查看: 13696|回复: 6
[Ubuntu] USB烧录失败
发表于 2021-4-25 14:16:09 | 显示全部楼层 |阅读模式
你好,
我用OK1043A-C-Linux- 用户资料-20200723 里面提供的镜像,拷贝到U盘上,用标准底板烧录,结果报如下错误,请问可能是哪个地方的问题?
[    3.238520] usb-storage 2-1:1.0: USB Mass Storage device detected
[    3.242820] scsi host1: usb-storage 2-1:1.0
[    3.614765] RAMDISK: gzip image found at block 0
[    3.872440] EXT4-fs (ram0): mounted filesystem with ordered data mode. Opts: (null)
[    3.880118] VFS: Mounted root (ext4 filesystem) on device 1:0.
[    3.886022] devtmpfs: mounted
[    3.889428] Freeing unused kernel memory: 1216K
[    4.256691] scsi 1:0:0:0: Direct-Access              aigo U330        PMAP PQ: 0 ANSI: 6
[    4.265556] sd 1:0:0:0: [sda] 122880000 512-byte logical blocks: (62.9 GB/58.6 GiB)
[    4.273686] sd 1:0:0:0: [sda] Write Protect is off
[    4.278908] sd 1:0:0:0: [sda] No Caching mode page found
[    4.284218] sd 1:0:0:0: [sda] Assuming drive cache: write through
[    4.292921]  sda: sda1
[    4.296332] sd 1:0:0:0: [sda] Attached SCSI removable disk
[    6.963682] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
|platform       |ok1043-c                                       [    6.993898] random: parted: uninitialized urandom read (16 bytes read)
|rootfs         |ubuntu.img
|qspiflash      |false
|emmcflash      |true
|sdfirmware     |firmware_ls1043ardb_uboot_sdboot.img
|qspifirmware   |firmware_ls1043ardb_uboot_qspiboot.img
[emmc partition]
2048+0 records in
2048+0 records out
1048576 bytes (1.0MB) copied, 0.004979 seconds, 200.8MB/s
parting, wait ...
Error: The location 2048 is outside of the device /dev/mmcblk0.
Error: The location 43008 is outside of the device /dev/mmcblk0.
Error: The location 247808 is outside of the device /dev/mmcblk0.
part, done.
formating, wait ...
mkfs.vfat: can't open '/dev/mmcblk0p1': No such file or directory
mkfs.vfat: can't open '/dev/mmcblk0p2': No such file or directory
format, done.
[emmc flash]
flashing, wait...
[    7.999528] random: fast init done
29270+1 records in
29270+1 records out
14986242 bytes (14.3MB) copied, 0.147858 seconds, 96.7MB/s
[    9.797960] random: crng init done
error: file_write: incomplete write
error: file_write: write: No space left on device
后面一直在重复这个错误。
请问该怎么解决。谢谢
发表于 2021-4-25 15:27:34 | 显示全部楼层
可能跟U盘有关系,建议您重新换一个U盘进行烧写,U盘的格式为FAT32格式的,没有隐藏分区,没有做过系统启动盘的,
 楼主| 发表于 2021-4-25 15:47:42 | 显示全部楼层
我再找个,谢谢
 楼主| 发表于 2021-4-26 11:52:51 | 显示全部楼层
已经换了好几个U盘了,包括京东新买的几个爱国者,scandisk,都不行。
确认一下步骤是插入U盘,启动时按任意键,进入bootloader命令行,然后运行boot命令即可
U盘上直接拷贝Ubuntu_images文件夹下面的所有文件即可。
djh
U盘烧写的前提是系统能正常启动,再按您说的进行操作, 您能留一下联系方式吗?跟您电话沟通一下;  详情 回复 发表于 2021-4-26 12:06
发表于 2021-4-26 12:06:53 | 显示全部楼层
确认一下步骤是插入U盘,启动时按任 ...
17310703769  详情 回复 发表于 2021-4-26 12:52
 楼主| 发表于 2021-4-26 12:52:40 | 显示全部楼层
17310703769
 楼主| 发表于 2021-4-26 12:54:38 | 显示全部楼层
附上完整log:
U-Boot 2018.03 (Jul 23 2020 - 15:29:18 +0800)
SoC:  LS1043AE Rev1.1 (0x87920211)
Clock Configuration:
       CPU0(A53):1600 MHz  CPU1(A53):1600 MHz  CPU2(A53):1600 MHz
       CPU3(A53):1600 MHz
       Bus:      400  MHz  DDR:      1600 MT/s  FMAN:     500  MHz
       00000000: 08100010 0a000000 00000000 00000000
       00000010: 14550002 80004012 40044000 c1002000
       00000020: 00000000 00000000 00000000 00438800
       00000030: 20004500 00001002 00000096 00000001
Model: OK1043-C
Board: LS1043ARDB, boot from QSPI
SERDES Reference Clocks:
SD1_CLK1 = 156.25MHZ, SD1_CLK2 = 100.00MHZ
I2C:   ready
DRAM:  Initialzing DDR using fixed setting
Configuring DDR for 1600 MT/s data rate
1.9 GiB (DDR4, 32-bit, CL=11, ECC off)
Using SERDES1 Protocol: 5205 (0x1455)
SEC0: RNG instantiated
PPA Firmware: Version LSDK-18.06-Forlinx
SEC Firmware: 'loadables' present in config
loadables: 'trustedOS@1'
DS2460 OK
MMC:   FSL_SDHC: 0
Loading Environment from SPI Flash... SF: Detected n25q128 with page size 256 BB
OK
In:    serial
Out:   serial
Err:   serial
SATA link 0 timeout.
AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
flags: 64bit ncq pm clo only pmp fbss pio slum part ccc apst
Found 0 device(s).
SCSI:  Net:   SF: Detected n25q128 with page size 256 Bytes, erase size 64 KiB,B
Fman1: Uploading microcode version 106.4.18
PCIe0: pcie@3400000 disabled
PCIe1: pcie@3500000 Root Complex: no link
PCIe2: pcie@3600000 Root Complex: no link
FM1@DTSEC1, FM1@DTSEC2, FM1@DTSEC3 [PRIME], FM1@DTSEC4, FM1@DTSEC5, FM1@DTSEC6,1
=> boot
starting USB...
USB0:   Register 200017f NbrPorts 2
Starting the controller
USB XHCI 1.00
USB1:   Register 200017f NbrPorts 2
USB XHCI 1.00
USB2:   Register 200017f NbrPorts 2
USB XHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
Device 0: Vendor:  USB Rev: 1.00 Prod:  SanDisk 3.2Gen1
            Type: Removable Hard Disk
            Capacity: 14944.0 MB = 14.5 GB (30605312 x 512)
... is now current device
Scanning usb 0:1...
Found U-Boot script /ls1043ardb_update.scr
365 bytes read in 21 ms (16.6 KiB/s)
## Executing script at 80000000
** Unable to read file AQR.cld **
15758100 bytes read in 165 ms (91.1 MiB/s)
## Loading kernel from FIT Image at a0000000 ...
   Using 'ls1043ardb' configuration
   Trying 'kernel' kernel subimage
     Description:  ARM64 Kernel
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0xa00000d0
     Data Size:    9374945 Bytes = 8.9 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x80080000
     Entry Point:  0x80080000
     Hash algo:    crc32
     Hash value:   4f3b3d73
   Verifying Hash Integrity ... crc32+ OK
## Loading ramdisk from FIT Image at a0000000 ...
   Trying 'initrd' ramdisk subimage
     Description:  initrd for arm64
     Type:         RAMDisk Image
     Compression:  uncompressed
     Data Start:   0xa08f0e94
     Data Size:    6238753 Bytes = 5.9 MiB
     OS:           Linux
     Load Address: 0x00000000
     Entry Point:  0x00000000
     Hash algo:    crc32
     Hash value:   0b0ed17b
## Loading fdt from FIT Image at a0000000 ...
   Trying 'ls1043ardb-dtb' fdt subimage
     Description:  ls1043ardb-dtb
     Type:         Flat Device Tree
     Data Start:   0xa0ef2320
     Data Size:    29406 Bytes = 28.7 KiB
     Load Address: 0x90000000
     Hash algo:    crc32
     Hash value:   3361fe15
   Loading fdt from 0xa0ef2320 to 0x90000000
   Booting using the fdt blob at 0x90000000
   Uncompressing Kernel Image ... OK
   Using Device Tree in place at 0000000090000000, end 000000009001a2dd
Starting kernel ...
[    0.000000] Linux version 4.14.47 (zyh@1ffe9f7b637e) (gcc version 7.3.0 (Ubu0
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] Machine model: LS1043A RDB Board
[    0.000000] earlycon: uart8250 at MMIO 0x00000000021c0500 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] OF: reserved mem: initialized node qman-fqd, compatible id fsl,qd
[    0.000000] OF: reserved mem: initialized node qman-pfdr, compatible id fsl,r
[    0.000000] OF: reserved mem: initialized node bman-fbpr, compatible id fsl,r
[    0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000fbdffff]
[    0.000000] NUMA: NODE_DATA [mem 0xfbdcad00-0xfbdcc4bf]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000fbdfffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000f7ffffff]
[    0.000000]   node   0: [mem 0x00000000fb000000-0x00000000fb7fffff]
[    0.000000]   node   0: [mem 0x00000000fbc00000-0x00000000fbdfffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000fbdfffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] percpu: Embedded 24 pages/cpu @ffff80007bd63000 s59992 r8192 d304
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 486152
[    0.000000] Policy zone: DMA
[    0.000000] Kernel command line: console=ttyS0,115200 earlycon=uart8250,mmiot
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Memory: 1898264K/1976320K available (13052K kernel code, 1436K r)
[    0.000000]     modules : 0xffff000000000000 - 0xffff000008000000   (   128 )
[    0.000000]     vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000   (129022 )
[    0.000000]       .text : 0xffff000008080000 - 0xffff000008d40000   ( 13056 )
[    0.000000]     .rodata : 0xffff000008d40000 - 0xffff000009280000   (  5376 )
[    0.000000]       .init : 0xffff000009280000 - 0xffff0000093b0000   (  1216 )
[    0.000000]       .data : 0xffff0000093b0000 - 0xffff000009517200   (  1437 )
[    0.000000]        .bss : 0xffff000009517200 - 0xffff00000960b550   (   977 )
[    0.000000]     fixed   : 0xffff7dfffe7f9000 - 0xffff7dfffec00000   (  4124 )
[    0.000000]     PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000   (    16 )
[    0.000000]     vmemmap : 0xffff7e0000000000 - 0xffff800000000000   (  2048 )
[    0.000000]               0xffff7e0000000000 - 0xffff7e0001ef8000   (    30 )
[    0.000000]     memory  : 0xffff800000000000 - 0xffff80007be00000   (  1982 )
[    0.000000]  RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000]  Tasks RCU enabled.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU inte**ce base to 0x000000000142f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: Enabling global workaround for Freescale erratum a008
[    0.000000] arch_timer: CPU0: Trapping CNTVCT access
[    0.000000] arch_timer: cp15 timer(s) running at 25.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[    0.000003] sched_clock: 56 bits at 25MHz, resolution 40ns, wraps every 4398s
[    0.008553] Console: colour dummy device 80x25
[    0.013053] Calibrating delay loop (skipped), value calculated using timer f)
[    0.023458] pid_max: default: 32768 minimum: 301
[    0.028165] Security Framework initialized
[    0.032831] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.040275] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.047373] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.054116] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.077324] ASID allocator initialised with 32768 entries
[    0.082792] Hierarchical SRCU implementation.
[    0.095785] EFI services will not be available.
[    0.108349] smp: Bringing up secondary CPUs ...
[    0.141848] Detected VIPT I-cache on CPU1
[    0.141883] arch_timer: CPU1: Trapping CNTVCT access
[    0.141888] CPU1: Booted secondary processor [410fd034]
[    0.169778] Detected VIPT I-cache on CPU2
[    0.169808] arch_timer: CPU2: Trapping CNTVCT access
[    0.169813] CPU2: Booted secondary processor [410fd034]
[    0.197824] Detected VIPT I-cache on CPU3
[    0.197854] arch_timer: CPU3: Trapping CNTVCT access
[    0.197859] CPU3: Booted secondary processor [410fd034]
[    0.197938] smp: Brought up 1 node, 4 CPUs
[    0.244859] SMP: Total of 4 processors activated.
[    0.249585] CPU features: detected feature: 32-bit EL0 Support
[    0.255445] CPU features: detected feature: Kernel page table isolation (KPT)
[    0.265774] CPU: All CPU(s) started at EL2
[    0.269895] alternatives: patching kernel code
[    0.275119] devtmpfs: initialized
[    0.281511] random: get_random_u32 called from bucket_table_alloc+0x108/0x250
[    0.290456] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[    0.300263] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.306852] xor: measuring software checksum speed
[    0.351694]    8regs     :  3070.000 MB/sec
[    0.395921]    8regs_prefetch:  2736.000 MB/sec
[    0.440499]    32regs    :  3774.000 MB/sec
[    0.484726]    32regs_prefetch:  3172.000 MB/sec
[    0.489363] xor: using function: 32regs (3774.000 MB/sec)
[    0.494789] pinctrl core: initialized pinctrl subsystem
[    0.500880] DMI not present or invalid.
[    0.504931] NET: Registered protocol family 16
[    0.513416] cpuidle: using governor menu
[    0.517676] Bman ver:0a02,02,01
[    0.522273] qman-fqd addr 0x00000000fb800000 size 0x400000
[    0.527788] qman-pfdr addr 0x00000000f8000000 size 0x2000000
[    0.533496] Qman ver:0a01,03,02,00
[    0.537045] vdso: 2 pages (1 code @ ffff000008d46000, 1 data @ ffff0000093b5)
[    0.544487] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.551922] DMA: preallocated 256 KiB pool for atomic allocations
[    0.558321] Serial: AMBA PL011 UART driver
[    0.563442] Machine: LS1043A RDB Board
[    0.567207] SoC family: QorIQ LS1043A
[    0.570879] SoC ID: svr:0x87920211, Revision: 1.1
[    0.595432] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.669620] raid6: int64x1  gen()   608 MB/s
[    0.741648] raid6: int64x1  xor()   498 MB/s
[    0.813668] raid6: int64x2  gen()   937 MB/s
[    0.885708] raid6: int64x2  xor()   741 MB/s
[    0.957756] raid6: int64x4  gen()  1443 MB/s
[    1.029789] raid6: int64x4  xor()  1000 MB/s
[    1.101845] raid6: int64x8  gen()  1340 MB/s
[    1.173903] raid6: int64x8  xor()  1007 MB/s
[    1.245923] raid6: neonx1   gen()   980 MB/s
[    1.317985] raid6: neonx1   xor()   997 MB/s
[    1.390018] raid6: neonx2   gen()  1622 MB/s
[    1.462054] raid6: neonx2   xor()  1577 MB/s
[    1.534124] raid6: neonx4   gen()  2143 MB/s
[    1.606151] raid6: neonx4   xor()  1958 MB/s
[    1.678197] raid6: neonx8   gen()  2303 MB/s
[    1.750235] raid6: neonx8   xor()  2086 MB/s
[    1.754523] raid6: using algorithm neonx8 gen() 2303 MB/s
[    1.759945] raid6: .... xor() 2086 MB/s, rmw enabled
[    1.764931] raid6: using neon recovery algorithm
[    1.769910] ACPI: Interpreter disabled.
[    1.775864] vgaarb: loaded
[    1.778755] SCSI subsystem initialized
[    1.782799] usbcore: registered new inte**ce driver usbfs
[    1.788342] usbcore: registered new inte**ce driver hub
[    1.793755] usbcore: registered new device driver usb
[    1.799255] imx-i2c 2180000.i2c: can't get pinctrl, bus recovery not supportd
[    1.806688] i2c i2c-0: IMX I2C adapter registered
[    1.811444] i2c i2c-0: using dma0chan16 (tx) and dma0chan17 (rx) for DMA tras
[    1.819113] imx-i2c 21a0000.i2c: fsl-scl-gpio not found
[    1.824390] imx-i2c 21a0000.i2c: can't get pinctrl, bus recovery not supportd
[    1.831743] i2c i2c-1: IMX I2C adapter registered
[    1.836474] i2c i2c-1: can't use DMA, using PIO instead.
[    1.841859] imx-i2c 21b0000.i2c: fsl-scl-gpio not found
[    1.847139] imx-i2c 21b0000.i2c: can't get pinctrl, bus recovery not supportd
[    1.854443] i2c i2c-2: IMX I2C adapter registered
[    1.859174] i2c i2c-2: can't use DMA, using PIO instead.
[    1.865342] pps_core: LinuxPPS API ver. 1 registered
[    1.870340] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[    1.879532] PTP clock support registered
[    1.883637] EDAC MC: Ver: 3.0.0
[    1.886947] dmi: Firmware registration failed.
[    1.891438] bman-fbpr addr 0x00000000fa000000 size 0x1000000
[    1.897161] Bman err interrupt handler present
[    1.902059] Bman portal initialised, cpu 0
[    1.906245] Bman portal initialised, cpu 1
[    1.910430] Bman portal initialised, cpu 2
[    1.914612] Bman portal initialised, cpu 3
[    1.918729] Bman portals initialised
[    1.923189] Qman err interrupt handler present
[    1.927839] QMan: Allocated lookup table at ffff00000ad25000, entry count 657
[    1.935564] Qman portal initialised, cpu 0
[    1.939740] Qman portal initialised, cpu 1
[    1.943915] Qman portal initialised, cpu 2
[    1.948096] Qman portal initialised, cpu 3
[    1.952211] Qman portals initialised
[    1.955861] Bman: BPID allocator includes range 32:32
[    1.960988] Qman: FQID allocator includes range 256:256
[    1.966239] Qman: FQID allocator includes range 32768:32768
[    1.971887] Qman: CGRID allocator includes range 0:256
[    1.977184] Qman: pool channel allocator includes range 1025:15
[    1.983218] No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree
[    1.989543] Advanced Linux Sound Architecture Driver Initialized.
[    1.996118] clocksource: Switched to clocksource arch_sys_counter
[    2.002336] VFS: Disk quotas dquot_6.6.0
[    2.006311] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    2.013292] pnp: PnP ACPI: disabled
[    2.020561] NET: Registered protocol family 2
[    2.025242] TCP established hash table entries: 16384 (order: 5, 131072 byte)
[    2.032606] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    2.039440] TCP: Hash tables configured (established 16384 bind 16384)
[    2.046072] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    2.052143] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    2.058713] NET: Registered protocol family 1
[    2.063299] RPC: Registered named UNIX socket transport module.
[    2.069264] RPC: Registered udp transport module.
[    2.073993] RPC: Registered tcp transport module.
[    2.078719] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.085279] Trying to unpack rootfs image as initramfs...
[    2.090922] rootfs image is not initramfs (no cpio magic); looks like an inid
[    2.107061] Freeing initrd memory: 6092K
[    2.111542] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters ae
[    2.119763] kvm [1]: 8-bit VMID
[    2.123613] kvm [1]: vgic interrupt IRQ1
[    2.127607] kvm [1]: Hyp mode initialized successfully
[    2.134332] audit: initializing netlink subsys (disabled)
[    2.139825] audit: type=2000 audit(2.040:1): state=initialized audit_enabled1
[    2.140020] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[    2.147916] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.148034] NFS: Registering the id_resolver key type
[    2.148049] Key type id_resolver registered
[    2.148051] Key type id_legacy registered
[    2.148056] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.148136] fuse init (API version 7.26)
[    2.148219] 9p: Installing v9fs 9p2000 file system support
[    2.149797] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[    2.149847] io scheduler noop registered
[    2.149873] io scheduler cfq registered (default)
[    2.149874] io scheduler mq-deadline registered
[    2.149876] io scheduler kyber registered
[    2.162416] OF: PCI: host bridge /soc/pcie@3500000 ranges:
[    2.162429] OF: PCI:    IO 0x4800010000..0x480001ffff -> 0x00000000
[    2.162435] OF: PCI:   MEM 0x4840000000..0x487fffffff -> 0x40000000
[    2.162538] layerscape-pcie 3500000.pcie: PCI host bridge to bus 0000:00
[    2.162543] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.162547] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.162551] pci_bus 0000:00: root bus resource [mem 0x4840000000-0x487ffffff)
[    2.162780] pci 0000:00:00.0: BAR 6: assigned [mem 0x4840000000-0x48400007ff]
[    2.162785] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.162932] pcieport 0000:00:00.0: Signaling PME with IRQ 65
[    2.163006] pcieport 0000:00:00.0: AER enabled with IRQ 66
[    2.163126] OF: PCI: host bridge /soc/pcie@3600000 ranges:
[    2.163135] OF: PCI:    IO 0x5000010000..0x500001ffff -> 0x00000000
[    2.163140] OF: PCI:   MEM 0x5040000000..0x507fffffff -> 0x40000000
[    2.163221] layerscape-pcie 3600000.pcie: PCI host bridge to bus 0001:00
[    2.163225] pci_bus 0001:00: root bus resource [bus 00-ff]
[    2.163229] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus ad)
[    2.163234] pci_bus 0001:00: root bus resource [mem 0x5040000000-0x507ffffff)
[    2.163427] pci 0001:00:00.0: BAR 6: assigned [mem 0x5040000000-0x50400007ff]
[    2.163431] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    2.163548] pcieport 0001:00:00.0: Signaling PME with IRQ 67
[    2.163617] pcieport 0001:00:00.0: AER enabled with IRQ 68
[    2.168398] Freescale LS2 console driver
[    2.168479] fsl-ls2-console: device fsl_mc_console registered
[    2.168524] fsl-ls2-console: device fsl_aiop_console registered
[    2.173053] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    2.174606] console [ttyS0] disabled
[    2.384885] 21c0500.serial: ttyS0 at MMIO 0x21c0500 (irq = 39, base_baud = 2A
[    2.393737] console [ttyS0] enabled
[    2.400722] bootconsole [uart8250] disabled
[    2.409432] 21c0600.serial: ttyS1 at MMIO 0x21c0600 (irq = 39, base_baud = 2A
[    2.418475] 21d0500.serial: ttyS2 at MMIO 0x21d0500 (irq = 40, base_baud = 2A
[    2.427520] 21d0600.serial: ttyS3 at MMIO 0x21d0600 (irq = 40, base_baud = 2A
[    2.437019] SuperH (H)SCI(F) driver initialized
[    2.442114] msm_serial: driver initialized
[    2.451521] brd: module loaded
[    2.458082] loop: module loaded
[    2.517860] ahci-qoriq 3200000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps e
[    2.526823] ahci-qoriq 3200000.sata: flags: 64bit ncq sntf pm clo only pmp f
[    2.537038] scsi host0: ahci-qoriq
[    2.540574] ata1: SATA max UDMA/133 mmio [mem 0x03200000-0x0320ffff] port 0x0
[    2.549691] fsl-quadspi 1550000.quadspi: spi-tx-bus-width 2 not supported
[    2.556520] fsl-quadspi 1550000.quadspi: n25q128a13 (16384 Kbytes)
[    2.565292] libphy: Fixed MDIO Bus: probed
[    2.569860] tun: Universal TUN/TAP device driver, 1.6
[    2.576005] libphy: Freescale XGMAC MDIO Bus: probed
[    2.582542] libphy: Freescale XGMAC MDIO Bus: probed
[    2.589117] libphy: Freescale XGMAC MDIO Bus: probed
[    2.594343] libphy: Freescale XGMAC MDIO Bus: probed
[    2.599531] libphy: Freescale XGMAC MDIO Bus: probed
[    2.604709] libphy: Freescale XGMAC MDIO Bus: probed
[    2.609898] libphy: Freescale XGMAC MDIO Bus: probed
[    2.615071] libphy: Freescale XGMAC MDIO Bus: probed
[    2.620272] libphy: Freescale XGMAC MDIO Bus: probed
[    2.637207] Freescale FM module, FMD API version 21.1.0
[    2.645194] Freescale FM Ports module
[    2.648859] fsl_mac: fsl_mac: FSL FMan MAC API based driver
[    2.654947] fsl_mac 1ae0000.ethernet: FMan MEMAC
[    2.659567] fsl_mac 1ae0000.ethernet: FMan MAC address: 66:ac:f9:2d:11:d0
[    2.666701] fsl_mac 1ae2000.ethernet: FMan MEMAC
[    2.671317] fsl_mac 1ae2000.ethernet: FMan MAC address: 3e:b7:71:d2:72:46
[    2.678204] fsl_mac 1ae4000.ethernet: FMan MEMAC
[    2.682821] fsl_mac 1ae4000.ethernet: FMan MAC address: aa:c7:db:2f:5e:67
[    2.689712] fsl_mac 1ae6000.ethernet: FMan MEMAC
[    2.694329] fsl_mac 1ae6000.ethernet: FMan MAC address: 9a:d7:3d:e3:7a:0e
[    2.701464] fsl_mac 1ae8000.ethernet: FMan MEMAC
[    2.706080] fsl_mac 1ae8000.ethernet: FMan MAC address: aa:e4:58:6e:dc:36
[    2.713217] fsl_mac 1aea000.ethernet: FMan MEMAC
[    2.717834] fsl_mac 1aea000.ethernet: FMan MAC address: da:f6:3c:a4:e2:7c
[    2.724726] fsl_mac 1af0000.ethernet: FMan MEMAC
[    2.729342] fsl_mac 1af0000.ethernet: FMan MAC address: e6:36:53:d2:8f:c4
[    2.736173] fsl_dpa: FSL DPAA Ethernet driver
[    2.741415] fsl_dpa soc:fsl,dpaa:ethernet@0: Skip RX PCD High Priority FQs in
[    2.753101] fsl_dpa: fsl_dpa: Probed inte**ce eth0
[    2.758614] fsl_dpa soc:fsl,dpaa:ethernet@1: Skip RX PCD High Priority FQs in
[    2.770578] fsl_dpa: fsl_dpa: Probed inte**ce eth1
[    2.776211] fsl_dpa soc:fsl,dpaa:ethernet@2: Skip RX PCD High Priority FQs in
[    2.787778] fsl_dpa: fsl_dpa: Probed inte**ce eth2
[    2.793525] fsl_dpa soc:fsl,dpaa:ethernet@3: Skip RX PCD High Priority FQs in
[    2.806062] fsl_dpa: fsl_dpa: Probed inte**ce eth3
[    2.811910] fsl_dpa soc:fsl,dpaa:ethernet@4: Skip RX PCD High Priority FQs in
[    2.824333] fsl_dpa: fsl_dpa: Probed inte**ce eth4
[    2.830281] fsl_dpa soc:fsl,dpaa:ethernet@5: Skip RX PCD High Priority FQs in
[    2.843087] fsl_dpa: fsl_dpa: Probed inte**ce eth5
[    2.849196] fsl_dpa soc:fsl,dpaa:ethernet@8: Skip RX PCD High Priority FQs in
[    2.861968] fsl_dpa: fsl_dpa: Probed inte**ce eth6
[    2.862371] ata1: SATA link down (SStatus 0 SControl 300)
[    2.872334] fsl_advanced: FSL DPAA Advanced drivers:
[    2.877295] fsl_proxy: FSL DPAA Proxy initialization driver
[    2.883118] fsl_oh: FSL FMan Offline Parsing port driver
[    2.888935] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[    2.895980] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    2.901760] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.907588] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.913583] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    2.920542] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.926136] igbvf: Intel(R) Gigabit Virtual Function Network Driver - versiok
[    2.933960] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    2.940259] sky2: driver version 1.30
[    2.944324] PPP generic driver version 2.4.2
[    2.948693] PPP BSD Compression module registered
[    2.953393] PPP Deflate Compression module registered
[    2.958454] PPP MPPE Compression module registered
[    2.963239] NET: Registered protocol family 24
[    2.967721] usbcore: registered new inte**ce driver asix
[    2.973154] usbcore: registered new inte**ce driver ax88179_178a
[    2.979262] usbcore: registered new inte**ce driver cdc_ether
[    2.985108] usbcore: registered new inte**ce driver net1080
[    2.990781] usbcore: registered new inte**ce driver cdc_subset
[    2.996716] usbcore: registered new inte**ce driver zaurus
[    3.002313] usbcore: registered new inte**ce driver cdc_ncm
[    3.007986] usbcore: registered new inte**ce driver huawei_cdc_ncm
[    3.014270] usbcore: registered new inte**ce driver qmi_wwan
[    3.020372] VFIO - User Level meta-driver version: 0.3
[    3.028145] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.034672] ehci-pci: EHCI PCI platform driver
[    3.039134] ehci-platform: EHCI generic platform driver
[    3.044515] ehci-orion: EHCI orion driver
[    3.048635] ehci-exynos: EHCI EXYNOS driver
[    3.052926] ehci-msm: Qualcomm On-Chip EHCI Host Controller
[    3.058585] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.064767] ohci-pci: OHCI PCI platform driver
[    3.069231] ohci-platform: OHCI generic platform driver
[    3.074584] ohci-exynos: OHCI EXYNOS driver
[    3.079240] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.084733] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus n1
[    3.092702] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f66d hci version 0x100
[    3.101423] xhci-hcd xhci-hcd.0.auto: irq 47, io mem 0x02f00000
[    3.107668] hub 1-0:1.0: USB hub found
[    3.111427] hub 1-0:1.0: 1 port detected
[    3.115504] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.120992] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus n2
[    3.128650] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0  SuperSpeed
[    3.135532] hub 2-0:1.0: USB hub found
[    3.139292] hub 2-0:1.0: 1 port detected
[    3.143396] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.148887] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus n3
[    3.156830] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f66d hci version 0x100
[    3.165545] xhci-hcd xhci-hcd.1.auto: irq 48, io mem 0x03000000
[    3.171703] hub 3-0:1.0: USB hub found
[    3.175459] hub 3-0:1.0: 1 port detected
[    3.179515] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.185000] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus n4
[    3.192657] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0  SuperSpeed
[    3.199525] hub 4-0:1.0: USB hub found
[    3.203281] hub 4-0:1.0: 1 port detected
[    3.207389] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    3.212881] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus n5
[    3.220848] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f66d hci version 0x100
[    3.229563] xhci-hcd xhci-hcd.2.auto: irq 49, io mem 0x03100000
[    3.235719] hub 5-0:1.0: USB hub found
[    3.239477] hub 5-0:1.0: 1 port detected
[    3.243535] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    3.249026] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus n6
[    3.256681] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0  SuperSpeed
[    3.263548] hub 6-0:1.0: USB hub found
[    3.267304] hub 6-0:1.0: 1 port detected
[    3.271684] usbcore: registered new inte**ce driver cdc_wdm
[    3.277407] usbcore: registered new inte**ce driver usb-storage
[    3.283466] usbcore: registered new inte**ce driver usbserial
[    3.289315] usbcore: registered new inte**ce driver usbserial_generic
[    3.295854] usbserial: USB Serial support registered for generic
[    3.301878] usbcore: registered new inte**ce driver option
[    3.307463] usbserial: USB Serial support registered for GSM modem (1-port)
[    3.314579] usbcore: registered new inte**ce driver pl2303
[    3.320163] usbserial: USB Serial support registered for pl2303
[    3.326116] usbcore: registered new inte**ce driver cdc_xr_usb_serial
[    3.332639] xr_usb_serial_common: Exar USB UART (serial port) driver
[    3.341830] i2c /dev entries driver
[    3.347265] IR NEC protocol handler initialized
[    3.351797] IR RC5(x/sz) protocol handler initialized
[    3.356870] IR RC6 protocol handler initialized
[    3.361398] IR JVC protocol handler initialized
[    3.365922] IR Sony protocol handler initialized
[    3.370534] IR SANYO protocol handler initialized
[    3.375234] IR Sharp protocol handler initialized
[    3.379934] IR MCE Keyboard/mouse protocol handler initialized
[    3.385759] IR XMP protocol handler initialized
[    3.392308] imx2-wdt 2ad0000.wdog: timeout 60 sec (nowayout=0)
[    3.398904] qoriq_cpufreq: Freescale QorIQ CPU frequency scaling driver
[    3.405883] sdhci: Secure Digital Host Controller Inte**ce driver
[    3.412059] sdhci: Copyright(c) Pierre Ossman
[    3.416597] Synopsys Designware ** Card Inte**ce Driver
[    3.423644] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.476148] mmc0: SDHCI controller on 1560000.esdhc [1560000.esdhc] using ADt
[    3.484175] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[    3.494676] ledtrig-cpu: registered to indicate activity on CPUs
[    3.503200] platform caam_qi: Linux CAAM Queue I/F driver initialised
[    3.509793] caam 1700000.crypto: device ID = 0x0a12060000000000 (Era 8)
[    3.516417] caam 1700000.crypto: job rings = 3, qi = 1, dpaa2 = no
[    3.523983] usb-storage 2-1:1.0: USB Mass Storage device detected
[    3.530438] scsi host1: usb-storage 2-1:1.0
[    3.535476] caam algorithms registered in /proc/crypto
[    3.542512] platform caam_qi: algorithms registered in /proc/crypto
[    3.549713] caam_jr 1710000.jr: registering rng-caam
[    3.554790] caam 1700000.crypto: caam pkc algorithms registered in /proc/cryo
[    3.562684] usbcore: registered new inte**ce driver usbhid
[    3.568311] usbhid: USB HID core driver
[    3.573189] Freescale USDPAA process driver
[    3.577412] fsl-usdpaa: no region found
[    3.581283] Freescale USDPAA process IRQ driver
[    3.587022] optee: probing for conduit method from DT.
[    3.592445] optee: initialized driver
[    3.596972] Netfilter messages via NETLINK v0.30.
[    3.601783] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    3.607975] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
[    3.614500] nf_tables_compat: (c) 2012 Pablo Neira Ayuso <pablo@netfilter.or>
[    3.621837] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.627361] Initializing XFRM netlink socket
[    3.631677] NET: Registered protocol family 10
[    3.636906] Segment Routing with IPv6
[    3.640619] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.646888] NET: Registered protocol family 17
[    3.651385] NET: Registered protocol family 15
[    3.655848] Bridge firewalling registered
[    3.659904] Ebtables v2.0 registered
[    3.663634] l2tp_core: L2TP core driver, V2.0
[    3.668039] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    3.672873] 8021q: 802.1Q VLAN Support v1.8
[    3.677120] 9pnet: Installing 9P2000 support
[    3.681469] Key type dns_resolver registered
[    3.686158] registered taskstats version 1
[    3.690631] Btrfs loaded, crc32c=crc32c-generic
[    3.696054] hctosys: unable to open rtc device (rtc0)
[    3.701245] ALSA device list:
[    3.704211]   No soundcards found.
[    3.707815] RAMDISK: gzip image found at block 0
[    3.969196] EXT4-fs (ram0): mounted filesystem with ordered data mode. Opts:)
[    3.976876] VFS: Mounted root (ext4 filesystem) on device 1:0.
[    3.982780] devtmpfs: mounted
[    3.986167] Freeing unused kernel memory: 1216K
[    4.544629] scsi 1:0:0:0: Direct-Access      USB      SanDisk 3.2Gen1 1.00 P6
[    4.553305] sd 1:0:0:0: [sda] 30605312 512-byte logical blocks: (15.7 GB/14.)
[    4.561774] sd 1:0:0:0: [sda] Write Protect is off
[    4.566825] sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doA
[    4.578481]  sda: sda1
[    4.581927] sd 1:0:0:0: [sda] Attached SCSI removable disk
[    7.059585] FAT-fs (sda1): Volume was not properly unmounted. Some data may .
|platform       |ok1043-c                                       [    7.089270] )
|rootfs         |ubuntu.img
|qspiflash      |false
|emmcflash      |true
[emmc partition]
2048+0 records in
2048+0 records out
1048576 bytes (1.0MB) copied, 0.005103 seconds, 196.0MB/s
parting, wait ...
part, done.
formating, wait ...
mkfs.vfat: can't open '/dev/[    7.169948] random: fast init done
format, done.
[emmc flash]
flashing, wait...
29270+1 records in
29270+1 records out
14986242 bytes (14.3MB) copied, 0.151306 seconds, 94.5MB/s
[    9.901153] random: crng init done
GMT+8, 2026-10-4 12:21
