查看: 29176|回复: 0
[Linux] sd卡分区
AM5718通行证i.MX6UL通行证
发表于 2021-3-22 22:58:46 | 显示全部楼层 |阅读模式
sd卡分区后,执行脚本 mksdcard.sh 出现警告:
        **********WARNING**********
        Selected Device is greater then 16GB
        Continuing past this point will erase data from device
        Double check that this is the correct SD Card
错误:
unmounting device '/dev/sdb1'
unmounting device '/dev/sdb2'
unmounting device '/dev/sdb3'
1024+0 records in
1024+0 records out
1048576 bytes (1.0 MB) copied, 0.707706 s, 1.5 MB/s
Disk /dev/sdb doesn't contain a valid partition table
DISK SIZE - 31914983424 bytes
mksdcard.sh: 151: [: 0: unexpected operator
mke2fs 1.42.9 (4-Feb-2014)
mksdcard.sh: 167: [: 0: unexpected operator
请问:如果从sd卡启动,超过16G的卡是不是不能用,另外贵公司能否提供SD卡分区的脚本用作参考
GMT+8, 2026-9-9 12:41
