查看: 38121|回复: 2
[Linux] hdmi输出闪频
RK3399通行证Hi3519A通信证i.MX6Q通行证
发表于 2021-2-24 14:52:11 | 显示全部楼层 |阅读模式
linux版本下,mipi屏有显示,接上hdmi屏显示
[root@rk3399:/userdata]# [ 5325.082972] dwhdmi-rockchip ff940000.hdmi: failed to
                                 get edid
sh: missing ]
[root@rk3399:/userdata]# [ 5325.093823] dw-mipi-dsi ff960000.dsi: final DSI-Link
bandwidth: 432 x 4 Mbps
sh: missing ]
[root@rk3399:/userdata]# [ 5325.691665] dwhdmi-rockchip ff940000.hdmi: failed to
get edid
sh: missing ]
[root@rk3399:/userdata]# [ 5326.200903] dwhdmi-rockchip ff940000.hdmi: failed to
get edid
sh: missing ]
[root@rk3399:/userdata]# [ 5326.705034] dwhdmi-rockchip ff940000.hdmi: failed to
get edid
sh: missing ]
[root@rk3399:/userdata]# [ 5326.755580] rockchip-vop ff8f0000.vop: [drm:vop_crtc
_enable] Update mode to 1                                024x600p84, type: 16
sh: missing ]
[root@rk3399:/userdata]# [ 5326.756595] dw-mipi-dsi ff960000.dsi: final DSI-Link
sh: missing ]
[root@rk3399:/userdata]# [ 5326.940442] rockchip-vop ff900000.vop: [drm:vop_crtc
_enable] Update mode to 1                                280x720p60, type: 11
sh: missing ]
这个可能啥回事呢?
发表于 2021-2-25 08:38:52 | 显示全部楼层
这个是没有读到显示器的EDID,获取不到分辨率等信息。可以尝试更换能正常获取EDID的显示屏
 楼主| 发表于 2021-3-4 09:44:42 | 显示全部楼层
请问这个edid是普遍都应该有的吗?是否可以在驱动中把这个EDID校验去掉,这样是否也可以呢
GMT+8, 2026-10-8 15:58
