查看: 18473|回复: 2
[Android] OK4418连网问题
发表于 2020-5-12 16:13:45 | 显示全部楼层 |阅读模式
您好,我于上个月采购了一块贵公司的OK4418C开发板,Wifi连网正常,用speedtest软件测试,速度可以高达50M(我司为100/40M宽频),但因客户条件无法使用无线网路,在测试有线网路碰到相当的困难,因为个人初次接触Android开发板,经打转了好机个星期了,只好硬着头来请教,还望您不吝赐教。目前使用20190725的镜像,碰到的问题如下:1.开机后eth0的DHCP正常启动,ping区域网路与外部网路都ping的到,但lose都在30%以上2.浏览器无法连网(但改用Wifi测试时就正常)3.网线断开在重新插上后,eth0就无法连线了,ip也无法获取我司都是软体开发人员,但对于Android系统非常陌生,提出这些外行问题,让您见笑了,还望您多帮忙
发表于 2020-5-13 16:09:36 | 显示全部楼层
您可以先用网线将开发板和电脑直接连接,看是否还会丢包。如果还有丢包现象,考虑网线问题或者开发板硬件问题。
 楼主| 发表于 2020-5-14 09:56:14 | 显示全部楼层
root@s5p4418_drone:/ # ping 192.168.0.143
PING 192.168.0.143 (192.168.0.143) 56(84) bytes of data.
64 bytes from 192.168.0.143: icmp_seq=9 ttl=128 time=30.3 ms
64 bytes from 192.168.0.143: icmp_seq=21 ttl=128 time=6.88 ms
64 bytes from 192.168.0.143: icmp_seq=24 ttl=128 time=17.9 ms
64 bytes from 192.168.0.143: icmp_seq=30 ttl=128 time=5.32 ms
64 bytes from 192.168.0.143: icmp_seq=32 ttl=128 time=16.6 ms
^C
--- 192.168.0.143 ping statistics ---
33 packets transmitted, 5 received, 84% packet loss, time 32006ms
rtt min/avg/max/mdev = 5.323/15.428/30.381/9.016 ms
PING 192.168.0.1 (192.168.0.1) 56(84) bytes of data.
64 bytes from 192.168.0.1: icmp_seq=4 ttl=64 time=1.02 ms
64 bytes from 192.168.0.1: icmp_seq=22 ttl=64 time=0.876 ms
64 bytes from 192.168.0.1: icmp_seq=31 ttl=64 time=0.969 ms
^C
--- 192.168.0.1 ping statistics ---
41 packets transmitted, 3 received, 92% packet loss, time 40002ms
rtt min/avg/max/mdev = 0.876/0.957/1.028/0.072 ms
root@s5p4418_drone:/ # ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=17 ttl=55 time=4.86 ms
64 bytes from 8.8.8.8: icmp_seq=20 ttl=55 time=4.11 ms
64 bytes from 8.8.8.8: icmp_seq=24 ttl=55 time=3.30 ms
64 bytes from 8.8.8.8: icmp_seq=31 ttl=55 time=7.10 ms
64 bytes from 8.8.8.8: icmp_seq=38 ttl=55 time=6.87 ms
64 bytes from 8.8.8.8: icmp_seq=40 ttl=55 time=5.54 ms
^C
--- 8.8.8.8 ping statistics ---
40 packets transmitted, 6 received, 85% packet loss, time 39004ms
rtt min/avg/max/mdev = 3.309/5.301/7.106/1.377 ms
感谢前辈回应。这两个星期所有网路硬体软体都有尝试过了,虽然Android的应用软件都经完成测试,但公司经过考量到我们自身开发能力不足,又欠缺资源的情况下,还是决定用原来的win7PE+PC。虽然成本较高,毕竟五六十台设备出货以后,后续的维护人力与公司信誉问题,价值应该超过这省下的十几万。
GMT+8, 2026-9-29 08:01
