查看: 6953|回复: 5
ok6410a核心板启动到如下位置??
发表于 2011-7-18 09:06:03 | 显示全部楼层 |阅读模式
ok6410a核心板启动到如下位置,不动时是哪的问题
sysIntr = 27)
[HSMMC1] Initializing the HSMMC Host Controller
-OALIntrRequestSysIntr(irq = 7, sysIntr = 28)
-OALIntrRequestSysIntr(irq = 95, sysIntr = 29)
[HSMMC0] Card is Inserted!
[HSMMC1] Turn OFF the F/B delay control.
[HSMMC1] Card is Inserted!
[HSMMC0] CSDHCSlotBase::SDClockOn: Timeout waiting for CLOCK_STABLE
[HSMMC1] CSDHCSlotBase::SDClockOn: Timeout waiting for CLOCK_STABLE
[HSMMC0] Setting for 1 bit mode , Clock Rate = 100000 Hz
[HSMMC1] Setting for 1 bit mode , Clock Rate = 100000 Hz
<DM9:++MiniportIntialize>
[dm9: The mapped address is D2F60000]
[dm9: Chip signature is 0A469000]
<DM9:--MiniportIntialize>
[USB] dii.dwIrq = 96
-OALIntrRequestSysIntr(irq = 96, sysIntr = 30)
ERR CMD:5 : ERR CMD:5 : ERR CMD:5 : ERR CMD:5 : ERR CMD:5 :
 楼主| 发表于 2011-7-18 10:06:46 | 显示全部楼层
好像是到sd的相关部分出了问题
发表于 2011-7-18 13:19:24 | 显示全部楼层
请问楼主烧写映像的来源,以及开发板型号?
 楼主| 发表于 2011-7-18 14:12:33 | 显示全部楼层
映像来源于飞凌光盘 开饭ok6410a
98
 楼主| 发表于 2011-7-18 16:27:32 | 显示全部楼层
应该是板子硬件出了啥问题,今年买的板子如何维修
发表于 2011-7-18 17:08:24 | 显示全部楼层
换个linux系统试试,看看这部分会不会报错。
GMT+8, 2026-10-6 04:25
