查看: 74087|回复: 11
[Linux] SPI1上加两个74x595可以吗?
i.MX6Q通行证i.MX6UL通行证RK3568通行证RK3399通行证
发表于 2020-3-9 22:32:01 | 显示全部楼层 |阅读模式
在spi1上加两个595,同spi4 一样的,怎么更改设备树呀?
        spi4 {
                compatible = "spi-gpio";
                pinctrl-names = "default";
                pinctrl-0 = <&pinctrl_spi4>;
                pinctrl-assert-gpios = <&gpio5 8 GPIO_ACTIVE_LOW>;
                status = "okay";
                gpio-sck = <&gpio5 11 0>;
                gpio-mosi = <&gpio5 10 0>;
                cs-gpios = <&gpio5 7 0>;
                num-chipselects = <1>;
                #address-cells = <1>;
                #size-cells = <0>;
                gpio_spi: gpio_spi@0 {
                        compatible = "fairchild,74hc595";
                        gpio-controller;
                        #gpio-cells = <2>;
                        reg = <0>;
                        registers-number = <1>;
                        registers-default = /bits/ 8 <0xa7>;
                        spi-max-frequency = <100000>;
发表于 2020-3-10 08:59:01 | 显示全部楼层
先参考应用笔记添加spi1,再参考spi4添加74hc595
 楼主| 发表于 2020-3-10 09:33:51 | 显示全部楼层
registers-default = /bits/ 16 <0x00a7>;
因为我是两片,这个地方是不是要改成16?
我用 cat /sys/kernel/debug/gpio,怎么是空的,查不到gpio
发表于 2020-3-10 09:50:08 | 显示全部楼层
路径应该是/sys/class/gpio/吧,ls /sys/class/gpio/查看
 楼主| 发表于 2020-3-10 22:23:17 | 显示全部楼层
root@freescale ~$ mount -t debugfs none /sys/kernel/debug
root@freescale ~$  cat /sys/kernel/debug/gpio
GPIOs 0-31, platform/209c000.gpio, 209c000.gpio:
gpio-9   (led2                ) out lo
gpio-19  (2190000.usdhc cd    ) in  hi
GPIOs 32-63, platform/20a0000.gpio, 20a0000.gpio:
GPIOs 64-95, platform/20a4000.gpio, 20a4000.gpio:
gpio-66  (usb_otg1_vbus       ) out lo
GPIOs 96-127, platform/20a8000.gpio, 20a8000.gpio:
GPIOs 128-159, platform/20ac000.gpio, 20ac000.gpio:
gpio-128 (GTP RST PORT        ) in  hi
gpio-129 (GTP INT IRQ         ) in  hi
gpio-131 (?                   ) out lo
gpio-133 (heartbeat           ) out lo
gpio-135 (spi32766.0          ) out lo
gpio-136 (?                   ) out lo
gpio-137 (led1                ) out lo
gpio-138 (spi4.15             ) out lo
gpio-139 (spi4.15             ) out lo
GPIOs 248-255, spi/spi32766.0, 74hc595, can sleep:
挂载后能看到GPIO的信息了,可我的SPI1下接的595没有看到,我的设备树是这样改的
        spi4 {
                pinctrl-assert-gpios = <&gpio5 8 GPIO_ACTIVE_LOW>;   //NOE
                status = "okay";
                gpio-sck = <&gpio5 11 0>;    //SHCP
                gpio-mosi = <&gpio5 10 0>;   //SDI
                cs-gpios = <&gpio5 7 0>;     //STCP
                #size-cells = <0>;
                        gpio-controller;
                        #gpio-cells = <2>;
                        reg = <0>;
        /*新增GPIO SPI1*/
        spi1 {
                pinctrl-0 = <&pinctrl_spi1>;
                //pinctrl-assert-gpios = <&gpio5 8 GPIO_ACTIVE_LOW>;    OE固定接低
                status = "okay";
                gpio-sck = <&gpio4 25 0>;
                gpio-mosi = <&gpio4 27 0>;
                cs-gpios = <&gpio4 26 0>;
                #size-cells = <0>;
                gpio_spi1: gpio_spi1@0 {
                        gpio-controller;
                        #gpio-cells = <2>;
                        reg = <0>;
        /*新增GPIO SPi1*/
        pinctrl_spi1: spi1grp {
                        fsl,pins = <
                                MX6UL_PAD_CSI_DATA06__GPIO4_IO27        0x70a1
                                MX6UL_PAD_CSI_DATA05__GPIO4_IO26        0x70a1
                                MX6UL_PAD_CSI_DATA04__GPIO4_IO25        0x70a1
                                MX6UL_PAD_CSI_DATA07__GPIO4_IO28        0x70a1
发表于 2020-3-11 08:41:29 | 显示全部楼层
参考应用笔记  去掉SN74HC595芯片,以其中的修改为参考添加芯片
 楼主| 发表于 2020-3-11 21:53:28 | 显示全部楼层
:@:@:@怎么又成去掉了,我是想在SPI1上再加两块595,不是去掉SPI4上的595
发表于 2020-3-12 09:05:16 | 显示全部楼层
只是参考改动了哪些位置,另外,您看看您使用的引脚是否在其他地方复用,595芯片是否接好
 楼主| 发表于 2020-3-12 09:47:56 | 显示全部楼层
能看一下5#我发的配置吗?
 楼主| 发表于 2020-3-12 09:49:23 | 显示全部楼层
问题总没有回答在点上,答非所问的感觉:funk:
发表于 2020-3-12 17:39:50 | 显示全部楼层
您可参考已有程序自行调试,可以用示波器测量各引脚状态,判断哪里有问题
 楼主| 发表于 2020-3-14 14:57:27 | 显示全部楼层
服务确实垃圾,早知道用米尔了
GMT+8, 2026-9-21 10:34
