm kernel: NET: Registered protocol family 10
Jun 20 18:00:11 okmx8mm kernel: Segment Routing with IPv6
Jun 20 18:00:11 okmx8mm kernel: NET: Registered protocol family 17
Jun 20 18:00:11 okmx8mm kernel: can: controller area network core (rev 20170425 abi 9)
Jun 20 18:00:11 okmx8mm kernel: NET: Registered protocol family 29
Jun 20 18:00:11 okmx8mm kernel: can: raw protocol (rev 20170425)
Jun 20 18:00:11 okmx8mm kernel: can: broadcast manager protocol (rev 20170425 t)
Jun 20 18:00:11 okmx8mm kernel: can: netlink gateway (rev 20170425) max_hops=1
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: RFCOMM TTY layer initialized
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: RFCOMM socket layer initialized
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: RFCOMM ver 1.11
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: BNEP filters: protocol multicast
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: BNEP socket layer initialized
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: HIDP (Human Inte**ce Emulation) ver 1.2
Jun 20 18:00:11 okmx8mm kernel: Bluetooth: HIDP socket layer initialized
Jun 20 18:00:11 okmx8mm kernel: 9pnet: Installing 9P2000 support
Jun 20 18:00:11 okmx8mm kernel: Key type dns_resolver registered
Jun 20 18:00:11 okmx8mm kernel: registered taskstats version 1
Jun 20 18:00:11 okmx8mm kernel: cpu cpu0: registered imx8mq-cpufreq
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie 33800000.pcie: 33800000.pcie supply epdev_on not found, using dummy regulator
Jun 20 18:00:11 okmx8mm kernel: OF: PCI: host bridge /pcie@0x33800000 ranges:
Jun 20 18:00:11 okmx8mm kernel: OF: PCI:   No bus range found for /pcie@0x33800000, using [bus 00-ff]
Jun 20 18:00:11 okmx8mm kernel: OF: PCI:    IO 0x1ff80000..0x1ff8ffff -> 0x00000000
Jun 20 18:00:11 okmx8mm kernel: OF: PCI:   MEM 0x18000000..0x1fefffff -> 0x18000000
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie 33800000.pcie: Initialize PHY with EXT REfCLK!.
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie 33800000.pcie: PHY Initialization End!.
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie 33800000.pcie: pcie phy pll is locked.
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie 33800000.pcie: phy link never came up
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie 33800000.pcie: failed to initialize host
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie 33800000.pcie: unable to add pcie port.
Jun 20 18:00:11 okmx8mm kernel: imx6q-pcie: probe of 33800000.pcie failed with error -110
Jun 20 18:00:11 okmx8mm kernel: usb 1-1.1: USB disconnect, device number 3
Jun 20 18:00:11 okmx8mm kernel: input: gpio-keys as /devices/platform/gpio-keys/input/input2
Jun 20 18:00:11 okmx8mm kernel: hctosys: unable to open rtc device (rtc0)
Jun 20 18:00:11 okmx8mm kernel: WLAN_EN: disabling
Jun 20 18:00:11 okmx8mm kernel: VSD_3V3: disabling
Jun 20 18:00:11 okmx8mm kernel: usb_otg1_vbus: disabling
Jun 20 18:00:11 okmx8mm kernel: ALSA device list:
Jun 20 18:00:11 okmx8mm kernel:   #0: wm8960-audio
Jun 20 18:00:11 okmx8mm kernel:   #1: imx-audio-micfil
Jun 20 18:00:11 okmx8mm kernel: EXT4-fs (mmcblk2p2): recovery complete
Jun 20 18:00:11 okmx8mm kernel: EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. Opts: (null)
Jun 20 18:00:11 okmx8mm kernel: VFS: Mounted root (ext4 filesystem) on device 179:2.
Jun 20 18:00:11 okmx8mm kernel: devtmpfs: mounted
Jun 20 18:00:11 okmx8mm kernel: Freeing unused kernel memory: 768K
Jun 20 18:00:11 okmx8mm systemd[1]: System time before build time, advancing clock.
Jun 20 18:00:11 okmx8mm systemd[1]: systemd 237 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
Jun 20 18:00:11 okmx8mm systemd[1]: Detected architecture arm64.
Jun 20 18:00:11 okmx8mm systemd[1]: Set hostname to <okmx8mm>.
Jun 20 18:00:11 okmx8mm systemd[1]: File /lib/systemd/system/systemd-journald.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
Jun 20 18:00:11 okmx8mm systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
Jun 20 18:00:11 okmx8mm kernel: random: systemd: uninitialized urandom read (16 bytes read)
Jun 20 18:00:11 okmx8mm systemd[1]: Created slice System Slice.
Jun 20 18:00:11 okmx8mm systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
Jun 20 18:00:11 okmx8mm systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Jun 20 18:00:11 okmx8mm systemd[1]: Created slice system-serial\x2dgetty.slice.
Jun 20 18:00:11 okmx8mm systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Jun 20 18:00:11 okmx8mm kernel: EXT4-fs (mmcblk2p2): re-mounted. Opts: (null)
Jun 20 18:00:11 okmx8mm systemd-journald[1909]: Journal started
Jun 20 18:00:11 okmx8mm systemd-journald[1909]: Runtime journal (/run/log/journal/94e1df36640a446a9b3bdbc917b10519) is 8.0M, max 64.0M, 56.0M free.
Jun 20 18:00:11 okmx8mm systemd-vconsole-setup[1906]: KD_FONT_OP_GET failed while trying to get the font metadata: Function not implemented
Jun 20 18:00:11 okmx8mm systemd-vconsole-setup[1906]: Fonts will not be copied to remaining consoles
Jun 20 18:00:11 okmx8mm systemd-modules-load[1908]: Module 'galcore' is builtin
Jun 20 18:00:11 okmx8mm systemd[1]: Started Create list of required static device nodes for the current kernel.
Jun 20 18:00:11 okmx8mm systemd[1]: Mounted POSIX Message Queue File System.
Jun 20 18:00:11 okmx8mm systemd[1]: Mounted Kernel Debug File System.
Jun 20 18:00:11 okmx8mm systemd[1]: Started Setup Virtual Console.
Jun 20 18:00:11 okmx8mm systemd[1]: Mounted Huge Pages File System.
Jun 20 18:00:11 okmx8mm systemd[1]: Started Load Kernel Modules.
Jun 20 18:00:11 okmx8mm systemd[1]: Mounted Temporary Directory (/tmp).
Jun 20 18:00:11 okmx8mm systemd[1]: Started Remount Root and Kernel File Systems.
Jun 20 18:00:11 okmx8mm systemd[1]: Starting Apply Kernel Variables...
Jun 20 18:00:11 okmx8mm systemd-sysctl[2484]: Couldn't write 'fq_codel' to 'net/core/default_qdisc', ignoring: No such file or directory
Jun 20 18:00:11 okmx8mm systemd[1]: Mounting Kernel Configuration File System...
Jun 20 18:00:11 okmx8mm systemd[1]: Starting Create Static Device Nodes in /dev...
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Flush Journal to Persistent Storage...
Jun 20 18:00:12 okmx8mm systemd[1]: Started Apply Kernel Variables.
Jun 20 18:00:12 okmx8mm systemd[1]: Mounted Kernel Configuration File System.
Jun 20 18:00:12 okmx8mm systemd[1]: Started Create Static Device Nodes in /dev.
Jun 20 18:00:12 okmx8mm systemd[1]: Reached target Local File Systems (Pre).
Jun 20 18:00:12 okmx8mm systemd[1]: Reached target Containers.
Jun 20 18:00:12 okmx8mm systemd[1]: Mounting /var/volatile...
Jun 20 18:00:12 okmx8mm systemd[1]: Starting udev Kernel Device Manager...
Jun 20 18:00:12 okmx8mm systemd[1]: Started udev Coldplug all Devices.
Jun 20 18:00:12 okmx8mm systemd[1]: Mounted /var/volatile.
Jun 20 18:00:12 okmx8mm systemd[1]: Started udev Kernel Device Manager.
Jun 20 18:00:12 okmx8mm systemd-journald[1909]: Runtime journal (/run/log/journal/94e1df36640a446a9b3bdbc917b10519) is 8.0M, max 64.0M, 56.0M free.
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Network Service...
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Load/Save Random Seed...
Jun 20 18:00:12 okmx8mm systemd[1]: Reached target Local File Systems.
Jun 20 18:00:12 okmx8mm systemd-networkd[3028]: Enumeration completed
Jun 20 18:00:12 okmx8mm systemd-networkd[3028]: lo: Removing non-existent address: ::1/128 (valid forever), ignoring
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Start Psplash Boot Screen...
Jun 20 18:00:12 okmx8mm systemd[1]: Started Network Service.
Jun 20 18:00:12 okmx8mm systemd[1]: Started Flush Journal to Persistent Storage.
Jun 20 18:00:12 okmx8mm systemd[1]: Started Load/Save Random Seed.
Jun 20 18:00:12 okmx8mm systemd[1]: Started Start Psplash Boot Screen.
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Create Volatile Files and Directories...
Jun 20 18:00:12 okmx8mm systemd-tmpfiles[3036]: "/var/log" already exists and is not a directory.
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Wait for Network to be Configured...
Jun 20 18:00:12 okmx8mm systemd-tmpfiles[3036]: "/var/tmp" already exists and is not a directory.
Jun 20 18:00:12 okmx8mm systemd-networkd-wait-online[3037]: ignoring: lo
Jun 20 18:00:12 okmx8mm systemd[1]: Started Create Volatile Files and Directories.
Jun 20 18:00:12 okmx8mm kernel: imx-sdma 302c0000.dma-controller: loaded firmware 4.4
Jun 20 18:00:12 okmx8mm kernel: imx-sdma 302b0000.dma-controller: loaded firmware 4.4
Jun 20 18:00:12 okmx8mm kernel: imx-sdma 30bd0000.dma-controller: loaded firmware 4.4
Jun 20 18:00:12 okmx8mm kernel: rtc-rx8010 1-0032: Frequency stop was detected
Jun 20 18:00:12 okmx8mm kernel: rtc-rx8010 1-0032: Frequency stop detected
Jun 20 18:00:12 okmx8mm kernel: rtc-rx8010 1-0032: rtc core: registered rx8010 as rtc0
Jun 20 18:00:12 okmx8mm kernel: edt_ft5x06 3-0038: touchscreen probe failed
Jun 20 18:00:12 okmx8mm systemd[1]: Found device /dev/ttymxc1.
Jun 20 18:00:12 okmx8mm systemd-udevd[3029]: Failed to apply ACL on /dev/video0: Operation not supported
Jun 20 18:00:12 okmx8mm systemd-udevd[3016]: Failed to apply ACL on /dev/dri/card0: Operation not supported
Jun 20 18:00:12 okmx8mm systemd[1]: Created slice system-systemd\x2dbacklight.slice.
Jun 20 18:00:12 okmx8mm systemd-udevd[3027]: Failed to apply ACL on /dev/snd/pcmC0D0p: Operation not supported
Jun 20 18:00:12 okmx8mm systemd-udevd[3029]: Failed to apply ACL on /dev/snd/pcmC0D0c: Operation not supported
Jun 20 18:00:12 okmx8mm systemd-udevd[3030]: Failed to apply ACL on /dev/snd/controlC0: Operation not supported
Jun 20 18:00:12 okmx8mm systemd-udevd[3032]: Failed to apply ACL on /dev/snd/pcmC1D0c: Operation not supported
Jun 20 18:00:12 okmx8mm systemd-udevd[3024]: Failed to apply ACL on /dev/snd/controlC1: Operation not supported
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:backlight@0...
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Jun 20 18:00:12 okmx8mm systemd[1]: Starting Network Time Synchronization...
Jun 20 18:00:12 okmx8mm systemd[1]: Started Load/Save Screen Backlight Brightness of backlight:backlight@0.
Jun 20 18:00:12 okmx8mm root[3119]: udev/mount.sh [/dev/loop4] is blacklisted, ignoring
Jun 20 18:00:12 okmx8mm root[3117]: udev/mount.sh [/dev/loop5] is blacklisted, ignoring
Jun 20 18:00:12 okmx8mm systemd[1]: Started Update UTMP about System Boot/Shutdown.
Jun 20 18:00:12 okmx8mm root[3123]: udev/mount.sh [/dev/loop3] is blacklisted, ignoring
Jun 20 18:00:12 okmx8mm root[3124]: udev/mount.sh [/dev/loop6] is blacklisted, ignoring
Jun 20 18:00:12 okmx8mm root[3120]: udev/mount.sh [/dev/mtdblock0] is blacklisted, ignoring
Jun 20 18:00:12 okmx8mm root[3115]: udev/mount.sh [/dev/loop2] is blacklisted, ignoring
Jun 20 18:00:12 okmx8mm root[3125]: udev/mount.sh [/dev/loop0] is blacklisted, ignoring
Jun 20 18:00:12 okmx8mm root[3126]: udev/mount.sh [/dev/loop7] is blacklisted, ignoring
Jun 20 18:00:12 okmx8mm root[3129]: udev/mount.sh [/dev/loop1] is blacklisted, ignoring
Jun 20 18:00:12 okmx8mm root[3144]: udev/mount.sh [/dev/ram0] is blacklisted, ignoring
Jun 20 18:00:12 okmx8mm systemd-timesyncd[3088]: System clock time unset or jumped backwards, restoring from recorded timestamp: Tue 2019-11-26 17:22:17 CST
Nov 26 17:22:17 okmx8mm systemd[1]: Started Network Time Synchronization.
Nov 26 17:22:17 okmx8mm systemd[1]: Reached target System Initialization.
Nov 26 17:22:17 okmx8mm root[3188]: udev/mount.sh [/dev/ram15] is blacklisted, ignoring
Nov 26 17:22:17 okmx8mm root[3185]: udev/mount.sh [/dev/ram12] is blacklisted, ignoring
Nov 26 17:22:17 okmx8mm root[3187]: udev/mount.sh [/dev/ram14] is blacklisted, ignoring
Nov 26 17:22:17 okmx8mm systemd[1]: Listening on dropbear.socket.
Nov 26 17:22:17 okmx8mm root[3192]: udev/mount.sh [/dev/ram11] is blacklisted, ignoring
Nov 26 17:22:17 okmx8mm systemd[1]: Starting Console System Startup Logging...
Nov 26 17:22:17 okmx8mm root[3201]: udev/mount.sh [/dev/ram10] is blacklisted, ignoring
Nov 26 17:22:17 okmx8mm root[3194]: udev/mount.sh [/dev/ram13] is blacklisted, ignoring
Nov 26 17:22:17 okmx8mm systemd[1]: Started Daily Cleanup of Temporary Directories.
Nov 26 17:22:17 okmx8mm systemd[1]: Starting Docker Socket for the API.
Nov 26 17:22:17 okmx8mm root[3216]: udev/mount.sh [/dev/ram2] is blacklisted, ignoring
Nov 26 17:22:17 okmx8mm systemd[1]: Listening on RPCbind Server Activation Socket.
Nov 26 17:22:17 okmx8mm root[3230]: udev/mount.sh [/dev/ram3] is blacklisted, ignoring
Nov 26 17:22:17 okmx8mm systemd[1]: Listening on D-Bus System Message Bus Socket.
Nov 26 17:22:17 okmx8mm root[3232]: udev/mount.sh [/dev/ram6] is blacklisted, ignoring
Nov 26 17:22:17 okmx8mm systemd-udevd[3023]: Failed to apply ACL on /dev/snd/timer: Operation not supported
Nov 26 17:22:17 okmx8mm systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Nov 26 17:22:17 okmx8mm root[3250]: udev/mount.sh [/dev/ram5] is blacklisted, ignoring
Nov 26 17:22:17 okmx8mm root[3251]: udev/mount.sh [/dev/ram1] is blacklisted, ignoring
Nov 26 17:22:17 okmx8mm systemd[1]: Reached target System Time Synchronized.
Nov 26 17:22:17 okmx8mm root[3246]: udev/mount.sh [/dev/ram4] is blacklisted, ignoring
Nov 26 17:22:17 okmx8mm root[3263]: udev/mount.sh [/dev/ram8] is blacklisted, ignoring
Nov 26 17:22:17 okmx8mm systemd[1]: logrotate.timer: Not using persistent file timestamp Wed 2019-11-27 00:30:17 CST as it is in the future.
Nov 26 17:22:17 okmx8mm systemd[1]: Started Daily rotation of log files.
Nov 26 17:22:17 okmx8mm systemd-networkd-wait-online[3037]: ignoring: lo
Nov 26 17:22:17 okmx8mm root[3241]: udev/mount.sh [/dev/ram7] is blacklisted, ignoring
Nov 26 17:22:17 okmx8mm systemd[1]: Reached target Timers.
Nov 26 17:22:17 okmx8mm root[3272]: udev/mount.sh [/dev/ram9] is blacklisted, ignoring
Nov 26 17:22:17 okmx8mm kernel: rtk_btusb: Realtek Bluetooth USB driver ver 3.1.abb7701.20181012-134852
Nov 26 17:22:17 okmx8mm kernel: rtk_btcoex: rtk_btcoex_init: version: 1.2
Nov 26 17:22:17 okmx8mm kernel: rtk_btcoex: create workqueue
Nov 26 17:22:17 okmx8mm kernel: rtk_btcoex: Coex over UDP
Nov 26 17:22:17 okmx8mm kernel: rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
Nov 26 17:22:17 okmx8mm systemd[1]: Started Console System Startup Logging.
Nov 26 17:22:17 okmx8mm systemd[1]: Listening on Docker Socket for the API.
Nov 26 17:22:17 okmx8mm kernel: FAT-fs (mmcblk2p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Nov 26 17:22:17 okmx8mm root[3281]: mount.sh/automount Auto-mount of [/run/media/mmcblk2p1] successful
Nov 26 17:22:17 okmx8mm systemd[1]: Reached target Sockets.
Nov 26 17:22:17 okmx8mm systemd[1]: Reached target Basic System.
Nov 26 17:22:18 okmx8mm systemd[1]: Started Updates psplash to basic.
Nov 26 17:22:18 okmx8mm systemd[1]: Starting LSB: Set system clock...
Nov 26 17:22:18 okmx8mm hwclock.sh[3302]: System time was Tue Nov 26 17:22:18 CST 2019.
Nov 26 17:22:18 okmx8mm hwclock.sh[3302]: Setting the System Clock using the Hardware Clock as reference...
Nov 26 17:22:18 okmx8mm hwclock.sh[3302]: hwclock: RTC_RD_TIME: Invalid argument
Nov 26 17:22:18 okmx8mm hwclock.sh[3302]: System Clock set. System local time is now Tue Nov 26 17:22:18 CST 2019.
Nov 26 17:22:18 okmx8mm kernel: usbcore: registered new inte**ce driver rtl8723bu
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInte**ceNumber 0
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: patch_add
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: auto suspend is disabled
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: pid = 0xb720
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: patch_add: Reset gEVersion to 0xff
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: btusb_probe: done
Nov 26 17:22:18 okmx8mm kernel: usbcore: registered new inte**ce driver rtk_btusb
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: btusb_open start pm_usage_cnt(0x1)
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: btusb_open hdev->promisc ==0
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: download_patch start
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: chip type value: 0x00
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: HCI reset.
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: read_ver_rsp->lmp_subver = 0x8723
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: read_ver_rsp->hci_rev = 0xb
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: patch_entry->lmp_sub = 0x8723
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: load_firmware start
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: lmp_version = 0x8723
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: config filename rtl8723bu_config
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: no bdaddr file /opt/bdaddr
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: config offset 00f4,length 08
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: config offset 01e3,length 01
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: config offset 00db,length 01
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: 55 ab 23 87 13 00 f4 00 08 01 00 00 00 05 50 00
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: 00 e3 01 01 04 db 00 01 42
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: Config file length 25, new length 25
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: fw name is  rtl8723b_fw
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: This is not 8723a, use new patch style!
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: rtk_get_eversion: gEVersion 255
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: eversion->status = 0x0, eversion->version = 0x1
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: load_firmware: New gEVersion 1
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 1
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: lmp_version is 8723, project_id is 8723, match!
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: fw_version = 0x1e6ca747
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: number_of_total_patch = 2
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: chipID 2
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: patch_length 0x58f0
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: start_offset 0x000058c0
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: Svn version:    19897
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: Coexistence: BTCOEX_20171128-6d50
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: buf_len = 0x5909
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: fw: exists, config file: exists
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: load_firmware done
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: download_data start
Nov 26 17:22:18 okmx8mm kernel: rtc-rx8010 1-0032: Frequency stop detected
Nov 26 17:22:18 okmx8mm systemd[1]: Started D-Bus System Message Bus.
Nov 26 17:22:18 okmx8mm systemd-networkd-wait-online[3037]: ignoring: lo
Nov 26 17:22:18 okmx8mm systemd[1]: Starting Network Time Service (one-shot ntpdate mode)...
Nov 26 17:22:18 okmx8mm systemd[1]: Starting Save/Restore Sound Card State...
Nov 26 17:22:18 okmx8mm systemd[1]: Starting Telephony service...
Nov 26 17:22:18 okmx8mm ofonod[3315]: oFono version 1.22
Nov 26 17:22:18 okmx8mm systemd[1]: Started TEE Supplicant.
Nov 26 17:22:18 okmx8mm tee-supplicant[3316]: ERR [3316] TEES:main:663: failed to find an OP-TEE supplicant device
Nov 26 17:22:18 okmx8mm systemd[1]: Started Job spooling tools.
Nov 26 17:22:18 okmx8mm systemd[1]: Starting LSB: run bluez5-obex daemon...
Nov 26 17:22:18 okmx8mm systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Nov 26 17:22:18 okmx8mm obexd[3318]: Starting Obexd.
Nov 26 17:22:18 okmx8mm systemd[1]: Starting System Logging Service...
Nov 26 17:22:18 okmx8mm avahi-daemon[3320]: Found user 'avahi' (UID 992) and group 'avahi' (GID 989).
Nov 26 17:22:18 okmx8mm avahi-daemon[3320]: Successfully dropped root privileges.
Nov 26 17:22:18 okmx8mm avahi-daemon[3320]: avahi-daemon 0.7 starting up.
Nov 26 17:22:18 okmx8mm avahi-daemon[3320]: Successfully called chroot().
Nov 26 17:22:18 okmx8mm avahi-daemon[3320]: Successfully dropped remaining capabilities.
Nov 26 17:22:18 okmx8mm avahi-daemon[3324]: ../../avahi-0.7/avahi-daemon/chroot.c: open() failed: No such file or directory
Nov 26 17:22:18 okmx8mm avahi-daemon[3320]: Failed to open /etc/resolv.conf: Invalid argument
Nov 26 17:22:18 okmx8mm avahi-daemon[3320]: Loading service file /services/sftp-ssh.service.
Nov 26 17:22:18 okmx8mm avahi-daemon[3320]: Loading service file /services/ssh.service.
Nov 26 17:22:18 okmx8mm systemd[1]: Started Periodic Command Scheduler.
Nov 26 17:22:18 okmx8mm avahi-daemon[3320]: Network inte**ce enumeration completed.
Nov 26 17:22:18 okmx8mm avahi-daemon[3320]: Server startup complete. Host name is okmx8mm.local. Local service cookie is 1519299992.
Nov 26 17:22:18 okmx8mm avahi-daemon[3320]: Service "okmx8mm" (/services/ssh.service) successfully established.
Nov 26 17:22:18 okmx8mm avahi-daemon[3320]: Service "okmx8mm" (/services/sftp-ssh.service) successfully established.
Nov 26 17:22:18 okmx8mm systemd[1]: Started Configuration for i.MX GPU (Former rc_gpu.S).
Nov 26 17:22:18 okmx8mm systemd[1]: Starting Login Service...
Nov 26 17:22:18 okmx8mm systemd-logind[3329]: New seat seat0.
Nov 26 17:22:18 okmx8mm systemd[1]: Starting RPC Bind Service...
Nov 26 17:22:18 okmx8mm systemd[1]: Starting Connection service...
Nov 26 17:22:18 okmx8mm systemd[3347]: connman.service: Executable /usr/lib/connman/wired-setup missing, skipping: No such file or directory
Nov 26 17:22:18 okmx8mm systemd[1]: Started LSB: Set system clock.
Nov 26 17:22:18 okmx8mm systemd[1]: Started Network Time Service (one-shot ntpdate mode).
Nov 26 17:22:18 okmx8mm systemd-logind[3329]: Watching system buttons on /dev/input/event0 (InputEmulator)
Nov 26 17:22:18 okmx8mm systemd[1]: Started Save/Restore Sound Card State.
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: download_data done
Nov 26 17:22:18 okmx8mm systemd[1]: tee-supplicant.service: Main process exited, code=exited, status=1/FAILURE
Nov 26 17:22:18 okmx8mm systemd[1]: tee-supplicant.service: Failed with result 'exit-code'.
Nov 26 17:22:18 okmx8mm systemd[1]: Started LSB: run bluez5-obex daemon.
Nov 26 17:22:18 okmx8mm systemd[1]: Started System Logging Service.
Nov 26 17:22:18 okmx8mm systemd[1]: Started RPC Bind Service.
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: read_ver_rsp->lmp_subver = 0xa747
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: read_ver_rsp->hci_rev = 0x1e6c
Nov 26 17:22:18 okmx8mm systemd[1]: Started Telephony service.
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: Rtk patch end 0
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: btusb_open set HCI_RUNNING
Nov 26 17:22:18 okmx8mm kernel: rtk_btcoex: Open BTCOEX
Nov 26 17:22:18 okmx8mm kernel: rtk_btcoex: create_udpsocket: connect_port: 30001
Nov 26 17:22:18 okmx8mm kernel: rtk_btcoex: send msg INVITE_REQ with len:11
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: btusb_open end  pm_usage_cnt(0x0)
Nov 26 17:22:18 okmx8mm kernel: rtk_btcoex: BTCOEX hci_rev 0x1e6c
Nov 26 17:22:18 okmx8mm systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Nov 26 17:22:18 okmx8mm kernel: rtk_btcoex: BTCOEX lmp_subver 0xa747
Nov 26 17:22:18 okmx8mm systemd[1]: Started Login Service.
Nov 26 17:22:18 okmx8mm kernel: rtk_btusb: btusb_notify: hci0 evt 3
Nov 26 17:22:18 okmx8mm kernel: random: crng init done
Nov 26 17:22:18 okmx8mm kernel: random: 7 urandom warning(s) missed due to ratelimiting
Nov 26 17:22:18 okmx8mm systemd[1]: Started Connection service.
Nov 26 17:22:18 okmx8mm systemd[1]: Starting Hostname Service...
Nov 26 17:22:18 okmx8mm systemd[1]: Starting WPA supplicant...
Nov 26 17:22:18 okmx8mm kernel: Atheros 8031 ethernet 30be0000.ethernet-1:01: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=30be0000.ethernet-1:01, irq=POLL)
Nov 26 17:22:18 okmx8mm systemd[1]: Starting Bluetooth service...
Nov 26 17:22:18 okmx8mm wpa_supplicant[3352]: Successfully initialized wpa_supplicant
Nov 26 17:22:18 okmx8mm systemd[1]: Starting Kernel Logging Service...
Nov 26 17:22:18 okmx8mm systemd[1]: Reached target Sound Card.
Nov 26 17:22:18 okmx8mm systemd[1]: Started WPA supplicant.
Nov 26 17:22:18 okmx8mm systemd[1]: Started Bluetooth service.
Nov 26 17:22:18 okmx8mm systemd[1]: Reached target Bluetooth.
Nov 26 17:22:18 okmx8mm systemd[1]: Reached target Network.
Nov 26 17:22:18 okmx8mm systemd[1]: Starting Permit User Sessions...
Nov 26 17:22:18 okmx8mm systemd[1]: Starting /etc/rc.local Compatibility...
Nov 26 17:22:18 okmx8mm systemd[1]: Started Vsftpd ftp daemon.
Nov 26 17:22:18 okmx8mm systemd[1]: Started NFS status monitor for NFSv2/3 locking..
Nov 26 17:22:19 okmx8mm rpc.statd[3361]: sm-notify: Version 2.1.1 starting
Nov 26 17:22:19 okmx8mm rpc.statd[3361]: sm-notify: No hosts to notify; exiting
Nov 26 17:22:19 okmx8mm systemd[1]: Started Update psplash to network.
Nov 26 17:22:19 okmx8mm systemd[1]: Starting Terminate Psplash Boot Screen...
Nov 26 17:22:19 okmx8mm systemd[1]: Starting telnetd...
Nov 26 17:22:19 okmx8mm systemd[1]: Starting Lightning Fast Webserver With Light System Requirements...
Nov 26 17:22:19 okmx8mm systemd[1]: Started Permit User Sessions.
Nov 26 17:22:19 okmx8mm lighttpd[3366]: Syntax OK
Nov 26 17:22:19 okmx8mm systemd[1]: Started /etc/rc.local Compatibility.
Nov 26 17:22:19 okmx8mm systemd[1]: Started Terminate Psplash Boot Screen.
Nov 26 17:22:19 okmx8mm systemd[1]: Started Kernel Logging Service.
Nov 26 17:22:19 okmx8mm systemd[1]: Started telnetd.
Nov 26 17:22:19 okmx8mm systemd[1]: Started Lightning Fast Webserver With Light System Requirements.
Nov 26 17:22:19 okmx8mm lighttpd[3368]: 2019-11-26 17:22:19: (../../lighttpd-1.4.48/src/server.c.1412) server started (lighttpd/1.4.48)
Nov 26 17:22:19 okmx8mm systemd[1]: Started Hostname Service.
Nov 26 17:22:19 okmx8mm systemd[1]: Starting Weston Wayland Compositor (on tty7)...
Nov 26 17:22:19 okmx8mm systemd[1]: Started Serial Getty on ttymxc1.
Nov 26 17:22:19 okmx8mm systemd[1]: Started Getty on tty1.
Nov 26 17:22:19 okmx8mm systemd[1]: Reached target Login Prompts.
Nov 26 17:22:19 okmx8mm systemd[1]: Started Weston Wayland Compositor (on tty7).
Nov 26 17:22:19 okmx8mm systemd[1]: Starting weston-touch-calibrator...
Nov 26 17:22:19 okmx8mm systemd[1]: Starting Matrix GUI...
Nov 26 17:22:19 okmx8mm systemd[1]: Created slice User Slice of root.
Nov 26 17:22:19 okmx8mm matrix-gui-2.0[3383]: /
Nov 26 17:22:19 okmx8mm systemd[1]: Starting User Manager for UID 0...
Nov 26 17:22:19 okmx8mm kernel: audit: type=1006 audit(1574760139.353:2): pid=3389 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
Nov 26 17:22:19 okmx8mm systemd-logind[3329]: New session c1 of user root.
Nov 26 17:22:19 okmx8mm systemd[1]: Started Session c1 of user root.
Nov 26 17:22:19 okmx8mm systemd-logind[3329]: Failed to apply ACLs: Operation not supported
Nov 26 17:22:19 okmx8mm systemd[3389]: Reached target Sockets.
Nov 26 17:22:19 okmx8mm systemd[3389]: Reached target Timers.
Nov 26 17:22:19 okmx8mm systemd[3389]: Reached target Paths.
Nov 26 17:22:19 okmx8mm systemd[3389]: Reached target Basic System.
Nov 26 17:22:19 okmx8mm systemd[3389]: Reached target Default.
Nov 26 17:22:19 okmx8mm systemd[3389]: Startup finished in 57ms.
Nov 26 17:22:19 okmx8mm systemd[1]: Started User Manager for UID 0.
Nov 26 17:22:19 okmx8mm matrix-gui-2.0[3383]: Starting Matrix GUI application.
Nov 26 17:22:19 okmx8mm systemd[1]: Started Matrix GUI.
Nov 26 17:22:19 okmx8mm weston-launch[3380]: Wrong panel position:
Nov 26 17:22:19 okmx8mm weston-launch[3380]: could not load cursor 'dnd-move'
Nov 26 17:22:19 okmx8mm weston-launch[3380]: could not load cursor 'dnd-copy'
Nov 26 17:22:19 okmx8mm weston-launch[3380]: could not load cursor 'dnd-none'
Nov 26 17:22:20 okmx8mm cal.sh[3381]: could not load cursor 'dnd-move'
Nov 26 17:22:20 okmx8mm cal.sh[3381]: could not load cursor 'dnd-copy'
Nov 26 17:22:20 okmx8mm cal.sh[3381]: could not load cursor 'dnd-none'
Nov 26 17:22:20 okmx8mm cal.sh[3381]: No devices listed.
Nov 26 17:22:20 okmx8mm systemd[1]: Started weston-touch-calibrator.
Nov 26 17:22:20 okmx8mm kernel: usb 1-1.1: new high-speed USB device number 5 using ci_hdrc
Nov 26 17:22:20 okmx8mm kernel: rtk_btusb: btusb_flush add delay
Nov 26 17:22:20 okmx8mm kernel: rtk_btusb: btusb_close
Nov 26 17:22:20 okmx8mm kernel: rtk_btcoex: Close BTCOEX
Nov 26 17:22:20 okmx8mm kernel: rtk_btcoex: release udp socket
Nov 26 17:22:20 okmx8mm kernel: rtk_btcoex: -x
Nov 26 17:22:20 okmx8mm systemd-networkd-wait-online[3037]: ignoring: lo
Nov 26 17:22:20 okmx8mm kernel: fec 30be0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
Nov 26 17:22:20 okmx8mm systemd-networkd[3028]: eth0: Gained carrier
Nov 26 17:22:20 okmx8mm kernel: 8021q: 802.1Q VLAN Support v1.8
Nov 26 17:22:20 okmx8mm avahi-daemon[3320]: Joining mDNS multicast group on inte**ce eth0.IPv4 with address 192.168.2.103.
Nov 26 17:22:20 okmx8mm avahi-daemon[3320]: New relevant inte**ce eth0.IPv4 for mDNS.
Nov 26 17:22:20 okmx8mm avahi-daemon[3320]: Registering new address record for 192.168.2.103 on eth0.IPv4.
Nov 26 17:22:20 okmx8mm systemd-timesyncd[3088]: Network configuration changed, trying to establish connection.
Nov 26 17:22:20 okmx8mm systemd[1]: Started Wait for Network to be Configured.
Nov 26 17:22:20 okmx8mm kernel: cdc_ether 1-1.1:2.0 wwan0: register 'cdc_ether' at usb-ci_hdrc.1-1.1, Mobile Broadband Network Device, 02:1e:10:1f:00:00
Nov 26 17:22:20 okmx8mm kernel: usbcore: registered new inte**ce driver cdc_ether
Nov 26 17:22:20 okmx8mm kernel: usbcore: registered new inte**ce driver usbserial
Nov 26 17:22:20 okmx8mm kernel: usbcore: registered new inte**ce driver usbserial_generic
Nov 26 17:22:20 okmx8mm kernel: usbserial: USB Serial support registered for generic
Nov 26 17:22:21 okmx8mm systemd[1]: Reached target Network is Online.
Nov 26 17:22:21 okmx8mm kernel: usbcore: registered new inte**ce driver option
Nov 26 17:22:21 okmx8mm kernel: usbserial: USB Serial support registered for GSM modem (1-port)
Nov 26 17:22:21 okmx8mm kernel: option 1-1.1:2.2: GSM modem (1-port) converter detected
Nov 26 17:22:21 okmx8mm kernel: usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB0
Nov 26 17:22:21 okmx8mm kernel: option 1-1.1:2.3: GSM modem (1-port) converter detected
Nov 26 17:22:21 okmx8mm kernel: usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB1
Nov 26 17:22:21 okmx8mm kernel: option 1-1.1:2.4: GSM modem (1-port) converter detected
Nov 26 17:22:21 okmx8mm kernel: usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB2
Nov 26 17:22:21 okmx8mm kernel: option 1-1.1:2.5: GSM modem (1-port) converter detected
Nov 26 17:22:21 okmx8mm kernel: usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB3
Nov 26 17:22:21 okmx8mm kernel: option 1-1.1:2.6: GSM modem (1-port) converter detected
Nov 26 17:22:21 okmx8mm kernel: usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB4
Nov 26 17:22:21 okmx8mm systemd[1]: Starting Docker Application Container Engine...
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21.396428000+08:00" level=info msg="libcontainerd: started new docker-containerd process" pid=3521
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="starting containerd" module=containerd revision=9b55aab90508bd389d7654c4baf173a981477d55 version=docker-17.12.1-ce
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.content.v1.content"..." module=containerd type=io.containerd.content.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.snapshotter.v1.btrfs"..." module=containerd type=io.containerd.snapshotter.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=warning msg="failed to load plugin io.containerd.snapshotter.v1.btrfs" error="path /var/lib/docker/containerd/daemon/io.containerd.snapshotter.v1.btrfs must be a btrfs filesystem to be used with the btrfs snapshotter" module=containerd
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.snapshotter.v1.overlayfs"..." module=containerd type=io.containerd.snapshotter.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.metadata.v1.bolt"..." module=containerd type=io.containerd.metadata.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=warning msg="could not use snapshotter btrfs in metadata plugin" error="path /var/lib/docker/containerd/daemon/io.containerd.snapshotter.v1.btrfs must be a btrfs filesystem to be used with the btrfs snapshotter" module="containerd/io.containerd.metadata.v1.bolt"
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.differ.v1.walking"..." module=containerd type=io.containerd.differ.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.gc.v1.scheduler"..." module=containerd type=io.containerd.gc.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.containers"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.content"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.diff"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.events"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.healthcheck"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.images"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.leases"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.namespaces"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.snapshots"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.monitor.v1.cgroups"..." module=containerd type=io.containerd.monitor.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.runtime.v1.linux"..." module=containerd type=io.containerd.runtime.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.tasks"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.version"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="loading plugin "io.containerd.grpc.v1.introspection"..." module=containerd type=io.containerd.grpc.v1
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg=serving... address="/var/run/docker/containerd/docker-containerd-debug.sock" module="containerd/debug"
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg=serving... address="/var/run/docker/containerd/docker-containerd.sock" module="containerd/grpc"
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21+08:00" level=info msg="containerd successfully booted in 0.016674s" module=containerd
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21.593107625+08:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21.644055375+08:00" level=info msg="Graph migration to content-addressability took 0.00 seconds"
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21.645550625+08:00" level=warning msg="Your kernel does not support cgroup cfs period"
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21.645742000+08:00" level=warning msg="Your kernel does not support cgroup cfs quotas"
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21.645808000+08:00" level=warning msg="Your kernel does not support cgroup rt period"
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21.645870875+08:00" level=warning msg="Your kernel does not support cgroup rt runtime"
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21.645946125+08:00" level=warning msg="Your kernel does not support cgroup blkio weight"
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21.646008375+08:00" level=warning msg="Your kernel does not support cgroup blkio weight_device"
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21.646071750+08:00" level=warning msg="Your kernel does not support cgroup blkio throttle.read_bps_device"
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21.646133000+08:00" level=warning msg="Your kernel does not support cgroup blkio throttle.write_bps_device"
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21.646195250+08:00" level=warning msg="Your kernel does not support cgroup blkio throttle.read_iops_device"
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21.646260625+08:00" level=warning msg="Your kernel does not support cgroup blkio throttle.write_iops_device"
Nov 26 17:22:21 okmx8mm dockerd[3509]: time="2019-11-26T17:22:21.651656500+08:00" level=info msg="Loading containers: start."
Nov 26 17:22:21 okmx8mm kernel: bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Nov 26 17:22:21 okmx8mm kernel: Bridge firewalling registered
Nov 26 17:22:21 okmx8mm kernel: nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
Nov 26 17:22:21 okmx8mm kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Nov 26 17:22:21 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=0
Nov 26 17:22:21 okmx8mm kernel: audit: type=1325 audit(1574760141.905:3): table=filter family=2 entries=0
Nov 26 17:22:21 okmx8mm audit[3572]: SYSCALL arch=c00000b7 syscall=273 success=yes exit=0 a0=0 a1=419fd0 a2=0 a3=0 items=0 ppid=5 pid=3572 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="modprobe" exe="/bin/kmod" key=(null)
Nov 26 17:22:21 okmx8mm audit: PROCTITLE proctitle=2F7362696E2F6D6F6470726F6265002D71002D2D0069707461626C655F66696C746572
Nov 26 17:22:22 okmx8mm kernel: audit: type=1300 audit(1574760141.905:3): arch=c00000b7 syscall=273 success=yes exit=0 a0=0 a1=419fd0 a2=0 a3=0 items=0 ppid=5 pid=3572 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="modprobe" exe="/bin/kmod" key=(null)
Nov 26 17:22:22 okmx8mm kernel: audit: type=1327 audit(1574760141.905:3): proctitle=2F7362696E2F6D6F6470726F6265002D71002D2D0069707461626C655F66696C746572
Nov 26 17:22:22 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=0
Nov 26 17:22:22 okmx8mm kernel: audit: type=1325 audit(1574760142.025:4): table=nat family=2 entries=0
Nov 26 17:22:22 okmx8mm audit[3580]: SYSCALL arch=c00000b7 syscall=273 success=yes exit=0 a0=1 a1=419fd0 a2=0 a3=1 items=0 ppid=5 pid=3580 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="modprobe" exe="/bin/kmod" key=(null)
Nov 26 17:22:22 okmx8mm audit: PROCTITLE proctitle=2F7362696E2F6D6F6470726F6265002D71002D2D0069707461626C655F6E6174
Nov 26 17:22:22 okmx8mm kernel: audit: type=1300 audit(1574760142.025:4): arch=c00000b7 syscall=273 success=yes exit=0 a0=1 a1=419fd0 a2=0 a3=1 items=0 ppid=5 pid=3580 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="modprobe" exe="/bin/kmod" key=(null)
Nov 26 17:22:22 okmx8mm kernel: audit: type=1327 audit(1574760142.025:4): proctitle=2F7362696E2F6D6F6470726F6265002D71002D2D0069707461626C655F6E6174
Nov 26 17:22:22 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=5
Nov 26 17:22:22 okmx8mm audit[3600]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=31f51a20 items=0 ppid=3509 pid=3600 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:22 okmx8mm kernel: audit: type=1325 audit(1574760142.181:5): table=nat family=2 entries=5
Nov 26 17:22:22 okmx8mm kernel: audit: type=1300 audit(1574760142.181:5): arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=31f51a20 items=0 ppid=3509 pid=3600 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:22 okmx8mm kernel: audit: type=1327 audit(1574760142.181:5): proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4E00444F434B4552
Nov 26 17:22:22 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4E00444F434B4552
Nov 26 17:22:22 okmx8mm avahi-daemon[3320]: Joining mDNS multicast group on inte**ce eth0.IPv6 with address fe80::c8d5:d0ff:fe72:30c1.
Nov 26 17:22:22 okmx8mm avahi-daemon[3320]: New relevant inte**ce eth0.IPv6 for mDNS.
Nov 26 17:22:22 okmx8mm systemd-networkd[3028]: eth0: Gained IPv6LL
Nov 26 17:22:22 okmx8mm avahi-daemon[3320]: Registering new address record for fe80::c8d5:d0ff:fe72:30c1 on eth0.*.
Nov 26 17:22:22 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=4
Nov 26 17:22:22 okmx8mm audit[3602]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=36ecf900 items=0 ppid=3509 pid=3602 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:22 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D740066696C746572002D4E00444F434B4552
Nov 26 17:22:22 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=6
Nov 26 17:22:22 okmx8mm audit[3604]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=3ac75ad0 items=0 ppid=3509 pid=3604 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:22 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D740066696C746572002D4E00444F434B45522D49534F4C4154494F4E
Nov 26 17:22:22 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=8
Nov 26 17:22:22 okmx8mm audit[3606]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=3a5cc360 items=0 ppid=3509 pid=3606 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:22 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4100444F434B45522D49534F4C4154494F4E002D6A0052455455524E
Nov 26 17:22:22 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=9
Nov 26 17:22:22 okmx8mm audit[3607]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=2de8ad90 items=0 ppid=3509 pid=3607 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:22 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D740066696C746572002D5000464F52574152440044524F50
Nov 26 17:22:22 okmx8mm dockerd[3509]: time="2019-11-26T17:22:22.247487625+08:00" level=warning msg="Could not load necessary modules for IPSEC rules: Running modprobe xfrm_user failed with message: `modprobe: WARNING: Module xfrm_user not found in directory /lib/modules/4.14.78`, error: exit status 1"
Nov 26 17:22:22 okmx8mm dockerd[3509]: time="2019-11-26T17:22:22.261292500+08:00" level=warning msg="Could not load necessary modules for Conntrack: Running modprobe nf_conntrack_netlink failed with message: `modprobe: WARNING: Module nf_conntrack_netlink not found in directory /lib/modules/4.14.78`, error: exit status 1"
Nov 26 17:22:22 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=7
Nov 26 17:22:22 okmx8mm audit[3619]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=36d598f0 items=0 ppid=3509 pid=3619 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:22 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4900504F5354524F5554494E47002D73003137322E31372E302E302F31360000002D6F00646F636B657230002D6A004D415351554552414445
Nov 26 17:22:22 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=8
Nov 26 17:22:22 okmx8mm audit[3631]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=2e0d2440 items=0 ppid=3509 pid=3631 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:22 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4900444F434B4552002D6900646F636B657230002D6A0052455455524E
Nov 26 17:22:22 okmx8mm audit[3634]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=3e9544d0 items=0 ppid=3509 pid=3634 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:22 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6900646F636B657230002D6F00646F636B657230002D6A00414343455054
Nov 26 17:22:22 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=10
Nov 26 17:22:22 okmx8mm audit[3636]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=e74c650 items=0 ppid=3509 pid=3636 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:22 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6900646F636B6572300000002D6F00646F636B657230002D6A00414343455054
Nov 26 17:22:22 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=9
Nov 26 17:22:22 okmx8mm audit[3638]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=201c3270 items=0 ppid=3509 pid=3638 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:22 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4100505245524F5554494E47002D6D006164647274797065002D2D6473742D74797065004C4F43414C002D6A00444F434B4552
Nov 26 17:22:22 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=10
Nov 26 17:22:22 okmx8mm audit[3640]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=28e7b440 items=0 ppid=3509 pid=3640 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:22 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D41004F5554505554002D6D006164647274797065002D2D6473742D74797065004C4F43414C002D6A00444F434B45520000002D2D647374003132372E302E302E302F38
Nov 26 17:22:22 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=11
Nov 26 17:22:22 okmx8mm audit[3642]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=3e7697c0 items=0 ppid=3509 pid=3642 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:22 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6F00646F636B657230002D6A00444F434B4552
Nov 26 17:22:22 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=12
Nov 26 17:22:22 okmx8mm audit[3644]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=fc048f0 items=0 ppid=3509 pid=3644 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:22 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6F00646F636B657230002D6D00636F6E6E747261636B002D2D637473746174650052454C415445442C45535441424C4953484544002D6A00414343455054
Nov 26 17:22:22 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=13
Nov 26 17:22:22 okmx8mm audit[3646]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=320edc50 items=0 ppid=3509 pid=3646 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:22 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6A00444F434B45522D49534F4C4154494F4E
Nov 26 17:22:22 okmx8mm avahi-daemon[3320]: Joining mDNS multicast group on inte**ce docker0.IPv4 with address 172.17.0.1.
Nov 26 17:22:22 okmx8mm avahi-daemon[3320]: New relevant inte**ce docker0.IPv4 for mDNS.
Nov 26 17:22:22 okmx8mm avahi-daemon[3320]: Registering new address record for 172.17.0.1 on docker0.IPv4.
Nov 26 17:22:22 okmx8mm dockerd[3509]: time="2019-11-26T17:22:22.725535000+08:00" level=info msg="Removing stale sandbox 7dbf5157052f7c12bb3a3fa3148d5a263c976a1aed066977a0a719257f5a6eb0 (d087cd0be2634034d92c40c1cc11f0fc3e469d682db88dc954262d52c7c81be8)"
Nov 26 17:22:22 okmx8mm dockerd[3509]: time="2019-11-26T17:22:22.740842500+08:00" level=warning msg="Error (Unable to complete atomic operation, key modified) deleting object [endpoint 8ac0274afcbe01cca43b3f7e208e2404b35b9e6b9498b95ed281a1e53c82f135 71884ad64f352b68db1b3e9547a74044820f85e666d25c911cd0863a882e2214], retrying...."
Nov 26 17:22:22 okmx8mm dockerd[3509]: time="2019-11-26T17:22:22.987811125+08:00" level=info msg="Removing stale sandbox a1eb9f597d31e81fa0c3b551d14c477b2a09dbcc020321ae66ba29911b553a24 (1d5d437e578d96ff1c397f8a378d66d4a898c0cfd3b83c89b2f42ad9b8ae0ed5)"
Nov 26 17:22:22 okmx8mm dockerd[3509]: time="2019-11-26T17:22:22.995349500+08:00" level=warning msg="Error (Unable to complete atomic operation, key modified) deleting object [endpoint 8ac0274afcbe01cca43b3f7e208e2404b35b9e6b9498b95ed281a1e53c82f135 c78576eebe9b1c3018bcf199cd8042fd5833e9cd775a58f5be2b79a5c9dc0785], retrying...."
Nov 26 17:22:23 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=11
Nov 26 17:22:23 okmx8mm audit[3683]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=37773050 items=0 ppid=3509 pid=3683 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:23 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4400504F5354524F5554494E47002D73003137322E31372E302E302F31360000002D6F00646F636B657230002D6A004D415351554552414445
Nov 26 17:22:23 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=10
Nov 26 17:22:23 okmx8mm audit[3685]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=14900860 items=0 ppid=3509 pid=3685 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:23 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4400444F434B4552002D6900646F636B657230002D6A0052455455524E
Nov 26 17:22:23 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=14
Nov 26 17:22:23 okmx8mm audit[3687]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=1caf1e60 items=0 ppid=3509 pid=3687 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:23 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4400464F5257415244002D6900646F636B657230002D6F00646F636B657230002D6A00414343455054
Nov 26 17:22:23 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=13
Nov 26 17:22:23 okmx8mm audit[3689]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=3b9decf0 items=0 ppid=3509 pid=3689 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:22:23 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4400464F5257415244002D6900646F636B6572300000002D6F00646F636B657230002D6A00414343455054
Nov 26 17:23:10 okmx8mm systemd-timesyncd[3088]: Synchronized to time server 120.25.115.20:123 (ntp1.aliyun.com).
Nov 26 17:23:10 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=12
Nov 26 17:23:10 okmx8mm audit[3692]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=263f6b70 items=0 ppid=3509 pid=3692 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:23:10 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4400464F5257415244002D6F00646F636B657230002D6A00444F434B4552
Nov 26 17:23:10 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=11
Nov 26 17:23:10 okmx8mm audit[3695]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=3ecefa80 items=0 ppid=3509 pid=3695 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:23:10 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4400464F5257415244002D6F00646F636B657230002D6D00636F6E6E747261636B002D2D637473746174650052454C415445442C45535441424C4953484544002D6A00414343455054
Nov 26 17:23:10 okmx8mm dockerd[3509]: time="2019-11-26T17:23:10.710677657+08:00" level=info msg="Default bridge (docker0) is assigned with an IP address 172.17.0.0/16. Daemon option --bip can be used to set a preferred IP address"
Nov 26 17:23:10 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=9
Nov 26 17:23:10 okmx8mm audit[3697]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=3dc38c90 items=0 ppid=3509 pid=3697 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:23:10 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4900504F5354524F5554494E47002D73003137322E31372E302E302F31360000002D6F00646F636B657230002D6A004D415351554552414445
Nov 26 17:23:10 okmx8mm audit: NETFILTER_CFG table=nat family=2 entries=10
Nov 26 17:23:10 okmx8mm audit[3699]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=20eec7e0 items=0 ppid=3509 pid=3699 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:23:10 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4900444F434B4552002D6900646F636B657230002D6A0052455455524E
Nov 26 17:23:10 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=10
Nov 26 17:23:10 okmx8mm audit[3702]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=3c359650 items=0 ppid=3509 pid=3702 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:23:10 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6900646F636B657230002D6F00646F636B657230002D6A00414343455054
Nov 26 17:23:10 okmx8mm audit[3704]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=48c47c0 items=0 ppid=3509 pid=3704 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:23:10 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6900646F636B6572300000002D6F00646F636B657230002D6A00414343455054
Nov 26 17:23:10 okmx8mm audit[3710]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=2e1bd940 items=0 ppid=3509 pid=3710 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:23:10 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6F00646F636B657230002D6A00444F434B4552
Nov 26 17:23:10 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=13
Nov 26 17:23:10 okmx8mm audit[3712]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=13c28a60 items=0 ppid=3509 pid=3712 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:23:10 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6F00646F636B657230002D6D00636F6E6E747261636B002D2D637473746174650052454C415445442C45535441424C4953484544002D6A00414343455054
Nov 26 17:23:10 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=14
Nov 26 17:23:10 okmx8mm audit[3714]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=ae58e60 items=0 ppid=3509 pid=3714 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:23:10 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4400464F5257415244002D6A00444F434B45522D49534F4C4154494F4E
Nov 26 17:23:10 okmx8mm audit[3715]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=1724c50 items=0 ppid=3509 pid=3715 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:23:10 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6A00444F434B45522D49534F4C4154494F4E
Nov 26 17:23:11 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=14
Nov 26 17:23:11 okmx8mm audit[3717]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=3a368710 items=0 ppid=3509 pid=3717 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:23:11 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D740066696C746572002D4E00444F434B45522D55534552
Nov 26 17:23:11 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=16
Nov 26 17:23:11 okmx8mm audit[3719]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=6a7dfa0 items=0 ppid=3509 pid=3719 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:23:11 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4100444F434B45522D55534552002D6A0052455455524E
Nov 26 17:23:11 okmx8mm audit: NETFILTER_CFG table=filter family=2 entries=17
Nov 26 17:23:11 okmx8mm audit[3721]: SYSCALL arch=c00000b7 syscall=208 success=yes exit=0 a0=4 a1=0 a2=40 a3=1cf30110 items=0 ppid=3509 pid=3721 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-multi" key=(null)
Nov 26 17:23:11 okmx8mm audit: PROCTITLE proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D6A00444F434B45522D55534552
Nov 26 17:23:11 okmx8mm dockerd[3509]: time="2019-11-26T17:23:11+08:00" level=info msg="shim docker-containerd-shim started" address="/containerd-shim/moby/d087cd0be2634034d92c40c1cc11f0fc3e469d682db88dc954262d52c7c81be8/shim.sock" debug=false module="containerd/tasks" pid=3730
Nov 26 17:23:11 okmx8mm dockerd[3509]: time="2019-11-26T17:23:11+08:00" level=info msg="shim docker-containerd-shim started" address="/containerd-shim/moby/1d5d437e578d96ff1c397f8a378d66d4a898c0cfd3b83c89b2f42ad9b8ae0ed5/shim.sock" debug=false module="containerd/tasks" pid=3737
Nov 26 17:23:11 okmx8mm dockerd[3509]: time="2019-11-26T17:23:11.714504407+08:00" level=info msg="Loading containers: done."
Nov 26 17:23:11 okmx8mm dockerd[3509]: time="2019-11-26T17:23:11.826727532+08:00" level=info msg="Docker daemon" commit=7390fc6 graphdriver(s)=overlay2 version=17.12.1-ce
Nov 26 17:23:11 okmx8mm dockerd[3509]: time="2019-11-26T17:23:11.827860907+08:00" level=info msg="Daemon has completed initialization"
Nov 26 17:23:11 okmx8mm dockerd[3509]: time="2019-11-26T17:23:11.885740407+08:00" level=info msg="API listen on /var/run/docker.sock"
Nov 26 17:23:11 okmx8mm systemd[1]: Started Docker Application Container Engine.
Nov 26 17:23:11 okmx8mm systemd[1]: Started helloworld.
Nov 26 17:23:11 okmx8mm systemd[1]: Reached target Multi-User System.
Nov 26 17:23:11 okmx8mm systemd[1]: Starting Update UTMP about System Runlevel Changes...
Nov 26 17:23:11 okmx8mm systemd[1]: Started Update UTMP about System Runlevel Changes.
Nov 26 17:23:11 okmx8mm systemd[1]: Startup finished in 3.878s (kernel) + 8.622s (userspace) = 12.501s.
Nov 26 17:23:12 okmx8mm helloworld.sh[3837]: Interactive keyboard handling in terminal not available.
Nov 26 17:23:12 okmx8mm helloworld.sh[3837]: Now playing /home/forlinx/audio/test.mp3
Nov 26 17:23:15 okmx8mm helloworld.sh[3837]: Prerolling...
Nov 26 17:23:15 okmx8mm helloworld.sh[3837]: ====== BEEP: 4.4.4 build on Jun 21 2019 06:49:05. ======
Nov 26 17:23:15 okmx8mm helloworld.sh[3837]:         Core: MP3 decoder Wrapper  build on Jan 11 2018 10:20:25
Nov 26 17:23:15 okmx8mm helloworld.sh[3837]:  file: /usr/lib/imx-mm/audio-codec/wrap/lib_mp3d_wrap_arm_elinux.so.3
Nov 26 17:23:15 okmx8mm helloworld.sh[3837]: CODEC: BLN_MAD-MMCODECS_MP3D_ARM_02.13.01_ARMV8  build on Jan 11 2018 10:05:45.
Nov 26 17:23:15 okmx8mm helloworld.sh[3837]: ===!!! Current pulsesink device is alsa_output.platform-sound.stereo-fallback !!!===
Nov 26 17:23:15 okmx8mm helloworld.sh[3837]: Redistribute latency...
Nov 26 17:24:07 okmx8mm systemd[1]: Created slice system-dropbear.slice.
Nov 26 17:24:07 okmx8mm systemd[1]: Started SSH Per-Connection Server (192.168.2.101:56908).
发表于 2019-11-27 09:27:11 | 显示全部楼层
这个得通过销售进行项目定制
GMT+8, 2026-9-14 01:43
