查看: 14607|回复: 8
[Ubuntu] tf卡启动
i.MX8MP通行证LS1028A通行证AM62x资料下载
发表于 2021-4-1 16:44:55 | 显示全部楼层 |阅读模式
tf卡启动,烧写dp2lvds firmware 出错
 楼主| 发表于 2021-4-1 16:46:20 | 显示全部楼层
 楼主| 发表于 2021-4-1 16:47:27 | 显示全部楼层
[erase qspi]
Erasi@ 44omlete.as0 - 26% complete.ra 64 Kibyte0000 - 27% c.asig 64 Kibyte @ 4700 comasing 64 Kibyte  480000 - 28% complete.ErnKibyte @ 49028% complete.a64 Kibyte @ aeg  asng4 Kibyte @ 4E0 70% complete.rasing 64 Kibyt000 - 71% comsg 64 Kibyte @ 0- 71% complete.Eraing 64 Kiyte 0 - 71% complete.a  0000 - 7omplete.rasin 64 Kibyte@ ba0000 - 2% coplete.rasinge @ bb0000 73% @Esby 9 complet.rasingte @ ff0000 - 99% complete.it0=========e @ fb - 98% compltrsi00008% complete.rasgKi00 - 9
flashing, wait ...
0n============================================================
[emmc partition]
================================8recors n4+0 repart, done.
ormating, waitformat, doe.
flashing, wait...
start to update dp2lvds firmware
ChipID 1605
ld2001+1 records in
10240583 bytes (9.8MB) copied, 0.961066 seconds, 10.2MB/s
cp: can't stat '/mnt/boot/*'ch file ordir
djh
您能发一下完整的打印信息吗?  详情 回复 发表于 2021-4-1 17:22
发表于 2021-4-1 17:22:07 | 显示全部楼层
skyxiao6688 发表于 2021-4-1 16:47
[erase qspi]
Erasi@ 44omlete.as0 - 26% complete.ra 64 Kibyte0000 - 27% c.asig 64 Kibyte @ 4700 coma ...
您能发一下完整的打印信息吗?最好整理成TXT文档,感谢
root@forlinx:~# NOTICE: 2 GB DDR4, 32-bit, CL=11, ECC off NOTICE: BL2: v1.5(release):203f2cf8-dirty NOTICE: BL2: Built : 16:30:21, Sep 1 2020 NOTICE: BL31: v1.5(release):203f2cf8-dirty NOTI  详情 回复 发表于 2021-4-2 11:09
 楼主| 发表于 2021-4-2 11:09:47 | 显示全部楼层
root@forlinx:~#
NOTICE:  BL31: Built : 16:30:25, Sep  1 2020
NOTICE:  Welcome to LS1028 BL31 Phase
U-Boot 2019.10 (Apr 01 2021 - 10:03:18 +0800)
SoC:  LS1028A Rev1.0 (0x870b0110)
Clock Configuration:
       CPU0(A72):1500 MHz  CPU1(A72):1500 MHz
       Bus:      400  MHz  DDR:      1600 MT/s
       00000000: 3c004010 00000030 00000000 00000000
       00000010: 00000000 018f0000 0030c000 00000000
       00000020: 01e031a0 00002580 00000000 00008296
       00000030: 00000000 00000050 00000000 00000000
       00000040: 00000000 00000000 00000000 00000000
       00000050: 00000000 00000000 00000000 00000000
       00000060: 00000000 00000000 100e7014 00000000
       00000070: eb580000 03000000
Model: Forlinx OK1028A-C Board
Board: LS1028A Rev1.0-RDB, Version: A, boot from SD
SERDES1 Reference : Clock1 = 100.00MHz Clock2 = 100.00MHz
DRAM:  1.9 GiB
DDR    1.9 GiB (DDR4, 32-bit, CL=11, ECC off)
Using SERDES1 Protocol: 60248 (0xeb58)
PCIe0: pcie@3400000 disabled
PCIe1: pcie@3500000 Root Complex: no link
WDT:   Started with servicing (60s timeout)
Loading Environment from MMC... OK
In:    serial
Out:   serial
Err:   serial
Net:   eth0: enetc-0, eth2: enetc-2, eth4: swp0, eth5: swp1, eth6: swp2, eth7: swp3
Trying load HDP firmware from SD..
Device: FSL_SDHC
Manufacturer ID: 3
OEM: 5344
Bus Speed: 50000000
Mode: SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 59.5 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
MMC read: dev # 0, block # 18944, count 512 ... 512 blocks read: OK
Loading hdp firmware from 0x00000000a0000000 offset 0x0000000000002000
Loading hdp firmware Complete
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /ls1028ardb_update.scr
356 bytes read in 17 ms (19.5 KiB/s)
## Executing script at 80000000
18691344 bytes read in 802 ms (22.2 MiB/s)
## Loading kernel from FIT Image at a0000000 ...
   Using 'ls1028ardb' configuration
   Trying 'kernel' kernel subimage
     Description:  ARM64 Kernel
     Created:      2020-09-15  10:43:10 UTC
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0xa00000d0
     Data Size:    12940275 Bytes = 12.3 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x81080000
     Entry Point:  0x81080000
     Hash algo:    crc32
     Hash value:   76b28d9d
   Verifying Hash Integrity ... crc32+ OK
## Loading ramdisk from FIT Image at a0000000 ...
   Trying 'initrd' ramdisk subimage
     Description:  initrd for arm64
     Type:         RAMDisk Image
     Compression:  uncompressed
     Data Start:   0xa0c575a4
     Data Size:    5727647 Bytes = 5.5 MiB
     OS:           Linux
     Load Address: 0x00000000
     Entry Point:  0x00000000
     Hash algo:    crc32
     Hash value:   b34f65b3
## Loading fdt from FIT Image at a0000000 ...
   Trying 'ls1028ardb-dtb' fdt subimage
     Description:  ls1028ardb-dtb
     Type:         Flat Device Tree
     Data Start:   0xa11cdc28
     Data Size:    21394 Bytes = 20.9 KiB
     Load Address: 0x90000000
     Hash algo:    crc32
     Hash value:   23c9f38e
   Loading fdt from 0xa11cdc28 to 0x90000000
   Booting using the fdt blob at 0x90000000
   Uncompressing Kernel Image
   Using Device Tree in place at 0000000090000000, end 0000000090008391
WARNING could not find node fsl,vf610-edma: FDT_ERR_NOTFOUND.
WARNING could not find node fsl,sec-v4.0-job-ring: FDT_ERR_NOTFOUND.
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[    0.000000] Linux version 5.4.3 (root@6fe3c1c906cc) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04)) #1 SMP PREEMPT Tue Sep 15 10:20:55 UTC 2020
[    0.000000] Machine model: LS1028A RDB Board
[    0.000000] earlycon: uart8250 at MMIO 0x00000000021c0500 (options '')
[    0.000000] printk: bootconsole [uart8250] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x00000000e0000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x00000000fbdfffff]
[    0.000000] NUMA: NODE_DATA [mem 0xfba09800-0xfba0afff]
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000080000000-0x00000000fbdfffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fbdfffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000fbdfffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 24 pages/cpu s58904 r8192 d31208 u98304
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU inte**ce
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 499464
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: console=ttyS0,115200 earlycon=uart8250,mmio,0x21c0500 init=/sbin/init ramdisk_size=32768 root=/dev/ram0 rw rootwait cma=256M iommu.passthrough=1 arm-smmu.disable_bypass=0
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1683204K/2029568K available (18108K kernel code, 1352K rwdata, 6860K rodata, 2944K init, 966K bss, 84220K reserved, 262144K cma-reserved)
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=16 to nr_cpu_ids=2.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: no VLPI support, no direct LPI support
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000006040000
[    0.000000] ITS [mem 0x06020000-0x0603ffff]
[    0.000000] ITS@0x0000000006020000: allocated 65536 Devices @f9080000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000000f9030000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000f9040000
[    0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x458 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 25.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x5c409fb33, max_idle_ns: 440795203156 ns
[    0.000002] sched_clock: 56 bits at 25MHz, resolution 39ns, wraps every 4398046511103ns
[    0.008290] Console: colour dummy device 80x25
[    0.012811] Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=100000)
[    0.023264] pid_max: default: 32768 minimum: 301
[    0.027982] LSM: Security Framework initializing
[    0.032687] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.040162] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.072111] ASID allocator initialised with 32768 entries
[    0.085572] rcu: Hierarchical SRCU implementation.
[    0.098451] Platform MSI: gic-its@6020000 domain created
[    0.103871] PCI/MSI: /interrupt-controller@6000000/gic-its@6020000 domain created
[    0.111453] fsl-mc MSI: /interrupt-controller@6000000/gic-its@6020000 domain created
[    0.119405] EFI services will not be available.
[    0.131985] smp: Bringing up secondary CPUs ...
[    0.168709] Detected PIPT I-cache on CPU1
[    0.168726] GICv3: CPU1: found redistributor 1 region 0:0x0000000006060000
[    0.168732] GICv3: CPU1: using allocated LPI pending table @0x00000000f9050000
[    0.168750] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[    0.168797] smp: Brought up 1 node, 2 CPUs
[    0.197790] SMP: Total of 2 processors activated.
[    0.202537] CPU features: detected: 32-bit EL0 Support
[    0.207729] CPU features: detected: CRC32 instructions
[    0.222880] CPU: All CPU(s) started at EL2
[    0.227021] alternatives: patching kernel code
[    0.232180] devtmpfs: initialized
[    0.237540] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.247387] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.257746] xor: measuring software checksum speed
[    0.302632]    8regs     :  6358.000 MB/sec
[    0.346871]    32regs    :  6401.000 MB/sec
[    0.391110]    arm64_neon:  6348.000 MB/sec
[    0.395328] xor: using function: 32regs (6401.000 MB/sec)
[    0.400779] pinctrl core: initialized pinctrl subsystem
[    0.406449] DMI not present or invalid.
[    0.410496] NET: Registered protocol family 16
[    0.420233] DMA: preallocated 256 KiB pool for atomic allocations
[    0.426390] audit: initializing netlink subsys (disabled)
[    0.431908] audit: type=2000 audit(0.360:1): state=initialized audit_enabled=0 res=1
[    0.439733] cpuidle: using governor menu
[    0.443918] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.451027] Serial: AMBA PL011 UART driver
[    0.455192] imx mu driver is registered.
[    0.459153] imx rpmsg driver is registered.
[    0.464069] Machine: LS1028A RDB Board
[    0.467850] SoC family: QorIQ LS1028A
[    0.471538] SoC ID: svr:0x870b0110, Revision: 1.0
[    0.489636] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.496413] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.503191] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.509955] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.517937] cryptd: max_cpu_qlen set to 1000
[    0.591988] raid6: neonx8   gen()  3629 MB/s
[    0.664005] raid6: neonx8   xor()  3128 MB/s
[    0.736043] raid6: neonx4   gen()  3077 MB/s
[    0.808085] raid6: neonx4   xor()  2816 MB/s
[    0.880143] raid6: neonx2   gen()  2405 MB/s
[    0.952168] raid6: neonx2   xor()  2447 MB/s
[    1.024528] raid6: neonx1   gen()  1813 MB/s
[    1.096890] raid6: neonx1   xor()  1861 MB/s
[    1.169273] raid6: int64x8  gen()  1624 MB/s
[    1.241622] raid6: int64x8  xor()  1352 MB/s
[    1.313989] raid6: int64x4  gen()  1819 MB/s
[    1.386344] raid6: int64x4  xor()  1289 MB/s
[    1.458726] raid6: int64x2  gen()  1259 MB/s
[    1.531080] raid6: int64x2  xor()  1015 MB/s
[    1.603479] raid6: int64x1  gen()   894 MB/s
[    1.675833] raid6: int64x1  xor()   647 MB/s
[    1.680140] raid6: using algorithm neonx8 gen() 3629 MB/s
[    1.685586] raid6: .... xor() 3128 MB/s, rmw enabled
[    1.690594] raid6: using neon recovery algorithm
[    1.695501] ACPI: Interpreter disabled.
[    1.700796] iommu: Default domain type: Passthrough (set via kernel command line)
[    1.708428] vgaarb: loaded
[    1.711311] SCSI subsystem initialized
[    1.715295] usbcore: registered new inte**ce driver usbfs
[    1.720849] usbcore: registered new inte**ce driver hub
[    1.726233] usbcore: registered new device driver usb
[    1.731568] imx-i2c 2000000.i2c: can't get pinctrl, bus recovery not supported
[    1.739007] i2c i2c-0: IMX I2C adapter registered
[    1.743842] imx-i2c 2050000.i2c: can't get pinctrl, bus recovery not supported
[    1.751216] i2c i2c-1: IMX I2C adapter registered
[    1.756102] mc: Linux media inte**ce: v0.10
[    1.760424] videodev: Linux video capture inte**ce: v2.00
[    1.765995] pps_core: LinuxPPS API ver. 1 registered
[    1.771004] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.780228] PTP clock support registered
[    1.784243] EDAC MC: Ver: 3.0.0
[    1.787723] No BMan portals available!
[    1.791793] QMan: Allocated lookup table at (____ptrval____), entry count 65537
[    1.799243] No QMan portals available!
[    1.803119] No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree
[    1.809412] FPGA manager framework
[    1.812891] Advanced Linux Sound Architecture Driver Initialized.
[    1.819637] clocksource: Switched to clocksource arch_sys_counter
[    1.825885] VFS: Disk quotas dquot_6.6.0
[    1.829873] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.836900] pnp: PnP ACPI: disabled
[    1.843403] thermal_sys: Registered thermal governor 'step_wise'
[    1.843405] thermal_sys: Registered thermal governor 'power_allocator'
[    1.849695] NET: Registered protocol family 2
[    1.860926] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    1.869561] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.877625] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    1.885171] TCP: Hash tables configured (established 16384 bind 16384)
[    1.891815] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.898608] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.905893] NET: Registered protocol family 1
[    1.910551] RPC: Registered named UNIX socket transport module.
[    1.916533] RPC: Registered udp transport module.
[    1.921280] RPC: Registered tcp transport module.
[    1.926025] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.932734] PCI: CLS 0 bytes, default 64
[    1.936770] Trying to unpack rootfs image as initramfs...
[    1.942416] rootfs image is not initramfs (no cpio magic); looks like an initrd
[    1.959045] Freeing initrd memory: 5588K
[    1.963448] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    1.971853] kvm [1]: IPA Size Limit: 44bits
[    1.976451] kvm [1]: GICv3: no GICV resource entry
[    1.981289] kvm [1]: disabling GICv2 emulation
[    1.985786] kvm [1]: GIC system register CPU inte**ce enabled
[    1.991694] kvm [1]: vgic interrupt IRQ1
[    1.995712] kvm [1]: Hyp mode initialized successfully
[    2.002209] Initialise system trusted keyrings
[    2.006767] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[    2.013592] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.019618] NFS: Registering the id_resolver key type
[    2.024736] Key type id_resolver registered
[    2.028955] Key type id_legacy registered
[    2.033003] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.039776] jffs2: version 2.2. (NAND) &#169; 2001-2006 Red Hat, Inc.
[    2.046072] fuse: init (API version 7.31)
[    2.050182] 9p: Installing v9fs 9p2000 file system support
[    2.065369] Key type asymmetric registered
[    2.069505] Asymmetric key parser 'x509' registered
[    2.074451] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    2.081975] io scheduler mq-deadline registered
[    2.086550] io scheduler kyber registered
[    2.091798] pci-host-generic 1f0000000.pcie: host bridge /soc/pcie@1f0000000 ranges:
[    2.099642] pci-host-generic 1f0000000.pcie:   MEM 0x1f8000000..0x1f815ffff -> 0x00000000
[    2.107913] pci-host-generic 1f0000000.pcie:   MEM 0x1f8160000..0x1f81cffff -> 0x00000000
[    2.116178] pci-host-generic 1f0000000.pcie:   MEM 0x1f81d0000..0x1f81effff -> 0x00000000
[    2.124445] pci-host-generic 1f0000000.pcie:   MEM 0x1f81f0000..0x1f820ffff -> 0x00000000
[    2.132712] pci-host-generic 1f0000000.pcie:   MEM 0x1f8210000..0x1f822ffff -> 0x00000000
[    2.140976] pci-host-generic 1f0000000.pcie:   MEM 0x1f8230000..0x1f824ffff -> 0x00000000
[    2.149240] pci-host-generic 1f0000000.pcie:   MEM 0x1fc000000..0x1fc3fffff -> 0x00000000
[    2.157530] pci-host-generic 1f0000000.pcie: ECAM at [mem 0x1f0000000-0x1f00fffff] for [bus 00]
[    2.166369] pci-host-generic 1f0000000.pcie: PCI host bridge to bus 0000:00
[    2.173400] pci_bus 0000:00: root bus resource [bus 00]
[    2.178675] pci_bus 0000:00: root bus resource [mem 0x1f8000000-0x1f815ffff] (bus address [0x00000000-0x0015ffff])
[    2.189126] pci_bus 0000:00: root bus resource [mem 0x1f8160000-0x1f81cffff pref] (bus address [0x00000000-0x0006ffff])
[    2.200016] pci_bus 0000:00: root bus resource [mem 0x1f81d0000-0x1f81effff] (bus address [0x00000000-0x0001ffff])
[    2.210468] pci_bus 0000:00: root bus resource [mem 0x1f81f0000-0x1f820ffff pref] (bus address [0x00000000-0x0001ffff])
[    2.221362] pci_bus 0000:00: root bus resource [mem 0x1f8210000-0x1f822ffff] (bus address [0x00000000-0x0001ffff])
[    2.231814] pci_bus 0000:00: root bus resource [mem 0x1f8230000-0x1f824ffff pref] (bus address [0x00000000-0x0001ffff])
[    2.242704] pci_bus 0000:00: root bus resource [mem 0x1fc000000-0x1fc3fffff] (bus address [0x00000000-0x003fffff])
[    2.253168] pci 0000:00:00.0: [1957:e100] type 00 class 0x020001
[    2.259262] pci 0000:00:00.0: BAR 0: [mem 0x1f8000000-0x1f803ffff 64bit] (from Enhanced Allocation, properties 0x0)
[    2.269802] pci 0000:00:00.0: BAR 2: [mem 0x1f8160000-0x1f816ffff 64bit pref] (from Enhanced Allocation, properties 0x1)
[    2.280781] pci 0000:00:00.0: VF BAR 0: [mem 0x1f81d0000-0x1f81dffff 64bit] (from Enhanced Allocation, properties 0x4)
[    2.291584] pci 0000:00:00.0: VF BAR 2: [mem 0x1f81f0000-0x1f81fffff 64bit pref] (from Enhanced Allocation, properties 0x3)
[    2.302838] pci 0000:00:00.0: PME# supported from D0 D3hot
[    2.308382] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x1f81d0000-0x1f81effff 64bit] (contains BAR0 for 2 VFs)
[    2.318394] pci 0000:00:00.0: VF(n) BAR2 space: [mem 0x1f81f0000-0x1f820ffff 64bit pref] (contains BAR2 for 2 VFs)
[    2.328946] pci 0000:00:00.1: [1957:e100] type 00 class 0x020001
[    2.335032] pci 0000:00:00.1: BAR 0: [mem 0x1f8040000-0x1f807ffff 64bit] (from Enhanced Allocation, properties 0x0)
[    2.345576] pci 0000:00:00.1: BAR 2: [mem 0x1f8170000-0x1f817ffff 64bit pref] (from Enhanced Allocation, properties 0x1)
[    2.356560] pci 0000:00:00.1: VF BAR 0: [mem 0x1f8210000-0x1f821ffff 64bit] (from Enhanced Allocation, properties 0x4)
[    2.367363] pci 0000:00:00.1: VF BAR 2: [mem 0x1f8230000-0x1f823ffff 64bit pref] (from Enhanced Allocation, properties 0x3)
[    2.378614] pci 0000:00:00.1: PME# supported from D0 D3hot
[    2.384155] pci 0000:00:00.1: VF(n) BAR0 space: [mem 0x1f8210000-0x1f822ffff 64bit] (contains BAR0 for 2 VFs)
[    2.394166] pci 0000:00:00.1: VF(n) BAR2 space: [mem 0x1f8230000-0x1f824ffff 64bit pref] (contains BAR2 for 2 VFs)
[    2.404707] pci 0000:00:00.2: [1957:e100] type 00 class 0x020001
[    2.410792] pci 0000:00:00.2: BAR 0: [mem 0x1f8080000-0x1f80bffff 64bit] (from Enhanced Allocation, properties 0x0)
[    2.421333] pci 0000:00:00.2: BAR 2: [mem 0x1f8180000-0x1f818ffff 64bit pref] (from Enhanced Allocation, properties 0x1)
[    2.432320] pci 0000:00:00.2: PME# supported from D0 D3hot
[    2.437936] pci 0000:00:00.3: [1957:ee01] type 00 class 0x088001
[    2.444023] pci 0000:00:00.3: BAR 0: [mem 0x1f8100000-0x1f811ffff 64bit] (from Enhanced Allocation, properties 0x0)
[    2.454564] pci 0000:00:00.3: BAR 2: [mem 0x1f8190000-0x1f819ffff 64bit pref] (from Enhanced Allocation, properties 0x1)
[    2.465557] pci 0000:00:00.3: PME# supported from D0 D3hot
[    2.471175] pci 0000:00:00.4: [1957:ee02] type 00 class 0x088001
[    2.477258] pci 0000:00:00.4: BAR 0: [mem 0x1f8120000-0x1f813ffff 64bit] (from Enhanced Allocation, properties 0x0)
[    2.487799] pci 0000:00:00.4: BAR 2: [mem 0x1f81a0000-0x1f81affff 64bit pref] (from Enhanced Allocation, properties 0x1)
[    2.498786] pci 0000:00:00.4: PME# supported from D0 D3hot
[    2.504400] pci 0000:00:00.5: [1957:eef0] type 00 class 0x020801
[    2.510486] pci 0000:00:00.5: BAR 0: [mem 0x1f8140000-0x1f815ffff 64bit] (from Enhanced Allocation, properties 0x0)
[    2.521026] pci 0000:00:00.5: BAR 2: [mem 0x1f81b0000-0x1f81bffff 64bit pref] (from Enhanced Allocation, properties 0x1)
[    2.532004] pci 0000:00:00.5: BAR 4: [mem 0x1fc000000-0x1fc3fffff 64bit] (from Enhanced Allocation, properties 0x0)
[    2.542553] pci 0000:00:00.5: PME# supported from D0 D3hot
[    2.548166] pci 0000:00:00.6: [1957:e100] type 00 class 0x020001
[    2.554249] pci 0000:00:00.6: BAR 0: [mem 0x1f80c0000-0x1f80fffff 64bit] (from Enhanced Allocation, properties 0x0)
[    2.564790] pci 0000:00:00.6: BAR 2: [mem 0x1f81c0000-0x1f81cffff 64bit pref] (from Enhanced Allocation, properties 0x1)
[    2.575779] pci 0000:00:00.6: PME# supported from D0 D3hot
[    2.581865] pci 0000:00:1f.0: [1957:e001] type 00 class 0x080700
[    2.587963] OF: /soc/pcie@1f0000000: no msi-map translation for rid 0xf8 on (null)
[    2.595996] layerscape-pcie 3500000.pcie: host bridge /soc/pcie@3500000 ranges:
[    2.603390] layerscape-pcie 3500000.pcie:    IO 0x8800010000..0x880001ffff -> 0x00000000
[    2.611566] layerscape-pcie 3500000.pcie:   MEM 0x8840000000..0x887fffffff -> 0x40000000
[    2.619818] layerscape-pcie 3500000.pcie: PCI host bridge to bus 0001:00
[    2.626586] pci_bus 0001:00: root bus resource [bus 00-ff]
[    2.632123] pci_bus 0001:00: root bus resource [io  0x0000-0xffff]
[    2.638362] pci_bus 0001:00: root bus resource [mem 0x8840000000-0x887fffffff] (bus address [0x40000000-0x7fffffff])
[    2.648998] pci 0001:00:00.0: [1957:82c1] type 01 class 0x060400
[    2.655080] pci 0001:00:00.0: reg 0x38: [mem 0x8840000000-0x88400007ff pref]
[    2.662229] pci 0001:00:00.0: supports D1 D2
[    2.666540] pci 0001:00:00.0: PME# supported from D0 D1 D2 D3hot
[    2.673638] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[    2.680325] pci 0001:00:00.0: BAR 6: assigned [mem 0x8840000000-0x88400007ff pref]
[    2.687969] pci 0001:00:00.0: PCI bridge to [bus 01]
[    2.693350] pwm-backlight backlight@0: backlight@0 supply power not found, using dummy regulator
[    2.702513] EINJ: ACPI disabled.
[    2.706733] Bus freq driver module loaded
[    2.712469] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    2.719662] printk: console [ttyS0] disabled
[    2.724011] 21c0500.serial: ttyS0 at MMIO 0x21c0500 (irq = 16, base_baud = 12500000) is a 16550A
[    2.732901] printk: console [ttyS0] enabled
[    2.741310] printk: bootconsole [uart8250] disabled
[    2.751384] 21c0600.serial: ttyS1 at MMIO 0x21c0600 (irq = 16, base_baud = 12500000) is a 16550A
[    2.761189] arm-smmu 5000000.iommu: probing hardware configuration...
[    2.767660] arm-smmu 5000000.iommu: SMMUv2 with:
[    2.772292] arm-smmu 5000000.iommu:  stage 1 translation
[    2.777620] arm-smmu 5000000.iommu:  stage 2 translation
[    2.782950] arm-smmu 5000000.iommu:  nested translation
[    2.788196] arm-smmu 5000000.iommu:  stream matching with 128 register groups
[    2.795357] arm-smmu 5000000.iommu:  64 context banks (0 stage-2 only)
[    2.801910] arm-smmu 5000000.iommu:  Supported page sizes: 0x61311000
[    2.808373] arm-smmu 5000000.iommu:  Stage-1: 48-bit VA -> 48-bit IPA
[    2.814839] arm-smmu 5000000.iommu:  Stage-2: 48-bit IPA -> 48-bit PA
[    2.821917] mali-dp f080000.display: Adding to iommu group 0
[    2.828175] [drm] found ARM Mali-DP500 version r1p2
[    2.833268] cdns-mhdp-imx f200000.display: IRQ plug_in not found
[    2.839298] cdns-mhdp-imx f200000.display: No plug_in irq number
[    2.845325] cdns-mhdp-imx f200000.display: IRQ plug_out not found
[    2.851440] cdns-mhdp-imx f200000.display: No plug_out irq number
[    2.857555] cdns-mhdp-imx f200000.display: lane-mapping 0x4e
[    2.863236] [drm] Resolution 1280x800@60 is enabled
[    2.869365] [drm] Started firmware!
[    2.873886] [drm] HDP FW Version - ver 32955 verlib 20560
[    2.945049] mali-dp f080000.display: bound f200000.display (ops cdns_mhdp_imx_ops)
[    2.952819] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.959458] [drm] No driver support for vblank timestamp query.
[    2.965626] [drm] Initialized mali-dp 1.0.0 20160106 for f080000.display on minor 0
[    2.974340] cdns-mhdp-imx f200000.display: No EDID function, use default video mode
[    2.984090] [drm] Mode: 1280x800p71100
[    3.050746] [drm] DP link id: , 0x0 0x0 0x0 0x0 0x0 0x0
[    3.058039] [drm] DP revision: 0x12
[    3.061538] [drm] DP rate: 162000 Mbps
[    3.065296] [drm] DP number of lanes: 4
[    3.069142] [drm] DP capabilities: 0x1
[    3.335923] mali-dp f080000.display: fb0: mali-dpdrmfb frame buffer device
[    3.347041] brd: module loaded
[    3.353977] loop: module loaded
[    3.358195] imx ahci driver is registered.
[    3.362465] ahci-qoriq 3200000.sata: Adding to iommu group 1
[    3.368192] ahci-qoriq 3200000.sata: 3200000.sata supply ahci not found, using dummy regulator
[    3.376874] ahci-qoriq 3200000.sata: 3200000.sata supply phy not found, using dummy regulator
[    3.385458] ahci-qoriq 3200000.sata: 3200000.sata supply target not found, using dummy regulator
[    3.394357] ahci-qoriq 3200000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[    3.403353] ahci-qoriq 3200000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    3.413524] scsi host0: ahci-qoriq
[    3.417080] ata1: SATA max UDMA/133 mmio [mem 0x03200000-0x0320ffff] port 0x100 irq 22
[    3.426442] spi-nor spi1.0: found w25q128, expected m25p80
[    3.431966] spi-nor spi1.0: w25q128 (16384 Kbytes)
[    3.440542] libphy: Fixed MDIO Bus: probed
[    3.445026] tun: Universal TUN/TAP device driver, 1.6
[    3.450235] mscc_felix 0000:00:00.5: Adding to iommu group 2
[    3.456101] mscc_felix 0000:00:00.5: Failed to register DSA switch: -517
[    3.463098] thunder_xcv, ver 1.0
[    3.466359] thunder_bgx, ver 1.0
[    3.469614] nicpf, ver 1.0
[    3.472521] Freescale FM module, FMD API version 21.1.0
[    3.477835] Freescale FM Ports module
[    3.481507] fsl_mac: fsl_mac: FSL FMan MAC API based driver
[    3.487149] fsl_dpa: FSL DPAA Ethernet driver
[    3.491557] fsl_advanced: FSL DPAA Advanced drivers:
[    3.496535] fsl_proxy: FSL DPAA Proxy initialization driver
[    3.502162] fsl_oh: FSL FMan Offline Parsing port driver
[    3.507609] fsl_enetc 0000:00:00.0: Adding to iommu group 3
[    3.619646] fsl_enetc 0000:00:00.0: enabling device (0400 -> 0402)
[    3.625920] libphy: Freescale ENETC MDIO Bus: probed
[    3.631555] fsl_enetc 0000:00:00.0: no MAC address specified for SI1, using 2e:52:00:b1:3a:cf
[    3.640130] fsl_enetc 0000:00:00.0: no MAC address specified for SI2, using 9e:8b:57:fe:0b:b6
[    3.649659] fsl_enetc 0000:00:00.0 eth0: ENETC PF driver v1.0
[    3.655440] fsl_enetc 0000:00:00.0: enetc_tsn_init: setup done
[    3.661360] fsl_enetc 0000:00:00.1: Adding to iommu group 4
[    3.666972] fsl_enetc 0000:00:00.1: device is disabled, skipping
[    3.673035] fsl_enetc 0000:00:00.2: Adding to iommu group 5
[    3.746284] ata1: SATA link down (SStatus 0 SControl 300)
[    3.783644] fsl_enetc 0000:00:00.2: enabling device (0400 -> 0402)
[    3.790530] fsl_enetc 0000:00:00.2 eth1: ENETC PF driver v1.0
[    3.796317] fsl_enetc 0000:00:00.2: enetc_tsn_init: setup done
[    3.802239] fsl_enetc 0000:00:00.6: Adding to iommu group 6
[    3.807851] fsl_enetc 0000:00:00.6: device is disabled, skipping
[    3.813962] fsl_enetc_mdio 0000:00:00.3: Adding to iommu group 7
[    3.927654] fsl_enetc_mdio 0000:00:00.3: enabling device (0400 -> 0402)
[    3.934338] libphy: FSL PCIe IE Central MDIO Bus: probed
[    3.941072] fsl_enetc_ptp 0000:00:00.4: Adding to iommu group 8
[    3.947032] fsl_enetc_ptp 0000:00:00.4: enabling device (0404 -> 0406)
[    3.953679] ptp_qoriq: device tree node missing required elements, try automatic configuration
[    3.962467] pps pps0: new PPS source ptp0
[    3.966790] hclge is initializing
[    3.970122] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    3.977368] hns3: Copyright (c) 2017 Huawei Corporation.
[    3.982724] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[    3.989800] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    3.995586] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    4.001437] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    4.007400] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[    4.014384] igb: Copyright (c) 2007-2014 Intel Corporation.
[    4.019997] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    4.027857] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    4.033859] sky2: driver version 1.30
[    4.037635] Intel(R) Wireless WiFi driver for Linux
[    4.042527] Copyright(c) 2003- 2015 Intel Corporation
[    4.047673] GobiNet: Quectel_Linux&Android_GobiNet_Driver_V1.6.2.9
[    4.053906] usbcore: registered new inte**ce driver GobiNet
[    4.059600] usbcore: registered new inte**ce driver r8152
[    4.065116] usbcore: registered new inte**ce driver asix
[    4.070550] usbcore: registered new inte**ce driver ax88179_178a
[    4.076906] VFIO - User Level meta-driver version: 0.3
[    4.082262] dwc3 3100000.usb: Adding to iommu group 9
[    4.087392] dwc3 3100000.usb: Failed to get clk 'ref': -2
[    4.093081] dwc3 3110000.usb: Adding to iommu group 10
[    4.098274] dwc3 3110000.usb: Failed to get clk 'ref': -2
[    4.104308] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.110862] ehci-pci: EHCI PCI platform driver
[    4.115340] ehci-platform: EHCI generic platform driver
[    4.120644] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.126851] ohci-pci: OHCI PCI platform driver
[    4.131331] ohci-platform: OHCI generic platform driver
[    4.136777] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.142293] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    4.150055] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010010
[    4.159508] xhci-hcd xhci-hcd.0.auto: irq 20, io mem 0x03100000
[    4.165811] hub 1-0:1.0: USB hub found
[    4.169593] hub 1-0:1.0: 1 port detected
[    4.173670] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.179183] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    4.186875] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    4.193450] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.201786] hub 2-0:1.0: USB hub found
[    4.205562] hub 2-0:1.0: 1 port detected
[    4.209675] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    4.215186] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    4.222953] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010010
[    4.232404] xhci-hcd xhci-hcd.1.auto: irq 21, io mem 0x03110000
[    4.238648] hub 3-0:1.0: USB hub found
[    4.242421] hub 3-0:1.0: 1 port detected
[    4.246480] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    4.251989] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[    4.259679] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    4.266253] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.274588] hub 4-0:1.0: USB hub found
[    4.278366] hub 4-0:1.0: 1 port detected
[    4.282502] usbcore: registered new inte**ce driver usb-storage
[    4.289403] input: InputEmulator as /devices/virtual/input/input0
[    4.295792] <<-GTP-INFO-928->> GTP driver installing...
[    4.301231] <<-GTP-INFO-928->> GTP Driver Version: V2.4<2014/11/28>
[    4.307526] <<-GTP-INFO-928->> GTP I2C Address: 0x14
[    4.313887] <<-GTP-ERROR-928->> I2C Read: 0x8047, 1 bytes failed, errcode: -6!
[    4.321138] <<-GTP-ERROR-928->> GTP i2c test failed time 1.
[    4.345010] <<-GTP-ERROR-928->> I2C Read: 0x8047, 1 bytes failed, errcode: -6!
[    4.352259] <<-GTP-ERROR-928->> GTP i2c test failed time 2.
[    4.377008] <<-GTP-ERROR-928->> I2C Read: 0x8047, 1 bytes failed, errcode: -6!
[    4.384256] <<-GTP-ERROR-928->> GTP i2c test failed time 3.
[    4.409008] <<-GTP-ERROR-928->> I2C Read: 0x8047, 1 bytes failed, errcode: -6!
[    4.416257] <<-GTP-ERROR-928->> GTP i2c test failed time 4.
[    4.441008] <<-GTP-ERROR-928->> I2C Read: 0x8047, 1 bytes failed, errcode: -6!
[    4.448255] <<-GTP-ERROR-928->> GTP i2c test failed time 5.
[    4.471637] <<-GTP-ERROR-928->> I2C read failed.
[    4.480267] rtc-rx8010 0-0032: Frequency stop was detected
[    4.489070] rtc-rx8010 0-0032: Frequency stop detected
[    4.494301] rtc-rx8010 0-0032: registered as rtc0
[    4.499103] i2c /dev entries driver
[    4.503901] sp805-wdt c000000.watchdog: registration successful
[    4.509924] sp805-wdt c010000.watchdog: registration successful
[    4.516396] qoriq_cpufreq: Freescale QorIQ CPU frequency scaling driver
[    4.523258] sdhci: Secure Digital Host Controller Inte**ce driver
[    4.529470] sdhci: Copyright(c) Pierre Ossman
[    4.533918] Synopsys Designware ** Card Inte**ce Driver
[    4.540156] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.546113] sdhci-esdhc 2140000.mmc: Adding to iommu group 11
[    4.577548] mmc0: SDHCI controller on 2140000.mmc [2140000.mmc] using ADMA
[    4.584755] sdhci-esdhc 2150000.mmc: Adding to iommu group 12
[    4.616595] mmc1: SDHCI controller on 2150000.mmc [2150000.mmc] using ADMA
[    4.624402] ledtrig-cpu: registered to indicate activity on CPUs
[    4.631051] usbcore: registered new inte**ce driver usbhid
[    4.636666] usbhid: USB HID core driver
[    4.641234] No fsl,qman node
[    4.644135] Freescale USDPAA process driver
[    4.648335] fsl-usdpaa: no region found
[    4.652188] Freescale USDPAA process IRQ driver
[    4.657457] optee: probing for conduit method from DT.
[    4.662626] optee: api uid mismatch
[    4.666303] galcore f0c0000.gpu: Adding to iommu group 13
[    4.671813] Galcore version 6.4.0.234062
[    4.713325] random: fast init done
[    4.722133] imx-wm8960 sound: wm8960-hifi <-> f130000.audio-controller mapping ok
[    4.729723] imx-wm8960 sound: ASoC: no DMI vendor name!
[    4.749130] mmc1: new HS200 MMC card at address 0001
[    4.754620] mmcblk1: mmc1:0001 Q2J55L 7.09 GiB
[    4.757559] mmc0: new ultra high speed SDR104 SDXC card at address e624
[    4.759421] mmcblk1boot0: mmc1:0001 Q2J55L partition 1 16.0 MiB
[    4.770284] mmcblk0: mmc0:e624 SD64G 59.5 GiB
[    4.772010] mmcblk1boot1: mmc1:0001 Q2J55L partition 2 16.0 MiB
[    4.781668]  mmcblk0: p1
[    4.782206] mmcblk1rpmb: mmc1:0001 Q2J55L partition 3 4.00 MiB, chardev (236:0)
[    4.797285]  mmcblk1: p1 p2 p3
[    4.852171] NET: Registered protocol family 26
[    4.856742] u32 classifier
[    4.859451]     input device check on
[    4.863142]     Actions configured
[    4.866934] Initializing XFRM netlink socket
[    4.871288] NET: Registered protocol family 10
[    4.876182] Segment Routing with IPv6
[    4.879951] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    4.886354] NET: Registered protocol family 17
[    4.890827] NET: Registered protocol family 15
[    4.895306] Bridge firewalling registered
[    4.899452] 8021q: 802.1Q VLAN Support v1.8
[    4.903662] lib80211: common routines for IEEE802.11 drivers
[    4.909374] 9pnet: Installing 9P2000 support
[    4.913677] tsn generic netlink module v1 init...
[    4.918458] Key type dns_resolver registered
[    4.923033] registered taskstats version 1
[    4.927155] Loading compiled-in X.509 certificates
[    4.933411] Btrfs loaded, crc32c=crc32c-generic
[    4.939534] pcieport 0001:00:00.0: Adding to iommu group 14
[    4.945282] pcieport 0001:00:00.0: PME: Signaling with IRQ 103
[    4.951313] pcieport 0001:00:00.0: AER: enabled with IRQ 104
[    4.964247] libphy: VSC9959 internal MDIO bus: probed
[    4.969600] mscc_felix 0000:00:00.5: Found PCS at internal MDIO address 0
[    4.976688] mscc_felix 0000:00:00.5: Found PCS at internal MDIO address 1
[    4.983763] mscc_felix 0000:00:00.5: Found PCS at internal MDIO address 2
[    4.990845] mscc_felix 0000:00:00.5: Found PCS at internal MDIO address 3
[    5.016982] mscc_felix 0000:00:00.5 swp0 (uninitialized): PHY [0000:00:00.3:08] driver [Generic PHY]
[    5.026794] mscc_felix 0000:00:00.5 swp1 (uninitialized): PHY [0000:00:00.3:09] driver [Generic PHY]
[    5.036527] mscc_felix 0000:00:00.5 swp2 (uninitialized): PHY [0000:00:00.3:0a] driver [Generic PHY]
[    5.046257] mscc_felix 0000:00:00.5 swp3 (uninitialized): PHY [0000:00:00.3:0b] driver [Generic PHY]
[    5.055693] mscc_felix 0000:00:00.5: configuring for fixed/gmii link mode
[    5.062529] mscc_felix 0000:00:00.5: Link is Up - 2.5Gbps/Full - flow control off
[    5.062547] DSA: tree 0 setup
[    5.075132] rtc-rx8010 0-0032: Frequency stop detected
[    5.080295] rtc-rx8010 0-0032: hctosys: unable to read the hardware clock
[    5.087254] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    5.095889] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.102485] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    5.103664] ALSA device list:
[    5.111146] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[    5.114114]   #0: wm8960-audio
[    5.125116] RAMDISK: gzip image found at block 0
[    5.349385] EXT4-fs (ram0): mounted filesystem with ordered data mode. Opts: (null)
[    5.357129] VFS: Mounted root (ext4 filesystem) on device 1:0.
[    5.363067] devtmpfs: mounted
[    5.368010] Freeing unused kernel memory: 2944K
[    5.372709] Run /sbin/init as init process
|platform       |ok1028-c
|rootfs         |ubuntu.img
|qspiflash      |false
|emmcflash      |true
|emmcfirmware   |firmware_ls1028ardb_uboot_emmcboot.img
|qspifirmware   |firmware_ls1028ardb_uboot_xspiboot.img
|dp2lvdsfirmware|dp2lvds_firmware.bin
[emmc partition]
2048+0 records in
2048+0 records out
1048576 bytes (1.0MB) copied, 1.014901 seconds, 1009.0KB/s
parting, wait ...
part, done.
formating, wait ...
format, done.
[emmc flash]
flashing, wait...
ChipID 1605
dp2lvds update done
cp: can't stat '/mnt/boot/*': No such file or directory
 楼主| 发表于 2021-4-2 11:11:32 | 显示全部楼层
上面是SD的启动日志,USB的启动日志昨天发送到邮箱了,期待回复
djh
您发的是邮箱吗?我这边没看到邮件啊  详情 回复 发表于 2021-4-2 12:04
发表于 2021-4-2 12:04:50 | 显示全部楼层
您发的是linux@forlinx.com邮箱吗?我这边没看到邮件啊
 楼主| 发表于 2021-4-2 12:45:25 | 显示全部楼层
重新发送了一份到linux@forlinx.com邮箱,请查收
djh
好的已收到,并回复您,您注意查收,建议您再换一个TF卡试试,再烧写内核镜像时没有读取到您的设备  详情 回复 发表于 2021-4-2 14:28
发表于 2021-4-2 14:28:41 | 显示全部楼层
skyxiao6688 发表于 2021-4-2 12:45
重新发送了一份到邮箱,请查收
GMT+8, 2026-9-30 04:04
