查看: 41972|回复: 6
[OpenWrt] openwrt编译error
LS1043A\46A通行证
发表于 2021-4-27 21:29:47 | 显示全部楼层 |阅读模式
Created filesystem with 1175/16384 inodes and 5079/65536 blocks
rm -f /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046ardb-kernel.bin
cp /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/vmlinux /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046ardb-kernel.bin
gzip -9n -c /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046ardb-kernel.bin  > /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046ardb-kernel.bin.new
mkimage -A arm64 -O linux -T kernel -C gzip -a 0x80080000 -e 0x80080000 -n 'ARM64 LEDE Linux-4.9.63' -d /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046ardb-kernel.bin /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046ardb-kernel.bin.new
Image Name:   ARM64 LEDE Linux-4.9.63
Created:      Wed Dec 16 06:14:46 2020
Image Type:   AArch64 Linux Kernel Image (gzip compressed)
Data Size:    7278345 Bytes = 7107.76 kB = 6.94 MB
Load Address: 80080000
Entry Point:  80080000
mv /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046ardb-kernel.bin.new /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046ardb-kernel.bin
[ -f /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/ls1046ardb-kernel.bin -a -f /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/root.squashfs ]
rm -f /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/tmp/lede-layerscape-armv8_64b-ls1046ardb-squashfs-firmware.bin
dd if=/home/forlinx/work/OK104x-linux-openwrt-C2/staging_dir/target-aarch64_generic_musl/image/ls1046ardb-rcw.bin >> /home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/tmp/lede-layerscape-armv8_64b-ls1046ardb-squashfs-firmware.bin
dd: failed to open '/home/forlinx/work/OK104x-linux-openwrt-C2/staging_dir/target-aarch64_generic_musl/image/ls1046ardb-rcw.bin': No such file or directory
Makefile:170: recipe for target '/home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/tmp/lede-layerscape-armv8_64b-ls1046ardb-squashfs-firmware.bin' failed
make[5]: *** [/home/forlinx/work/OK104x-linux-openwrt-C2/build_dir/target-aarch64_generic_musl/linux-layerscape_armv8_64b/tmp/lede-layerscape-armv8_64b-ls1046ardb-squashfs-firmware.bin] Error 1
make[5]: Leaving directory '/home/forlinx/work/OK104x-linux-openwrt-C2/target/linux/layerscape/image'
Makefile:25: recipe for target 'install' failed
make[4]: *** [install] Error 2
make[4]: Leaving directory '/home/forlinx/work/OK104x-linux-openwrt-C2/target/linux/layerscape'
Makefile:13: recipe for target 'install' failed
make[3]: *** [install] Error 2
make[3]: Leaving directory '/home/forlinx/work/OK104x-linux-openwrt-C2/target/linux'
target/Makefile:23: recipe for target 'target/linux/install' failed
make[2]: *** [target/linux/install] Error 2
make[2]: Leaving directory '/home/forlinx/work/OK104x-linux-openwrt-C2'
target/Makefile:19: recipe for target '/home/forlinx/work/OK104x-linux-openwrt-C2/staging_dir/target-aarch64_generic_musl/stamp/.target_install' failed
make[1]: *** [/home/forlinx/work/OK104x-linux-openwrt-C2/staging_dir/target-aarch64_generic_musl/stamp/.target_install] Error 2
make[1]: Leaving directory '/home/forlinx/work/OK104x-linux-openwrt-C2'
/home/forlinx/work/OK104x-linux-openwrt-C2/include/toplevel.mk:216: recipe for target 'world' failed
make: *** [world] Error 2
源码解压没有改动编译。
发表于 2021-4-28 14:00:59 | 显示全部楼层
建议您再多编译几次,openwrt编译不是很容易编译通过
试过了,不行。还有其他原因吗?  详情 回复 发表于 2021-4-29 21:34
LS1043A\46A通行证
 楼主| 发表于 2021-4-29 21:34:10 | 显示全部楼层
试过了,不行。还有其他原因吗?
djh
没有了,只能多次编译,尽量单核编译,  详情 回复 发表于 2021-4-30 13:50
发表于 2021-4-30 13:50:41 | 显示全部楼层
csjtl 发表于 2021-4-29 21:34
试过了,不行。还有其他原因吗?
没有了,只能多次编译,尽量单核编译,
编译出的bin文件用什么方式刷入开发板?  详情 回复 发表于 2021-5-1 14:21
LS1043A\46A通行证
 楼主| 发表于 2021-5-1 14:21:24 | 显示全部楼层
djh 发表于 2021-4-30 13:50
没有了,只能多次编译,尽量单核编译,
LS1012A通行证LS1043A\46A通行证A40i/T3/T507/T527通行证LS1028A通行证
发表于 2021-10-30 23:45:51 | 显示全部楼层
djh
需要制作成.img格式的镜像,通过U盘烧写进开发板 关于openwrt系统的编译开发可以参考19年用户资料中的openwrt软件手册  详情 回复 发表于 2021-11-1 08:52
发表于 2021-11-1 08:52:13 | 显示全部楼层
GMT+8, 2026-10-4 10:26
