查看: 10084|回复: 1
[Linux] OKA40i开发板镜像打包失败
发表于 2021-6-19 15:49:19 | 显示全部楼层 |阅读模式
按照OKA40i-C&OKT3-C-Linux-软件用户手册-V1.5-20201218 手册操作全源码编译成功了,但是在打包烧写镜像的时候失败了。下面是全源码编译和打包镜像时的log
  1. manyi@manyi-virtual-machine:~/work/lichee$ ./build.sh config
  2. Welcome to mkscript setup progress
  3. All available chips:
  4.    0. sun8iw11p1
  5. Choice: 0
  6. All available platforms:
  7.    0. android
  8.    1. dragonboard
  9.    2. linux
  10.    3. camdroid
  11. Choice: 2
  12. All available kernel:
  13.    0. linux-3.10
  14. Choice: 0
  15. All available boards:
  16.    0. OKA40i_C
  17.    1. OKT3_C
  18.    2. a40i-p3
  19. Choice: 0
  20. All available buildroot:
  21.   0. buildroot
  22.   1. buildroot-201611
  23. Choice: 1
  24. select buildroot-201611
  25. All available float:
  26.   0. gnueabi
  27.   1. gnueabihf
  28. Choice: 1
  29. select gnueabihf
  30. All available qt version:
  31.   0. 5.9.0
  32. Choice: 0
  33. select 5.9.0
  34. create misc_config gnueabihf
  35. All available lcd resolutions:
  36.    0. 480x272
  37.    1. 800x480
  38.    2. 800x600
  39.    3. 1024x600
  40.    4. 1024x600mipi
  41.    5. 1280x800
  42.    6. 800x480_v1
  43.    7. 800x600_v1
  44.    8. 1024x600_v1
  45.    9. 1024x600mipi_v1
  46.   10. 1280x800_v1
  47. Choice: 5
  48. manyi@manyi-virtual-machine:~/work/lichee$ ./build.sh
  49. build buidroot-201611...
  50. xgnueabihf
  51. sun8iw11p1_hf_defconfig
  52. INFO: ----------------------------------------
  53. INFO: build lichee ...
  54. INFO: chip: sun8iw11p1
  55. INFO: platform: linux
  56. INFO: kernel: linux-3.10
  57. INFO: board: OKA40i_C
  58. INFO: output: out/sun8iw11p1/linux/OKA40i_C
  59. INFO: ----------------------------------------
  60. INFO: build buildroot ...
  61. make: Entering directory '/home/manyi/work/lichee/buildroot-201611'
  62. >>>   Finalizing target directory
  63. rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/glib-2.0/schemas/*.xml /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/glib-2.0/schemas/*.dtd
  64. /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/glib-compile-schemas /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/share/glib-2.0/schemas --targetdir=/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/glib-2.0/schemas
  65. PYTHONPATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7/sysconfigdata/:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7/site-packages/" /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/python2.7 support/scripts/pycompile.py /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7
  66. find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7 -name '*.py' -print0 | xargs -0 --no-run-if-empty rm -f
  67. find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7 -name '*.pyo' -print0 | xargs -0 --no-run-if-empty rm -f
  68. mkdir -p /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc
  69. echo "A40i" > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/hostname
  70. /bin/sed -i -e '$a \127.0.1.1\tA40i' -e '/^127.0.1.1/d' /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/hosts
  71. mkdir -p /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc
  72. echo "Welcome to Allwinner A40i Linux Platform V1.3" > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/issue
  73. mkdir -p /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/network/
  74. ( echo "# inte**ce file auto-generated by buildroot"; echo ; echo "auto lo"; echo "iface lo inet loopback"; echo ; echo "allow-hotplug eth0"; echo "iface eth0 inet dhcp"; ) > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/network/inte**ces
  75. /bin/sed -i -e s,^root:[^:]*:,root::, /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/shadow
  76. ln -sf bash /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/bin/sh
  77. /bin/sed -i -e '/# GENERIC_SERIAL$/s~^.*#~ttyS0::respawn:/sbin/getty -L  ttyS0 115200 vt100 #~' /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/inittab
  78. /bin/sed -i -e '/^#.*-o remount,rw \/$/s~^#\+~~' /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/inittab
  79. rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/locales.nopurge
  80. for i in C en_US locale-archive; do echo $i >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/locales.nopurge; done
  81. for dir in /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/locale; do for langdir in $dir/*; do if [ -e "${langdir}" ]; then grep -qx "${langdir##*/}" /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/locales.nopurge || rm -rf $langdir; fi done; done
  82. if [ -d /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/X11/locale ]; then for lang in C en_US; do if [ -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/X11/locale/$lang/XLC_LOCALE ]; then echo "$lang/XLC_LOCALE: $lang"; fi done > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/X11/locale/locale.dir; fi
  83. rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/include /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/aclocal \
  84.         /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/pkgconfig /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/pkgconfig \
  85.         /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/cmake /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/cmake
  86. find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/{lib,share}/ -name '*.cmake' -print0 | xargs -0 rm -f
  87. find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/lib/ /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/ /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/libexec/ \
  88.         \( -name '*.a' -o -name '*.la' \) -print0 | xargs -0 rm -f
  89. rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/zsh
  90. rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/man /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/man
  91. rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/info /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/info
  92. rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/doc /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/doc
  93. rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/gtk-doc
  94. rmdir /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share 2>/dev/null
  95. make[1]: [Makefile:648: target-finalize] Error 1 (ignored)
  96. find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target -type f \( -perm /111 -o -name '*.so*' \) -not \( -name 'libpthread*.so*' -o -name 'ld-*.so*' -o -name '*.ko' \) -print0 | xargs -0 /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/arm-linux-gnueabihf-strip --remove-section=.comment --remove-section=.note 2>/dev/null || true
  97. find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/lib/ -type f -name 'libpthread*.so*' | \
  98.         xargs -r /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/arm-linux-gnueabihf-strip --remove-section=.comment --remove-section=.note --strip-debug
  99. find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/lib/ -type f -name 'ld-*.so*' | \
  100.         xargs -r /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/arm-linux-gnueabihf-strip --remove-section=.comment --remove-section=.note --strip-debug
  101. test -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/ld.so.conf && \
  102.         { echo "ERROR: we shouldn't have a /etc/ld.so.conf file"; exit 1; } || true
  103. test -d /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/ld.so.conf.d && \
  104.         { echo "ERROR: we shouldn't have a /etc/ld.so.conf.d directory"; exit 1; } || true
  105. mkdir -p /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc
  106. ( \
  107.         echo "NAME=Buildroot"; \
  108.         echo "VERSION=2016.11"; \
  109.         echo "ID=buildroot"; \
  110.         echo "VERSION_ID=2016.11"; \
  111.         echo "PRETTY_NAME="Buildroot 2016.11"" \
  112. ) >  /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/os-release
  113. >>>   Executing post-build script target/user_rootfs_build.sh
  114. run user rootfs build script------------genrootfs =
  115. not genrootfs DO NOT compile sdk lib
  116. >>>   Generating root filesystem image rootfs.tar
  117. rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  118. rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
  119. rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt
  120. echo '#!/bin/sh' > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  121. echo "set -e" >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  122. echo "chown -h -R 0:0 /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target" >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  123. printf '           dbus -1 dbus -1 * /var/run/dbus - dbus DBus messagebus user\n         - - docker -1 * - - - Docker Application Container Framework\n         - - input -1 * - - - Input device group\n         sshd -1 sshd -1 * - - - SSH drop priv user\n         ftp -1 ftp -1 * /home/ftp - - Anonymous FTP User\n\n' >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt
  124. PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /home/manyi/work/lichee/buildroot-201611/support/scripts/mkusers /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  125. /home/manyi/work/lichee/buildroot-201611/support/scripts/mkusers: line 417: [: -ge: unary operator expected
  126. /home/manyi/work/lichee/buildroot-201611/support/scripts/mkusers: line 426: [: -eq: unary operator expected
  127. cat system/device_table.txt > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt
  128. printf '           /bin/busybox                     f 4755 0  0 - - - - -\n         /usr/libexec/dbus-daemon-launch-helper f 4755 0 0 - - - - -\n /dev/console c 622 0 0 5 1 - - -\n\n' >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt
  129. echo "/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/makedevs -d /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target" >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  130. printf '           tar  -cf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.tar --numeric-owner -C /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target .\n' >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  131. chmod a+x /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  132. PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/fakeroot -- /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  133. rootdir=/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target
  134. table='/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt'
  135. /usr/bin/install -m 0644 support/misc/target-dir-warning.txt /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
  136. PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" gzip -9 -c /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.tar > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.tar.gz
  137. make: Leaving directory '/home/manyi/work/lichee/buildroot-201611'
  138. INFO: build buildroot OK.
  139. INFO: build kernel ...
  140. INFO: prepare toolchain of sun8iw11p1...
  141. error format,file shoule end with gz or xz or none
  142. Building kernel
  143. /home/manyi/work/lichee/linux-3.10/output/lib/modules/3.10.65
  144. Copy rootfs for arm
  145. rootfs_32bit.cpio_buildroot_201611.gz
  146.   CHK     include/generated/uapi/linux/version.h
  147.   CHK     include/generated/utsrelease.h
  148. make[1]: “include/generated/mach-types.h”已是最新。
  149.   CC      scripts/mod/devicetable-offsets.s
  150.   CALL    scripts/checksyscalls.sh
  151.   GEN     scripts/mod/devicetable-offsets.h
  152.   HOSTCC  scripts/mod/file2alias.o
  153.   HOSTLD  scripts/mod/modpost
  154.   CHK     include/generated/compile.h
  155.   CHK     kernel/config_data.h
  156.   CC      drivers/soc/allwinner/pm/standby/common.o
  157.   CC      drivers/soc/allwinner/pm/standby/standby_twi.o
  158.   CC      drivers/soc/allwinner/pm/standby/power/axp_power.o
  159.   CC      drivers/soc/allwinner/pm/standby/power/axp15_power.o
  160.   CC      drivers/soc/allwinner/pm/standby/power/axp22_power.o
  161.   CC      drivers/soc/allwinner/pm/standby/power/axp20_power.o
  162.   CC      drivers/soc/allwinner/pm/standby/power/standby_power.o
  163. drivers/soc/allwinner/pm/standby/power/standby_power.c: In function 'pmu_get_voltage':
  164. drivers/soc/allwinner/pm/standby/power/standby_power.c:41:9: warning: implicit declaration of function 'axp20_get_volt' [-Wimplicit-function-declaration]
  165.    ret = axp20_get_volt(tree);
  166.          ^
  167. drivers/soc/allwinner/pm/standby/power/standby_power.c:44:9: warning: implicit declaration of function 'axp22_get_volt' [-Wimplicit-function-declaration]
  168.    ret = axp22_get_volt(tree);
  169.          ^
  170. drivers/soc/allwinner/pm/standby/power/standby_power.c:57:9: warning: implicit declaration of function 'axp15_get_volt' [-Wimplicit-function-declaration]
  171.    ret = axp15_get_volt(tree);
  172.          ^
  173. drivers/soc/allwinner/pm/standby/power/standby_power.c: In function 'pmu_set_voltage':
  174. drivers/soc/allwinner/pm/standby/power/standby_power.c:82:9: warning: implicit declaration of function 'axp20_set_volt' [-Wimplicit-function-declaration]
  175.    ret = axp20_set_volt(tree, voltage);
  176.          ^
  177. drivers/soc/allwinner/pm/standby/power/standby_power.c:85:9: warning: implicit declaration of function 'axp22_set_volt' [-Wimplicit-function-declaration]
  178.    ret = axp22_set_volt(tree, voltage);
  179.          ^
  180. drivers/soc/allwinner/pm/standby/power/standby_power.c:98:9: warning: implicit declaration of function 'axp15_set_volt' [-Wimplicit-function-declaration]
  181.    ret = axp15_set_volt(tree, voltage);
  182.          ^
  183. drivers/soc/allwinner/pm/standby/power/standby_power.c: In function 'pmu_get_state':
  184. drivers/soc/allwinner/pm/standby/power/standby_power.c:126:9: warning: implicit declaration of function 'axp20_get_state' [-Wimplicit-function-declaration]
  185.    ret = axp20_get_state(tree);
  186.          ^
  187. drivers/soc/allwinner/pm/standby/power/standby_power.c:129:9: warning: implicit declaration of function 'axp22_get_state' [-Wimplicit-function-declaration]
  188.    ret = axp22_get_state(tree);
  189.          ^
  190. drivers/soc/allwinner/pm/standby/power/standby_power.c:142:9: warning: implicit declaration of function 'axp15_get_state' [-Wimplicit-function-declaration]
  191.    ret = axp15_get_state(tree);
  192.          ^
  193. drivers/soc/allwinner/pm/standby/power/standby_power.c: In function 'pmu_set_state':
  194. drivers/soc/allwinner/pm/standby/power/standby_power.c:170:9: warning: implicit declaration of function 'axp20_set_state' [-Wimplicit-function-declaration]
  195.    ret = axp20_set_state(tree, state);
  196.          ^
  197. drivers/soc/allwinner/pm/standby/power/standby_power.c:173:9: warning: implicit declaration of function 'axp22_set_state' [-Wimplicit-function-declaration]
  198.    ret = axp22_set_state(tree, state);
  199.          ^
  200. drivers/soc/allwinner/pm/standby/power/standby_power.c:186:9: warning: implicit declaration of function 'axp15_set_state' [-Wimplicit-function-declaration]
  201.    ret = axp15_set_state(tree, state);
  202.          ^
  203. drivers/soc/allwinner/pm/standby/power/standby_power.c: In function 'pmu_suspend_calc':
  204. drivers/soc/allwinner/pm/standby/power/standby_power.c:215:9: warning: implicit declaration of function 'axp20_suspend_calc' [-Wimplicit-function-declaration]
  205.    ret = axp20_suspend_calc(mask, func);
  206.          ^
  207. drivers/soc/allwinner/pm/standby/power/standby_power.c:219:9: warning: implicit declaration of function 'axp22_suspend_calc' [-Wimplicit-function-declaration]
  208.    ret = axp22_suspend_calc(mask, func);
  209.          ^
  210. drivers/soc/allwinner/pm/standby/power/standby_power.c:232:9: warning: implicit declaration of function 'axp15_suspend_calc' [-Wimplicit-function-declaration]
  211.    ret = axp15_suspend_calc(mask, func);
  212.          ^
  213.   CC      drivers/soc/allwinner/pm/standby/standby_clock.o
  214.   CC      drivers/soc/allwinner/pm/standby/standby_debug.o
  215.   AS      drivers/soc/allwinner/pm/standby/standby_divlib.o
  216.   CC      drivers/soc/allwinner/pm/standby/standby_dram.o
  217.   AS      drivers/soc/allwinner/pm/standby/./../mem_mmu_pc_asm.o
  218.   CC      drivers/soc/allwinner/pm/standby/./../mem_divlibc.o
  219.   CC      drivers/soc/allwinner/pm/standby/./../mem_clk.o
  220.   CC      drivers/soc/allwinner/pm/standby/./../mem_timing.o
  221.   CC      drivers/soc/allwinner/pm/standby/./../mem_serial.o
  222.   CC      drivers/soc/allwinner/pm/standby/./../mem_printk.o
  223.   CC      drivers/soc/allwinner/pm/standby/./../pm_debug.o
  224.   CC      drivers/soc/allwinner/pm/standby/main.o
  225. drivers/soc/allwinner/pm/standby/main.c: In function 'standby_main':
  226. drivers/soc/allwinner/pm/standby/main.c:135:3: warning: implicit declaration of function 'power_enter_super_calc' [-Wimplicit-function-declaration]
  227.    power_enter_super_calc(&pm_info, &extended_standby_para_info,
  228.    ^
  229. drivers/soc/allwinner/pm/standby/main.c:144:3: warning: implicit declaration of function 'standby_twi_init_losc' [-Wimplicit-function-declaration]
  230.    standby_twi_init_losc(pm_info.pmu_arg.twi_port);
  231.    ^
  232. drivers/soc/allwinner/pm/standby/main.c: In function 'bus_enter_lowfreq':
  233. drivers/soc/allwinner/pm/standby/main.c:332:3: warning: implicit declaration of function 'standby_clk_ldodisable' [-Wimplicit-function-declaration]
  234.    standby_clk_ldodisable();
  235.    ^
  236. drivers/soc/allwinner/pm/standby/main.c: In function 'bus_freq_resume':
  237. drivers/soc/allwinner/pm/standby/main.c:342:3: warning: implicit declaration of function 'standby_clk_ldoenable' [-Wimplicit-function-declaration]
  238.    standby_clk_ldoenable();
  239.    ^
  240.   CC      drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.o
  241. drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c: In function 'dram_udelay':
  242. drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c:30:2: warning: implicit declaration of function 'change_runtime_env' [-Wimplicit-function-declaration]
  243.   change_runtime_env();
  244.   ^
  245. drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c:31:2: warning: implicit declaration of function 'delay_us' [-Wimplicit-function-declaration]
  246.   delay_us(n);
  247.   ^
  248. In file included from drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c:18:0:
  249. drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c: In function 'mctl_channel_init_standby':
  250. drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_hal-sun8iw11.h:77:35: warning: implicit declaration of function 'printk' [-Wimplicit-function-declaration]
  251. #define dram_dbg_0(fmt, args...)  printk(fmt, ##args)
  252.                                    ^
  253. drivers/soc/allwinner/pm/standby/dram/sun8iw11p1/mctl_standby-sun8iw11.c:713:2: note: in expansion of macro 'dram_dbg_0'
  254.   dram_dbg_0("mctl_channel_init_standby\n");
  255.   ^
  256.   AS      drivers/soc/allwinner/pm/standby.o
  257.   CC      drivers/soc/allwinner/pm/mem_divlibc.o
  258.   CC      drivers/soc/allwinner/pm/mem_int.o
  259.   CC      drivers/soc/allwinner/pm/mem_clk.o
  260.   CC      drivers/soc/allwinner/pm/mem_gpio.o
  261.   CC      drivers/soc/allwinner/pm/mem_timing.o
  262.   LD      drivers/video/sunxi/disp2/hdmi/hdmi.o
  263.   LD      drivers/video/sunxi/disp2/hdmi/built-in.o
  264.   LD      drivers/video/sunxi/built-in.o
  265.   CC      drivers/soc/allwinner/pm/mem_serial.o
  266.   LD      drivers/video/built-in.o
  267.   LD      drivers/soc/allwinner/pm/pm_tmp.o
  268.   LD      drivers/soc/allwinner/pm/built-in.o
  269.   LD      drivers/soc/allwinner/built-in.o
  270.   LD      drivers/soc/built-in.o
  271.   LD      drivers/built-in.o
  272.   LINK    vmlinux
  273.   LD      vmlinux.o
  274.   MODPOST vmlinux.o
  275. WARNING: modpost: Found 1 section mismatch(es).
  276. To see full details build your kernel with:
  277. 'make CONFIG_DEBUG_SECTION_MISMATCH=y'
  278.   GEN     .version
  279.   CHK     include/generated/compile.h
  280.   UPD     include/generated/compile.h
  281.   CC      init/version.o
  282.   LD      init/built-in.o
  283.   KSYM    .tmp_kallsyms1.o
  284.   KSYM    .tmp_kallsyms2.o
  285.   LD      vmlinux
  286.   SORTEX  vmlinux
  287.   SYSMAP  System.map
  288.   OBJCOPY arch/arm/boot/Image
  289.   Building modules, stage 2.
  290.   MODPOST 23 modules
  291.   Kernel: arch/arm/boot/Image is ready
  292.   GZIP    arch/arm/boot/compressed/piggy.gzip
  293.   AS      arch/arm/boot/compressed/piggy.gzip.o
  294.   LD      arch/arm/boot/compressed/vmlinux
  295.   OBJCOPY arch/arm/boot/zImage
  296.   Kernel: arch/arm/boot/zImage is ready
  297.   UIMAGE  arch/arm/boot/uImage
  298. Image Name:   Linux-3.10.65
  299. Created:      Sat Jun 19 15:29:59 2021
  300. Image Type:   ARM Linux Kernel Image (uncompressed)
  301. Data Size:    5159544 Bytes = 5038.62 KiB = 4.92 MiB
  302. Load Address: 40008000
  303. Entry Point:  40008000
  304.   Image arch/arm/boot/uImage is ready
  305. 'arch/arm/boot/Image' -> 'output/bImage'
  306. 'arch/arm/boot/uImage' -> 'output/uImage'
  307. 'arch/arm/boot/zImage' -> 'output/zImage'
  308. Building modules
  309. build nand library /home/manyi/work/lichee/linux-3.10/modules/nand/sun8iw11p1/lib
  310. build nand with existing library
  311. make: Entering directory '/home/manyi/work/lichee/linux-3.10/modules/nand'
  312. make -C /home/manyi/work/lichee/linux-3.10 M=/home/manyi/work/lichee/linux-3.10/modules/nand
  313. make[1]: Entering directory '/home/manyi/work/lichee/linux-3.10'
  314.   LD [M]  /home/manyi/work/lichee/linux-3.10/modules/nand/sun8iw11p1/nand.o
  315.   Building modules, stage 2.
  316.   MODPOST 1 modules
  317.   LD [M]  /home/manyi/work/lichee/linux-3.10/modules/nand/sun8iw11p1/nand.ko
  318. make[1]: Leaving directory '/home/manyi/work/lichee/linux-3.10'
  319. make: Leaving directory '/home/manyi/work/lichee/linux-3.10/modules/nand'
  320. [GPU]: Building mali400 device driver...
  321. make: Entering directory '/home/manyi/work/lichee/linux-3.10/modules/gpu'
  322. make -j -C mali400/kernel_mode/driver/src/devicedrv/mali BUILD=release
  323. make[1]: Entering directory '/home/manyi/work/lichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali'
  324. make ARCH=arm -C /home/manyi/work/lichee/linux-3.10 M=/home/manyi/work/lichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali modules
  325. make[2]: Entering directory '/home/manyi/work/lichee/linux-3.10'
  326.   CC [M]  /home/manyi/work/lichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali/__malidrv_build_info.o
  327.   LD [M]  /home/manyi/work/lichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali/mali.o
  328.   Building modules, stage 2.
  329.   MODPOST 1 modules
  330.   CC      /home/manyi/work/lichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali/mali.mod.o
  331.   LD [M]  /home/manyi/work/lichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali/mali.ko
  332. make[2]: Leaving directory '/home/manyi/work/lichee/linux-3.10'
  333. make[1]: Leaving directory '/home/manyi/work/lichee/linux-3.10/modules/gpu/mali400/kernel_mode/driver/src/devicedrv/mali'
  334. 'mali400/kernel_mode/driver/src/devicedrv/mali/mali.ko' -> '/home/manyi/work/lichee/linux-3.10/output/lib/modules/3.10.65/mali.ko'
  335. make: Leaving directory '/home/manyi/work/lichee/linux-3.10/modules/gpu'
  336. [GPU]: mali400 device driver has been built.
  337. regenerate rootfs cpio
  338. 4283 blocks
  339. 5004 blocks
  340. build_ramfs
  341. Copy boot.img to output directory ...
  342. Copy modules to target ...
  343. ./scripts/build.sh
  344. sun8iw11p1 compile Kernel successful
  345. INFO: build kernel OK.
  346. INFO: build rootfs ...
  347. /home/manyi/work/lichee/out/sun8iw11p1/linux/common
  348. make: Entering directory '/home/manyi/work/lichee/buildroot-201611'
  349. >>>   Finalizing target directory
  350. rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/glib-2.0/schemas/*.xml /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/glib-2.0/schemas/*.dtd
  351. /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/glib-compile-schemas /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/share/glib-2.0/schemas --targetdir=/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/glib-2.0/schemas
  352. PYTHONPATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7/sysconfigdata/:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7/site-packages/" /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/python2.7 support/scripts/pycompile.py /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7
  353. find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7 -name '*.py' -print0 | xargs -0 --no-run-if-empty rm -f
  354. find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/python2.7 -name '*.pyo' -print0 | xargs -0 --no-run-if-empty rm -f
  355. mkdir -p /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc
  356. echo "A40i" > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/hostname
  357. /bin/sed -i -e '$a \127.0.1.1\tA40i' -e '/^127.0.1.1/d' /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/hosts
  358. mkdir -p /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc
  359. echo "Welcome to Allwinner A40i Linux Platform V1.3" > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/issue
  360. mkdir -p /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/network/
  361. ( echo "# inte**ce file auto-generated by buildroot"; echo ; echo "auto lo"; echo "iface lo inet loopback"; echo ; echo "allow-hotplug eth0"; echo "iface eth0 inet dhcp"; ) > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/network/inte**ces
  362. /bin/sed -i -e s,^root:[^:]*:,root::, /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/shadow
  363. ln -sf bash /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/bin/sh
  364. /bin/sed -i -e '/# GENERIC_SERIAL$/s~^.*#~ttyS0::respawn:/sbin/getty -L  ttyS0 115200 vt100 #~' /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/inittab
  365. /bin/sed -i -e '/^#.*-o remount,rw \/$/s~^#\+~~' /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/inittab
  366. rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/locales.nopurge
  367. for i in C en_US locale-archive; do echo $i >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/locales.nopurge; done
  368. for dir in /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/locale; do for langdir in $dir/*; do if [ -e "${langdir}" ]; then grep -qx "${langdir##*/}" /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/locales.nopurge || rm -rf $langdir; fi done; done
  369. if [ -d /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/X11/locale ]; then for lang in C en_US; do if [ -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/X11/locale/$lang/XLC_LOCALE ]; then echo "$lang/XLC_LOCALE: $lang"; fi done > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/X11/locale/locale.dir; fi
  370. rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/include /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/aclocal \
  371.         /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/pkgconfig /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/pkgconfig \
  372.         /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/cmake /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/cmake
  373. find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/{lib,share}/ -name '*.cmake' -print0 | xargs -0 rm -f
  374. find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/lib/ /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/ /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/libexec/ \
  375.         \( -name '*.a' -o -name '*.la' \) -print0 | xargs -0 rm -f
  376. rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/zsh
  377. rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/man /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/man
  378. rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/info /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/info
  379. rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/doc /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/doc
  380. rm -rf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share/gtk-doc
  381. rmdir /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/share 2>/dev/null
  382. make[1]: [Makefile:648: target-finalize] Error 1 (ignored)
  383. find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target -type f \( -perm /111 -o -name '*.so*' \) -not \( -name 'libpthread*.so*' -o -name 'ld-*.so*' -o -name '*.ko' \) -print0 | xargs -0 /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/arm-linux-gnueabihf-strip --remove-section=.comment --remove-section=.note 2>/dev/null || true
  384. find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/lib/ -type f -name 'libpthread*.so*' | \
  385.         xargs -r /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/arm-linux-gnueabihf-strip --remove-section=.comment --remove-section=.note --strip-debug
  386. find /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/lib/ -type f -name 'ld-*.so*' | \
  387.         xargs -r /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/arm-linux-gnueabihf-strip --remove-section=.comment --remove-section=.note --strip-debug
  388. test -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/ld.so.conf && \
  389.         { echo "ERROR: we shouldn't have a /etc/ld.so.conf file"; exit 1; } || true
  390. test -d /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/ld.so.conf.d && \
  391.         { echo "ERROR: we shouldn't have a /etc/ld.so.conf.d directory"; exit 1; } || true
  392. mkdir -p /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc
  393. ( \
  394.         echo "NAME=Buildroot"; \
  395.         echo "VERSION=2016.11"; \
  396.         echo "ID=buildroot"; \
  397.         echo "VERSION_ID=2016.11"; \
  398.         echo "PRETTY_NAME="Buildroot 2016.11"" \
  399. ) >  /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/etc/os-release
  400. >>>   Executing post-build script target/user_rootfs_build.sh
  401. run user rootfs build script------------genrootfs = y
  402. cp: target '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/target/bin/' is not a directory
  403. rm: cannot remove '*.a': No such file or directory
  404. rm: cannot remove '*.la': No such file or directory
  405. libsdk.so compile ok!!!
  406. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libMemAdapter.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libMemAdapter.so'
  407. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libOmxVdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libOmxVdec.so'
  408. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libOmxVenc.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libOmxVenc.so'
  409. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libVE.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libVE.so'
  410. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libadecoder.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libadecoder.so'
  411. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaencoder.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaencoder.so'
  412. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_aacdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_aacdec.so'
  413. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_alacdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_alacdec.so'
  414. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_amrdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_amrdec.so'
  415. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_apedec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_apedec.so'
  416. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_atrcdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_atrcdec.so'
  417. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_cookdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_cookdec.so'
  418. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_dsddec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_dsddec.so'
  419. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_flacdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_flacdec.so'
  420. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_g729dec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_g729dec.so'
  421. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_mp3dec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_mp3dec.so'
  422. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_oggdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_oggdec.so'
  423. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_opusdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_opusdec.so'
  424. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_radec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_radec.so'
  425. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_siprdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_siprdec.so'
  426. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libaw_wavdec.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libaw_wavdec.so'
  427. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawavs.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawavs.so'
  428. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawh264.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawh264.so'
  429. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawh265.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawh265.so'
  430. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmjpeg.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmjpeg.so'
  431. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmjpegplus.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmjpegplus.so'
  432. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmpeg2.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmpeg2.so'
  433. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmpeg4base.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmpeg4base.so'
  434. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmpeg4dx.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmpeg4dx.so'
  435. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmpeg4h263.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmpeg4h263.so'
  436. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmpeg4normal.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmpeg4normal.so'
  437. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawmpeg4vp6.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawmpeg4vp6.so'
  438. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawrecorder.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawrecorder.so'
  439. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawvp8.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawvp8.so'
  440. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawvp9Hw.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawvp9Hw.so'
  441. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libawwmv3.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libawwmv3.so'
  442. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdc_base.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdc_base.so'
  443. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdc_omxil_core.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdc_omxil_core.so'
  444. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdx_base.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdx_base.so'
  445. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdx_common.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdx_common.so'
  446. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdx_muxer.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdx_muxer.so'
  447. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdx_parser.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdx_parser.so'
  448. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdx_playback.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdx_playback.so'
  449. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcdx_stream.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcdx_stream.so'
  450. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcrypto.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcrypto.so'
  451. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libcrypto.so.1.0.0' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libcrypto.so.1.0.0'
  452. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libsalsa.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libsalsa.so'
  453. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libssl.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libssl.so'
  454. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libssl.so.1.0.0' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libssl.so.1.0.0'
  455. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libsubdecoder.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libsubdecoder.so'
  456. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libvdecoder.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libvdecoder.so'
  457. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libvencoder.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libvencoder.so'
  458. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libvideoengine.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libvideoengine.so'
  459. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libxmetadataretriever.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libxmetadataretriever.so'
  460. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libxml2.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libxml2.so'
  461. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libxml2.so.2' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libxml2.so.2'
  462. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libxml2.so.2.9.4' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libxml2.so.2.9.4'
  463. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libxplayer.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libxplayer.so'
  464. '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_lib/cedarx/lib_hf/libz.so' -> '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/usr/lib/libz.so'
  465. make[2]: Nothing to be done for 'all'.
  466. cp: cannot stat '/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/sdktest/eve_module/classifier/*': No such file or directory
  467. make[2]: Nothing to be done for 'all'.
  468. make[2]: Nothing to be done for 'all'.
  469. make finish!!!
  470. make[2]: Nothing to be done for 'all'.
  471. make[2]: Nothing to be done for 'all'.
  472. echo ----------vproxy---------
  473. ----------vproxy---------
  474. /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-g++ --sysroot=/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot -c ./videoprosy.cpp -o ./videopro.o -rdynamic -fPIC -shared   -DUSE_LOGCAT -DHAVE_PTHREADS -DHAVE_SYS_UIO_H -DANDROID_SMP=1 -D__ARM_HAVE_DMB -D__ARM_HAVE_LDREX_STREX  -DHAVE_POSIX_CLOCKS -DHAVE_PRCTL -DWATERMARK -DCDX_V27  -DSUPPORT_NEW_DRIVER  -D_GNU_SOURCE -DCONFIG_CHIP=7 -DCONFIG_TARGET_PRODUCT= -DCONFIG_PRODUCT=2 -DCONFIG_VE_IPC=1 -DROTATE_PIC_HW=0 -DVE_PHY_OFFSET=0x40000000 -DCONFIG_LOG_LEVEL=0   -I-I./ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/include/disp2 -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/include/utils -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib//include/cutils/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/media -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/camera -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/camera/moudle -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/camera/allwinnertech/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/camera/allwinnertech/water_mark/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/camera/adas/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/storage/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/sound/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/memory/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/misc/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/audioenc/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/eve_module/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/eve_module -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../tools/pack/chips/sun8iw11p1/hal/gpu/fbdev_hf/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/glib-2.0/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/lib/glib-2.0/include/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/gio-unix-2.0/  -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/adecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/aencoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/alsa/sound -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/adecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/libxml -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/live -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/openssl -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/sdecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/external/include/zlib -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcedarc/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/base/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/muxer/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/parser/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/playback/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/stream/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/common/iniparser -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/libcore/common/plugin -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/xmetadataretriever/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/include/xplayer/include  -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/../shm/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/../dbusmedia/
  475. In file included from ./videoprosy.cpp:8:0:
  476. /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/../dbusmedia/dbusmediavideotype.h:19:1: warning: 'typedef' was ignored in this declaration
  477. };
  478. ^
  479. /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/../dbusmedia/dbusmediavideotype.h:25:1: warning: 'typedef' was ignored in this declaration
  480. };
  481. ^
  482. /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-g++ --sysroot=/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot  -o ./libvideoproxy.so ./videopro.o  -rdynamic -fPIC -shared -L./cedarx// -Wl,--no-undefined -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/cedarx/lib_hf/ -Wl,--no-undefined -ladecoder -laencoder -lcdx_base -lcdx_common -lcdx_muxer -lcdx_parser -lcdx_playback -lcdx_stream -lMemAdapter  -lcdc_base  -lsubdecoder -lvdecoder -lvencoder -lVE -lvideoengine -lxmetadataretriever -lxplayer -lrt -lpthread -lz -lcrypto -lssl -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/libs_hf -lsdk_compose  -lsdk_disp  -lsdk_g2d -lsdk_dvr   -lsdk_player  -lsdk_tr -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../../../../../tools/pack/chips/sun8iw11p1/hal/gpu/fbdev_hf/lib/ -lGLESv2 -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib   -lsdk  -ltinyalsa  -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/libs    -lawshm -lawcommediavideo  -I../shm/ -I../dbusmedia/
  483. cp ./libvideoproxy.so /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoproxy/../../sdk_lib/libs
  484. make[2]: Circular videoserv <- videoserv dependency dropped.
  485. echo -------------------
  486. -------------------
  487. /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-g++ --sysroot=/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot -c ./background_video_player.cpp -o ./background_video_player.o -g  -DUSE_LOGCAT -DHAVE_PTHREADS -DHAVE_SYS_UIO_H -DANDROID_SMP=1 -D__ARM_HAVE_DMB -D__ARM_HAVE_LDREX_STREX  -DHAVE_POSIX_CLOCKS -DHAVE_PRCTL -DWATERMARK -DADAS_ENABLE -DCDX_V27  -DSUPPORT_NEW_DRIVER  -D_GNU_SOURCE -DCONFIG_CHIP=7 -DCONFIG_TARGET_PRODUCT= -DCONFIG_PRODUCT=2 -DCONFIG_VE_IPC=1 -DROTATE_PIC_HW=0 -DVE_PHY_OFFSET=0x40000000 -DCONFIG_LOG_LEVEL=0  -DBGVIDEO_SER -I-I./ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/include/disp2 -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/include/utils -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib//include/cutils/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/media -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/moudle -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/allwinnertech/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/allwinnertech/water_mark/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/adas/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/storage/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/sound/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/memory/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/misc/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/audioenc/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/eve_module/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/eve_module -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../tools/pack/chips/sun8iw11p1/hal/gpu/fbdev_hf/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/glib-2.0/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/lib/glib-2.0/include/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/gio-unix-2.0/  -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/adecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/aencoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/alsa/sound -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/adecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/libxml -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/live -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/openssl -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/sdecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/zlib -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcedarc/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/base/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/muxer/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/parser/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/playback/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/stream/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/common/iniparser -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/common/plugin -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/xmetadataretriever/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/xplayer/include  -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/../shm/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/../dbusmedia/
  488. In file included from ./background_video_player.cpp:11:0:
  489. /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/../dbusmedia/dbusmediavideotype.h:19:1: warning: 'typedef' was ignored in this declaration
  490. };
  491. ^
  492. /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/../dbusmedia/dbusmediavideotype.h:25:1: warning: 'typedef' was ignored in this declaration
  493. };
  494. ^
  495. ./background_video_player.cpp: In static member function 'static int CBackGroundMediaVideo::handleShareMemControlCmd(int, int, char*, void*, void*)':
  496. ./background_video_player.cpp:410:21: warning: NULL used in arithmetic [-Wpointer-arith]
  497.     if(pout->val0 != NULL)
  498.                      ^
  499. /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-g++ --sysroot=/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot -c ./bg_video_serv_warper.cpp    -o ./bg_video_serv_warper.o    -g  -DUSE_LOGCAT -DHAVE_PTHREADS -DHAVE_SYS_UIO_H -DANDROID_SMP=1 -D__ARM_HAVE_DMB -D__ARM_HAVE_LDREX_STREX  -DHAVE_POSIX_CLOCKS -DHAVE_PRCTL -DWATERMARK -DADAS_ENABLE -DCDX_V27  -DSUPPORT_NEW_DRIVER  -D_GNU_SOURCE -DCONFIG_CHIP=7 -DCONFIG_TARGET_PRODUCT= -DCONFIG_PRODUCT=2 -DCONFIG_VE_IPC=1 -DROTATE_PIC_HW=0 -DVE_PHY_OFFSET=0x40000000 -DCONFIG_LOG_LEVEL=0   -DBGVIDEO_SER -I-I./ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/include/disp2 -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/include/utils -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib//include/cutils/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/media -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/moudle -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/allwinnertech/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/allwinnertech/water_mark/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/camera/adas/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/storage/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/sound/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/memory/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/misc/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/audioenc/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/eve_module/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/eve_module -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../tools/pack/chips/sun8iw11p1/hal/gpu/fbdev_hf/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/glib-2.0/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/lib/glib-2.0/include/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot/usr/include/gio-unix-2.0/  -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/adecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/aencoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/alsa/sound -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/adecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/libxml -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/live -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/openssl -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/sdecoder -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/external/include/zlib -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcedarc/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/base/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/muxer/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/parser/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/playback/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/stream/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/common/iniparser -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/libcore/common/plugin -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/xmetadataretriever/include -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/include/xplayer/include  -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/../shm/ -I/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/../dbusmedia/
  500. In file included from ./bg_video_serv_warper.cpp:14:0:
  501. /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/../dbusmedia/dbusmediavideotype.h:19:1: warning: 'typedef' was ignored in this declaration
  502. };
  503. ^
  504. /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/../dbusmedia/dbusmediavideotype.h:25:1: warning: 'typedef' was ignored in this declaration
  505. };
  506. ^
  507. /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin/arm-linux-gnueabihf-g++ --sysroot=/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot  -o ./video_serv  ./background_video_player.o ./bg_video_serv_warper.o -DBGVIDEO_SER -L./cedarx// -Wl,--no-undefined -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/cedarx/lib_hf/ -Wl,--no-undefined -ladecoder -laencoder -lcdx_base -lcdx_common -lcdx_muxer -lcdx_parser -lcdx_playback -lcdx_stream -lMemAdapter  -lcdc_base  -lsubdecoder -lvdecoder -lvencoder -lVE -lvideoengine -lxmetadataretriever -lxplayer -lrt -lpthread -lz -lcrypto -lssl -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/libs_hf -lsdk_compose  -lsdk_disp  -lsdk_g2d -lsdk_dvr   -lsdk_player  -lsdk_tr -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../../../../../tools/pack/chips/sun8iw11p1/hal/gpu/fbdev_hf/lib/ -lGLESv2 -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib  -lsdk   -ltinyalsa -L/home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/sdk_demo/videoservice/../../sdk_lib/libs   -lawshm -lawcommediavideo
  508. target/user_rootfs_build.sh: 152: [: -a: unexpected operator
  509. make[2]: Nothing to be done for 'first'.
  510. make[2]: Nothing to be done for 'first'.
  511. make[2]: Nothing to be done for 'first'.
  512. user apps build cmd begin
  513. make[3]: Nothing to be done for 'build'.
  514. make[3]: Nothing to be done for 'build'.
  515. make[3]: Nothing to be done for 'build'.
  516. make[3]: Nothing to be done for 'build'.
  517. make[3]: Nothing to be done for 'build'.
  518. watchdog.c: In function 'main':
  519. watchdog.c:18:6: warning: implicit declaration of function 'strcmp' [-Wimplicit-function-declaration]
  520.    if(strcmp(argv[2],"settimeout") == 0){
  521.       ^
  522. watchdog.c:30:7: warning: implicit declaration of function 'sleep' [-Wimplicit-function-declaration]
  523.        sleep(2);
  524.        ^
  525. /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/qt_demo/Launcher
  526. user apps build cmd finish
  527. user apps build qt5 begin
  528. make[4]: Nothing to be done for 'first'.
  529. make[4]: Nothing to be done for 'first'.
  530. make[4]: Nothing to be done for 'first'.
  531. make[4]: Nothing to be done for 'first'.
  532. make[4]: Nothing to be done for 'first'.
  533. make[4]: Nothing to be done for 'first'.
  534. make[4]: Nothing to be done for 'first'.
  535. /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/qt_demo/Launcher
  536. user apps build qt5 finish
  537. build extean 3th apps begin
  538. /home/manyi/work/lichee/buildroot-201611/target/user_rootfs_misc/OKA40i_C/qt_demo/Launcher
  539. build extean 3th apps finish
  540. run user rootfs build script---------done!
  541. >>>   Generating root filesystem image rootfs.ext2
  542. rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  543. rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
  544. rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt
  545. echo '#!/bin/sh' > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  546. echo "set -e" >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  547. echo "chown -h -R 0:0 /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target" >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  548. printf '           dbus -1 dbus -1 * /var/run/dbus - dbus DBus messagebus user\n         - - docker -1 * - - - Docker Application Container Framework\n         - - input -1 * - - - Input device group\n         sshd -1 sshd -1 * - - - SSH drop priv user\n         ftp -1 ftp -1 * /home/ftp - - Anonymous FTP User\n\n' >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt
  549. PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /home/manyi/work/lichee/buildroot-201611/support/scripts/mkusers /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  550. /home/manyi/work/lichee/buildroot-201611/support/scripts/mkusers: line 417: [: -ge: unary operator expected
  551. /home/manyi/work/lichee/buildroot-201611/support/scripts/mkusers: line 426: [: -eq: unary operator expected
  552. cat system/device_table.txt > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt
  553. printf '           /bin/busybox                     f 4755 0  0 - - - - -\n         /usr/libexec/dbus-daemon-launch-helper f 4755 0 0 - - - - -\n /dev/console c 622 0 0 5 1 - - -\n\n' >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt
  554. echo "/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/makedevs -d /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target" >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  555. printf '           PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" mke2img -d /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target -G 4 -R 1 -B 1524000 -I 0 -l "rootfs" -o /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.ext2\n' >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  556. chmod a+x /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  557. PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/fakeroot -- /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  558. rootdir=/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target
  559. table='/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt'
  560. tune2fs 1.43.3 (04-Sep-2016)
  561. tune2fs 1.43.3 (04-Sep-2016)
  562. Please run e2fsck -f on the filesystem.
  563. Creating journal inode: done
  564. This filesystem will be automatically checked every 20 mounts or
  565. 0 days, whichever comes first.  Use tune2fs -c or -i to override.
  566. mke2img: e2fsck was successfully run on '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.ext2' (ext4)
  567. tune2fs 1.43.3 (04-Sep-2016)
  568. Setting maximal mount count to -1
  569. Setting interval between checks to 0 seconds
  570. /usr/bin/install -m 0644 support/misc/target-dir-warning.txt /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
  571. ln -sf rootfs.ext2 /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.ext4
  572. >>>   Generating root filesystem image rootfs.tar
  573. rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  574. rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
  575. rm -f /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt
  576. echo '#!/bin/sh' > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  577. echo "set -e" >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  578. echo "chown -h -R 0:0 /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target" >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  579. printf '           dbus -1 dbus -1 * /var/run/dbus - dbus DBus messagebus user\n         - - docker -1 * - - - Docker Application Container Framework\n         - - input -1 * - - - Input device group\n         sshd -1 sshd -1 * - - - SSH drop priv user\n         ftp -1 ftp -1 * /home/ftp - - Anonymous FTP User\n\n' >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt
  580. PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /home/manyi/work/lichee/buildroot-201611/support/scripts/mkusers /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_users_table.txt /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  581. /home/manyi/work/lichee/buildroot-201611/support/scripts/mkusers: line 417: [: -ge: unary operator expected
  582. /home/manyi/work/lichee/buildroot-201611/support/scripts/mkusers: line 426: [: -eq: unary operator expected
  583. cat system/device_table.txt > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt
  584. printf '           /bin/busybox                     f 4755 0  0 - - - - -\n         /usr/libexec/dbus-daemon-launch-helper f 4755 0 0 - - - - -\n /dev/console c 622 0 0 5 1 - - -\n\n' >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt
  585. echo "/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/makedevs -d /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target" >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  586. printf '           tar  -cf /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.tar --numeric-owner -C /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target .\n' >> /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  587. chmod a+x /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  588. PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin/fakeroot -- /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_fakeroot.fs
  589. rootdir=/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target
  590. table='/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/build/_device_table.txt'
  591. /usr/bin/install -m 0644 support/misc/target-dir-warning.txt /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
  592. PATH="/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/bin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/usr/sbin:/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/lib:/home/manyi/work/lichee/tools/pack/chips/sun8iw11p1/hal/gpu/fbdev/include:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin" gzip -9 -c /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.tar > /home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.tar.gz
  593. make: Leaving directory '/home/manyi/work/lichee/buildroot-201611'
  594. INFO: build rootfs OK.
  595. INFO: ----------------------------------------
  596. INFO: build lichee OK.
  597. INFO: ----------------------------------------
  598. manyi@manyi-virtual-machine:~/work/lichee$ ./build.sh -m pack_rootfs
  599. build buidroot-201611...
  600. xgnueabihf
  601. sun8iw11p1_hf_defconfig
  602. INFO: create ext4 rootfs ...
  603. rootdir=/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/target
  604. table='/home/manyi/work/lichee/tools/pack/common/devices/_device_table.txt'
  605. tune2fs 1.45.5 (07-Jan-2020)
  606. tune2fs 1.45.5 (07-Jan-2020)
  607. Please run e2fsck -f on the filesystem.
  608. Creating journal inode: done
  609. This filesystem will be automatically checked every 20 mounts or
  610. 0 days, whichever comes first.  Use tune2fs -c or -i to override.
  611. mke2img: e2fsck was successfully run on '/home/manyi/work/lichee/out/sun8iw11p1/linux/common/buildroot/images/rootfs.ext2' (ext4)
  612. tune2fs 1.45.5 (07-Jan-2020)
  613. Setting maximal mount count to -1
  614. Setting interval between checks to 0 seconds
  615. /home/manyi/work/lichee
  616. INFO: create ext4 rootfs OK.
  617. manyi@manyi-virtual-machine:~/work/lichee$ ./build.sh pack
  618. build buidroot-201611...
  619. xgnueabihf
  620. sun8iw11p1_hf_defconfig
  621. INFO: packing firmware ...
  622. copying tools file
  623. copying configs file
  624. ./out/aultls32.fex
  625. ./out/aultools.fex
  626. ./out/boot_package.cfg
  627. ./out/boot_package.fex
  628. ./out/boot_package_nor.cfg
  629. ./out/cardscript.fex
  630. ./out/cardscript_secure.fex
  631. ./out/cardtool.fex
  632. ./out/diskfs.fex
  633. ./out/env.cfg
  634. ./out/env_burn.cfg
  635. ./out/image.cfg
  636. renamed './out/image_linux.cfg' -> './out/image.cfg'
  637. ./out/split_**x.fex
  638. ./out/sunxi.fex
  639. ./out/sys_config.fex
  640. ./out/sys_config1024x600.fex
  641. ./out/sys_config1024x600_100M.fex
  642. ./out/sys_config1024x600_pwm4.fex
  643. ./out/sys_config1024x600_v1.fex
  644. ./out/sys_config1024x600mipi-gt9xx.fex
  645. ./out/sys_config1024x600mipi.fex
  646. ./out/sys_config1024x600mipi_v1.fex
  647. ./out/sys_config1080p.fex
  648. ./out/sys_config1080p_v1.fex
  649. ./out/sys_config1280x800.fex
  650. ./out/sys_config1280x800_v1.fex
  651. ./out/sys_config800x480.fex
  652. ./out/sys_config800x480_v1.fex
  653. ./out/sys_configFCU2401.fex
  654. ./out/sys_configFCU2401_100M.fex
  655. ./out/sys_config_new_evb_lvds1024600.fex
  656. ./out/sys_partition_dump.fex
  657. renamed './out/sys_partition_linux.fex' -> './out/sys_partition.fex'
  658. ./out/sys_partition_linux_128M.fex
  659. ./out/sys_partition_linux_256M.fex
  660. ./out/sys_partition_linux_mmc.fex
  661. ./out/sys_partition_private.fex
  662. ./out/toc0.fex
  663. ./out/toc1.fex
  664. ./out/usbtool.fex
  665. ./out/usbtool_test.fex
  666. copying boot resource
  667. copying usr resource
  668. copying boot file
  669. p=soc c=product state=0
  670. p=soc c=platform state=0
  671. p=soc c=target state=0
  672. p=soc c=norflash state=0
  673. p=soc c=boot_init_gpio state=0
  674. p=soc c=power_sply state=0
  675. p=soc c=card_boot state=0
  676. p=soc c=pm_para state=0
  677. p=soc c=card0_boot_para state=0
  678. p=soc c=card2_boot_para state=0
  679. p=soc c=twi_para state=0
  680. p=soc c=uart_para state=0
  681. p=soc c=jtag_para state=0
  682. p=soc c=clock state=0
  683. p=soc c=dram state=0
  684. p=soc c=emac0 state=0
  685. p=soc c=gmac0 state=0
  686. p=soc c=can0 state=0
  687. p=soc c=can0 state=1
  688. p=soc c=twi0 state=0
  689. p=soc c=twi1 state=0
  690. p=soc c=twi2 state=0
  691. p=soc c=twi3 state=0
  692. p=soc c=twi4 state=0
  693. p=twi2 c=rx8010 state=0
  694. p=twi4 c=at24 state=0
  695. p=soc c=ir0 state=0
  696. p=soc c=uart0 state=0
  697. p=soc c=uart0 state=1
  698. p=soc c=uart1 state=0
  699. p=soc c=uart1 state=1
  700. p=soc c=uart2 state=0
  701. p=soc c=uart2 state=1
  702. p=soc c=uart3 state=0
  703. p=soc c=uart3 state=1
  704. p=soc c=uart4 state=0
  705. p=soc c=uart4 state=1
  706. p=soc c=uart5 state=0
  707. p=soc c=uart5 state=1
  708. p=soc c=uart6 state=0
  709. p=soc c=uart6 state=1
  710. p=soc c=uart7 state=0
  711. p=soc c=uart7 state=1
  712. p=soc c=spi0 state=0
  713. p=soc c=spi1 state=0
  714. p=soc c=spi2 state=0
  715. p=soc c=spi3 state=0
  716. p=soc c=rtp_para state=0
  717. p=soc c=ctp state=0
  718. p=soc c=ctp_list state=0
  719. p=soc c=tkey_para state=0
  720. p=soc c=motor_para state=0
  721. p=soc c=nand0 state=0
  722. p=soc c=sata state=0
  723. p=soc c=disp state=0
  724. p=soc c=tv0 state=0
  725. p=soc c=tv1 state=0
  726. p=soc c=tvd state=0
  727. p=soc c=tvd0 state=0
  728. p=soc c=tvd1 state=0
  729. p=soc c=tvd2 state=0
  730. p=soc c=tvd3 state=0
  731. p=soc c=lcd0 state=0
  732. p=soc c=lcd0 state=1
  733. p=soc c=pwm0 state=0
  734. p=soc c=pwm0 state=1
  735. p=soc c=car_reverse state=0
  736. p=soc c=Transmit_fm state=0
  737. p=soc c=hdmi state=0
  738. p=soc c=ak7601 state=0
  739. p=soc c=csi0 state=0
  740. p=csi0 c=csi0_dev0 state=0
  741. p=soc c=csi1 state=0
  742. p=csi1 c=csi1_dev0 state=0
  743. p=soc c=tvout_para state=0
  744. p=soc c=tvin_para state=0
  745. p=soc c=di state=0
  746. p=soc c=sdc0 state=0
  747. p=soc c=sdc1 state=0
  748. p=soc c=sdc2 state=0
  749. p=soc c=sdc3 state=0
  750. p=soc c=smc state=0
  751. p=soc c=gpio_para state=0
  752. p=soc c=usbc0 state=0
  753. p=soc c=usbc1 state=0
  754. p=soc c=usbc2 state=0
  755. p=soc c=gsensor_para state=0
  756. p=soc c=gps_para state=0
  757. p=soc c=ril_para state=0
  758. p=soc c=wlan state=0
  759. p=soc c=bt state=0
  760. p=soc c=btlpm state=0
  761. p=soc c=gy_para state=0
  762. p=soc c=ls_para state=0
  763. p=soc c=compass_para state=0
  764. p=soc c=spdif state=0
  765. p=soc c=sndspdif state=0
  766. p=soc c=audiohdmi state=0
  767. p=soc c=sndhdmi state=0
  768. p=soc c=snddaudio0 state=0
  769. p=soc c=daudio0 state=0
  770. p=soc c=snddaudio1 state=0
  771. p=soc c=daudio1 state=0
  772. p=soc c=sndcodec state=0
  773. p=soc c=codec state=0
  774. p=soc c=pmu0 state=0
  775. p=soc c=charger0 state=0
  776. p=soc c=powerkey0 state=0
  777. p=soc c=regulator0 state=0
  778. p=soc c=axp_gpio0 state=0
  779. p=soc c=dvfs_table state=0
  780. p=soc c=Vdevice state=0
  781. p=soc c=gpu_mali400_0 state=0
  782. Conver script to dts ok.
  783. dtbpath=/home/manyi/work/lichee/tools/pack/out/sunxi.fex
  784. update_fdt: u-boot.fex will merage sunxi.fex, generate u-boot.fex
  785. ---0xd0, 0xd
  786. update_fdt: num 844384 randto1k
  787. update_fdt: num 155696 randto1k
  788. file1_len = ce400, file2_len = 28400
  789. dtb offset ce400,size 28400
  790. update_fdt:genrate /home/manyi/work/lichee/tools/pack/out/u-boot.fex ok
  791. pack boot package
  792. GetPrivateProfileSection read to end
  793. content_count=1
  794. packing for linux
  795. normal
  796. mbr count = 4
  797. partitation file Path=/home/manyi/work/lichee/tools/pack/out/sys_partition.bin
  798. mbr_name file Path=/home/manyi/work/lichee/tools/pack/out/sunxi_mbr.fex
  799. download_name file Path=/home/manyi/work/lichee/tools/pack/out/dlinfo.fex
  800. mbr size = 16384
  801. mbr magic softw411
  802. disk name=boot-resource
  803. filename = boot-resource.fex
  804. dl_file_size = 10682 sector
  805. part_size = 28672 sector
  806. disk name=env
  807. filename = env.fex
  808. dl_file_size = 256 sector
  809. part_size = 8192 sector
  810. disk name=boot
  811. filename = boot.fex
  812. dl_file_size = 26104 sector
  813. part_size = 32768 sector
  814. disk name=rootfs
  815. filename = rootfs.fex
  816. dl_file_size = 3873280 sector
  817. part_size = 4200000 sector
  818. disk name=private
  819. disk name=usr
  820. unable to open file usr-resource.fex
  821. dl file usr-resource.fex size too large
  822. update_for_part_info -1
  823. update mbr file fail
  824. ERROR: update_mbr failed
  825. manyi@manyi-virtual-machine:~/work/lichee$
usr-resource.fex 这个文件我在lichee目录下面搜了,根本就没有。
现在要怎么做才能完成打包烧写镜像啊。。。公司项目,很着急啊,求速回复。
发表于 2021-6-21 08:46:10 | 显示全部楼层
您的分区是不是改过,是不是修改的太大了,另外您的源码路径应该和手册一致,编译容易出错
GMT+8, 2026-9-21 07:53
