查看: 39960|回复: 6
[Ubuntu] ubuntu 磁盘空间不足问题
LS1012A通行证
发表于 2021-3-10 14:35:42 | 显示全部楼层 |阅读模式
你好! 我的是OK1012A的开发环境,
     我按照文档《OK1012A-C-1GHZ-Ubuntu-用户手册-V1.3-2020.05.25.pdf》的5.5节单独编译内核及模块,编译内核及模块;
   每编译一次,windows 下磁盘空间占用大2G,window10 下的硬盘空间快不足了
但是ubuntu 下看磁盘大小占用不变
   root@ubuntu:/home/forlinx/work/OK10xx-linux-fs/flexbuild# df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            1.4G     0  1.4G   0% /dev
tmpfs           281M  3.4M  278M   2% /run
/dev/sda1        98G   18G   76G  19% /
tmpfs           1.4G     0  1.4G   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           1.4G     0  1.4G   0% /sys/fs/cgroup
/dev/loop0       87M   87M     0 100% /snap/core/4917
/dev/loop1       56M   56M     0 100% /snap/core18/1944
/dev/loop3       13M   13M     0 100% /snap/gnome-characters/103
/dev/loop4      3.8M  3.8M     0 100% /snap/gnome-system-monitor/51
/dev/loop2       15M   15M     0 100% /snap/gnome-logs/37
/dev/loop5       90M   90M     0 100% /snap/core/6130
/dev/loop6      2.4M  2.4M     0 100% /snap/gnome-calculator/180
/dev/loop7       98M   98M     0 100% /snap/core/10583
/dev/loop8       35M   35M     0 100% /snap/gtk-common-themes/319
/dev/loop9       65M   65M     0 100% /snap/gtk-common-themes/1514
/dev/loop11     384K  384K     0 100% /snap/gnome-characters/570
/dev/loop10     141M  141M     0 100% /snap/gnome-3-26-1604/70
/dev/loop12     1.0M  1.0M     0 100% /snap/gnome-logs/100
/dev/loop13     141M  141M     0 100% /snap/gnome-3-26-1604/100
/dev/loop14     2.3M  2.3M     0 100% /snap/gnome-system-monitor/148
/dev/loop15      15M   15M     0 100% /snap/gnome-logs/45
/dev/loop16      35M   35M     0 100% /snap/gtk-common-themes/818
/dev/loop17     3.8M  3.8M     0 100% /snap/gnome-system-monitor/57
/dev/loop18      13M   13M     0 100% /snap/gnome-characters/139
/dev/loop19     141M  141M     0 100% /snap/gnome-3-26-1604/74
/dev/loop21     2.5M  2.5M     0 100% /snap/gnome-calculator/826
/dev/loop20     2.3M  2.3M     0 100% /snap/gnome-calculator/260
tmpfs           281M   16K  281M   1% /run/user/121
tmpfs           281M   28K  281M   1% /run/user/1000
怎么解决这个问题啊!
发表于 2021-3-10 15:13:15 | 显示全部楼层
可以给Vmware虚拟机清理瘦身,可以参考以下链接:
https://blog.csdn.net/hzf202/article/details/89316897?utm_medium=distribute.pc_relevant.none-task-blog-baidujs_baidulandingword-1&spm=1001.2101.3001.4242
ubuntu中看根本没有涨,不知道你们用的vm版本是多少,是不是和vm有关 oot@ubuntu:/# du -sh * 13M bin 73M boot 4.0K cdrom 0 dev 14M etc 10G home 0 initrd.img 0 initrd.img.old 556M lib 4.0K lib64  详情 回复 发表于 2021-3-10 17:47
按照方法做了,没有减少占用空间,每次编译内核都会增加,早上是占用76G 到现在已经是84G了  详情 回复 发表于 2021-3-10 17:45
LS1012A通行证
 楼主| 发表于 2021-3-10 17:45:23 | 显示全部楼层
https://blog.csdn.net/hzf202/article/details/8931689 ...
LS1012A通行证
 楼主| 发表于 2021-3-10 17:47:58 | 显示全部楼层
13M        bin
73M        boot
4.0K        cdrom
0        dev
14M        etc
10G        home
0        initrd.img
0        initrd.img.old
556M        lib
4.0K        lib64
16K        lost+found
8.0K        media
8.0K        mnt
4.0K        opt
du: cannot read directory 'proc/1775/task/1775/net': Invalid argument
du: cannot read directory 'proc/1775/net': Invalid argument
du: cannot access 'proc/2004/task/2004/fd/4': No such file or directory
du: cannot access 'proc/2004/task/2004/fdinfo/4': No such file or directory
du: cannot access 'proc/2004/fd/3': No such file or directory
du: cannot access 'proc/2004/fdinfo/3': No such file or directory
0        proc
60K        root
du: cannot access 'run/user/1000/gvfs': Permission denied
3.2M        run
12M        sbin
4.0K        srv
2.1G        swapfile
0        sys
88K        tmp
2.6G        usr
1.8G        var
0        vmlinuz
root@ubuntu:/#
djh
我用的VM15.0,你用的哪个版本啊?  详情 回复 发表于 2021-3-11 08:48
用这个方案解决问题:从86G降为24G 虚拟机内部执行 cat /dev/zero > zero.fill;sync;sleep 1;sync;rm -f zero.fill后关闭虚拟机 宿主win10机器上进入虚拟机文件目录执行 "C:\Program Files (x86)\VMware\VMware  详情 回复 发表于 2021-3-10 18:58
LS1012A通行证
 楼主| 发表于 2021-3-10 18:58:45 | 显示全部楼层
13M        bin
用这个方案解决问题:从86G降为24G
虚拟机内部执行
"C:\Program Files (x86)\VMware\VMware Workstation\vmware-vdiskmanager.exe" -k Ubuntu18.vmdk
发表于 2021-3-11 08:48:19 | 显示全部楼层
13M        bin
我用的VM15.0,你用的哪个版本啊?
VMware® Workstation 15 Pro 15.5.2 build-15785246  详情 回复 发表于 2021-3-25 14:08
LS1012A通行证
 楼主| 发表于 2021-3-25 14:08:00 | 显示全部楼层
djh 发表于 2021-3-11 08:48
我用的VM15.0,你用的哪个版本啊?
GMT+8, 2026-10-3 14:21
