查看: 21078|回复: 3
[Ubuntu] 不能用U盘烧写
LS1043A\46A通行证
发表于 2020-3-26 09:38:56 | 显示全部楼层 |阅读模式
U-Boot 2018.03 (Aug 15 2019 - 02:30:28 +0000)
SoC:  LS1046AE Rev1.0 (0x87070010)
Clock Configuration:
       CPU0(A72):1800 MHz  CPU1(A72):1800 MHz  CPU2(A72):1800 MHz
       CPU3(A72):1800 MHz
       Bus:      700  MHz  DDR:      2100 MT/s  FMAN:     800  MHz
       00000000: 0e150012 10000000 00000000 00000000
       00000010: 10405559 40005012 40025000 c1000000
       00000020: 00000000 00000000 00000000 00238802
       00000030: 20044500 00001102 00000096 00000001
Model: OK1046-C
Board: LS1046ARDB, boot from QSPI
SERDES Reference Clocks:
SD1_CLK1 = 100.00MHZ, SD1_CLK2 = 156.25MHZ
SD2_CLK1 = 100.00MHZ, SD2_CLK2 = 100.00MHZ
I2C:   ready
DRAM:  Initialzing DDR using fixed setting
Configuring DDR for 2100 MT/s data rate
1.9 GiB (DDR4, 32-bit, CL=15, ECC off)
DS2460 OK
SEC0: RNG instantiated
PPA Firmware: Version LSDK-18.06-Forlinx
SEC Firmware: 'loadables' present in config
loadables: 'trustedOS@1'
Using SERDES1 Protocol: 4160 (0x1040)
Using SERDES2 Protocol: 21849 (0x5559)
MMC:   FSL_SDHC: 0
Loading Environment from SPI Flash... SF: Detected n25q128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB
OK
In:    serial
Out:   serial
Err:   serial
SATA link 0 timeout.
AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
flags: 64bit ncq pm clo only pmp fbss pio slum part ccc apst
Found 0 device(s).
SCSI:  Net:   SF: Detected n25q128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB
Fman1: Uploading microcode version 106.4.18
PCIe0: pcie@3400000 Root Complex: no link
PCIe1: pcie@3500000 Root Complex: no link
PCIe2: pcie@3600000 Root Complex: no link
FM1@DTSEC1, FM1@DTSEC3 [PRIME], FM1@DTSEC4, FM1@DTSEC5, FM1@DTSEC6, FM1@DTSEC10, FM1@TGEC1
starting USB...
USB0:   Register 200017f NbrPorts 2
Starting the controller
USB XHCI 1.00
USB1:   Register 200017f NbrPorts 2
USB XHCI 1.00
USB2:   Register 200017f NbrPorts 2
USB XHCI 1.00
scanning bus 0 for devices... WARN halted endpoint, queueing URB anyway.
Unexpected XHCI event TRB, skipping... (fbc7c1b0 00000000 13000000 01008401)
BUG at /home/zyh/workspace/RELEASE/OK10xx-linux-fs/flexbuild/packages/firmware/OK10xx-linux-uboot/drivers/usb/host/xhci-ring.c:496/abort_td()!
BUG!
resetting ...
       CPU3(A72):1800 MHz
Model: OK1046-C
I2C:   ready
DS2460 OK
MMC:   FSL_SDHC: 0
OK
In:    serial
Out:   serial
Err:   serial
Found 0 device(s).
starting USB...
USB XHCI 1.00
USB XHCI 1.00
USB XHCI 1.00
发表于 2020-3-26 10:39:14 | 显示全部楼层
能把您的操作过程发一下吗,这些打印信息看不出哪里有问题
=> run usb_boot Device 0: Vendor: aigo Rev: 1100 Prod: MiniKing Type: Removable Hard Disk Capacity: 15100.0 MB = 14.7 GB (30924800 x 512) ... is now current  详情 回复 发表于 2020-3-26 10:55
LS1043A\46A通行证
 楼主| 发表于 2020-3-26 10:55:11 | 显示全部楼层
=> run usb_boot
... is now current device
Scanning usb 0:4...
Found U-Boot script /ls1046ardb_update.scr
365 bytes read in 20 ms (17.6 KiB/s)
## Executing script at 80000000
** Invalid partition 1 **
Wrong Image Format for bootm command
ERROR: can't get kernel image!
SCRIPT FAILED: continuing...
Found U-Boot script /boot/ls1046ardb_boot.scr
886 bytes read in 35 ms (24.4 KiB/s)
** Invalid partition 3 **
** Invalid partition 2 **
Bad Linux ARM64 Image magic!
发表于 2020-3-26 13:45:04 | 显示全部楼层
您用的U盘是手册上说的U 盘的第一个分区为 FAT32 且大于 4G吗
您换个U盘试试吧
GMT+8, 2026-10-4 10:31
