查看: 87695|回复: 6
[Linux] 开发板wifi模块8723bu存在严重问题
发表于 2021-5-7 20:39:50 | 显示全部楼层 |阅读模式
我用开发板自带的8723bu模块连接路由器热点后,尝试用scp或者ftp从开发板向PC机下载文件,文件大小400MB左右,传输大概3分钟时开发板的wifi模块自动断开连接,尝试rmmod后重新insmod后dmesg提示加载驱动失败,打印信息如下,此时再无法连接路由器热点,只有重启开发板才能再次正常使用wifi模块,此BUG使用开发板自带的镜像100%能复现
[  483.379610] RTW: USB_SPEED_HIGH
[  483.379619] RTW: CHIP TYPE: RTL8723BU
[  483.892202] RTW: reg 0xf0, usb read 4 fail, status:-110 value=0x0, vendorreq_times:1
[  484.412215] RTW: reg 0xf0, usb read 4 fail, status:-110 value=0x0, vendorreq_times:2
[  484.932291] RTW: reg 0xf0, usb read 4 fail, status:-110 value=0x0, vendorreq_times:3
[  485.452278] RTW: reg 0xf0, usb read 4 fail, status:-110 value=0x0, vendorreq_times:4
[  485.972307] RTW: reg 0xf0, usb read 4 fail, status:-110 value=0x0, vendorreq_times:5
[  485.972325] RTW: [dvobj:e2fdf000][ERROR] continual_io_error:5 > 4
[  485.972338] RTW: rtw_hal_config_rftype RF_Type is 0 TotalTxPath is 1
[  485.972349] RTW: Chip Version Info: CHIP_8723B_Normal_Chip_TSMC_A_CUT_1T1R_RomVer(0)
[  485.972360] RTW: _ConfigChipOutEP_8723 OutEpQueueSel(0x07), OutEpNumber(4)
[  485.972369] RTW: EEPROM type is E-FUSE
[  485.972378] RTW: Boot from EFUSE, Autoload Fail !
 楼主| 发表于 2021-5-7 20:43:39 | 显示全部楼层
连接路由器也是用手册的命令
insmod /lib/modules/$(uname -r)/8723bu.ko
wifi.sh -i 8723 -s **x -p 123456789
 楼主| 发表于 2021-5-7 20:45:33 | 显示全部楼层
wifi模块断开连接时驱动打印信息如下,看上去是usb接口通信失败了
[  179.392295] RTW: reg 0x508, usb write 4 fail, status:-110 value=0x5ea42b, vendorreq_times:1
[  179.912653] RTW: reg 0x508, usb write 4 fail, status:-110 value=0x5ea42b, vendorreq_times:2
[  180.432778] RTW: reg 0x508, usb write 4 fail, status:-110 value=0x5ea42b, vendorreq_times:3
[  180.952663] RTW: reg 0x508, usb write 4 fail, status:-110 value=0x5ea42b, vendorreq_times:4
[  181.472229] RTW: reg 0x508, usb write 4 fail, status:-110 value=0x5ea42b, vendorreq_times:5
[  181.472264] RTW: [dvobj:e3ccf000][ERROR] continual_io_error:5 > 4
[  181.872771] RTW: wlan0 cmd=57,2,0 process_time=3000
[  181.872798] RTW: rtw_cmd_thread: DriverStopped(False) SurpriseRemoved(True) break at line 583
[  181.872815] RTW: rtw_cmd_thread(wlan0) Exit
发表于 2021-5-27 14:29:12 | 显示全部楼层
您连接路由器热点后是怎么通过FTP传输文件的,您是如何ftp访问开发板的
用任何支持FTP或者SCP协议的软件都行,我用的是Windows下的WinSCP软件,通过scp登录开发板(官方固件),然后从开发板下载一个任意的几百兆的文件,大约传输5、6分钟就会出问题  详情 回复 发表于 2021-6-11 10:12
 楼主| 发表于 2021-6-11 10:12:35 | 显示全部楼层
发表于 2021-6-11 10:20:50 | 显示全部楼层
这边测试了一下,8723bu确实有这个问题,用8723du试了一下,没有问题,您可以用8723du试试,我们有移植的方法,您可以联系销售获取,芯片是 贴装WIFI+BT二合一模块  BL-M8723DU1,单天线
好的,谢谢  详情 回复 发表于 2021-6-16 11:37
 楼主| 发表于 2021-6-16 11:37:44 | 显示全部楼层
zhichao 发表于 2021-6-11 10:20
这边测试了一下,8723bu确实有这个问题,用8723du试了一下,没有问题,您可以用8723du试试,我们有移植的方 ...
好的,谢谢
GMT+8, 2026-9-21 07:02
