查看: 31123|回复: 2
[Linux] RK3399对OV13850摄像头支持的最高分辨率是多少?
RK3399通行证
发表于 2020-12-20 17:43:27 | 显示全部楼层 |阅读模式
通过v4l2-ctl --list-formats-ext -d /dev/video1命令查看摄像头设备信息,如下
  1. ioctl: VIDIOC_ENUM_FMT
  2.         Type: Video Capture Multiplanar
  3.         [0]: 'YUYV' (YUYV 4:2:2)
  4.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  5.         [1]: '422P' (Planar YVU 4:2:2)
  6.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  7.         [2]: 'NV16' (Y/CbCr 4:2:2)
  8.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  9.         [3]: 'NV61' (Y/CrCb 4:2:2)
  10.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  11.         [4]: 'YM16' (Planar YUV 4:2:2 (N-C))
  12.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  13.         [5]: 'NV21' (Y/CrCb 4:2:0)
  14.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  15.         [6]: 'NV12' (Y/CbCr 4:2:0)
  16.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  17.         [7]: 'NM21' (Y/CrCb 4:2:0 (N-C))
  18.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  19.         [8]: 'NM12' (Y/CbCr 4:2:0 (N-C))
  20.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  21.         [9]: 'YU12' (Planar YUV 4:2:0)
  22.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  23.         [10]: 'YM24' (Planar YUV 4:4:4 (N-C))
  24.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  25.         [11]: 'RGGB' (8-bit Bayer RGRG/GBGB)
  26.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  27.         [12]: 'GRBG' (8-bit Bayer GRGR/BGBG)
  28.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  29.         [13]: 'GBRG' (8-bit Bayer GBGB/RGRG)
  30.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  31.         [14]: 'BA81' (8-bit Bayer BGBG/GRGR)
  32.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  33.         [15]: 'RG10' (10-bit Bayer RGRG/GBGB)
  34.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  35.         [16]: 'BA10' (10-bit Bayer GRGR/BGBG)
  36.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  37.         [17]: 'GB10' (10-bit Bayer GBGB/RGRG)
  38.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  39.         [18]: 'BG10' (10-bit Bayer BGBG/GRGR)
  40.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  41.         [19]: 'RG12' (12-bit Bayer RGRG/GBGB)
  42.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  43.         [20]: 'BA12' (12-bit Bayer GRGR/BGBG)
  44.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  45.         [21]: 'GB12' (12-bit Bayer GBGB/RGRG)
  46.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
  47.         [22]: 'BG12' (12-bit Bayer BGBG/GRGR)
  48.                 Size: Stepwise 32x16 - 2112x1568 with step 8/8
分辨率最高支持到2112x1568吗?
通过摄像头预览命令
gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-raw, format=NV12, width=640, height=480, framerate=30/1 ! waylandsink
其中width和height只能设置到1920,1080怎么回事?
发表于 2020-12-22 08:33:53 | 显示全部楼层
驱动部分没有支持这么高,目前工程师正在解决
RV1126通行证
发表于 2026-4-24 21:50:59 | 显示全部楼层
1126B带13850为啥黑色的  看不清东西
GMT+8, 2026-9-20 23:19
