查看: 60540|回复: 3
[Linux] OKMX6UL 256M nand flash 关于QT5
LS1043A\46A通行证LS1028A通行证i.MX6UL通行证
发表于 2020-5-17 12:33:55 | 显示全部楼层 |阅读模式
如题 OKMX6UL 256M nand flash 当前是否支持QT5?
SD卡制作脚本是否支持32gSD卡?
 楼主| 发表于 2020-5-17 13:10:30 | 显示全部楼层
制作SD卡无反应
log如下:
root@ubuntu:/home/ubuntu/Desktop/imx6ul+qt4/Linux/工具/SD/烧写/256Mnand# ./createSdcard.sh
This script will create a bootable SD card from custom or pre-built binaries.
The script must be run with root permissions and from the bin directory of
the SDK
Example:
$ sudo ./create-sdcard.sh
Formatting can be skipped if the SD card is already formatted and
partitioned properly.
1:   8       16   30228480 sdb
Enter Device Number: 1
sdb was selected
                **********WARNING**********
        Selected Device is greater then 16GB
        Continuing past this point will erase data from device
        Double check that this is the correct SD Card
Would you like to continue [y/n] : y
Checking the device is unmounted
sdb1  sdb2   sdb3
SD Card is not correctly partitioned
                Now ** 1 partitions
记录了1+0 的读入
记录了1+0 的写出
1024 bytes (1.0 kB, 1.0 KiB) copied, 0.00328148 s, 312 kB/s
DISK SIZE - 30953963520 bytes
sfdisk: unsupported unit 'M'
                Partitioning Boot
mkfs.fat 3.0.28 (2015-05-16)
/dev/sdb1: No such file or directory
Mount the partitions
mount: special device /dev/sdb1 does not exist
Emptying partitions
        Copying files now... will take minutes
Copying boot partition
untar update.tar.bz2 to boot partition
sdrun/
sdrun/imx6ul-14x14-evk.dtb
sdrun/ramdisk.img.u
sdrun/zImage
sdrun/u-boot.imx
target/
target/imx6ul-14x14-evk-gpmi-c-256m-10.4-r.dtb
target/imx6ul-14x14-evk-gpmi-c-256m-10.1-1280x800.dtb
target/imx6ul-14x14-evk-gpmi-c-256m-8-r.dtb
target/imx6ul-14x14-evk-gpmi-c-256m-7-800x480.dtb
target/zImage
target/imx6ul-14x14-evk-gpmi-c-256m-7-1024x600.dtb
target/imx6ul-14x14-evk-gpmi-c-256m-4.3-r.dtb
target/imx6ul-14x14-evk-gpmi-c-256m-3.5-r.dtb
target/u-boot.imx
target/imx6ul-14x14-evk-gpmi-c-256m-5.6-r.dtb
target/logo.bmp
target/rootfs.tar.bz2
target/modules.tar.bz2
Buring th u-boot.imx to sdcard
记录了129+0 的读入
记录了129+0 的写出
132096 bytes (132 kB, 129 KiB) copied, 0.0441671 s, 3.0 MB/s
记录了319+0 的读入
记录了319+0 的写出
326656 bytes (327 kB, 319 KiB) copied, 0.0903524 s, 3.6 MB/s
Syncing....
Un-mount the partitions
umount: boot: not mounted
Operation Finished
发表于 2020-5-18 08:43:23 | 显示全部楼层
256M nandflash的linux4.1.15系统是console 文件系统,不含qt。
制卡不成功,您使用的我们提供的开发环境吗,高版本的开发环境可能要改制卡脚本
 楼主| 发表于 2020-7-26 00:51:18 | 显示全部楼层
制卡不成功
GMT+8, 2026-10-4 13:19
