查看: 118535|回复: 13
[Linux] OKMX6Q的wifi问题
发表于 2020-3-10 15:48:29 | 显示全部楼层 |阅读模式
root@freescale /root$ ./wifi.sh -i 8723 -s OKMX -p 12345678
wifi 8723
ssid OKMX
pasw 12345678
ps: invalid option -- 'f'
BusyBox v1.20.2 (2015-07-01 11:39:37 CST) multi-call binary.
Usage: ps
Show list of processes
This version of ps accepts no options
        l       Long output
        T       Show threads
Successfully initialized wpa_supplicant
RTL871X: set bssid:00:00:00:00:00:00
ioctl[SIOCSIWAP]: Operation not pRTL871X: set ssid [g苅sQ
发表于 2020-3-12 14:23:56 | 显示全部楼层
ln -s /media/mmcblk0p1/ntp/ntp/Shanghai  /etc/localtime
把附件Shanghai 链接到 /etc/localtime
Shanghai.zip
355 Bytes, 下载次数: 5, 下载积分: 贡献 1
此方法可行,已经解决,谢谢  详情 回复 发表于 2020-3-12 15:14
点评回复 支持 1 反对 0
 楼主| 发表于 2020-3-10 15:54:10 | 显示全部楼层
ioctl[SIOCGIWSCAN]: Resource temporarily unavailable
RTL871X: indicate disassoc
wlan0: Trying to associate with aRTL871X: set ssid [OKMX] fw_state=0x00000008
8:7d:12:2b:6b:f5 (SSID='OKMX' freRTL871X: set bssid:a8:7d:12:2b:6b:f5
q=2437 MHz)
RTL871X: start auth
udhcpc (v1.20.2) started
Sending discover...
wlan0: CTRL-EVENT-DISCONNECTED bssid=a8:7d:12:2b:6b:f5 reason=0
Sending discover...
q=2437 MHz)
RTL871X: start auth
RTL871X: auth success, start assoc
RTL871X: OnDeAuth(wlan0) reason=2, ta=a8:7d:12:2b:6b:f5, ignore=1
Sending discover...
q=2437 MHz)
RTL871X: start auth
RTL871X: assoc success
wlan0: Associated with a8:7d:12:2b:6b:f5
RTL871X: send eapol packet
RTL871X: set pairwise key camid:4, addr:a8:7d:12:2b:6b:f5, kid:0, type:AES
wlan0: WPA: Key negotiation completed with a8:7d:12:2b:6b:f5 [PTKRTL871X: set gr
oup key camid:5, addr:a8:7d:12:2b:6b:f5, kid:1, type:AES
=CCMP GTK=CCMP]
wlan0: CTRL-EVENT-CONNECTED - Connection to a8:7d:12:2b:6b:f5 completed [id=0 id
_str=]
root@freescale /root$ RTL871X: set bssid:00:00:00:00:00:00
?X%]X閊垣餐茮碩倀A!=車媇 fw_state=0x00000008[f2
ermitted
wlan0: CTRL-EVENT-DISCONNECTED bssid=a8:7d:12:2b:6b:f5 reason=3 locally_generate
d=1
测试完4G后,在测试wifi就连接不上了,之前正常。
请大神支招,谢谢!
发表于 2020-3-10 16:07:02 | 显示全部楼层
目前4G和wifi不能同时使用,会优先使用wifi,您看看是否是开着以太网,以太网优先级最高,或者看看天线是否正常,是否卸载了模块
发表于 2020-3-11 17:32:39 | 显示全部楼层
请问将utc时间转cst时间怎么修改,有没有类似zoneinfo这样的配置文件?
发表于 2020-3-11 18:14:45 | 显示全部楼层
发表于 2020-3-12 09:24:30 | 显示全部楼层
您看一下https://blog.csdn.net/fervent/article/details/68962196,仅供参考,具体修改以开发板实际内容为准
主要是fcu1201上没有sysconfig,localtime这样的文件  详情 回复 发表于 2020-3-12 10:43
发表于 2020-3-12 10:43:51 | 显示全部楼层
zhichao 发表于 2020-3-12 09:24
您看一下https://blog.csdn.net/fervent/article/details/68962196,仅供参考,具体修改以开发板实际内容为 ...
主要是fcu1201上没有sysconfig,localtime这样的文件:'(
发表于 2020-3-12 15:14:14 | 显示全部楼层
此方法可行,已经解决,谢谢
发表于 2020-3-12 15:39:46 | 显示全部楼层
你好,请问fcu1201有没有eeprom,产品序列号我们应该如何读写?可以自己定义序列号吗?
发表于 2020-3-12 17:42:49 | 显示全部楼层
fcu1201没有eeprom,您说的序列号是什么号
产品序列号  详情 回复 发表于 2020-3-12 18:50
发表于 2020-3-12 18:50:57 | 显示全部楼层
产品序列号
发表于 2020-3-13 08:34:39 | 显示全部楼层
这个您应该是改不了
发表于 2020-3-13 09:17:13 | 显示全部楼层
好的,谢谢
GMT+8, 2026-10-4 13:20
