查看: 41901|回复: 3
[Android] wifi无法使用
A40i/T3/T507/T527通行证T153通行证
发表于 2021-2-23 16:05:55 | 显示全部楼层 |阅读模式
移植AP6181wifi模块驱动打印如下:wlan0,无法配置,wifi无法使用,谁能指导一下a40-p1:/ # insmod /system/vendor/modules/bcmdhd.ko
[  798.670459] dhd_module_init: in
[  798.674101] ======== bcm_wlan_set_plat_data ========
[  798.679640] host_oob_irq: 165
[  798.683259] host_oob_irq_flags=0x4084
[  798.687292] dhd_wifi_platform_load: Enter
[  798.691920] Power-up adapter 'DHD generic adapter'
[  798.698203] wifi_platform_set_power = 1
[  798.702727] ======== PULL WL_REG_ON HIGH! ========
[  798.711029] sunxi-wlan wlan.23: check wlan wlan_power voltage: 3300000
[  798.720586] sunxi-wlan wlan.23: check wlan io_regulator voltage: 3300000
[  799.040289] wifi_platform_bus_enumerate device present 1
[  799.046340] sunxi-wlan wlan.23: bus_index: 1
[  799.051277] ======== Card detection to detect SDIO card! ========
[  799.750679] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[  799.808589] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[  799.817122] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[  799.827085] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[  799.837831] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[  799.847909] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[  799.870525] mmc2: new high speed SDIO card at address 0001
[  799.906228] bcmsdh_register: register client driver
[  799.912835] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[  799.918690] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[  799.924419] bus num (host idx)=2, slot num (rca)=1
[  799.929855] found adapter info 'DHD generic adapter'
[  799.936051] sdioh_attach: set sd_f2_blocksize 128
[  799.941967] dhdsdio_probe : no mutex held. set lock
[  799.947821] F1 signature read @0x18000000=0x1591a962
[  799.955544] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362
[  799.964885] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9
[  799.973471] DHD: dongle ram size is set to 245760(orig 245760) at 0x0
[  799.982023] dhd_conf_set_chiprev: chip=0xa962, chiprev=1
[  799.987913] dhd_conf_set_conf_path_by_nv_path: config_path=/system/vendor/modules/config.txt
[  800.001838] wl_create_event_handler(): thread:wl_event_handler:61d1 started
[  800.001866] tsk Enter, tsk = 0xe16a14a0
[  800.018977] dhd_attach(): thread:dhd_watchdog_thread:61d4 started
[  800.026333] dhd_attach(): thread:dhd_dpc:61d5 started
[  800.026349] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[  800.038780] dhd_attach(): thread:dhd_rxf:61d7 started
[  800.044705] dhd_deferred_work_init: work queue initialized
[  800.066710] Dongle Host Driver, version 1.201.59.6 (r506368)
[  800.066710] Compiled in drivers/net/wireless/bcmdhd on Feb 23 2021 at 14:27:29
[  800.095258] Register inte**ce [wlan0]  MAC: b0:02:47:3f:a2:9f
[  800.095258]
[  800.103806] dhd_prot_ioctl : bus is down. we have nothing to do
[  800.111162] bcmsdh_oob_intr_unregister: Enter
[  800.115970] bcmsdh_oob_intr_unregister: irq is not registered
[  800.122628] dhd_txglom_enable: enable 0
[  800.126828] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
[  800.133694] dhd_conf_set_txglom_params: txglom_bucket_size=0
[  800.140091] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=0
[  800.148713] dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0
[  800.155884] dhd_bus_devreset:  WLAN OFF DONE
[  800.160892] wifi_platform_set_power = 0
[  800.165102] ======== PULL WL_REG_ON LOW! ========
[  800.171700] dhdsdio_probe : the lock is released.
[  800.177646] dhd_module_init: Exit err=0
a40-p1:/ #
发表于 2021-2-24 09:00:34 | 显示全部楼层
您好,A40i android系统自带驱动和wifi固件不支持AP6181
 楼主| 发表于 2021-2-24 10:06:36 | 显示全部楼层
我知道,上次你回复我了,现在我在移植AP6181
 楼主| 发表于 2021-2-24 10:07:47 | 显示全部楼层
@tanglu 目前看,是扫卡成功了,但是ifconfig wlan0 up不成功
GMT+8, 2026-9-21 07:03
