查看: 61421|回复: 1
[Linux] ./build.sh 失败, kernel make distclean,后面再./build.sh 再来一遍?
发表于 2019-12-29 11:35:26 | 显示全部楼层 |阅读模式
./build.sh 失败, arm-linux-gnueabihf-ld: error: drivers/soc/allwinner/pm/pm_debug.o uses VFP register arguments, drivers/soc/allwinner/pm/pm_tmp.o does not
arm-linux-gnueabihf-ld: failed to merge target specific data of file drivers/soc/allwinner/pm/pm_debug.o
make[4]: *** [drivers/soc/allwinner/pm/pm_tmp.o] Error 1
make[3]: *** [drivers/soc/allwinner/pm] Error 2
make[2]: *** [drivers/soc/allwinner] Error 2
make[1]: *** [drivers/soc] Error 2
make: *** [drivers] Error 2
ERROR: build kernel Failed
后面再./build.sh的话,很容易出现上述问题(我这边出现3次了),
那不是说,只要小改一点代码,都很可能要make  distclean,再来一遍,这个时间,长。。。
 楼主| 发表于 2019-12-29 11:59:19 | 显示全部楼层
发现点技巧:
(1)有时重启虚拟机,再./build.sh可以
(2)有时./build.sh clean,再./build.sh可以
GMT+8, 2026-9-21 06:17
