查看: 166609|回复: 5
[Linux] 4G模块测试
发表于 2021-6-6 18:46:56 | 显示全部楼层 |阅读模式
在超级终端上测试4G模块时,出现unknown怎么回事?
发表于 2021-6-7 13:39:42 | 显示全部楼层
有完整打印信息吗,发出来看看
FCU2401通行证
发表于 2021-9-29 18:00:20 | 显示全部楼层
  1. [08-28_17:52:15:322] WCDMA&LTE_QConnectManager_Linux&Android_V1.1.34
  2. [08-28_17:52:15:323] /usr/bin/quectel-CM profile[1] = (null)/(null)/(null)/0, pincode = (null)
  3. [08-28_17:52:15:324] Find /sys/bus/usb/devices/2-1.3 idVendor=2c7c idProduct=0125
  4. [08-28_17:52:15:324] Find /sys/bus/usb/devices/2-1.3:1.4/net/usb0
  5. [08-28_17:52:15:324] Find usbnet_adapter = usb0
  6. [08-28_17:52:15:325] Find /sys/bus/usb/devices/2-1.3:1.4/GobiQMI/qcqmi0
  7. [08-28_17:52:15:325] Find qmichannel = /dev/qcqmi0
  8. [08-28_17:52:15:408] Get clientWDS = 7
  9. [08-28_17:52:15:440] Get clientDMS = 8
  10. [08-28_17:52:15:472] Get clientNAS = 9
  11. [08-28_17:52:15:504] Get clientUIM = 10
  12. [08-28_17:52:15:536] Get clientWDA = 11
  13. [08-28_17:52:15:568] requestBaseBandVersion EC20CEHDLGR06A07M1G
  14. [08-28_17:52:15:664] requestGetSIMStatus SIMStatus: SIM_ABSENT
  15. [08-28_17:52:15:696] requestGetProfile[1] ctnet///0
  16. [08-28_17:52:15:728] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  17. [08-28_17:52:15:760] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
  18. [08-28_17:52:15:824] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  19. [08-28_17:52:20:944] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  20. [08-28_17:52:26:064] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  21. [08-28_17:52:31:184] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  22. [08-28_17:52:36:304] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  23. [08-28_17:52:41:424] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  24. [08-28_17:52:46:544] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  25. [08-28_17:52:51:664] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  26. [08-28_17:52:56:784] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  27. [08-28_17:53:01:904] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  28. [08-28_17:53:01:904] requestSetOperatingMode(1)
  29. [08-28_17:53:01:936] requestSetOperatingMode(0)
  30. [08-28_17:53:02:224] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
  31. [08-28_17:53:02:672] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  32. [08-28_17:53:02:704] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  33. [08-28_17:53:07:312] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  34. [08-28_17:53:12:432] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  35. [08-28_17:53:17:552] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  36. [08-28_17:53:22:672] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  37. [08-28_17:53:27:792] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  38. [08-28_17:53:32:912] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  39. [08-28_17:53:38:032] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  40. [08-28_17:53:43:152] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  41. [08-28_17:53:48:272] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  42. [08-28_17:53:48:272] requestSetOperatingMode(1)
  43. [08-28_17:53:48:304] requestSetOperatingMode(0)
  44. [08-28_17:53:48:592] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
  45. [08-28_17:53:49:072] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  46. [08-28_17:53:49:104] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  47. [08-28_17:53:53:680] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  48. [08-28_17:53:58:800] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  49. [08-28_17:54:03:920] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  50. [08-28_17:54:09:040] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  51. [08-28_17:54:14:160] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
  52. [08-28_17:54:16:592] GobiNetThread exit
  53. [08-28_17:54:16:592] main exit
我也有时候遇到,来咨询一下。以上是一条完整的,其它的基本都是一致,直到拨号程序退出
您看一下您用的手机卡是不是物联网卡,从打印信息上看是识别到卡有问题,正常是 requestGetSIMStatus SIMStatus: SIM_READY,您这个是SIM_ABSENT,应该是卡没有正常识别,您可以换张SIM卡试试,尽量用普通手机卡,物  详情 回复 发表于 2021-9-30 10:46
发表于 2021-9-30 10:46:27 | 显示全部楼层
您看一下您用的手机卡是不是物联网卡,从打印信息上看是识别到卡有问题,正常是 requestGetSIMStatus SIMStatus: SIM_READY,您这个是SIM_ABSENT,应该是卡没有正常识别,您可以换张SIM卡试试,尽量用普通手机卡,物联网卡需要apn拨号
对的 ,我们使用的是物联网卡。我们采购的设备都是使用的这种卡,有时候会出现这样的问题。不知道有什么好的解决方案?  详情 回复 发表于 2021-9-30 16:16
FCU2401通行证
发表于 2021-9-30 16:16:55 | 显示全部楼层
zhichao 发表于 2021-9-30 10:46
您看一下您用的手机卡是不是物联网卡,从打印信息上看是识别到卡有问题,正常是 requestGetSIMStatus SIM ...
发表于 2021-9-30 16:29:38 | 显示全部楼层
应该是需要AT指令设置一些参数,比如
1. 物联网卡的APN
2. 物联网卡的鉴权模式:PAP还是CHAP,或者是认证回退
3. 物联网卡的用户名
4. 物联网卡的密码
具体可以百度一下
GMT+8, 2026-9-21 06:19
